Page 3 of 6
Re: Python Plugin: Growatt Inverter
Posted: Wednesday 18 March 2020 11:15
by anconakip
Can someone help me? i get an error while using de plugin:
2020-03-18 11:04:49.581 Error: (growatt) 'onStart' failed 'KeyError'.
2020-03-18 11:04:49.581 Error: (growatt) ----> Line 260 in '/home/pi/domoticz/plugins/Domoticz-Growatt-Webserver-Plugin/plugin.py'
2020-03-18 11:04:49.581 Error: (growatt) ----> Line 135 in '/home/pi/domoticz/plugins/Domoticz-Growatt-Webserver-Plugin/plugin.py'
2020-03-18 11:04:49.581 Error: (growatt) ----> Line 349 in '/home/pi/domoticz/plugins/Domoticz-Growatt-Webserver-Plugin/plugin.py'
What to do?
Posted: Friday 20 March 2020 10:04
by sincze
Had the same issue.
- Stopped the plugin
- Removed the Growatt icon (select the icons press red delete button).
- Restarted the plugin.
Posted: Tuesday 14 April 2020 21:05
by sincze
Currently building on expanding the Current Plugin. So much interesting info to find.
However still does not work as expected all the time.
2020-04-14 19:51:35.345 Error: (Growatt-dev) 'onMessage' failed 'KeyError'.
2020-04-14 19:51:35.345 Error: (Growatt-dev) ----> Line 426 in '/home/pi/domoticz/plugins/Domoticz-Growatt-dev/plugin.py', function onMessage
2020-04-14 19:51:35.345 Error: (Growatt-dev) ----> Line 338 in '/home/pi/domoticz/plugins/Domoticz-Growatt-dev/plugin.py', function onMessage
2020-04-14 19:58:35.815 Error: (Growatt-dev) 'onMessage' failed 'KeyError'.
2020-04-14 19:58:35.815 Error: (Growatt-dev) ----> Line 426 in '/home/pi/domoticz/plugins/Domoticz-Growatt-dev/plugin.py', function onMessage
2020-04-14 19:58:35.816 Error: (Growatt-dev) ----> Line 338 in '/home/pi/domoticz/plugins/Domoticz-Growatt-dev/plugin.py', function onMessage
2020-04-14 20:03:35.402 Error: (Growatt-dev) 'onMessage' failed 'KeyError'.
2020-04-14 20:03:35.402 Error: (Growatt-dev) ----> Line 426 in '/home/pi/domoticz/plugins/Domoticz-Growatt-dev/plugin.py', function onMessage
2020-04-14 20:03:35.402 Error: (Growatt-dev) ----> Line 338 in '/home/pi/domoticz/plugins/Domoticz-Growatt-dev/plugin.py', function onMessage
2020-04-14 20:04:35.469 Error: (Growatt-dev) No transport, write directive to 'Growatt Portal API' ignored.
Posted: Saturday 18 April 2020 10:29
by upiter81
How can I get this additional parameters?:
sincze wrote: Tuesday 14 April 2020 21:05 Currently building on expanding the Current Plugin. So much interesting info to find.
Posted: Saturday 18 April 2020 16:22
by sincze
Obtained by calling an additional URL from the Growatt interface.
However after specific time the cookie expires and the data is not updated anymore so that is a big miss.
Seems to be unable for me to fix it at the moment.
2020-04-18 16:16:51.193 (Growatt-dev) HTTP Details (2):
2020-04-18 16:16:51.193 (Growatt-dev) >'Status':'302'
2020-04-18 16:16:51.193 (Growatt-dev) >'Headers':
2020-04-18 16:16:51.193 (Growatt-dev) ---->'Date':'Sat, 18 Apr 2020 14:16:51 GMT'
2020-04-18 16:16:51.193 (Growatt-dev) ---->'Content-Length':'0'
2020-04-18 16:16:51.194 (Growatt-dev) ---->'Connection':'keep-alive'
2020-04-18 16:16:51.194 (Growatt-dev) ---->'Set-Cookie':
2020-04-18 16:16:51.194 (Growatt-dev) --------['JSESSIONID=E5F94E6433C6A154CF8A913123456789; Path=/; HttpOnly']
2020-04-18 16:16:51.194 (Growatt-dev) --------['SERVERID=e86db72cfd4d7e78f9dfe06123456789|123456789|123456789;Path=/']
2020-04-18 16:16:51.194 (Growatt-dev) ---->'Location':'/error.do?errorMess=errorNoLogin'
The following does not catch it so it seems.
 elif (Status == 302):
                Domoticz.Error("Probably no login possible!.")
                Connection.Send(self.cookieRequest())
Maybe need help from @Dnpwwo to fix it :D
Posted: Saturday 18 April 2020 19:09
by MdeBoer
@Sincze, Is it possible to retrieve the "month total"? I'm trying to edit the plugin.py but im stuc on the Device. I edit following pice of code
elif ('powerValue' in apiResponse):
                    current = apiResponse['powerValue']
                    total = apiResponse['totalValue']
                    totalmonth = apiResponse['monthValue']                            # Convert kWh to Wh
                    sValue=str(current)+";"+str( float(total)*1000 )+";"+str(totalmonth)
                    Domoticz.Log("Currently producing: "+str(current)+" Watt. Totall produced: "+str(total)+" kWh in Wh that is: "+str(float(total)*1000)+" Month totall: "+str(totalmonth)+" kWh" )
                    UpdateDevice(Unit=1, nValue=0, sValue=sValue, TimedOut=0)
                    UpdateDevice(Unit=2, nValue=0, sValue=current, TimedOut=0)
                    UpdateDevice(Unit=3, nValue=0, SValue=totalmonth, TimeOut=0)
I also edit the create devices part. That piece works fine, the device is being created. but the device wouldn't be updated. Is there something special whit the update device part?
