Have you tried the forever command? It's about 8 comments up I think.. I've not set this ups yet but intend to today so can't really help.. Sorry.SwordFish wrote:this works great.
But when i close the putty sessie after run npm run start its stop working?
Is there a way to keep it running? Or do i mis something.
Siri / HomeKit support for Domoticz
simon_rb
- Target OS: -
SwordFish
- Domoticz version: V4.11375
Re: Siri / HomeKit support for Domoticz
Yes i tried, but i get this warning.
root@domoticzpi:~# forever start /root/homebridge/app.js
warn: --minUptime not set. Defaulting to: 1000ms
warn: --spinSleepTime not set. Your script will exit if it does not stay up for at least 1000ms
info: Forever processing file: /root/homebridge/app.js
- G3rard
- Target OS: -
- Domoticz version: No
I am using Eve and it's working great
Thanks for sharing this!!!
Not using Domoticz anymore
- G3rard
- Target OS: -
I get those warnings to when running forever, but apparently this doesn't matter because homebridge is working.SwordFish wrote:Yes i tried, but i get this warning.Code: Select all
root@domoticzpi:~# forever start /root/homebridge/app.js warn: --minUptime not set. Defaulting to: 1000ms warn: --spinSleepTime not set. Your script will exit if it does not stay up for at least 1000ms info: Forever processing file: /root/homebridge/app.js
emke
That's not a critica's warming. After that it should run.
I also got a couple of switches that disconnected and can't find anymore. Restarting homebridge doesn't have any effect. Someone found a solution?
simon_rb
- Target OS: -
Your a lot closer than I am. I followed the wiki to the letter and I get this error when trying to run npm run start
- gizmocuz
i think you should use the program "putty", and i think there is a lot more debug log abovesimon_rb wrote:Your a lot closer than I am. I followed the wiki to the letter and I get this error when trying to run npm run start
i remember i had an error with "mdns" not sure how i solved it, but for sure you have to add the required packages first (with apt-get) before installing this.
if you did not do the apt-get , i suggest to remove the solver, do this, and start again
something like
sudo apt-get update
sudo apt-get install libnss-mdns libavahi-compat-libdnssd-dev
simon_rb
- Target OS: -
Start from the beginning you mean? I did use apt-get. I don't know how to remove it though. I'm not too good with the command line side of raspberry pi. Thank you for the reply
- gizmocuz
you should have a homebridge folder in your home foldersimon_rb wrote:Start from the beginning you mean? I did use apt-get. I don't know how to remove it though. I'm not too good with the command line side of raspberry pi. Thank you for the reply
cd ~
sudo rm -Rf homebridge
simonrg
- Domoticz version: 3.8807
It looks like simon_rb might have the same problem as I do, as gizmocuz says the errors above are more informative - it seems to try to use a port out of bounds - which is in a dns routine, gizmocuz what did you do with mdns to sort this out?:gizmocuz wrote:you should have a homebridge folder in your home foldersimon_rb wrote:Start from the beginning you mean? I did use apt-get. I don't know how to remove it though. I'm not too good with the command line side of raspberry pi. Thank you for the reply
cd ~
/home/pi/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/advertisement.js:56
dns_sd.DNSServiceRegister(self.serviceRef, flags, ifaceIdx, name,
Error: argument 8: port number is out of bounds.
at Error (native)
at new Advertisement (/home/pi/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/advertisement.js:56:10)
at Object.create [as createAdvertisement] (/home/pi/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/advertisement.js:64:10)
at Object.startAdvertising (/home/pi/homebridge/lib/HAP-NodeJS/Advertiser.js:7:28)
at Object.publishAccessory (/home/pi/homebridge/lib/HAP-NodeJS/Accessory.js:10:29)
at createHAPServer (/home/pi/homebridge/app.js:167:15)
at /home/pi/homebridge/app.js:92:17
at Request._callback (/home/pi/homebridge/platforms/Domoticz.js:62:5)
at Request.self.callback (/home/pi/homebridge/node_modules/request/request.js:373:22)
at Request.emit (events.js:110:17)Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
- gizmocuz
good question, not sure anymore
#1 use the above apt-get command
#2 install the mdns packet
npm install mdns
#3 remove the homebridge folder
#4 start the homebridge tutorial again
something like this, and google helped me too
npm install mdns
simon_rb
- Target OS: -
Done above and I have the same errors. It does find all my devices but can control them as it doesn't stay running. I am running default ports on Domoticz.. I'm completely at a loss. No idea what to google to try and get it working.gizmocuz wrote:good question, not sure anymore
npm install mdns
v40jlt4
- Domoticz version: 2021.1
Tried npm install --verbose and get:
npm verb request uri https://registry.npmjs.org/ip
npm verb request no auth needed
npm info attempt registry request try #1 at 15:50:40
npm verb etag "2CPEK6B74CEVLLFG2E792DIY5"
npm http request GET https://registry.npmjs.org/ip
npm verb gentlyRm vacuuming /home/pi/homebridge/node_modules/wemo/node_modules/request/node_modules/combined-stream/node_modules/delayed-stream
npm http 200 https://registry.npmjs.org/bunyan-prettystream
npm verb get saving bunyan-prettystream to /home/pi/.npm/registry.npmjs.org/bunyan-prettystream/.cache.json
npm verb get saving bunyan to /home/pi/.npm/registry.npmjs.org/bunyan/.cache.json
npm verb tar unpack /home/pi/.npm/delayed-stream/1.0.0/package.tgz
npm verb tar unpacking to /home/pi/homebridge/node_modules/wemo/node_modules/request/node_modules/combined-stream/node_modules/delayed-stream
npm verb afterAdd /home/pi/.npm/lodash/2.4.2/package/package.json written
Then it hangs.
Any ideas??
Then it hangs.
Any ideas??
pvm
- Domoticz version: 4.10538
Simon_rb, it does not stay running after Restart of your machine?
simon_rb
- Target OS: -
Pvm, it doesn't run at all. It crashes before it runs. It finds all of my devices but then crashes. My devices show up within the insteon app on my iPhone but can't do anything with them as they do not respond...
Very puzzling.
Very puzzling.
spudgunman
I added a little to the wiki and cleaned up some syntax for ease of use.
simon_rb
- Target OS: -
I ran NPM Test and got the same error
simonrg
What happens if you run npm test in the Hombridge directory?simon_rb wrote:I ran NPM Test and got the same error
I don't think homebridge provides a test package - see npm help:
pi@raspberrypi ~ $ npm help test
NAME
npm-test - Test a package
SYNOPSIS
npm test [-- <args>]
npm tst [-- <args>]
DESCRIPTION
This runs a package's "test" script, if one was provided.
To run tests as a condition of installation, set the npat config to true.
pi@raspberrypi ~/homebridge $ npm test
> [email protected] test /home/pi/homebridge
> echo "Error: no test specified"
Error: no test specifiedRaspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
simon_rb
- Target OS: -
That's correct. That's the error I got.simonrg wrote:What happens if you run npm test in the Hombridge directory?simon_rb wrote:I ran NPM Test and got the same error
I don't think homebridge provides a test package - see npm help:So running in homebridge directory should give:Code: Select all
pi@raspberrypi ~ $ npm help test NAME npm-test - Test a package SYNOPSIS npm test [-- <args>] npm tst [-- <args>] DESCRIPTION This runs a package's "test" script, if one was provided. To run tests as a condition of installation, set the npat config to true.Code: Select all
pi@raspberrypi ~/homebridge $ npm test > [email protected] test /home/pi/homebridge > echo "Error: no test specified" Error: no test specified
I don't know what to try now!
simon_rb
- Target OS: -
Maybe I need to remove npm, node from the system completely and start again.. What would be the best way of doing that? Tried sudo NPM Unintsall but that didn't work
