Page 3 of 5
Re: Smartwares introduces 433 thermostat valve
Posted: Thursday 26 February 2015 11:59
by blackdog65
Not with mine
and the valve has stopped opening too
Of course this may be a valve fault, I'll be checking it later today.
Posted: Friday 20 March 2015 20:56
by mschut
Thanks, will play with is soon.
But really, idx 954?
Posted: Friday 20 March 2015 23:23
by StanHD
Yep, 966 now. But there are gaps. It's actually only @ 100 entries in the devices table
Posted: Saturday 21 March 2015 10:20
by mschut
I have connected the Smartware thermostat to Domoticz. Two items appear in domoticz, one switch (on/off) and one in Utility. With the item in utility I am able to set a certain temperature, also with timers. However, the item appears red for not having any recent actions. The tempertature shown by the item is not the last temperature send to the radiator.
- Screenshot 2015-03-21 at 10.01.50.png (18.99 KiB) Viewed 5866 times
Also in the log noithing appears, it's completely empty although the commands are succesfully send.
- Screenshot 2015-03-21 at 10.02.06.png (132.23 KiB) Viewed 5866 times
Is this normal behaviour of this valve, or should this be able to work?
Posted: Thursday 07 May 2015 21:50
by Egregius
Any updates on this? I'm expecting my valves back from RMA soon.
Do I see it right that I can only send on/off from domoticz? And I cannot set a temperature?
Posted: Thursday 14 May 2015 9:15
by Egregius
I think I found a bug:
When adding a Smarwares to the dashboard as favorite I can click it to set the temperature. The signal is sent to the valve but isn't updated on the screen or in the database.
If I choose 'edit' on the other switches panel (where you change the name etc) and set a temperature, the signal is sent AND updated on the dashboard.
This is also true when updating the device with the json udevice command.
Posted: Tuesday 23 June 2015 18:18
by DutchHans
Are there any updates concerning the Logfile from the Smartwares thermostat?
Or the bug that has been reported?
Nothing since may 14..
Regards, Hans
Posted: Thursday 06 August 2015 15:36
by gizmocuz
Plz try #2692
The switching between day/night is now logged, and the setpoint value, timeout is disabled as there is no feedback/input from the device
@DutchHans, thanks for lending the device!!
Posted: Sunday 09 August 2015 8:50
by Egregius
Great
Now figuring out a way to display the setpoint and the real temperature in one graph
Posted: Sunday 09 August 2015 10:54
by gizmocuz
you probably can do this with the custom graph
is there a temperature feedback from this sensor ?
Posted: Sunday 09 August 2015 10:58
by Egregius
No, it's a seperate thermometer in the room.
Posted: Sunday 09 August 2015 11:08
by gizmocuz
Ahh ok
Posted: Sunday 09 August 2015 11:24
by Egregius
Just fixed it in my own temperature graph
SELECT t.Date, t.Temperature as Temperature, s.Temperature as Setpoint
FROM Temperature t
JOIN Temperature s ON t.Date = s.Date
WHERE t.DeviceRowID = $sensor AND s.DeviceRowID = $setpoint
Posted: Sunday 09 August 2015 11:27
by gizmocuz
Nice, where/how did you do this ?
Posted: Sunday 09 August 2015 11:36
by Egregius
Posted: Sunday 09 August 2015 11:44
by gizmocuz
Cant download the zip, receive:
http://goo.gl/Hzh2I9 – this goo.gl shortlink has been disabled. It was found to be violating our Terms of Service. Click here and here for more information about our terms and policies respectively.
Posted: Sunday 09 August 2015 11:50
by Egregius
Oh, didn't know there are rules for Googles URL shortner. I use it to view it's animo about it.
Anyway, here it is:
http://egregius.be/files/floorplan20150809.zip
Also updated the other topic
Posted: Saturday 24 October 2015 23:50
by mistysnip
I received my valve but I can't seem to add it to Domoticz. Could you share the step-by-step instructions, please? I have an RFLink, BTW
Posted: Tuesday 01 December 2015 19:29
by ubfssF
I can ad the thermostat by using the remote, using LEARN, and by using MANUAL from Domoticz. Both work, for switching on and off. Directly after successful connecting I have adjusted both to a thermostat-type instead of an on-off-switch.
However, with both ways no thermostat entry is created within the Utilities tab!
I am using a desktop browser, so that shouldn't be a problem. Domoticz-version is 2.3564 and it's running on Ubuntu.
The only thing I can think off is that I have to added through MANUAL with a different type. But I've used on-of because I see no other reasonable option in that pull-down list. Only afterwards I can change it to a thermostat-type......
Can anyone indicate what kind of adding ons has to do?
Thnx,
Joop
Posted: Monday 04 January 2016 12:41
by rammstan
Im new on this forum and domoticZ. I think i ll be more present here, cause i just bought a new house, the rfxcom and enocean usb 300
. I have first questions:
- Did you experience the battery life?
- Is it PID regulation in the smartwares?
