Script to restart Domoticz if it crashes Topic is solved
- Domoticz version: 2022.2
Re: Script to restart Domoticz if it crashes
I'll post my script when I am at home tonight or tomorrow
- K3rryBlue
- Domoticz version: V4.10xx
Not sure havnegata, since i moved the installation from the SD card to a USB drive, it runs very stable. I expect that when Domoticz hangs, there will no response and enters the ELSE of the statement.
I'll wait for the script of Jan. Just saw below remark it's not working..................
Domoticz V4.10717, RPi2 -> Linux raspberrypi 4.4.47-v7+ , RFXCOM - RFXtrx433 USB 433.92MHz ,RAZBERRY2 and OpenZWave USB Version: 1.4-2363-g1f10253-dirty
Hi again!
Holy.....
Egregius and jannl are right. Today my Domoticz hanged and script for detecting if it is running is ok and runs perfectly. I also checked manually if domo is running and it is all OK, but the web page is not responding...
Holy.....
- K3rryBlue
Just remember that I already have one to check the status of zwave....
fill in your own ip, port and idx which you want to check. In my case its 1. the number of the RAZBERY2 board.
#!/bin/sh
# check ZWave
CONFIG=/home/pi/domoticz/scripts/bash/domoticz_state_checker.txt
dt=$(date '+%d/%m/%Y %H:%M:%S')
status=`curl -s -i -H "Accept: application/json" "http://xxx.xxx.xxx:xxxx/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
if [ $status ]
then
echo "Zwave is responsive!"
sudo service domoticz.sh stop
sleep 5
sudo service domoticz.sh start
echo echo "$dt, ZWave was offline. Restarted Domoticz...." >> "$CONFIG"
fi
Basically that is what my script does as well
- Egregius
- Domoticz version: v2024.7
This is my version:
If the status is OK, nothing happens. If not 2 retries are done.
If all 3 are NOK the logfile is copied (otherwise cleared because tmpfs), the service is stopped, then kill whatever is running on port 8084 and start it again.
the kill is added because I once encountered that service stop didn't work because domoticz was really crashed but still running and blocking the port.
Keep in mind that this is for Syno, should be big thing to change it to RPi.
#!/bin/bash
DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://127.0.0.1:8084/json.htm?type=devices&rid=1"`
STATUS=`echo $DOMOTICZ | jq -r '.status'`
if [ "$STATUS" == "OK" ] ; then
exit
sleep 5
STATUS2=`echo $DOMOTICZ | jq -r '.status'`
if [ "$STATUS2" == "OK" ] ; then
exit
sleep 5
STATUS3=`echo $DOMOTICZ | jq -r '.status'`
if [ "$STATUS3" == "OK" ] ; then
exit
curl -s --connect-timeout 2 --max-time 5 --data-urlencode "text=Domoticz Bad - Restarting" --data "silent=false" http://127.0.0.1/secure/telegram.php
NOW=$(date +"%Y-%m-%d_%H%M%S")
cp /tmp/domoticz.log /volume1/files/temp/domoticz-$NOW.txt
sudo /var/packages/domoticz/scripts/start-stop-status stop
sleep 8
sudo kill $(sudo netstat -anp | awk '/ LISTEN / {if($4 ~ ":8084$") { gsub("/.*","",$7); print $7; exit } }')
sleep 8
sudo /var/packages/domoticz/scripts/start-stop-status start
fi
fi
fi
- K3rryBlue
Hi Egregius,
Seems promising, I will look into it and adapt it for the rPi.
- K3rryBlue
This one works for the pi, needed to make more changes then expected.
#!/bin/bash
STATUS=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://192.168.1.109:8080/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
if [ $STATUS ] ; then
exit
sleep 5
STATUS2=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://192.168.1.109:8080/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
if [ $STATUS2] ; then
exit
sleep 5
STATUS3=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://192.168.1.109:8080/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
if [ $STATUS3 ] ; then
exit
sleep 8
sudo killall domoticz
sleep 8
echo "$dt, Domoticz was offline. Restarted Domoticz...." >> "$CONFIG"
fi
fi
fi
- G3rard
- Target OS: -
- Domoticz version: No
Thanks @K3rryBlue for sharing the script. Works fine on my Ubuntu Server with some small changes.
Not using Domoticz anymore
- EdwinK
- Domoticz version: BETA
Trying this, after my version of Domoticz had already crashed. This is the output.Egregius wrote:This is my version:
cp: cannot stat ‘/tmp/domoticz.log’: No such file or directory
Domoticz is not running
kill: not enough arguments
Starting Domoticz ...
insmod: ERROR: could not insert module /lib/modules/usbserial.ko: File exists
insmod: ERROR: could not insert module /lib/modules/ftdi_sio.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/cp210x.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/pl2303.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/ch341.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/ti_usb_3410_5052.ko: File exists
ln: failed to create symbolic link ‘/lib/udev/rules.d/60-synocommunity.domoticz.rules’: File exists
- Egregius
Line by line:
1: Is your logfile in /tmp? Otherwise change path or remove line so it's not copied.
2: Domoticz was already stopped
3: No process found to kill on port 8084
4+ Normal behavior if you restart Domoticz on Syno because those modules are already loaded.
- EdwinK
Trying to work this.
- havnegata
- Domoticz version: V4.10162
@Jannl I'm qurious to hear about how you implement the Pushover notification?
I am a bit busy coming days. I will post the code beginning of next week. Just sent me a pm if I seem to forget it
Below the command that sends a message to my pushover, replace the tokens with your own (2 different).
status=`curl -s --form-string "token=pushoverapitoken" --form-string "user=pushoverusertoken" --form-string "message=Domoticz is opnieuw gestart" https://api.pushover.net/1/messages.json`
- Domoticz version: 3.8993
wrong topic
- Domoticz version: 2023.2
When my Domoticz crashes/not responding, status says: "active (exited)". The script doesn't work.
So I changed this
elif [[ $DomoticzState == *"inactive (dead)"* ]]
To
elif [[ $DomoticzState != *"active (running)"* ]]
grtz Ralph
So I changed this
To
grtz Ralph
Odroid N2+ | Raspberry P 3 ModelB | RFXcom | AEOTEC Zwave | Honeywell Lyric T6| Milight | Milighthub (NodeMCU) | SolarEdge | P1 Smart meter USB | KAKU | Wemos D1 (esphome) | Denon | Logitech Harmony
- EdwinK
Installed. Hope it's working.Egregius wrote:This is my version:
Hi G3rard,G3rard wrote:Thanks @K3rryBlue for sharing the script. Works fine on my Ubuntu Server with some small changes.
Would you mind to share your version including these small changes please?
- G3rard
- Target OS: -
Here it is. Just change the folders and Domoticz URL and port to yours and it should work.Caribou wrote: Hi G3rard,
#!/bin/bash
CONFIG=/home/gerard/scripts/domoticz/domoticz_state_checker.txt
STATUS=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://192.168.1.157:8084/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
echo "Domoticz online"
echo "$STATUS"
exit
sleep 5
STATUS2=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://192.168.1.157:8084/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
exit
sleep 5
STATUS3=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://192.168.1.157:8084/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
exit
cp /var/log/domoticz.log /home/gerard/scripts/domoticz/domoticz-$NOW.txt
echo "Domoticz offline"
#You can send a Pushover message here
sudo service domoticz.sh restart
echo "$NOW, Domoticz was offline. Restarted Domoticz...." >> "$CONFIG"
fi
fi
fi