Posted: Saturday 18 April 2020 20:11
by sincze
MdeBoer wrote: Saturday 18 April 2020 19:09 @Sincze, Is it possible to retrieve the "month total"? I'm trying to edit the plugin.py but im stuc on the Device. I edit following pice of code
mmm. Well I notice this:
[/code]
SValue?? doest that exist? The rest says sValue.
According to my info (but I could be wrong. sValue = &nvalue=0&svalue=COUNTER;USAGE
So it could be your sValue by adding totalmonth is illegal.
Posted: Saturday 18 April 2020 21:05
by MdeBoer
That was an issue, thanks!
The above doesn't work indeed, I made it back to original. (see below) Is there an easy way to get the "month total" in a device?
Edit: I made a mistake, I thought die code above was made to set the data in the string so it can send to the devices. But it's only for the first Device!.
I'm taking a look to the code again. Maybe I a find a way myself.
Posted: Sunday 19 April 2020 11:43
by sincze
MdeBoer wrote: Saturday 18 April 2020 21:05
Nice Job.
Why not create an additional device like a custom sensor to store the month total in?
Stay away from incremental counters as that will work against you.
Posted: Friday 24 April 2020 21:08
by rvandijk
Hi!
Stumbled upon this thread a few days ago. I also have Growatt inverter and was using an energy meter with a s0 connection to get power values into domoticz. Sadly the energy meter broke down last week. So, I started looking if someone already tried to use the API from Growatt itself. And see here...
I got the plugin working in Domoticz on my Synology NAS. Great!
Just a few things I am wondering about:
- Why is the plugin creating two devices? Is it not possible to combine? (For my 'slimme meter' also more values are combined in 1 device)
- Only the totally produced kWH is stored in a device. Is it also possible to story only the day total? (Because I am sending it also to Grafana for nicer graphs and dashboarding). This value is send in the response, example: "todayValue":"13.7"
Could you also share your beta code to get more data like you showed in the screenshots?
Posted: Sunday 26 April 2020 10:48
by sincze
rvandijk wrote: Friday 24 April 2020 21:08 Q: Why is the plugin creating two devices? Is it not possible to combine? (For my 'slimme meter' also more values are combined in 1 device)
A: It should create the follwing devices:
- On/Off
- Watt
- KwH
rvandijk wrote: Friday 24 April 2020 21:08 Q:- Only the totally produced kWH is stored in a device. Is it also possible to story only the day total? (Because I am sending it also to Grafana for nicer graphs and dashboarding). This value is send in the response, example: "todayValue":"13.7"
A: You can do that as that data is available however it will mess up the current counter AS that should be incremental. You can add a device and store it in a custom sensor for example. I just push all received data straight into Influx / Grafana and dit not worry about the daily result as that is stored in Domoticz for me.
rvandijk wrote: Friday 24 April 2020 21:08 Q: Could you also share your beta code to get more data like you showed in the screenshots?
A: It's available in the dev branch. :lol:
Posted: Friday 15 May 2020 15:43
by vandermark1977
I have a new Growatt inverter and the growatt portal works fine. I can login and see all data via server.growatt.com
I added new hardware with your plugin and a few numbers come in but after 2 measurements it is not renewed. This is the log regarding the Growatt plugin:
2020-05-15 15:40:19.982 (Growatt Omvormer) Pushing 'onHeartbeatCallback' on to queue
2020-05-15 15:40:20.014 (Growatt Omvormer) Processing 'onHeartbeatCallback' message
2020-05-15 15:40:20.014 (Growatt Omvormer) Calling message handler 'onHeartbeat'.
2020-05-15 15:40:20.014 (Growatt Omvormer) onHeartbeat called, run again in 3 heartbeats.
2020-05-15 15:40:29.983 (Growatt Omvormer) Pushing 'onHeartbeatCallback' on to queue
2020-05-15 15:40:30.030 (Growatt Omvormer) Processing 'onHeartbeatCallback' message
2020-05-15 15:40:30.030 (Growatt Omvormer) Calling message handler 'onHeartbeat'.
2020-05-15 15:40:30.030 (Growatt Omvormer) onHeartbeat called, run again in 2 heartbeats.
2020-05-15 15:40:39.985 (Growatt Omvormer) Pushing 'onHeartbeatCallback' on to queue
2020-05-15 15:40:39.997 (Growatt Omvormer) Processing 'onHeartbeatCallback' message
2020-05-15 15:40:39.997 (Growatt Omvormer) Calling message handler 'onHeartbeat'.
2020-05-15 15:40:39.997 (Growatt Omvormer) onHeartbeat called, run again in 1 heartbeats.
2020-05-15 15:40:50.167 (Growatt Omvormer) 31 33 3a 34 30 3a 35 30 20 47 4d 54 0d 0a 43 6f 6e 74 65 6e 13:40:50.GMT..Conten
2020-05-15 15:40:50.167 (Growatt Omvormer) 74 2d 54 79 70 65 3a 20 61 70 70 6c 69 63 61 74 69 6f 6e 2f t-Type:.application/
2020-05-15 15:40:50.167 (Growatt Omvormer) 6a 73 6f 6e 3b 63 68 61 72 73 65 74 3d 55 54 46 2d 38 0d 0a json;charset=UTF-8..
