Page 3 of 16
Re: Is it gonna rain within the next X minutes?
Posted: Sunday 31 May 2015 23:32
by Brutus
markk wrote:
tlpeter wrote:Hi Hans i know, that is the problem :mrgreen:
I use a different script now and i have it working.
But thanks anyway.
Hi Tlpeter
Would you mind sharing your windows script please?
Mark
Yeah please ;) Also a Windows user. Have ordered screens but the fibaro module is already installed. So I have al the time preparing the windows script for it.
Posted: Wednesday 03 June 2015 16:09
by Luuc_a
I have taken the script of tlpeter and made it to my needs.
I have done the following
- Integrate the script with the rain prediction of 'buienradar'.
- made user variables from the thresholds in Domoticz so I can control it from the web interface.
-- LUA Script
-- Extract values from Weather Underground device and 'Buienradar'-rain
-- prediction to control the sunscreen
-- Auteur: Luuc_A
-- Datum : 29-05-2014
-- Setup uservariables:
--   1) Weather_Debug          			= String = True / False
--   2) Weather_WindSpeedThreshold		= integer
--   3) Weather_WindGustThreshold		= integer
--   4) Weather_RainThreshold			= integer
--   5) Weather_UVThreshold				= integer
--   6) Weather_TempThreshold			= integer
-- Create Switches:
--   1) Regen             				= Dummy Humiditysensor
--   2) WindSnelheid      				= Dummy Text
--   3) WindRichting      				= Dummy Text
--	 4) Barometer		  				= Weather Underground/Forecast IO
--	 5) Wind			  				= Weather Underground/Forecast IO
--	 6) Regen			  				= Weather Underground/Forecast IO
--   7) Zon				  				= Weather Underground/Forecast IO
--   8) Zonnescherm		  				= Up/Down switch
--   9) Zonnescherm manual override		= Dummy switch
-- Variabelen
lat='52.025526'   -- example lat/lon for Gouda
lon='4.692806'
sDebug = tostring(uservariables["Weather_Debug"])
UVThreshold = uservariables["Weather_UVThreshold"]
WindSpeedThreshold = uservariables["Weather_WindSpeedThreshold"]
WindGustThreshold = uservariables["Weather_WindGustThreshold"]
RainThreshold = uservariables["Weather_RainThreshold"]
TempThreshold = uservariables["Weather_TempThreshold"]
tempfilename = '/var/tmp/rain.tmp' -- can be anywhere writeable
idx = 220  --idx regen
idx2 = 221 -- idx windrichting
idx3 = 222 -- idx windsnelheid
minuten = 5
sBarometer = 'Barometer Gouda'
sWind = 'Wind Gouda'
sRain = 'Regen Gouda'
sUV = 'UV Gouda'
sSolar = 'Zon Gouda'
--Sunscreen thresholds:
        -- Windspeed            = 100.0 (value is multiplied by 100)
        -- Rain                 =  0.0
        -- UV                   =  2.0
        -- Temperature          = 12.0
        -- Closed       = Down  = On
        -- Open         = Up    = Off
-- Functies
function Message(fMessage, fDebug)
        if (fDebug == "True") then
                print("Weather: " .. fMessage)
function Notification(fNotification, fDebug)
	if (fDebug == "False") then
	    commandArray['SendNotification'] = "" .. fNotification .. ""
function IsItGonnaRain( minutesinfuture )
   url='http://gps.buienradar.nl/getrr.php?lat='..lat..'&lon='..lon
   Message("-- "..url,sDebug)
   read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
   file = io.open(tempfilename, "r")
   totalrain=0
   rainlines=0
   -- now analyse the received lines, format is like 000|15:30 per line.
