Script to restart Domoticz if it crashes Topic is solved
All kinds of 'OS' scripts
jannl
Domoticz version: 2025.5.x
Re: Script to restart Domoticz if it crashes
Post by jannl »
I'll post my script when I am at home tonight or tomorrow
K3rryBlue
Domoticz version: V4.10xx
Post by K3rryBlue »
Not sure havnegata, since i moved the installation from the SD card to a USB drive, it runs very stable. I expect that when Domoticz hangs, there will no response and enters the ELSE of the statement.
I'll wait for the script of Jan. Just saw below remark it's not working..................
Domoticz V4.10717, RPi2 -> Linux raspberrypi 4.4.47-v7+ , RFXCOM - RFXtrx433 USB 433.92MHz ,RAZBERRY2 and OpenZWave USB Version: 1.4-2363-g1f10253-dirty
uc530
Post by uc530 »
Hi again!
Holy.....
Egregius and jannl are right. Today my Domoticz hanged and script for detecting if it is running is ok and runs perfectly. I also checked manually if domo is running and it is all OK, but the web page is not responding...
K3rryBlue
Post by K3rryBlue »
Just remember that I already have one to check the status of zwave....
fill in your own ip, port and idx which you want to check. In my case its 1. the number of the RAZBERY2 board.
#!/bin/sh
# check ZWave
CONFIG=/home/pi/domoticz/scripts/bash/domoticz_state_checker.txt
dt=$(date '+%d/%m/%Y %H:%M:%S')
status=`curl -s -i -H "Accept: application/json" "http://xxx.xxx.xxx:xxxx/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
if [ $status ]
then
echo "Zwave is responsive!"
sudo service domoticz.sh stop
sleep 5
sudo service domoticz.sh start
echo  echo "$dt, ZWave was offline. Restarted Domoticz...." >> "$CONFIG"
fi
jannl
Post by jannl »
Basically that is what my script does as well
Egregius
Domoticz version: v2024.7
Post by Egregius »
This is my version:
#!/bin/bash
DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://127.0.0.1:8084/json.htm?type=devices&rid=1"`
STATUS=`echo $DOMOTICZ | jq -r '.status'`
if [ "$STATUS" == "OK" ] ; then
	exit
	sleep 5
	STATUS2=`echo $DOMOTICZ | jq -r '.status'`
	if [ "$STATUS2" == "OK" ] ; then
		exit
		sleep 5
		STATUS3=`echo $DOMOTICZ | jq -r '.status'`
		if [ "$STATUS3" == "OK" ] ; then
			exit
			curl -s --connect-timeout 2 --max-time 5 --data-urlencode "text=Domoticz Bad - Restarting" --data "silent=false" http://127.0.0.1/secure/telegram.php
			NOW=$(date +"%Y-%m-%d_%H%M%S")
			cp /tmp/domoticz.log /volume1/files/temp/domoticz-$NOW.txt
			sudo /var/packages/domoticz/scripts/start-stop-status stop
			sleep 8
			sudo kill $(sudo netstat -anp | awk '/ LISTEN / {if($4 ~ ":8084$") { gsub("/.*","",$7); print $7; exit } }')
			sleep 8
			sudo /var/packages/domoticz/scripts/start-stop-status start
		fi
	fi
fi
If the status is OK, nothing happens. If not 2 retries are done.
If all 3 are NOK the logfile is copied (otherwise cleared because tmpfs), the service is stopped, then kill whatever is running on port 8084 and start it again.
the kill is added because I once encountered that service stop didn't work because domoticz was really crashed but still running and blocking the port.
Keep in mind that this is for Syno, should be big thing to change it to RPi.
K3rryBlue
Post by K3rryBlue »
Hi Egregius,
Seems promising, I will look into it and adapt it for the rPi.
K3rryBlue
Post by K3rryBlue »
This one works for the pi, needed to make more changes then expected.
