Re: Zigbee in Domoticz (win10)
Posted: Monday 19 December 2022 22:32
sound good. thanks for your support
git checkout develop
git pull
sudo python3 -m pip install requirements.txt --upgradeCode: Select all
python -m pip install requirements.txt --upgradeCode: Select all
python3 --versionhehe, you and me both thenpipiche wrote: Sunday 26 March 2023 19:46 I'm starting to be lost.
The subject is talking about Windows 10 and here we are talking about Buster ?
python -m pip install -r requirements.txt --upgradeCode: Select all
Error: Zigbee: (Zigate) failed to load 'plugin.py', Python Path used was 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\;C:\Program Files (x86)\Python38-32\python38.zip;C:\Program Files (x86)\Python38-32\Lib\;C:\Program Files (x86)\Python38-32\DLLs\;C:\Program Files (x86)\Domoticz;C:\Program Files (x86)\Python38-32;C:\Program Files (x86)\Python38-32\lib\site-packages'.
2023-03-26 20:14:52.734 Error: Zigbee: Traceback (most recent call last):
2023-03-26 20:14:52.734 Error: Zigbee: File "C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\plugin.py", line 98, in <module>
2023-03-26 20:14:52.735 Error: Zigbee: import z4d_certified_devices
2023-03-26 20:14:52.735 Error: Zigbee: ModuleNotFoundError: No module named 'z4d_certified_devices'Code: Select all
python -m pip install -r requirements.txt --upgradeThank you for bearing with me. I ran the command under Windows cmd started with administrator privileges and it skips all steps since it says that all requirements are already met. Domoticz starts with the same error message regarding the zigbee plugin as before.pipiche wrote: Sunday 26 March 2023 22:34 As you are on Windows you must run theunder a command/terminal which is AdministratorCode: Select all
git pull
python -m pip install -r requirements.txt --upgrade --force-reinstall
python -m pip install -r requirements.txt --upgrade (which says that everything allready meets requirements)
2023-03-27 18:44:49.681 Status: Incoming connection from: 192.168.0.47
2023-03-27 18:44:52.499 Status: Zigbee: Initialized version 6.4, author 'pipiche38'
2023-03-27 18:44:52.499 Status: Zigbee: Zigbee for Domoticz plugin started!
2023-03-27 18:44:52.499 Status: Zigbee: Python3 requires 3.8 or above and you are running 3.8
2023-03-27 18:44:52.499 Status: Zigbee: Checking Python modules C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\requirements.txt
2023-03-27 18:44:52.783 Error: Zigbee: Call to function 'onStart' failed, exception details:
2023-03-27 18:44:52.783 Error: Zigbee: Traceback (most recent call last):
2023-03-27 18:44:52.783 Error: Zigbee: File "C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\plugin.py", line 1537, in onStart
2023-03-27 18:44:52.783 Error: Zigbee: _plugin.onStart()
2023-03-27 18:44:52.783 Error: Zigbee: File "C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\plugin.py", line 285, in onStart
2023-03-27 18:44:52.783 Error: Zigbee: if check_requirements( self ):
2023-03-27 18:44:52.783 Error: Zigbee: File "C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\plugin.py", line 1504, in check_requirements
2023-03-27 18:44:52.783 Error: Zigbee: pkg_resources.require(req)
2023-03-27 18:44:52.783 Error: Zigbee: File "C:\Program Files (x86)\Python38-32\lib\site-packages\pkg_resources\__init__.py", line 966, in require
2023-03-27 18:44:52.783 Error: Zigbee: needed = self.resolve(parse_requirements(requirements))
2023-03-27 18:44:52.783 Error: Zigbee: File "C:\Program Files (x86)\Python38-32\lib\site-packages\pkg_resources\__init__.py", line 827, in resolve
2023-03-27 18:44:52.783 Error: Zigbee: dist = self._resolve_dist(
2023-03-27 18:44:52.783 Error: Zigbee: File "C:\Program Files (x86)\Python38-32\lib\site-packages\pkg_resources\__init__.py", line 873, in _resolve_dist
2023-03-27 18:44:52.783 Error: Zigbee: raise VersionConflict(dist, req).with_context(dependent_req)