   while true do
      line = file:read("*line")
      if not line then break end
      Message("-- Line:" ..line,sDebug)
      linetime=string.sub(tostring(line), 5, 9)
	  Message("-- Linetime: "..linetime,sDebug)
         -- Linetime2 holds the full date calculated from the time on a line
         linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
         difference = os.difftime (linetime2,os.time())
      -- When a line entry has a time in the future AND is in the given range, then totalize the rainfall
      if ((difference > 0) and (difference<=minutesinfuture*60)) then
         Message("-- Line in time range found",sDebug)
		 rain=tonumber(string.sub(tostring(line), 0, 3))
         totalrain = totalrain+rain
         rainlines=rainlines+1
         Message("-- Rain in timerange: "..rain,sDebug)
		 Message("-- Total rain now: "..totalrain,sDebug)
   file:close()
   averagerain=totalrain/rainlines
return(averagerain)
	regen = IsItGonnaRain(minuten)
	Message("-- Regen verwacht: "..regen.." binnen "..minuten.." minuten.",sDebug)
	if (regen > 0  ) then verw = 3 else verw = 2 end
	--Weatherstation data:
	sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2 = otherdevices_svalues[sBarometer]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
	sWeatherTemp = tonumber(sWeatherTemp);
	sWeatherHumidity = tonumber(sWeatherHumidity);
	sWeatherPressure = tonumber(sWeatherPressure);
	sWeatherUV = tonumber(sWeatherUV);
	sWeatherUV2 = tonumber(sWeatherUV2);
	Message("______________________________________________________________________________________",sDebug)
	Message("Weather station: Temperature is " .. sWeatherTemp .. " ",sDebug)
	Message("Weather station: Humidity is " .. sWeatherHumidity .. " ",sDebug)
	Message("Weather station: Pressure is " .. sWeatherPressure .. " ",sDebug)
	Message("Weather station: UV is " .. sWeatherUV .. " ",sDebug)
	Message("Weather station: UV2 is " .. sWeatherUV2 .. " ",sDebug)
	--Windmeter data:
	sWindDirectionDegrees, sWindDirection, sWindSpeed, sWindGust, sWindTemperature, sWindFeel = otherdevices_svalues[sWind]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
	sWindDirectionDegrees = tonumber(sWindDirectionDegrees);
	sWindDirection = (sWindDirection);
	sWindSpeed = tonumber(sWindSpeed);
	sWindGust = tonumber(sWindGust);
	sWindTemperature = tonumber(sWindTemperature);
	sWindFeel = tonumber(sWindFeel);
	Message("Windmeter: Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ",sDebug)
	Message("Windmeter: Winddirection is: " .. sWindDirection .. " ",sDebug)
	Message("Windmeter: Windspeed is: " .. sWindSpeed .. " ",sDebug)
	Message("Windmeter: Windgust is: " .. sWindGust .. " ",sDebug)
	Message("Windmeter: Windtemperature is: " .. sWindTemperature .. " ",sDebug)
	Message("Windmeter: Windfeel is: " .. sWindFeel .. " ",sDebug)
	Message("______________________________________________________________________________________")
	--Rainmeter data:
	sRainmeterCurrent, sRainmeterTotal = otherdevices_svalues[sRain]:match("([^;]+);([^;]+)")
	sRainmeterCurrent = tonumber(sRainmeterCurrent);
	sRainmeterTotal = tonumber(sRainmeterTotal);
	Message("Rainmeter: Actual rain is: " .. sRainmeterCurrent .. " ",sDebug)
	Message("Rainmeter: Total rain is: " .. sRainmeterTotal .. " ",sDebug)
	Message("Rainmeter: Predicted rain is: " .. regen .. " ",sDebug)
	--UV data:
	sUV = otherdevices_svalues[sUV]:match("([^;]+)")
	sSolar = otherdevices_svalues[sSolar]:match("([^;]+)")
	sUV = tonumber(sUV);
	sSolar = tonumber(sSolar);
	Message("UV: UV Strength is: " .. sUV .." ",sDebug)
	Message("UV: Solar radiation is: " .. sSolar .." ",sDebug)
	--Thresholds:
	Message("Thresholds: Temp threshold is: " .. TempThreshold .." ",sDebug)
	Message("Thresholds: UV threshold is: " .. UVThreshold .." ",sDebug)
	Message("Thresholds: WindSpeed threshold is: " .. WindSpeedThreshold .." ",sDebug)
	Message("Thresholds: WindGust threshold is: " .. WindGustThreshold .." ",sDebug)
	Message("Thresholds: Rain threshold is: " .. RainThreshold .." ",sDebug)
	if (timeofday['Daytime']) then
        Message('It is past sunrise, monitoring variables for sunscreen',sDebug)
        if (otherdevices['Zonnescherm'] == 'Open' ) then
