Page 3 of 7
Re: SmartEvse support
Posted: Sunday 04 August 2024 16:09
by FlyingDomotic
Idea is to build you own MqttMapper.json file (which should be in /home/pi/Domoticz/plugins/MqttMapper/)
To make it, use your own editor (nano, vi, ... or even anything on a PC which will be copied then to the RPi).
Just cut and paste parts of the message you need, and make some cleanup (keep only one opening "{" at beginning of file and one closing "}" at end, add "," between parts. This should give you something like:
"SmartEVSE charge current": {
"topic": "[MQTTprefix]/Charge Current",
"type": "243", "subtype": "23", "switchtype": "0",
"mapping": {"item": "", "multiplier": 0.1}
"SmartEVSE max current": {
"topic": "[MQTTprefix]/Max Current",
"SmartEVSE state": {
"topic": "[MQTTprefix]/State",
"type": "243", "subtype": "19", "switchtype": "0",
"mapping": {"item": ""}
"SmartEVSE status": {
"topic": "[MQTTprefix]/Status",
"type": "244", "subtype": "73", "switchtype": "18",
"options": {"SelectorStyle":"1", "LevelOffHidden": "false", "LevelNames":"None|No Power Available|Communication Error|Temperature High|EV Meter Comm Error|RCM Tripped|Waiting for Solar|Test IO|Flash Error|**Unknown**"},
"mapping": {"item": "", "default": "90",
"values": {
"None": "0",
"No Power Available": "10",
"Communication Error": "20",
"Temperature High": "30",
"EV Meter Comm Error": "40",
"RCM Tripped": "50",
"Waiting for Solar": "60",
"Test IO": "70",
"Flash Error": "80",
"**Unknown**": "90"
"SmartEVSE charge current override": {
"topic": "[MQTTprefix]/ChargeCurrentOverride",
"type": "242", "subtype": "1", "switchtype": "0",
"options": {"ValueStep": "1", "ValueMin": "0", "ValueMax": "200", "ValueUnit": "A"},
"initial": {"nvalue": "0", "svalue": "0"},
"mapping": {"item": "", "multiplier": 0.1},
"set": {"topic": "[MQTTprefix]/Set/CurrentOverride", "digits": 0}
Posted: Sunday 04 August 2024 16:11
by FlyingDomotic
And don't worry about indentation, each tool does its own. At the end, all end of lines, tabs and spaces between elements are removed to keep only useful data.
Posted: Sunday 04 August 2024 17:40
by rron
Ok, thanks for your help I’m going to try this again and keep you posted.
Posted: Sunday 04 August 2024 22:52
by waltervl
And also change [MQTTprefix] in the json configuration file in your real MQTT prefix you use in your SmartEvse setup. Currently you are using "domoticz" but default is SmartEvse-xxxxx where xxxx is the serial number of the device. Better use the default.
Posted: Wednesday 07 August 2024 21:53
by DiaDomo
Although I don't have the hardware (SmartEVSE module) yet, I tested the mqtt setup with the json mapping file as described above:
5 devices are created, so the concept works!
Of course more devices should be added in the json mapping file.
Posted: Friday 09 August 2024 14:48
by rron
DiaDomo wrote: ↑Wednesday 07 August 2024 21:53
I have the same devices created in my system but there's no update of the devices. The time you see is the creation time. In the logging there's no activity from the mapper.
Posted: Friday 09 August 2024 15:58
by waltervl
rron wrote: ↑Friday 09 August 2024 14:48
Please check with the application MQTT Explorer what SmartEVSE MQTT topics you now have.
Did you change the MQTTprefix in the SmartEVSE configuration (from domoticz to something like SmartEVSE-xxxxx)?
Did you modify the MQTTMapper configuration json with this new MQTTprefix?
Posted: Friday 09 August 2024 16:11
by rron
Yesi did all the recommendations you have provided. The device are made as you can see in the screenshot but they are not updated from the smartevse. If I compare this with the mqtt explorer there are a lot of updates which they are not in domoticz.
Posted: Friday 09 August 2024 16:17
by waltervl
can you post a screenshot of MQTT explorer with the smartevse topic.
Also post the contents of MqttMapper.json file (which should be in /home/pi/Domoticz/plugins/MqttMapper/)
Posted: Friday 09 August 2024 16:26
by rron
"values": {
"None": "0",
"Test IO": "70",
"**Unknown**": "90"
Ps the topic smartevse in the explorer is the old one which i haven't deleted.
Posted: Friday 09 August 2024 16:32
by waltervl
Thank you. You made a mistake: In the MqttMapper.json change every [MQTTprefix] into SmartEVSE-5572
So for example
should be
"topic": "SmartEVSE-5572/Charge Current"
Then you probably have to restart the plugin (click on update when selecting the plugin in menu Setup - Hardware)
Edit: It also seems you are running a SmartEVSE not according the documentation. A lot of MQTT topics (like for example SmartEVSE-5572/Set) are not available.
Posted: Friday 09 August 2024 17:25
by rron
"topic": "SmartEVSE-5572/Charge Current",
"topic": "SmartEVSE-5572/Max Current",
"topic": "SmartEVSE-5572/State",
"topic": "SmartEVSE-5572/Status",
"values": {
"None": "0",
"Test IO": "70",
"**Unknown**": "90"
"topic": "SmartEVSE-5572/ChargeCurrentOverride",
Yes that was the solution, mqtt prefix change to SmartEVSE-5572. Now I have one part working "charge current overide"the rest is still not updating. I have to look why that is.
Posted: Friday 09 August 2024 19:14
by FlyingDomotic
Would it be possible to provide a full extract of "SmartEVSE-5572"?
Posted: Friday 09 August 2024 19:19
by rron
FlyingDomotic wrote: ↑Friday 09 August 2024 19:14
I don’t know what you mean by that
Posted: Friday 09 August 2024 19:26
by FlyingDomotic
Idea is to use a tool (like MQTT Explorer) to extract data from MQTT topic "SmartEVSE-5572" and copy it here.
Posted: Friday 09 August 2024 19:32
by waltervl
Looking at the screenshot of his mqtt explorer it is not showing all the MQTT topics you have listed. So it seems SmartEVSE of @rron is not the same implementation as the one you have found......
Especially there not seems to be a Set topic so no possibility to send MQTT to SmartEVSE. So also not possible to send Domoticz Mqttmapper commands to SmartEVSE
@rron check your smartEVSE software version and update or change from repository so full MQTT functionality will come available.
Posted: Friday 09 August 2024 19:36
by FlyingDomotic
That's the reason why I would like to have an idea how his MQTT data is structured, in order to adapt JSON configuration file.
It seems that at least one topic is ok.
Posted: Friday 09 August 2024 19:48
by rron
FlyingDomotic wrote: ↑Friday 09 August 2024 19:26
There ' s no further information in the mqtt explorer. I have made 2 screenshots from the explorer, 1 from zigbee2mqtt with information and 2 from smartevse without detailed information.
Posted: Friday 09 August 2024 19:50
by rron
waltervl wrote: ↑Friday 09 August 2024 19:32
I have the latest firmware version 3.6.7.
Posted: Friday 09 August 2024 20:33
by DiaDomo
@rron: please post this screenshot:
