Page 3 of 4
Re: Lidl now also sells Zigbee smarthome devices
Posted: Thursday 03 December 2020 22:00
by heggink
BertB wrote:EddyG wrote: Thursday 03 December 2020 9:20
BertB wrote: Wednesday 02 December 2020 20:05
Right. So the story so far is, that the lidl gateway does not work with domoticz.
But the good story is that eventually the devices of Lidl will work with zigbee2MQTT.
And most of them already do. Now it is waiting for the support in the zigbee plugin.
True, but now I have to decide to buy an USB Zigbee device.
Can you recommend one?
I use the zzh stick. Flashing is a breeze and it's nicely powerful.
Sent from my SM-G980F using Tapatalk
Posted: Thursday 03 December 2020 22:51
by BertB
Thanks all.
Posted: Friday 04 December 2020 17:13
by Thorgal789
Pacman42 wrote: Thursday 03 December 2020 19:17
Has anyone managed to get the colors working on the RGB E27 LED?
I get them to work in Phosconn App (Conbee), but the RGB controls are not working from Domoticz. Any ideas?
Perhaps a problem with the Python plugin?
Can you pm me if you still have the problem, I need too the device JSON, if it work with phoscon I need to work with domoticz too.
Posted: Saturday 05 December 2020 15:22
by Pacman42
Thorgal789 wrote: Friday 04 December 2020 17:13
It is now working perfectly with the beta code! Great job finding it so quickly! Many thanks.
Posted: Monday 07 December 2020 7:21
by tonbor
tonbor wrote: Thursday 03 December 2020 13:09
tonbor wrote: Saturday 28 November 2020 14:45
Anybody succeded in connecting this lidl silvercrest hub with Domoticz?
Did I buy it in vain, anybody succeded in connecting the wired hub to domoticz?
Never mind I took it back to lidl and got my money back.
Posted: Tuesday 08 December 2020 10:27
by AndrewmHull
I am exploring the whole zigbee side of things.. I currently have a mixture of RF 433mhz and Sonoff basic (tasmota) devices all happily working with Domoticz....
a few weeks ago i got the Sonoff Zigbee bridge which I flashed with Tasmota. I successfully paired some Sonoff Zigbee temperature sensors and use rules to send the info to Domoticz... this all works ok.
So I have now bought some of Lidl Smart plugs.
last night I got the Plugs to pair with the Sonoff Zgbee bridge.. I can issue the ZBsend command (from the tasmota console)to turn it on or off. this works ok.
Is there a way to send information from Domoticz to turn on plug? maybe MQTT...
any hints and Tips greatly received.
Cheers
Andy
Posted: Tuesday 08 December 2020 11:05
AndrewmHull wrote: Tuesday 08 December 2020 10:27
Cheers
Andy
Check this
viewtopic.php?t=33841
Posted: Tuesday 08 December 2020 11:42
by AndrewmHull
waltervl wrote: Tuesday 08 December 2020 11:05
Cheers
Andy
Check this
Thanks Waltervl,
I have seen and read this before. It helped me with the idea to use rules to send the Temp sensor data... what I need to be able to do is send a zigbee command to the (tasomota) sonoff zigbee bridge to turn on / off my plugs...
Cheers
Andy
Posted: Tuesday 08 December 2020 18:56
Andy, You better ask it in that topic.
Posted: Wednesday 09 December 2020 13:17
by BertB
I purchased a ConBee II yesterday and managed to set it up using the deCONZ plugin.
Now, with the web based GUI (
http://DOMOTICZ-IP/pwa/), I try to connect it with lamps and window door sensors from LIDL.
ConBee keeps searching without result. Do I require another software or firmware version?
Posted: Wednesday 09 December 2020 16:45
by Thorgal789
@BertB wich one deconz have you ? You need the last one for sensors
You need too the beta version of the domoticz plugin for some bulbs (but it s color problem, not inclusion one, you will see later).
But bulbs are working natively, wich one bulb have you ? What if your reset procedure for the bulb ?
Posted: Wednesday 09 December 2020 18:18
by BertB
Thorgal789 wrote: Wednesday 09 December 2020 16:45
sudo sh -c "echo 'deb [arch=amd64] http: //phoscon.de/apt/deconz $(lsb_release -cs) main' > etc/apt/sources.list.d/deconz.list" is what I had to use.
The bulbs are from Lidl
Posted: Wednesday 09 December 2020 21:35
by Thorgal789
But what is the deconz version displayed in phoscon ?
And there is so much bulb on lidl, on the manuel I have for HG06106A HG06106B HG06106C to reset the bulb you have to make 3 * off/ on then on
Posted: Thursday 10 December 2020 7:14
by BertB
Ok, i did reset the bulb aan IT was in connect mode.
The bulb is HG06106G.
DeCONZ is version 2.07.00 / 15-11-2020
26660700
Posted: Thursday 10 December 2020 17:20
by Thorgal789
2.07 beta is fine for door sensor >
https://github.com/dresden-elektronik/d ... ssues/3767
It mean it have worked or not ?
Posted: Thursday 10 December 2020 18:01
by BertB
Posted: Thursday 10 December 2020 19:04
by Thorgal789
From the manual with your device, it need to blink after the procedure, you have the blink ?
From a forum, they work exactly like the ikea one (and are compatible)
When you power up a device for the first time, the light will start flashing. At this point, you can not pair yet.
The best thing to do is to reset it first by switching on/off or remove/insert power 3 times quickly. Just like with the Trådfri stuff (although the latter requires 6 power cycles).
Now you have to wait a few minutes for the device to stop flashing. I think the flashing is a pairing mode for the Lidl gateway.
After the flashing stops, you can pair it like any other Trådfri device using the IKEA app. However, make sure you are several meters away from any Trådfri device, since the remotes heavily prefer those over the Lidl devices, and will try to pair with them instead.
Do you already have a working device on the conbee, or it s your first one ?
Posted: Thursday 10 December 2020 20:33
by BertB
Thank you for your help. When i tried to connect the light to the conbee, the light was blinking. There are no other devices connected to the conbee.
The light can easily connect to the Lidl gateway.
Posted: Friday 11 December 2020 9:28
by BertB
Thorgal789 wrote: Thursday 10 December 2020 19:04
Do you mean, I have to use the Ikea app to pair a LIDL bulb to a ConBee II ?
Posted: Friday 11 December 2020 16:19
by Thorgal789
BertB wrote: Friday 11 December 2020 9:28
No ^^, it s just a copy paste from a forum.
But look at your PM, for me the problem is direclty from the conbee, not the lidl stuff.