2020-05-15 15:40:50.167 (Growatt Omvormer) 53 65 74 2d 43 6f 6f 6b 69 65 3a 20 4a 53 45 53 53 49 4f 4e Set-Cookie:.JSESSION
2020-05-15 15:40:50.167 (Growatt Omvormer) 49 44 3d 31 33 38 46 45 45 44 45 36 35 41 34 38 43 39 35 37 ID=138FEEDE65A48C957
2020-05-15 15:40:50.167 (Growatt Omvormer) 32 34 32 39 30 35 38 34 42 31 33 35 37 46 36 3b 20 50 61 74 24290584B1357F6;.Pat
2020-05-15 15:40:50.167 (Growatt Omvormer) 68 3d 2f 3b 20 48 74 74 70 4f 6e 6c 79 0d 0a 53 65 74 2d 43 h=/;.HttpOnly..Set-C
2020-05-15 15:40:50.167 (Growatt Omvormer) 6f 6f 6b 69 65 3a 20 53 45 52 56 45 52 49 44 3d 31 37 36 38 ookie:.SERVERID=1768
2020-05-15 15:40:50.167 (Growatt Omvormer) 62 62 32 33 31 35 61 64 36 61 64 30 61 31 65 36 63 36 62 39 bb2315ad6ad0a1e6c6b9
2020-05-15 15:40:50.167 (Growatt Omvormer) 30 30 63 32 61 63 62 36 7c 31 35 38 39 35 35 30 30 35 30 7c 00c2acb6|1589550050|
2020-05-15 15:40:50.167 (Growatt Omvormer) 31 35 38 39 35 35 30 30 35 30 3b 50 61 74 68 3d 2f 0d 0a 58 1589550050;Path=/..X
2020-05-15 15:40:50.167 (Growatt Omvormer) 2d 43 61 63 68 65 3a 20 4d 49 53 53 20 66 72 6f 6d 20 73 6f -Cache:.MISS.from.so
2020-05-15 15:40:50.168 (Growatt Omvormer) 6c 2d 70 72 6f 64 2d 66 69 6c 74 65 72 2d 30 35 2d 64 72 6f l-prod-filter-05-dro
2020-05-15 15:40:50.168 (Growatt Omvormer) 2e 73 6f 6c 63 6f 6e 2e 6e 6c 0d 0a 43 6f 6e 74 65 6e 74 2d .solcon.nl..Content-
2020-05-15 15:40:50.168 (Growatt Omvormer) 4c 65 6e 67 74 68 3a 20 31 30 33 39 0d 0a 43 6f 6e 6e 65 63 Length:.1039..Connec
2020-05-15 15:40:50.168 (Growatt Omvormer) 74 69 6f 6e 3a 20 43 6c 6f 73 65 0d 0a 0d 0a 7b 22 62 61 63 tion:.Close....{"bac
2020-05-15 15:40:50.168 (Growatt Omvormer) 6b 22 3a 7b 22 69 73 4f 70 65 6e 44 65 76 69 63 65 4c 69 73 k":{"isOpenDeviceLis
2020-05-15 15:40:50.168 (Growatt Omvormer) 74 22 3a 31 2c 22 69 73 4f 70 65 6e 44 65 76 69 63 65 50 61 t":1,"isOpenDevicePa
2020-05-15 15:40:50.168 (Growatt Omvormer) 72 61 6d 73 22 3a 30 2c 22 64 61 74 61 22 3a 5b 7b 22 70 6c rams":0,"data":[{"pl
2020-05-15 15:40:50.168 (Growatt Omvormer) 61 6e 74 4e 61 6d 65 22 3a 22 4d 6f 75 74 65 72 69 6a 20 32 antName":"Mouterij.2
2020-05-15 15:40:50.168 (Growatt Omvormer) 30 20 57 61 67 65 6e 69 6e 67 65 6e 22 2c 22 70 6c 61 6e 74 0.Wageningen","plant
2020-05-15 15:40:50.168 (Growatt Omvormer) 49 64 22 3a 22 33 30 36 34 33 31 22 7d 5d 2c 22 73 65 72 76 Id":"306431"}],"serv
2020-05-15 15:40:50.168 (Growatt Omvormer) 69 63 65 22 3a 22 31 22 2c 22 71 75 61 6c 69 74 79 22 3a 22 ice":"1","quality":"
2020-05-15 15:40:50.168 (Growatt Omvormer) 30 22 2c 22 69 73 4f 70 65 6e 53 6d 61 72 74 46 61 6d 69 6c 0","isOpenSmartFamil
2020-05-15 15:40:50.168 (Growatt Omvormer) 79 22 3a 30 2c 22 74 6f 74 61 6c 44 61 74 61 22 3a 7b 7d 2c y":0,"totalData":{},
2020-05-15 15:40:50.168 (Growatt Omvormer) 22 73 75 63 63 65 73 73 22 3a 74 72 75 65 2c 22 75 73 65 72 "success":true,"user
2020-05-15 15:40:50.168 (Growatt Omvormer) 22 3a 7b 22 75 69 64 22 3a 22 22 2c 22 75 73 65 72 4c 61 6e ":{"uid":"","userLan
2020-05-15 15:40:50.168 (Growatt Omvormer) 67 75 61 67 65 22 3a 22 68 6f 22 2c 22 69 6e 76 65 72 74 65 guage":"ho","inverte
2020-05-15 15:40:50.168 (Growatt Omvormer) 72 47 72 6f 75 70 22 3a 5b 5d 2c 22 74 69 6d 65 5a 6f 6e 65 rGroup":[],"timeZone
2020-05-15 15:40:50.168 (Growatt Omvormer) 22 3a 31 2c 22 6c 6e 67 22 3a 22 22 2c 22 64 61 74 61 41 63 ":1,"lng":"","dataAc
2020-05-15 15:40:50.168 (Growatt Omvormer) 71 4c 69 73 74 22 3a 5b 5d 2c 22 74 79 70 65 22 3a 30 2c 22 qList":[],"type":0,"
2020-05-15 15:40:50.168 (Growatt Omvormer) 70 61 73 73 77 6f 72 64 22 3a 22 37 64 33 39 34 61 61 32 38 password":"7d394aa28
2020-05-15 15:40:50.168 (Growatt Omvormer) 38 39 38 34 61 38 30 64 66 33 61 66 64 61 34 63 34 35 36 35 8984a80df3afda4c4565
2020-05-15 15:40:50.168 (Growatt Omvormer) 63 36 66 22 2c 22 69 73 56 61 6c 69 50 68 6f 6e 65 22 3a 30 c6f","isValiPhone":0
2020-05-15 15:40:50.168 (Growatt Omvormer) 2c 22 6b 69 6e 64 22 3a 30 2c 22 6d 61 69 6c 4e 6f 74 69 63 ,"kind":0,"mailNotic
2020-05-15 15:40:50.168 (Growatt Omvormer) 65 22 3a 74 72 75 65 2c 22 69 64 22 3a 34 37 36 38 34 32 2c e":true,"id":476842,