            Message ('Sunscreen is up',sDebug)
            Message ('Sunscreen is down',sDebug)
			and sRainmeterCurrent   == RainThreshold
			and sWeatherTemp        > TempThreshold
			and sUV            		> UVThreshold
			and sWindSpeed          < WindSpeedThreshold
			and sWindGust           < WindGustThreshold)
		then
			Message ('Sun is shining, all thresholds OK, lowering sunscreen',sDebug)
			Message('______________________________________________________________________________________',sDebug)
			Notification('Sunscreen#Sunscreen down --> Sun is shining',sDebug)
			commandArray['Zonnescherm']='On'
		elseif (otherdevices['Zonnescherm'] == 'Closed' and (sRainmeterCurrent > RainThreshold or regen > 0)) then
            Message ('It is raining, raising sunscreen')
            Notification('Sunscreen#Sunscreen up --> It is raining',sDebug)
            commandArray['Zonnescherm']='Off'
        elseif (otherdevices['Zonnescherm'] == 'Closed' and sWeatherTemp < TempThreshold and otherdevices['Zonnescherm manual override'] == 'Off') then
            Message ('Temperature too low, raising sunscreen',sDebug)
            Notification('Sunscreen#Sunscreen up --> It is too cold',sDebug)
        elseif (otherdevices['Zonnescherm'] == 'Closed' and sUV < UVThreshold and otherdevices['Zonnescherm manual override'] == 'Off') then
            Message ('Sun not shining too bright, raising sunscreen',sDebug)
            Notification('Sunscreen#Sunscreen up --> Sunshine not too bright',sDebug)
        elseif (otherdevices['Zonnescherm'] == 'Closed' and sWindSpeed > WindSpeedThreshold) then
            Message ('Windspeed too high, raising sunscreen',sDebug)
            Notification('Sunscreen#Sunscreen up --> Windspeed too high',sDebug)
        elseif (otherdevices['Zonnescherm'] == 'Closed' and sWindGust > WindGustThreshold) then
            Message ('Windgust too high, raising sunscreen',sDebug)
            Notification('Sunscreen#Sunscreen up --> Windgust too high',sDebug)
			Message('Sunscreen status OK --> No action',sDebug)
		::done::
		Message("At the end of the script",sDebug)
    elseif (timeofday['Nighttime'] and otherdevices['Zonnescherm'] == 'Closed') then
		Message('It is night, raising sunscreen',sDebug)
		Notification('Sunscreen#Sunscreen up --> It is night',sDebug)
		Message('Sunscreen already up --> No action',sDebug)
	commandArray[1] = {['UpdateDevice'] = idx .. '|'..tostring(regen)..'|'..tostring(verw)}
	commandArray[2] = {['UpdateDevice'] = idx2 .. '|0|'.. sWindDirection}
	commandArray[3] = {['UpdateDevice'] = idx3 .. '|0|'.. sWindSpeed}
return CommandArray
There is a little question. In the settings of Domoticz you can set the langitude and longitude. Is it possible to read this out by LUA?
Posted: Friday 05 June 2015 12:45
by Justintime
Luuc_a wrote:I have taken the script of tlpeter and made it to my needs.
-- LUA Script
-- Auteur: Luuc_A
-- Create Switches:
-- Variabelen
lon='4.692806'
minuten = 5
sUV = 'UV Gouda'
        -- Rain                 =  0.0
        -- UV                   =  2.0
        -- Open         = Up    = Off
-- Functies
   totalrain=0
   rainlines=0
   while true do
   file:close()
return(averagerain)
	--Windmeter data:
	--Rainmeter data:
	--UV data:
	--Thresholds:
		then
		::done::
return CommandArray
Thanks for the script. I tested it (only on temperature).
Outside temp. is 25 degrees. When i set the treshold variable on 30 the screen is Up (off). When is switch manually down (on) it goes up. so thats ok. Because temperature is too low.
But when i set the treshold temperature on 12 degrees nothing happens.... Up or down, the status is ok.
Which blinds switch did you use?? Looks like up/down, open/close on/off are mixed?
Posted: Friday 05 June 2015 13:44
by Luuc_a
Do you have a override switch called "Zonnescherm manual override"? The first time I used it I had the same sort of issues. Then I saw that I don't had the override switch.
When you don't want to use the override script you can edit the code:
to
elseif (otherdevices['Zonnescherm'] == 'Closed' and sWeatherTemp < TempThreshold) then
and the same for the UV check.
