SolarEdge individual optimizer dzVents script
Dols
Re: SolarEdge individual optimizer dzVents script
Post by Dols »
McMelloW wrote: Friday 22 May 2020 21:34 Actueel Vermogen SE = directly taken from the Inverter via a LAN connection to my RPi
Any good hints to open up my inverter to my lan?
I have a brand new SE5000H, debug mode disabled, no port 80 or 8080. I have firmware version 4.8.28 which has a security hole, with a bash/python script it possible to open up those ports. But a new firmware is already release which closes this hole (4.9.33). I don't want to shield off the complete inverter from the internet.
freijn
Domoticz version: Stable
Post by freijn »
Yes , of course.
You can enable modbus over lan and use my adapted Python script (posted in an other thread) to read all directly from the inverter.
However.. on that data I have not seen the optimizers listed... :-(
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
Dols wrote: Saturday 23 May 2020 15:17
McMelloW wrote: Saturday 23 May 2020 1:32 In this api guide http://www.solaredge.com/files/pdfs/se_ ... ng_api.pdf They speak about "lifetime" But not all API's return with this value.
Do you use the same API guide?
No i don't use the official API. I use the API the monitoring website is using. Found a hint somewhere on the internet, from there it's reverse engineering.
:D :D I guess we are talking about the same. Go to this page
https://monitoring.solaredge.com/solare ... siteAccess
At the bottom you see a link Read the API Guide That is the above link to the api guide.
Greetings McMelloW
McMelloW
Post by McMelloW »
Dols wrote: Saturday 23 May 2020 15:28
See this topic. https://www.domoticz.com/forum/viewtopi ... 94#p168694
Configured my inverter for Modbus over TCP via LAN according this document (You need a cabled lAN connection for your inverter.)
https://www.solaredge.com/sites/default ... l-note.pdf
Then I used perl script sunpsec-monitor https://github.com/tjko/sunspec-monitor to read-out the registers of the inverter. But cannot read the optimizers. The output of this script goes to a .txt file. This file is parsed by a dzVents script and updates the dummy devices.
So it is a kindop 3-stage-rocket But is t works sufficient so far.
I think Freijn made an advanced script in python.
There is also a python sunspec-ardexa option. https://github.com/ardexa/sunspec-inverters However I did not get this working on my RPi
Greetings McMelloW
Dols
Post by Dols »
McMelloW wrote: Saturday 23 May 2020 16:23
No its not the same API. The document refers to the api for actual customer use. The API I'm using is the API of the website itself, thats why it needs username and password instead of the api key. It request the data from the "normal" website as if it was for the layout webpage.
McMelloW
Post by McMelloW »
Dols wrote: Saturday 23 May 2020 17:42 No its not the same API. The document refers to the api for actual customer use. The API I'm using is the API of the website itself, thats why it needs username and password instead of the api key. It request the data from the "normal" website as if it was for the layout webpage.
Where can i find the descriptionof this API?
When you the data from the website, you must be able to get the lifetime total, because it is displayed on the website.
Greetings McMelloW
Dols
Post by Dols »
McMelloW wrote: Saturday 23 May 2020 19:32 Where can i find the descriptionof this API?
I don't have any documentation of this api. But you can try to find what you looking for:
- In Firefox (or chrome) press [F12] to open the developer tools.
- In top bar of the opened window select "Network"
- Open your monitoring.solaredge.com website.
- In the right pane, select response
- You can browse through the files/request see if you can find you are looking for
Maybe this is the url you are looking for?
https://monitoring.solaredge.com/solare ... es/XXXXXXX
Dols
Post by Dols »
Hmmm,
The optimizer data is not updated anymore at the solaredge website. Funny thing is the inverter data is updated. Yesterday evening it still worked. I used the setapp to enable modbus over tcp yesterday afternoon.
Don't know if i did something wrong with the setapp or solaredge just cut me off...
Dols
Post by Dols »
Dols wrote: Sunday 24 May 2020 9:49 Hmmm,
Okay, didn't apply to the first rule of problem solving "Did you turn it off and on again?". It looks like it's updating the website with the missing historical data on a very slow rate......
Dols
Post by Dols »
McMelloW wrote: Saturday 23 May 2020 16:42 Then I used perl script sunpsec-monitor https://github.com/tjko/sunspec-monitor to read-out the registers of the inverter. But cannot read the optimizers. The output of this script goes to a .txt file. This file is parsed by a dzVents script and updates the dummy devices.
I have it running. Thanks.
McMelloW
Post by McMelloW »
Dols wrote: Sunday 24 May 2020 13:49
So it is a kind of 3-stage-rocket But it works sufficient so far.
Good work, well done.
What do you do with the output of the Perl script.
Greetings McMelloW
Dols
Post by Dols »
McMelloW wrote: Sunday 24 May 2020 14:38 Good work, well done.
I do it a little different.
I use a dzVent script. It is triggered by the P1 smart meter (every second).
The dzVent script runs the perl script, gets the output directly from the execution, without a temp file. Parse the CSV line. Since i also have fresh p1 data i can computer the actual energy consumption.
McMelloW
Post by McMelloW »
Dols wrote: Sunday 24 May 2020 16:03 I do it a little different.
Interesting, a bit like freijn does.
Can you share the script, I would like to have a look at it.
Greetings McMelloW
Dols
Post by Dols »
McMelloW wrote: Sunday 24 May 2020 16:34 Interesting, a bit like freijn does.
It's highly volatile at the moment, i put it on
https://github.com/RDols/dzRequestSolar ... lSolarEdge
McMelloW
Post by McMelloW »
Dols wrote: Sunday 24 May 2020 17:02 It's highly volatile at the moment, i put it on
Looks good.
