Dashticz V3.4.2 beta
florisi
Domoticz version: 2020beta
Re: Dashticz V3.4.2 beta
Post by florisi »
I have another problem with PVoutput.
I displayed a subdevice ('90_2')which gave the actual output in Watts.
In this beta I can't see it anymore.
When I display the full device, I got all three subdevices in dashticz
Lokonli
Post by Lokonli »
florisi wrote: Tuesday 07 April 2020 9:57 I have another problem with PVoutput.
Do you not see the block at all, or only no value/title inside a block?
And if you try to display '90_1' or '90_3'?
EDIT:
It's bug. Will be fixed.
florisi
Post by florisi »
ok, thanks. I'll wait for the fix and I will test it.
toro
Post by toro »
I have a switch in Domotocz which will turn ON if someone is at the door.
In CONFIG.js is a block for this switch, with the option gotoslideOn: 3, where the feed of de camera is displayed.
But it won't slide (anymore). It will only slide if I add the block to a column. But I do not want to display this switch in Dashticz.
Is this possible?
Lokonli
Post by Lokonli »
toro wrote: Tuesday 07 April 2020 17:14 I have a switch in Domotocz which will turn ON if someone is at the door.
Is this possible?
Indeed, actions will only be executed if you add a block to a column.
However, you can hide the block. One way of doing that is the following. Use the addClass parameter to add the 'hidden' class, and add the block to a column:
blocks[123] = {
	addClass: 'hidden'
columns[1] = {
	blocks: [123]
and in custom.css define the 'hidden' class:
.hidden {
	display: none
Lokonli
Post by Lokonli »
florisi wrote: Tuesday 07 April 2020 11:29 ok, thanks. I'll wait for the fix and I will test it.
Fixed in latest beta.
(Update with git pull)
florisi
Post by florisi »
Installed latest beta, and it is working correct now.
Thanks.
Good service.
New problem introduced now: all Corona data not vissible anymore, graph and numbers lost.
clinkadink
Post by clinkadink »
Its an issue with the external source corona api, it is currently down. I am guessing its overloaded. But there is an alternative url you can apply, if you don't want to wait for the next update (which has been submitted).
See here: https://www.domoticz.com/forum/viewtopi ... 28#p242770
florisi
Post by florisi »
Thanks, changed the url.
toro
Post by toro »
Lokonli wrote: Tuesday 07 April 2020 17:51 Indeed, actions will only be executed if you add a block to a column.
Lokonli,
Again, thanks for your super-fast reply.
Great tip, that's working great.
I really appreciate all your effort. Cheers!
I hope you can find a moment to take a look at my lastest question in 112 Meldingen https://www.domoticz.com/forum/viewtopi ... 20#p241683 if you didn't already do so :)
geertvercamer
Post by geertvercamer »
Lokonli wrote: Friday 03 April 2020 21:43
geertvercamer wrote: Friday 03 April 2020 18:13 you're welcome.
Glad to learn something new.
new beta: the title of those blocks is gone
Did you define the subblocks in CONFIG.js?
That might have been solved in the most recent beta.
If not, can you post your CONFIG.js parts for this block? (the block and column definition)
sorry, missed this.
Not sure what you mean with subblocks.
My device '95' is THB from openweather
blocks['95_1'] = {title: 'Temperatuur', show_lastupdate: true, switch: true, width: 3};
blocks['95_2'] = {title: 'Vochtigheid', show_lastupdate: true, switch: true, width: 3};
blocks['95_3'] = {title: 'Barometer', show_lastupdate: true, switch: true, width: 3};
blocks['95_4'] = {title: 'Dauw Punt', show_lastupdate: true, switch: true, width: 3};
This below worked before:
columns[2]['blocks'] = [95, 'weather_owm', 149, 153, 35, buttons.webcam];
I've changed to this and this is working:
columns[2]['blocks'] = ['95_1', '95_2', '95_3', '95_4', 'weather_owm', 149, 153, 35, buttons.webcam];
Last edited by geertvercamer on Thursday 09 April 2020 18:20, edited 1 time in total.
madradrakie
Post by madradrakie »
Lokonli wrote: Monday 06 April 2020 22:58 Please check a few posts earlier, and read:
https://dashticz.readthedocs.io/en/beta ... fterupdate
any idea how to modify the following code:
function getStatus_413(block){
   if(parseFloat(device['Usage'])>0){
       block.icon= 'fas fa-sun slow-spin'; //if you use "fa-spin" instead of "slow-spin" then it is not necessary to add code to custom.css
   else {
      block.icon= 'fas fa-sun';
i tried but this one is not working:
	Dashticz.setBlock('413_1', {
Lokonli
Post by Lokonli »
Almost ok :)
Try this:
   var usage = block.device.Usage;
   if(parseFloat(usage)>0) {
       		icon: 'fas fa-sun slow-spin'
   else {
	      icon: 'fas fa-sun'
I'll add this as an example to the documentation (if it works ...)
Lokonli
Post by Lokonli »
Wait, i've to check the usage of the subblock 413_1
madradrakie
i have tried your solution but not working yet unfortunately.
Lokonli
Post by Lokonli »
First I had to do some checks, but everything seems to be fine, assuming you have updated to latest beta.
You just want to change the icon of subblock 413_1. You can do it as follows:
 function getStatus_413_1(block) {
     if (parseFloat(usage) > 0) {
         block.icon = 'fas fa-sun slow-spin'
     } else {
         block.icon = 'fas fa-sun';
EdwinK
Post by EdwinK »
After getting the latest beta yesterday, I'm getting this message:
Screen Shot 2020-04-11 at 08.56.22.png (27.51 KiB) Viewed 1037 times
(should have been in topic for 3.4.3)
Lokonli
Post by Lokonli »
EdwinK wrote: Saturday 11 April 2020 9:02 After getting the latest beta yesterday, I'm getting this message:
Check:
https://www.domoticz.com/forum/viewtopi ... 45#p243203
Users browsing this forum: Amazon [Bot] and 1 guest