2020-05-15 15:40:50.169 (Growatt Omvormer) 22 6c 61 73 74 4c 6f 67 69 6e 49 70 22 3a 22 31 30 30 2e 31 "lastLoginIp":"100.1
2020-05-15 15:40:50.169 (Growatt Omvormer) 32 30 2e 39 36 2e 39 22 2c 22 70 68 6f 6e 65 4e 75 6d 22 3a 20.96.9","phoneNum":
2020-05-15 15:40:50.169 (Growatt Omvormer) 22 2b 33 31 36 32 34 36 32 32 30 37 39 22 2c 22 61 70 70 72 "+31624622079","appr
2020-05-15 15:40:50.169 (Growatt Omvormer) 6f 76 65 64 22 3a 66 61 6c 73 65 2c 22 61 72 65 61 22 3a 22 oved":false,"area":"
2020-05-15 15:40:50.169 (Growatt Omvormer) 45 75 72 6f 70 65 22 2c 22 73 6d 73 4e 6f 74 69 63 65 22 3a Europe","smsNotice":
2020-05-15 15:40:50.169 (Growatt Omvormer) 66 61 6c 73 65 2c 22 69 73 41 67 65 6e 74 22 3a 30 2c 22 74 false,"isAgent":0,"t
2020-05-15 15:40:50.169 (Growatt Omvormer) 6f 6b 65 6e 22 3a 22 22 2c 22 6e 69 63 6b 4e 61 6d 65 22 3a oken":"","nickName":
2020-05-15 15:40:50.169 (Growatt Omvormer) 22 22 2c 22 70 61 72 65 6e 74 55 73 65 72 49 64 22 3a 30 2c "","parentUserId":0,
2020-05-15 15:40:50.169 (Growatt Omvormer) 22 63 75 73 74 6f 6d 65 72 43 6f 64 65 22 3a 22 22 2c 22 63 "customerCode":"","c
2020-05-15 15:40:50.169 (Growatt Omvormer) 6f 75 6e 72 74 79 22 3a 22 4e 65 74 68 65 72 6c 61 6e 64 73 ounrty":"Netherlands
2020-05-15 15:40:50.169 (Growatt Omvormer) 22 2c 22 69 73 50 68 6f 6e 65 4e 75 6d 52 65 67 22 3a 30 2c ","isPhoneNumReg":0,
2020-05-15 15:40:50.169 (Growatt Omvormer) 22 63 72 65 61 74 65 44 61 74 65 22 3a 22 32 30 32 30 2d 30 "createDate":"2020-0
2020-05-15 15:40:50.169 (Growatt Omvormer) 35 2d 31 34 20 32 30 3a 35 32 3a 32 36 22 2c 22 72 69 67 68 5-14.20:52:26","righ
2020-05-15 15:40:50.169 (Growatt Omvormer) 74 6c 65 76 65 6c 22 3a 31 2c 22 61 70 70 54 79 70 65 22 3a tlevel":1,"appType":
2020-05-15 15:40:50.169 (Growatt Omvormer) 22 63 22 2c 22 73 65 72 76 65 72 55 72 6c 22 3a 22 22 2c 22 "c","serverUrl":"","
2020-05-15 15:40:50.169 (Growatt Omvormer) 6c 61 74 22 3a 22 22 2c 22 6c 61 73 74 4c 6f 67 69 6e 54 69 lat":"","lastLoginTi
2020-05-15 15:40:50.169 (Growatt Omvormer) 6d 65 22 3a 22 32 30 32 30 2d 30 35 2d 31 35 20 32 31 3a 34 me":"2020-05-15.21:4
2020-05-15 15:40:50.169 (Growatt Omvormer) 30 3a 35 30 22 2c 22 72 6f 6c 65 49 64 22 3a 30 2c 22 65 6e 0:50","roleId":0,"en
2020-05-15 15:40:50.169 (Growatt Omvormer) 61 62 6c 65 64 22 3a 74 72 75 65 2c 22 61 67 65 6e 74 43 6f abled":true,"agentCo
2020-05-15 15:40:50.169 (Growatt Omvormer) 64 65 22 3a 22 41 4e 4a 57 32 22 2c 22 69 6e 76 65 72 74 65 de":"ANJW2","inverte
2020-05-15 15:40:50.169 (Growatt Omvormer) 72 4c 69 73 74 22 3a 5b 5d 2c 22 69 73 56 61 6c 69 45 6d 61 rList":[],"isValiEma
2020-05-15 15:40:50.169 (Growatt Omvormer) 69 6c 22 3a 30 2c 22 61 63 63 6f 75 6e 74 4e 61 6d 65 22 3a il":0,"accountName":
2020-05-15 15:40:50.169 (Growatt Omvormer) 22 76 61 6e 64 65 72 6d 61 72 6b 22 2c 22 65 6d 61 69 6c 22 "33","email"
2020-05-15 15:40:50.169 (Growatt Omvormer) 3a 22 62 61 72 74 2e 76 61 6e 64 65 72 6d 61 72 6b 40 67 6d :"33@gm
2020-05-15 15:40:50.170 (Growatt Omvormer) 61 69 6c 2e 63 6f 6d 22 2c 22 63 6f 6d 70 61 6e 79 22 3a 22 ail.com","company":"
2020-05-15 15:40:50.170 (Growatt Omvormer) 22 2c 22 61 63 74 69 76 65 4e 61 6d 65 22 3a 22 42 61 72 74 ","activeName":"33
2020-05-15 15:40:50.170 (Growatt Omvormer) 20 76 61 6e 20 64 65 72 20 4d 61 72 6b 22 2c 22 63 6f 64 65 .33","code
2020-05-15 15:40:50.170 (Growatt Omvormer) 49 6e 64 65 78 22 3a 31 2c 22 61 70 70 41 6c 69 61 73 22 3a Index":1,"appAlias":
2020-05-15 15:40:50.170 (Growatt Omvormer) 22 76 61 6e 64 65 72 6d 61 72 6b 22 2c 22 69 73 42 69 67 43 "33","isBigC
2020-05-15 15:40:50.170 (Growatt Omvormer) 75 73 74 6f 6d 65 72 22 3a 30 2c 22 6e 6f 74 69 63 65 54 79 ustomer":0,"noticeTy
2020-05-15 15:40:50.170 (Growatt Omvormer) 70 65 22 3a 22 22 7d 2c 22 6d 73 67 22 3a 22 22 2c 22 61 70 pe":""},"msg":"","ap
2020-05-15 15:40:50.170 (Growatt Omvormer) 70 5f 63 6f 64 65 22 3a 22 31 35 22 7d 7d .. .. .. .. .. .. p_code":"15"}}
2020-05-15 15:40:50.170 (Growatt Omvormer) Pushing 'onMessageCallback' on to queue
2020-05-15 15:40:50.170 (Growatt Omvormer) Processing 'DisconnectedEvent' message
2020-05-15 15:40:50.170 (Growatt Omvormer) Disconnect event received for 'server-api.growatt.com:80'.
2020-05-15 15:40:50.170 (Growatt Omvormer) Pushing 'onDisconnectCallback' on to queue
2020-05-15 15:40:50.170 (Growatt Omvormer) Processing 'onMessageCallback' message
2020-05-15 15:40:50.170 (Growatt Omvormer) Calling message handler 'onMessage'.
2020-05-15 15:40:50.170 (Growatt Omvormer) HTTP Details (3):
2020-05-15 15:40:50.170 (Growatt Omvormer) >'Status':'200'
2020-05-15 15:40:50.171 (Growatt Omvormer) >'Headers':
2020-05-15 15:40:50.171 (Growatt Omvormer) ---->'Date':'Fri, 15 May 2020 13:40:50 GMT'
2020-05-15 15:40:50.171 (Growatt Omvormer) ---->'Content-Type':'application/json;charset=UTF-8'
2020-05-15 15:40:50.171 (Growatt Omvormer) ---->'Set-Cookie':
2020-05-15 15:40:50.171 (Growatt Omvormer) --------['JSESSIONID=138FEEDE65A48C95724290584B1357F6; Path=/; HttpOnly']
2020-05-15 15:40:50.171 (Growatt Omvormer) --------['SERVERID=1768bb2315ad6ad0a1e6c6b900c2acb6|1589550050|1589550050;Path=/']
2020-05-15 15:40:50.171 (Growatt Omvormer) ---->'X-Cache':'MISS from sol-prod-filter-05-dro.solcon.nl'
2020-05-15 15:40:50.171 (Growatt Omvormer) ---->'Content-Length':'1039'
2020-05-15 15:40:50.171 (Growatt Omvormer) ---->'Connection':'Close'
2020-05-15 15:40:50.171 (Growatt Omvormer) >'Data':'b'{"back":{"isOpenDeviceList":1,"isOpenDeviceParams":0,"data":[{"plantName":"33","plantId":"306431"}],"service":"1","quality":"0","isOpenSmartFamily":0,"totalData":{},"success":true,"user":{"uid":"","userLanguage":"ho","inverterGroup":[],"timeZone":1,"lng":"","dataAcqList":[],"type":0,"password":"7d394aa288984a80df3afda4c4565c6f","isValiPhone":0,"kind":0,"mailNotice":true,"id":476842,"lastLoginIp":"100.120.96.9","phoneNum":"+31624622079","approved":false,"area":"Europe","smsNotice":false,"isAgent":0,"token":"","nickName":"","parentUserId":0,"customerCode":"","counrty":"Netherlands","isPhoneNumReg":0,"createDate":"2020-05-14 20:52:26","rightlevel":1,"appType":"c","serverUrl":"","lat":"","lastLoginTime":"2020-05-15 21:40:50","roleId":0,"enabled":true,"agentCode":"ANJW2","inverterList":[],"isValiEmail":0,"accountName":"33","email":"33","company":"","activeName":"33","codeIndex":1,"appAlias":"vandermark","isBigCustomer":0,"noticeType":""},"msg":"","app_code":"15"}}''
2020-05-15 15:40:50.172 (Growatt Omvormer) Retrieved following json: {"back": {"isOpenDeviceList": 1, "isOpenDeviceParams": 0, "data": [{"plantName": "Mouterij 20 Wageningen", "plantId": "306431"}], "service": "1", "quality": "0", "isOpenSmartFamily": 0, "totalData": {}, "success": true, "user": {"uid": "", "userLanguage": "ho", "inverterGroup": [], "timeZone": 1, "lng": "", "dataAcqList": [], "type": 0, "password": "7d394aa288984a80df3afda4c4565c6f", "isValiPhone": 0, "kind": 0, "mailNotice": true, "id": 476842, "lastLoginIp": "100.120.96.9", "phoneNum": "+31624622079", "approved": false, "area": "Europe", "smsNotice": false, "isAgent": 0, "token": "", "nickName": "", "parentUserId": 0, "customerCode": "", "counrty": "Netherlands", "isPhoneNumReg": 0, "createDate": "2020-05-14 20:52:26", "rightlevel": 1, "appType": "c", "serverUrl": "", "lat": "", "lastLoginTime": "2020-05-15 21:40:50", "roleId": 0, "enabled": true, "agentCode": "ANJW2", "inverterList": [], "isValiEmail": 0, "accountName": "vandermark", "email": "[email protected]", "company": "", "activeName": "Bart van der Mark", "codeIndex": 1, "appAlias": "vandermark", "isBigCustomer": 0, "noticeType": ""}, "msg": "", "app_code": "15"}}
2020-05-15 15:40:50.172 (Growatt Omvormer) Login Succesfull
2020-05-15 15:40:50.172 (Growatt Omvormer) Plant ID: 306431 was found
2020-05-15 15:40:50.172 (Growatt Omvormer) Analyzing Data (3):
2020-05-15 15:40:50.172 (Growatt Omvormer) ---> Headers found
2020-05-15 15:40:50.172 (Growatt Omvormer) ---> Process Cookie Started
2020-05-15 15:40:50.172 (Growatt Omvormer) ---> SessionID found: 138FEEDE65A48C95724290584B1357F6
2020-05-15 15:40:50.172 (Growatt Omvormer) ---> ServerID found: 1768bb2315ad6ad0a1e6c6b900c2acb6|1589550050|1589550050
2020-05-15 15:40:50.172 (Growatt Omvormer) Request Data with retrieved cookie!
2020-05-15 15:40:50.172 (Growatt Omvormer) Pushing 'WriteDirective' on to queue
2020-05-15 15:40:50.172 (Growatt Omvormer) Processing 'onDisconnectCallback' message
2020-05-15 15:40:50.172 (Growatt Omvormer) Calling message handler 'onDisconnect'.
2020-05-15 15:40:50.172 (Growatt Omvormer) onDisconnect called for connection to: server-api.growatt.com:80
2020-05-15 15:40:50.173 (Growatt Omvormer) Processing 'WriteDirective' message
2020-05-15 15:40:50.173 Error: (Growatt Omvormer) No transport, write directive to 'HTTP Test' ignored.
2020-05-15 15:40:59.989 (Growatt Omvormer) Pushing 'onHeartbeatCallback' on to queue
2020-05-15 15:41:00.038 (Growatt Omvormer) Processing 'onHeartbeatCallback' message
2020-05-15 15:41:00.038 (Growatt Omvormer) Calling message handler 'onHeartbeat'.
2020-05-15 15:41:00.039 (Growatt Omvormer) onHeartbeat called, run again in 5 heartbeats.
2020-05-15 15:41:09.990 (Growatt Omvormer) Pushing 'onHeartbeatCallback' on to queue
2020-05-15 15:41:10.005 (Growatt Omvormer) Processing 'onHeartbeatCallback' message
2020-05-15 15:41:10.005 (Growatt Omvormer) Calling message handler 'onHeartbeat'.
2020-05-15 15:41:10.005 (Growatt Omvormer) onHeartbeat called, run again in 4 heartbeats.
Can i do anything about it?
Posted: Saturday 16 May 2020 11:59
by rick8245
Same issue here.
Since yesterday fri 15 may at 13:40 I do not get any updates anymore.
In domoticz the Growatt Inverter is red.
I changed the Ip adres because I setup my raspbian for wifi while it first was wired.
I cannot find any ip address in the PHP or growatt py which I should adapt.
Everything works fine except Growatt-Inverter
Anybody the same issue ??
Posted: Saturday 16 May 2020 15:11
by vandermark1977
I have further investigated and still don't know what causes the problem. The strange thing is that about every hour one measurement comes through. See image below in Domoticz:
On my 'Homey' I installed the 'zonnepanelen' app which can also connect to server.growatt.com with username and password. This app works fine and i get new data every 5 minutes.
@sincze , perhaps you can check the code of this Homey app? Connection to Growatt inverter with just username and password works fine right now.
URL for the Github of this app is: https://github.com/DiedB/Homey-SolarPanels
Growatt code: https://github.com/DiedB/Homey-SolarPan ... rs/growatt
Recently a error for Growatt regarding cookies was fixed:
        const error = 'Could not login to Growatt server'
        const response = await this.request('POST', loginURL, body, error)
        if (response.body.back.success) {
            this.cookies = response.headers.getAll('Set-Cookie').map(directive => directive.split(';')[0]).join(';')
            this.plants = response.body.back.data
            this.cookies = response.headers.raw()['set-cookie'].map(directive => directive.split(';')[0]).join(';');
            this.plants = response.body.back.data;
        } else {
            throw new Error(error)
Again the full log regarding the Growatt inverter (some personal details are now 'xx'):
2020-05-16 15:25:12.873 (Growatt) 31 33 3a 32 35 3a 31 32 20 47 4d 54 0d 0a 43 6f 6e 74 65 6e 13:25:12.GMT..Conten
2020-05-16 15:25:12.873 (Growatt) 74 2d 54 79 70 65 3a 20 61 70 70 6c 69 63 61 74 69 6f 6e 2f t-Type:.application/
2020-05-16 15:25:12.873 (Growatt) 6a 73 6f 6e 3b 63 68 61 72 73 65 74 3d 55 54 46 2d 38 0d 0a json;charset=UTF-8..
2020-05-16 15:25:12.873 (Growatt) 53 65 74 2d 43 6f 6f 6b 69 65 3a 20 4a 53 45 53 53 49 4f 4e Set-Cookie:.JSESSION
2020-05-16 15:25:12.873 (Growatt) 49 44 3d 34 43 33 36 41 46 31 30 38 38 30 39 45 45 44 39 42 ID=4C36AF108809EED9B
2020-05-16 15:25:12.873 (Growatt) 41 32 41 30 38 41 38 30 38 38 44 31 33 44 35 3b 20 50 61 74 A2A08A8088D13D5;.Pat
2020-05-16 15:25:12.873 (Growatt) 68 3d 2f 3b 20 48 74 74 70 4f 6e 6c 79 0d 0a 53 65 74 2d 43 h=/;.HttpOnly..Set-C
2020-05-16 15:25:12.873 (Growatt) 6f 6f 6b 69 65 3a 20 53 45 52 56 45 52 49 44 3d 65 38 36 64 ookie:.SERVERID=e86d
2020-05-16 15:25:12.873 (Growatt) 62 37 32 63 66 64 34 64 37 65 37 38 66 39 64 66 65 30 36 39 b72cfd4d7e78f9dfe069
2020-05-16 15:25:12.873 (Growatt) 61 66 35 38 39 32 32 36 7c 31 35 38 39 36 33 35 35 31 32 7c af589226|1589635512|
2020-05-16 15:25:12.873 (Growatt) 31 35 38 39 36 33 35 35 31 32 3b 50 61 74 68 3d 2f 0d 0a 58 1589635512;Path=/..X
2020-05-16 15:25:12.873 (Growatt) 2d 43 61 63 68 65 3a 20 4d 49 53 53 20 66 72 6f 6d 20 73 6f -Cache:.MISS.from.so
2020-05-16 15:25:12.873 (Growatt) 6c 2d 70 72 6f 64 2d 66 69 6c 74 65 72 2d 30 35 2d 64 72 6f l-prod-filter-05-dro
2020-05-16 15:25:12.873 (Growatt) 2e 73 6f 6c 63 6f 6e 2e 6e 6c 0d 0a 43 6f 6e 74 65 6e 74 2d .solcon.nl..Content-
2020-05-16 15:25:12.873 (Growatt) 4c 65 6e 67 74 68 3a 20 31 30 34 30 0d 0a 43 6f 6e 6e 65 63 Length:.1040..Connec
2020-05-16 15:25:12.873 (Growatt) 74 69 6f 6e 3a 20 43 6c 6f 73 65 0d 0a 0d 0a 7b 22 62 61 63 tion:.Close....{"bac
2020-05-16 15:25:12.873 (Growatt) 6b 22 3a 7b 22 69 73 4f 70 65 6e 44 65 76 69 63 65 4c 69 73 k":{"isOpenDeviceLis
2020-05-16 15:25:12.873 (Growatt) 74 22 3a 31 2c 22 69 73 4f 70 65 6e 44 65 76 69 63 65 50 61 t":1,"isOpenDevicePa
2020-05-16 15:25:12.873 (Growatt) 72 61 6d 73 22 3a 30 2c 22 64 61 74 61 22 3a 5b 7b 22 70 6c rams":0,"data":[{"pl
2020-05-16 15:25:12.873 (Growatt) 61 6e 74 4e 61 6d 65 22 3a 22 4d 6f 75 74 65 72 69 6a 20 32 antName":"xx
2020-05-16 15:25:12.873 (Growatt) 30 20 57 61 67 65 6e 69 6e 67 65 6e 22 2c 22 70 6c 61 6e 74 0.xx","plant
2020-05-16 15:25:12.873 (Growatt) 49 64 22 3a 22 33 30 36 34 33 31 22 7d 5d 2c 22 73 65 72 76 Id":"xx"}],"serv
2020-05-16 15:25:12.873 (Growatt) 69 63 65 22 3a 22 31 22 2c 22 71 75 61 6c 69 74 79 22 3a 22 ice":"1","quality":"
2020-05-16 15:25:12.873 (Growatt) 30 22 2c 22 69 73 4f 70 65 6e 53 6d 61 72 74 46 61 6d 69 6c 0","isOpenSmartFamil
2020-05-16 15:25:12.873 (Growatt) 79 22 3a 30 2c 22 74 6f 74 61 6c 44 61 74 61 22 3a 7b 7d 2c y":0,"totalData":{},
2020-05-16 15:25:12.873 (Growatt) 22 73 75 63 63 65 73 73 22 3a 74 72 75 65 2c 22 75 73 65 72 "success":true,"user
2020-05-16 15:25:12.873 (Growatt) 22 3a 7b 22 75 69 64 22 3a 22 22 2c 22 75 73 65 72 4c 61 6e ":{"uid":"","userLan
2020-05-16 15:25:12.873 (Growatt) 67 75 61 67 65 22 3a 22 68 6f 22 2c 22 69 6e 76 65 72 74 65 guage":"ho","inverte
2020-05-16 15:25:12.873 (Growatt) 72 47 72 6f 75 70 22 3a 5b 5d 2c 22 74 69 6d 65 5a 6f 6e 65 rGroup":[],"timeZone
2020-05-16 15:25:12.873 (Growatt) 22 3a 31 2c 22 6c 6e 67 22 3a 22 22 2c 22 64 61 74 61 41 63 ":1,"lng":"","dataAc
2020-05-16 15:25:12.873 (Growatt) 71 4c 69 73 74 22 3a 5b 5d 2c 22 74 79 70 65 22 3a 30 2c 22 qList":[],"type":0,"
2020-05-16 15:25:12.873 (Growatt) 70 61 73 73 77 6f 72 64 22 3a 22 37 64 33 39 34 61 61 32 38 password":"7d394aa28
2020-05-16 15:25:12.873 (Growatt) 38 39 38 34 61 38 30 64 66 33 61 66 64 61 34 63 34 35 36 35 8984a80df3afda4c4565
2020-05-16 15:25:12.873 (Growatt) 63 36 66 22 2c 22 69 73 56 61 6c 69 50 68 6f 6e 65 22 3a 30 c6f","isValiPhone":0