I trigger every minute at daytime. No use in polling the inverter when there is no sun at night. :) :)
		timer = { 'every minute between 15 minutes before sunrise and 15 minutes after sunset' }
I like your bits on -- Execute perl script and -- Convert CSV result line into array.
This saves a write and read to the SD-card every minute.
Much success with the further developing of this script. I will follow it.
I also send a support request to SolarEdge. How to read the optimizer/panel values via Modbus over TCP. This is somewhere in the inverter, how else can they present it at the monitor website of your installation
Greetings McMelloW
McMelloW
Post by McMelloW »
Started a bit to early to test your script i Think.
This is the first bit of your code.
return
	active = true,
	on =
	data = {},
	execute = function(domoticz, triggeredItem)
        LogDebug(domoticz, "--==[ Start ]==-----------------------------------")
        cmd = string.format("perl %s --numeric --meter=0 --port=%d %s", script, port, ip)
        local f = io.popen(cmd, 'r')
        local result = f:read('*a')
        f:close()
        local fields = {}
        for value in result:gmatch('([^,]+)') do
            table.insert(fields, tonumber(value))
            LogDebug(domoticz, fields)
And this is the result. The is something not OK with the read of the inverter I think.
2020-05-24 18:17:00.993 Status: dzVents: dzPollSolarEdge : --==[ Start ]==-----------------------------------
2020-05-24 18:17:01.479 Status: dzVents: dzPollSolarEdge : table: 0x6ec90b78
2020-05-24 18:17:01.480 Status: dzVents: dzPollSolarEdge : table: 0x6ec90b78
2020-05-24 18:17:01.481 Status: dzVents: dzPollSolarEdge : --==[ End ]==-----------------------------------
2020-05-24 18:17:01.482 Status: dzVents: Info: ------ Finished dzPollSolarEdge
2020-05-24 18:18:01.447 Status: dzVents: dzPollSolarEdge : table: 0x61d56800
2020-05-24 18:18:01.448 Status: dzVents: dzPollSolarEdge : table: 0x61d56800
2020-05-24 18:18:01.449 Status: dzVents: dzPollSolarEdge : --==[ End ]==-----------------------------------
2020-05-24 18:18:01.449 Status: dzVents: Info: ------ Finished dzPollSolarEdge
Greetings McMelloW
Dols
Post by Dols »
McMelloW wrote: Sunday 24 May 2020 18:25 Started a bit to early to test your script i Think.
The result is pretty much i expect from an succesfull run.
Try the following:
After f:close() you put this debug line:
LogDebug(domoticz, result )
replace LogDebug(domoticz, fields) with:
LogDebug(domoticz, value)
This probably give you more insight what happens
McMelloW
Post by McMelloW »
Dols wrote: Sunday 24 May 2020 19:18 The result is pretty much i expect from an succesfull run.
You are quite right. See the output below.
2020-05-24 19:22:00.920 Status: dzVents: Info: ------ Start internal script: dzPollSolarEdge:, trigger: "every minute between 15 minutes before sunrise and 15 minutes after sunset"
2020-05-24 19:22:00.921 Status: dzVents: dzPollSolarEdge : --==[ Start ]==-----------------------------------
2020-05-24 19:22:01.497 Status: dzVents: dzPollSolarEdge : 1590340921,4,5,5,8615844,230.50,0.91,369.60,0.02,42.91,0,0,0,0
2020-05-24 19:22:01.498 Status: dzVents: dzPollSolarEdge : 1590340921
2020-05-24 19:22:01.498 Status: dzVents: dzPollSolarEdge : 4
2020-05-24 19:22:01.498 Status: dzVents: dzPollSolarEdge : 5
2020-05-24 19:22:01.498 Status: dzVents: dzPollSolarEdge : 8615844
2020-05-24 19:22:01.498 Status: dzVents: dzPollSolarEdge : 230.50
2020-05-24 19:22:01.498 Status: dzVents: dzPollSolarEdge : 0.91
2020-05-24 19:22:01.498 Status: dzVents: dzPollSolarEdge : 369.60
2020-05-24 19:22:01.498 Status: dzVents: dzPollSolarEdge : 0.02
2020-05-24 19:22:01.498 Status: dzVents: dzPollSolarEdge : 42.91
2020-05-24 19:22:01.499 Status: dzVents: dzPollSolarEdge : 0
2020-05-24 19:22:01.499 Status: dzVents: dzPollSolarEdge : --==[ End ]==-----------------------------------
2020-05-24 19:22:01.500 Status: dzVents: Info: ------ Finished dzPollSolarEdge
Thanks a lot, I am going to implement it in my script and skip the file write and read.
Greetings McMelloW
freijn
Post by freijn »
McMellow
Please do exe from the commandline >python -V
2.7 might still be on your system.
And even in the onine doc its not mentioned optimizers over Modbus :-(
McMelloW
Post by McMelloW »
freijn wrote: Sunday 24 May 2020 20:38 McMellow
And even in the online doc its not mentioned optimizers over Modbus :-(
Yes, python 2.7 is still on my RPi. But there are no active python2.7 jobs running.
Don't know or it it save to remove python 2.7 and how.
On the other hand, I implemented the way Richard polls the inverter and convert the CSV output in one go. Skip the write / read to a file. The whole dzVents script is running in less than 0.5 sec. So why changing to the sunspec-ardexa solution.
2020-05-24 21:52:00.667 Status: dzVents: Info: SELAN 0.1.6: ------ Start external script: script_SolarEdge-LAN.lua:, trigger: "every minute between 15 minutes before sunrise and 15 minutes after sunset"
2020-05-24 21:52:01.102 Status: dzVents: Info: SELAN 0.1.6: ------ Finished script_SolarEdge-LAN.lua
Greetings McMelloW