#!/bin/bash
STATUS=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://192.168.1.109:8080/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
if [ $STATUS ] ; then
   exit
   sleep 5
   STATUS2=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://192.168.1.109:8080/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
   if [ $STATUS2] ; then
      exit
      sleep 5
      STATUS3=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://192.168.1.109:8080/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
      if [ $STATUS3 ] ; then
         exit
         sleep 8
		 sudo killall domoticz
         sleep 8
		 echo   "$dt, Domoticz was offline. Restarted Domoticz...." >> "$CONFIG"
      fi
   fi
fi
G3rard
Domoticz version: No
Post by G3rard »
Thanks @K3rryBlue for sharing the script. Works fine on my Ubuntu Server with some small changes.
Not using Domoticz anymore
EdwinK
Post by EdwinK »
Egregius wrote:This is my version:
Trying this, after my version of Domoticz had already crashed. This is the output.
cp: cannot stat ‘/tmp/domoticz.log’: No such file or directory
Domoticz is not running
kill: not enough arguments
Starting Domoticz ...
insmod: ERROR: could not insert module /lib/modules/usbserial.ko: File exists
insmod: ERROR: could not insert module /lib/modules/ftdi_sio.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/cp210x.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/pl2303.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/ch341.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/ti_usb_3410_5052.ko: File exists
ln: failed to create symbolic link ‘/lib/udev/rules.d/60-synocommunity.domoticz.rules’: File exists
I'm not much of a coder, so much of it means not much for me.
Egregius
Post by Egregius »
Line by line:
1: Is your logfile in /tmp? Otherwise change path or remove line so it's not copied.
2: Domoticz was already stopped
3: No process found to kill on port 8084
4+ Normal behavior if you restart Domoticz on Syno because those modules are already loaded.
EdwinK
Post by EdwinK »
Trying to work this.
havnegata
Domoticz version: V4.10162
Post by havnegata »
@Jannl I'm qurious to hear about how you implement the Pushover notification?
jannl
Post by jannl »
I am a bit busy coming days. I will post the code beginning of next week. Just sent me a pm if I seem to forget it
jannl
Post by jannl »
Below the command that sends a message to my pushover, replace the tokens with your own (2 different).
status=`curl -s  --form-string "token=pushoverapitoken"  --form-string "user=pushoverusertoken"  --form-string "message=Domoticz is opnieuw gestart" https://api.pushover.net/1/messages.json`
poudenes
Domoticz version: 3.8993
Post by poudenes »
wrong topic
rfvdboom
Domoticz version: 2023.2
Post by rfvdboom »
When my Domoticz crashes/not responding, status says: "active (exited)". The script doesn't work.
So I changed this
elif [[ $DomoticzState == *"inactive (dead)"* ]]
To
elif [[ $DomoticzState != *"active (running)"* ]]
grtz Ralph
Odroid N2+ | Raspberry P 3 ModelB | RFXcom | AEOTEC Zwave | Honeywell Lyric T6| Milight | Milighthub (NodeMCU) | SolarEdge | P1 Smart meter USB | KAKU | Wemos D1 (esphome) | Denon | Logitech Harmony
EdwinK
Post by EdwinK »
Installed. Hope it's working.
Caribou
Post by Caribou »
G3rard wrote:Thanks @K3rryBlue for sharing the script. Works fine on my Ubuntu Server with some small changes.
Hi G3rard,
Would you mind to share your version including these small changes please?
G3rard
Post by G3rard »
Caribou wrote: Hi G3rard,
Here it is. Just change the folders and Domoticz URL and port to yours and it should work.
#!/bin/bash
CONFIG=/home/gerard/scripts/domoticz/domoticz_state_checker.txt
STATUS=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://192.168.1.157:8084/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
   echo "Domoticz online"
   echo "$STATUS"
   exit
   sleep 5
   STATUS2=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://192.168.1.157:8084/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
      exit
      sleep 5
      STATUS3=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://192.168.1.157:8084/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
         exit
         cp /var/log/domoticz.log /home/gerard/scripts/domoticz/domoticz-$NOW.txt
         echo "Domoticz offline"
         #You can send a Pushover message here
         sudo service domoticz.sh restart
         echo "$NOW, Domoticz was offline. Restarted Domoticz...." >> "$CONFIG"
      fi
   fi
fi