Posted: Tuesday 16 June 2015 8:13
by Luuc_a
I have made a new script with the following adaptions:
- 2 new variables (RainPredThreshold and SolarThreshold)
- Check if UV or Solar is right to open or close the sunscreen
- Check if Rain Current of Rain Predicted is right to open or close the sunscreen
- More loging when debug is on
-- LUA Script
-- Extract values from WU device
-- Auteur: Luuc Alarm
--   5) Weather_RainPredThreshold		= integer
--   6) Weather_UVThreshold            	= integer
--	 7) Weather_SolarThreshold			= integer
--   8) Weather_TempThreshold         	= integer
-- Create Switches:
--   9) Zonnescherm manual override		= Dummy On/Off switch
-- tijd ophalen
time = os.date("*t")
-- Variabelen
lon='4.692806'
SolarThreshold = uservariables["Weather_SolarThreshold"]
RainPredThreshold = uservariables["Weather_RainPredThreshold"]
minuten = 5  -- time within rainprediction
sUV = 'UV Gouda'
        -- Rain                 =  0.0
        -- UV                   =  2.0
        -- Open         = Up    = Off
-- Functies
   totalrain=0
   rainlines=0
   while true do
   file:close()
return(averagerain)
        --Windmeter data:
        --Rainmeter data:
        --UV data:
        --Thresholds:
        Message("Thresholds: Solar threshold is: " .. SolarThreshold .." ",sDebug)
        Message("Thresholds: Rain Prediction threshold is: " .. RainPredThreshold .." ",sDebug)
        Message("Override: ".. otherdevices['Zonnescherm manual override'],sDebug)
				and (sUV > UVThreshold or sSolar > SolarThreshold)
			then
		elseif (otherdevices['Zonnescherm'] == 'Closed' and (sRainmeterCurrent > RainThreshold or regen > RainPredThreshold)) then
        elseif (otherdevices['Zonnescherm'] == 'Closed' and sWeatherTemp < TempThreshold-1 and otherdevices['Zonnescherm manual override'] == 'Off') then
        elseif (otherdevices['Zonnescherm'] == 'Closed' and (sUV < UVThreshold-1 or sSolar < SolarThreshold) and otherdevices['Zonnescherm manual override'] == 'Off') then
        ::done::
return CommandArray
For me this would be the latest version because in my case I can not trust on WU of Forecast IO.
When there is a clear blue sky WU sometimes think it's rain. As long as I don't have a dedicated weather station I will leave it like this. If anyone has any comments or want something else let me know and I will take a look into it.
Posted: Tuesday 16 June 2015 23:01
by Brutus
For the people who are interested, I made the rain prediction script usable for Windows. 8-)
Steps to make it work:
- Make a virtual Humidity device in Domoticz and remember the IDX number.
- Go to the following website: http://curl.haxx.se/dlwiz/ and download the needed setup. (x86, x64).
In my case I selected "curl executable", "Win64", "Generic", "Any" and "x86_64" (I use Windows 8.1 64Bits)
- Create A new folder on your Domoticz Computer (For example: C:\Rain ).
- Extract the downloaded "Curl" zip file in this map.
- Make also a new file in this folder called: "rain.tmp"
- Make a new lua file called: "script_time_rain_prediction.lua" Fill the file with the following code:
    -- IsItGonnaRain( int minutesinfuture)
    -- returns: int avarage rainfall for the next minutesinfuture
    -- Function to get rain prediction from Buienradar.nl (dutch)
    -- http://gratisweerdata.buienradar.nl/#Buienradar You may use their free service for non-commercial purposes.
    -- Written in LUA by Hans van der Heijden (h4nsie @ gmail.com)
    -- Spring 2015
    -- 28-03-2015 v0.3 bug: quotes around url added.
