Page 3 of 4
Re: ZXT-120
Posted: Friday 30 December 2016 16:38
by Ben0it
I was wondering if the problem could come from a commandGet occuring too fast after the commandSet?
Out of curiosity, I'm doing a test with a dirty « sleep(2) » after a commandSet, will post the result here...
Edit: it didn't help, same bug as before.
Re: ZXT-120
Posted: Friday 30 December 2016 18:16
by juankar
It looks like a problem of protocol. Remotec says that the device answer with a signal of command received to controller before the device do its work. So the next command produce the error.
I've found a solution setting an sleep just after the commandSet message is remove from queue of commands. And it works because the sleep is in the message processor. (multi thread!).
I've added a new parameter to config zwcfg (I named toSleep), this parameter is the number of microseconds to sleep after send command. So for normal devices this value is 0, but for Remotec the value is about 2000 (usleep(us) use microseconds). Then we need define some new functions and add this paremater to zwcfg by hand, yes, i don't like this
but now is the only way I've found.
If you have a bit of knaoledge about programing you can apply it modifying the following files
Driver.h about line 401
uint32 GetNodeMaxBaudRate( uint8 const _nodeId ); // this exist, is for reference
uint16 GetNodetoSleep(uint8 const _nodeId); //OJO: this is for new param toSleep, it's the sleep time
Dirver.cpp
About line 4545
// <Driver::GetNodetoSleep>
// OJO REad the value of parameter toSleep
uint16 Driver::GetNodetoSleep
uint8 const _nodeId
uint16 tsleep = 0;
LockGuard LG(m_nodeMutex);
if( Node* node = GetNode( _nodeId ) )
tsleep = node->GettoSleep();
return tsleep;
I
About line 1286, inside Driver::RemoveCurrentMsg
//OJO: number of node, then read the toSleep for this node.
uint8 nodeId = GetNodeNumber( m_currentMsg );
if( Node* node = GetNodeUnsafe( nodeId ) )
uint16 toSleep = node->GettoSleep();
if (toSleep > 0)
usleep(toSleep);
Node.h, about line 322..343
bool IsNodeReset(); //it exists, for refrence
uint16 GettoSleep()const{ return m_toSleep; } //OJO: get the value of toSleep.
bool m_addingNode; //it exists, for refrence
uint16 m_toSleep; //OJO: microseconds for usleep in Drivers::RemoveCurrentMsg
Node.cpp, inside writeXML, about 1281
nodeElement->SetAttribute( "max_baud_rate", str ); //it exists, for refrence
//OJO: property toSleep for include in usleep() . If it's 0 don't store.
if (m_toSleep > 0){
snprintf( str, 32, "%d", m_toSleep );
nodeElement->SetAttribute( "toSleep", str );
snprintf( str, 32, "%d", m_version ); //it exists, for refrence
inside ReadXML, about 1014
//OJO: give a value to m_toSleep
m_toSleep = 0;
if( TIXML_SUCCESS == _node->QueryIntAttribute( "toSleep", &intVal ) )
m_toSleep = (uint16)intVal;
m_version = 0; //it exists, for refrence
if( TIXML_SUCCESS == _node->QueryIntAttribute( "version", &intVal ) ) //it exists, for refrence
I think it's all. The name of parameter is toSleep and must be written in zwcfg in the same area as max_baud_rate.
This works for Linux, I don't check in windows.
Re: ZXT-120
Posted: Friday 30 December 2016 20:53
by Ben0it
Hi Juankar,
First, thanks a lot for your patch. I have applied the modifications you documented to my OpenZWave directory, and it didn't work at the first attempt.
So I added debugging information (calls to
Log::Write() ) to see if the call to
usleep() was really performed, it was. Then I increased the sleep period from 2,000us to 20,000us and that did it! (
OpenZWave debug log file location)
I have gathered the modifications into a single patch file it this can help: (I have just changed 'toSleep' by 'sleep_before_send' and named the methods & members accordingly to better match the variable&function naming in the code of OpenZWave):
To apply the patch, uncompress (7-zip) the file, and from the open-zwave folder, type:
git apply < path/to/file/remotec-zxt120.diff
Recompile OpenZWave + Domoticz, edit your Z-Wave config file Config/zwcfg_0x????????.xml in the Domoticz folder to add the field sleep_before_send on your ZXT-120 device, for example:
<Node id="25" name="ClimEntree" location="" basic="4" generic="8" specific="6" type="General Thermostat V2" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" sleep_after_send="20000" secured="true" query_stage="Complete">
I think you should submit your patch to the OpenZWave team
Best Regards,
Re: ZXT-120
Posted: Saturday 07 January 2017 10:30
by Ben0it
By the way, should the checkbox "Enable polling" be checked on the ZWave node for ZXT-120?
- domoticz-zxt-120ozw.jpg (162.36 KiB) Viewed 5236 times
I don't know if it has an impact on the stability of the node.
Best Regards,
Re: ZXT-120
Posted: Saturday 07 January 2017 20:41
by juankar
I don't have enabled the polling for this device, although I think it doesn't send temperature readings if it's off, you need refresh node to get temperature. So if you use its temperature sensor for control AC you have to use the polling. But if you use another temperature sensor polling is not necessary.
Re: ZXT-120
Posted: Thursday 26 January 2017 0:38
by whyrywhy
Long time reader, first time questioner.
Maybe I'm missing something simple you fine people could assist with: I can add this device, and apparently even program the codes via Domoticz (I'm leveraging this for AV IR). I send set a location, enter 000, apply, it blinks, then accepts the code I give it.
The problem is - I have no idea what to do with it after. I can't seem to figure out how to send a location I've set. I only see a single utility entry, with none of these options (attached pictures).