2023-03-27 18:44:52.799 Error: Zigbee: pkg_resources.VersionConflict: (dnspython 2.2.1 (c:\program files (x86)\python38-32\lib\site-packages), Requirement.parse('dnspython==2.3.0'))Code: Select all
{"PluginInfos":{"HardwareID":15,"HomeFolder":"C:\\Program Files (x86)\\Domoticz\\plugins\\Domoticz-Zigbee\\","StartupFolder":"C:\\Program Files (x86)\\Domoticz\\","UserDataFolder":"C:\\Program Files (x86)\\Domoticz\\","WebRoot":"","Database":"C:\\Program Files (x86)\\Domoticz\\domoticz.db","Language":"en","Version":"6.4","Author":"pipiche38","Name":"Zigbee","Address":"0.0.0.0","Port":"9999","SerialPort":"COM4","Key":"Zigate","Mode1":"ZigpyZNP","Mode2":"USB","Mode3":"False","Mode4":"9440","Mode6":"2","DomoticzVersion":"2022.2","DomoticzHash":"eea9db734","DomoticzBuildTime":"2022-11-05 13:05:35","PluginBranch":"beta6","PluginVersion":"6.4.325","CertifiedDbVersion":"1.30","TimeStamp":1680106112,"available":"6.4.321","available-firmMajor":0,"available-firmMinor":0,"FirmwareVersion":"Z-Stack 3.30+ (build 20220219)","FirmwareUpdate":false,"PluginUpdate":false,"LogLevel":7,"Zigpy":true,"CoordinatorModel":"CC1352/CC2652, Z-Stack 3.30+ (znp)","CoordinatorFirmwareVersion":"Z-Stack 3.30+ (build 20220219)","DisplayFirmwareVersion":"Znp - Z-Stack 3.30+ (build 20220219)","CoordinatorIEEE":"00124b0025e14d52","NetworkSize":"Total: 7 | Routers: 7 | End Devices: 0","NetworkDevices":{"1002":{"_TZE200_e3oitdyu":["TS0601-2Gangs-dimmer"]},"117c":{"IKEA of Sweden":["TRADFRIbulbE27WSglobeopal1055lm"]}}},"Analytics":1,"Device":{"Version":"3","ZDeviceName":"","Status":"UNKNOW","SQN":"a1","Ep":{},"Heartbeat":"379","RIA":"6","LQI":40,"Battery":{},"Model":"","ForceAckCommands":[],"MacCapa":"8e","IEEE":"a4c13878bb79118e","Type":{},"ProfileID":{},"ZDeviceID":{},"App Version":"","Attributes List":{},"DeviceType":"FFD","HW Version":"","Last Cmds":[],"LogicalType":"Router","Manufacturer":"1141","Manufacturer Name":"","NbEp":"","PowerSource":"Main","ReadAttributes":{"Ep":{"01":{"0000":{"TimeStamp":1680104162,"iSQN":{"0004":"01","0000":"01","0001":"01","0005":"01","0007":"01","fffe":"01"},"Attributes":{},"ZigateRequest":{}}}}},"ReceiveOnIdle":"On","Stack Version":"","Stamp":{"time":1680104231.6411927,"Time":"2023-03-29 17:37:11","MsgType":" 100","LastSeen":1680104231},"ZCL Version":"","Health":"Not Reachable","Capability":["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"],"ZCLSQN":"01","ZDPSQN":"06","PairingInProgress":true,"ConsistencyCheck":"Bad Pairing","_rawNodeDescriptor":"1141004200422a00008e424001","Max Buffer Size":"42","Max Rx":"0042","Max Tx":"0042","macapa":"8e","bitfield":"4001","server_mask":"2a00","descriptor_capability":"00","ZCL-IN-SQN":{"e000":"9b","0006":"a0","e001":"9d","000a":"a1"},"RollingLQI":[10,40,36,36,40,40,36,40,40,40],"SQN_000a":"a1"}}
2023-03-29 18:04:57.140 Error: (JSONtoPython) Parse Error on '{ "PluginConf":{ "TimeStamp":1680078311.341207,"b64Settings":{ "filename":"C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Conf/PluginConf-15.json","pluginHome":"C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\","homedirectory":"C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\","pluginData":"C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Data/","pluginConfig":"C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Conf/","pluginOTAFirmware":"C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\OTAFirmware/","pluginReports":"C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Reports/","pluginWWW":"C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\www/","pluginLogs":"C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Logs/","expJsonDatabase":0},"Version":1}}'
2023-03-29 18:04:57.140 Error: Zigbee: setConfigItem - Domoticz.Configuration operation failed: ''NoneType' object does not support item assignment'Windows 10 with develop branch and python 3.8.9.pipiche wrote: Thursday 30 March 2023 13:58 I’ll have a look to the errors, and see what can be done.
Just to summarise you are on Windows and with the develop branche
Ça. You drop the PluginConf-xx.json file here ?