    -- 27-03-2015 v0.2 return value is now average for next time
    -- 26-03-2015 v0.1 Initial release
    -- todo: some error checking on http and file handling (tmp file)
       -- config ---------------------------------------------------------
       lat='50.891508'   -- example lat/lon for Heerlen
       lon='5.960975'
       debug=False
       tempfilename = 'C:\\Rain\\rain.tmp' -- can be anywhere writeable
       if debug then print(url) end
       read = os.execute('"C:/Rain/Curl/bin/curl.exe -s -o '..tempfilename..' "'..url..'"')
       totalrain=0
       rainlines=0
       while true do
          if debug then print('Line:'..line) end
          if debug then print('Linetime: '..linetime) end
             if debug then print('Line in time range found') end
             if debug then print('Rain in timerange: '..rain) end
             if debug then print('Total rain now: '..totalrain) end
       file:close()
       -- Returned value is average rain fall for next time
       -- 0 is no rain, 255 is very heavy rain
       -- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
    return(averagerain)
    ----- REGEN ------
    minuten=15
    print('Regen verwacht(0-255 hoe hoger hoe meer regen): '..regen..' binnen '..minuten..' minuten.')
    commandArray['UpdateDevice'] = '170|'..tostring(regen)..'|'..tostring(verw)
Change the following data in your script:
- Change the longitude and latitude to your location. You can find these numbers in your Domoticz Settings.
- Change the path after: "tempfilename" if you have chosen another location.
- Change the path after: "read = os.execute: if you have chosen another location.
Greetings.
Posted: Wednesday 17 June 2015 0:39
by Siewert308SW
Just wanna say thx for the script.
Gonna use it for my Garden Irrigation.
Why irrigating while rain is coming up ;-)
Posted: Wednesday 17 June 2015 18:30
by Justintime
It's a great script!! And two nice thresholds added.
Now some playing with the settings to get it right.
Thanks Luuc and Hansbit
Posted: Sunday 19 July 2015 14:38
by Bram81
Hi Hans,
I've tried to send you a PM (in Dutch) but it seems that I can't get any messasges sent. I'm not familiar witch lua just yet but I would like to get data from Buienradar as well to add to my garden irrigation system and moisture sensors already in place. Can you put me on the right track about how to integrate this in domoticz exactly?
Thank in advance!
Posted: Sunday 19 July 2015 14:41
by Siewert308SW
Bram81 wrote:Hi Hans,
Thank in advance!
Maybe you could try my script, just finished it and does what you want...
viewtopic.php?f=23&t=7290
Posted: Monday 20 July 2015 13:31
by jjnj
I would like to use the outcome of the rain value/virtual humidity sensor in blocky. But for some reason blocky doesn't seem to respond to the value of the virtual humidity sensor. anybody has an idea?
Posted: Monday 20 July 2015 14:43
by Brutus
jjnj wrote:I would like to use the outcome of the rain value/virtual humidity sensor in blocky. But for some reason blocky doesn't seem to respond to the value of the virtual humidity sensor. anybody has an idea?
Can you post an example of your Blockly?
Posted: Monday 20 July 2015 15:08
by jjnj
Just a plain and simple blocky just to test
Posted: Monday 20 July 2015 15:57
by Brutus
I think you need to compare something like in my Blockly:
And I have my doubts about the "open" command.
Maybe test to write something in the log file or send a notification.
Timer Regen = virtual switch that is on when there is rain and off when there isn't. (needed for not creating loops in blockly).
Screens Dicht = Virtual switch for indicating if the screens are closed. (needed for not creating any loops in blockly).
Posted: Tuesday 21 July 2015 10:20
by Bram81
Thank in advance!
Thanks! Haven't worked with lua before, so I guess there is a lot to learn but this will help me for sure!
Posted: Friday 24 July 2015 23:52
by Hansbit
Posted a install instruction in the Wiki
https://www.domoticz.com/wiki/Is_it_gonna_rain
Please note that a threshold of 70 is (in my opinion) the best value to trigger for rain.
Posted: Saturday 25 July 2015 0:07
by jjnj
Hansbit wrote:Posted a install instruction in the Wiki
Why a threshold for 70? Then it would already be raining right below 70? So that would be to late
Posted: Saturday 25 July 2015 0:25
by Hansbit
jjnj wrote:Why a threshold for 70? Then it would already be raining right below 70? So that would be to late
With lower values to trigger for rain you'll get too many false positives. Even on sunny days with clear blue sky, Buienrader sometimes reports values like 35 or 40.
Posted: Saturday 25 July 2015 11:13
by RayAmsterdam
The wiki script gives me the following error: Error: EventSystem: Lua script did not return a commandArray
Any idea what's wrong?
Posted: Saturday 25 July 2015 12:09
by jvdz
Do you have this line at the bottom of the script?
return CommandArray
Jos