This seems like a total issue between the seat and keyboard, but if somebody could point me in the right direction, I'd appreciate it.
Re: ZXT-120
Posted: Tuesday 28 February 2017 8:42
by bdormael
Any news on making this compatible with the gen5 stick ?
Re: ZXT-120
Posted: Tuesday 28 February 2017 10:54
by juankar
I sent a pull request to GirHub, and, after a pair of modifications, I'm waiting for aproval.
You can see it in
https://github.com/OpenZWave/open-zwave/pull/1090
After commit of this request, I have a modification in OZW control panel related with this modification.
Re: ZXT-120
Posted: Tuesday 14 March 2017 14:41
by antares
The device itself seems to work smoothly. I've switched over to openHAB with it to try and I can without any problems run my Mitsubishi Heavy AC with it.
Re: ZXT-120
Posted: Tuesday 14 March 2017 15:08
by juankar
Wonderfull! I like to know that this modification is useful for other users!!
I am waiting for GitHub commit my modification, so I'll can send a new pull request for panel OZW. But this process is a very slow one.
Re: ZXT-120
Posted: Wednesday 15 March 2017 12:54
by yaggii
Hi All,
I have the Synology DSM 6.1 version and installed the Domoticz 3.6953 that was here:
http://www.jadahl.com/domoticz_beta_6.1 ... =cedarview
When I was using the DSM 6 with the stable version from Jadahl I could see my remotec device and all the configurations, but now I see the remotec, but keeps on not updating it's details. also is I go to the Control Panel and check information for the device I have Library, Protocol and Application version all Unknown.
Did anyone had the same situation? Is there anyone that could help me on this matter?
Re: ZXT-120
Posted: Friday 07 July 2017 1:30
by dpons039
Hey there,
I have the same issues with the ZXT-120 and since the Pull request seems to go nowhere. And I would love to have my AC working automatically this summer
Could some1 explain how can I apply the changes of the Pull request?
Thank you very much
Re: ZXT-120
Posted: Friday 07 July 2017 2:55
by juankar
You have the answer 11 posts before this one.
You can also download the modified files from github and recompile your openzwave and domoticz
And you can ask for this modification be commited in github, so If there are many users with the same problem the request would be incorporated to openzwave.
Re: ZXT-120
Posted: Wednesday 02 August 2017 15:11
by Ptje
I have the same problem I think. It seems to that the remotec is online in domoticz, but when most of the time I send a command, the domoticz logs tells the remotec is offline (timeout)
Where do I find the open z-wave folder to execute the patch from ?
Greetings,
Peter
Re: ZXT-120
Posted: Wednesday 02 August 2017 16:18
by juankar
I sent the patch to GitHub long time ago (last modification about February). You can see the post here:
I don't know why this modification is waiting so long. Perhaps if more users claim for it, the assigned editor (Fishwaldo) publish it in OZW library.
So you need to modify several files and main config file in your net. It's easy and it works fine.
Bye.
Re: ZXT-120
Posted: Wednesday 02 August 2017 17:55
by Ptje
Best Juankar,
I did leave a message in de github toppic. I did buy the remotec to get my airco working, but I don't have anything on the remotec this way. I did get a new one, because they thought it was maybe defective. That is not true, the new one has the same problem.
I would do it by my self, but I don't know, where I can find the files to modify. Installing the patch is not necessary then ? I did not know where I could find the open z-wave folder to execute the patch from.
Greetings,
Peter
Re: ZXT-120
Posted: Wednesday 02 August 2017 18:42
by Ptje
What I think it's strange, the state of the remotec is never "sleep" when you look at the z-wave devices in domoticz. Even not when I use battery in stat of Usb. When I look at my thermostaat of danfoss, they are even on batteries. They are most of the time in sleep. Domoticz send then a command, when that devices send an update and are not in sleep.
Because domoticz thinks that the remotec is not in sleep, it sends commands and gets time out I think.
Greetings,
Peter
Re: ZXT-120
Posted: Thursday 03 August 2017 17:59
by Ptje
Where is the folder to execute patch from ? I did what I thought was wright, but thats not good. See te screen shots. Who can help ?
Greetings,
Peter
Re: ZXT-120
Posted: Tuesday 05 September 2017 21:59
by miniomar
Hello to everybody,
It is my first post in this forum.
I have an AEOTEC USB z-stick gen5 with 4 flush 1D relays with domoticz on raspberry pi-3.
I bought a remotec zxt-120, but I can't include it.
To include it I use this procedure, let me know if it is correct:
I disconnect the z-stick from the raspberry, the I push the button and the led starts to blink slowly (only blue color).
Then I push the PROG button on the remotec zxt-120 and I see the red led to blink one time, but the z-stick led doesn't blink quickly as expected when it includes a new devices.
If I insert it in the raspberry and I do again the configuration of the z-stick I don't see any new device.
Le me know if it is right.
Any suggestion ?
Thanks a lot
Marco
Re: ZXT-120
Posted: Wednesday 06 September 2017 10:48
by miniomar
juankar wrote: Wednesday 02 August 2017 16:18
Bye.
Hi Juankar
I have some update about my test with remotec zxt-120.
As I Wrote in a previous post this is my configuration:
Raspberry pi 3 with raspbian, AEOTEC z-stick gen5, domoticz and remotec zxt-120 (v1.8).
After a factory reset on remotec zxt-120 I was able to include it in the z wave net.
But now I was not able to change the IR code (parameter 27), always settled to 0.
My question are:
1) is it this issue linked to the pull up request opened in OZW (1090) ?
2) is it possible to fix it by compiling it as described above ?
3) do you have a step by step tutorial to compile it ?
Thanks for your feedback
Marco