2020-05-16 15:25:12.873 (Growatt) 2c 22 6b 69 6e 64 22 3a 30 2c 22 6d 61 69 6c 4e 6f 74 69 63 ,"kind":0,"mailNotic
2020-05-16 15:25:12.873 (Growatt) 65 22 3a 74 72 75 65 2c 22 69 64 22 3a 34 37 36 38 34 32 2c e":true,"id":476842,
2020-05-16 15:25:12.873 (Growatt) 22 6c 61 73 74 4c 6f 67 69 6e 49 70 22 3a 22 31 30 30 2e 31 "lastLoginIp":"100.1
2020-05-16 15:25:12.873 (Growatt) 32 30 2e 39 36 2e 32 34 22 2c 22 70 68 6f 6e 65 4e 75 6d 22 20.96.24","phoneNum"
2020-05-16 15:25:12.873 (Growatt) 3a 22 2b 33 31 36 32 34 36 32 32 30 37 39 22 2c 22 61 70 70 :"xx","app
2020-05-16 15:25:12.873 (Growatt) 72 6f 76 65 64 22 3a 66 61 6c 73 65 2c 22 61 72 65 61 22 3a roved":false,"area":
2020-05-16 15:25:12.874 (Growatt) 22 45 75 72 6f 70 65 22 2c 22 73 6d 73 4e 6f 74 69 63 65 22 "Europe","smsNotice"
2020-05-16 15:25:12.874 (Growatt) 3a 66 61 6c 73 65 2c 22 69 73 41 67 65 6e 74 22 3a 30 2c 22 :false,"isAgent":0,"
2020-05-16 15:25:12.874 (Growatt) 74 6f 6b 65 6e 22 3a 22 22 2c 22 6e 69 63 6b 4e 61 6d 65 22 token":"","nickName"
2020-05-16 15:25:12.874 (Growatt) 3a 22 22 2c 22 70 61 72 65 6e 74 55 73 65 72 49 64 22 3a 30 :"","parentUserId":0
2020-05-16 15:25:12.874 (Growatt) 2c 22 63 75 73 74 6f 6d 65 72 43 6f 64 65 22 3a 22 22 2c 22 ,"customerCode":"","
2020-05-16 15:25:12.874 (Growatt) 63 6f 75 6e 72 74 79 22 3a 22 4e 65 74 68 65 72 6c 61 6e 64 counrty":"Netherland
2020-05-16 15:25:12.874 (Growatt) 73 22 2c 22 69 73 50 68 6f 6e 65 4e 75 6d 52 65 67 22 3a 30 s","isPhoneNumReg":0
2020-05-16 15:25:12.874 (Growatt) 2c 22 63 72 65 61 74 65 44 61 74 65 22 3a 22 32 30 32 30 2d ,"createDate":"2020-
2020-05-16 15:25:12.874 (Growatt) 30 35 2d 31 34 20 32 30 3a 35 32 3a 32 36 22 2c 22 72 69 67 05-14.20:52:26","rig
2020-05-16 15:25:12.874 (Growatt) 68 74 6c 65 76 65 6c 22 3a 31 2c 22 61 70 70 54 79 70 65 22 htlevel":1,"appType"
2020-05-16 15:25:12.874 (Growatt) 3a 22 63 22 2c 22 73 65 72 76 65 72 55 72 6c 22 3a 22 22 2c :"c","serverUrl":"",
2020-05-16 15:25:12.874 (Growatt) 22 6c 61 74 22 3a 22 22 2c 22 6c 61 73 74 4c 6f 67 69 6e 54 "lat":"","lastLoginT
2020-05-16 15:25:12.874 (Growatt) 69 6d 65 22 3a 22 32 30 32 30 2d 30 35 2d 31 36 20 32 31 3a ime":"2020-05-16.21:
2020-05-16 15:25:12.874 (Growatt) 32 35 3a 31 32 22 2c 22 72 6f 6c 65 49 64 22 3a 30 2c 22 65 25:12","roleId":0,"e
2020-05-16 15:25:12.874 (Growatt) 6e 61 62 6c 65 64 22 3a 74 72 75 65 2c 22 61 67 65 6e 74 43 nabled":true,"agentC
2020-05-16 15:25:12.874 (Growatt) 6f 64 65 22 3a 22 41 4e 4a 57 32 22 2c 22 69 6e 76 65 72 74 ode":"ANJW2","invert
2020-05-16 15:25:12.874 (Growatt) 65 72 4c 69 73 74 22 3a 5b 5d 2c 22 69 73 56 61 6c 69 45 6d erList":[],"isValiEm
2020-05-16 15:25:12.874 (Growatt) 61 69 6c 22 3a 30 2c 22 61 63 63 6f 75 6e 74 4e 61 6d 65 22 ail":0,"accountName"
2020-05-16 15:25:12.874 (Growatt) 3a 22 76 61 6e 64 65 72 6d 61 72 6b 22 2c 22 65 6d 61 69 6c :"xx","email
2020-05-16 15:25:12.874 (Growatt) 22 3a 22 62 61 72 74 2e 76 61 6e 64 65 72 6d 61 72 6b 40 67 ":"xx.xx@g
2020-05-16 15:25:12.874 (Growatt) 6d 61 69 6c 2e 63 6f 6d 22 2c 22 63 6f 6d 70 61 6e 79 22 3a mail.com","company":
2020-05-16 15:25:12.874 (Growatt) 22 22 2c 22 61 63 74 69 76 65 4e 61 6d 65 22 3a 22 42 61 72 "","activeName":"xx
2020-05-16 15:25:12.874 (Growatt) 74 20 76 61 6e 20 64 65 72 20 4d 61 72 6b 22 2c 22 63 6f 64 t.xx.xx","cod
2020-05-16 15:25:12.874 (Growatt) 65 49 6e 64 65 78 22 3a 31 2c 22 61 70 70 41 6c 69 61 73 22 eIndex":1,"appAlias"
2020-05-16 15:25:12.874 (Growatt) 3a 22 76 61 6e 64 65 72 6d 61 72 6b 22 2c 22 69 73 42 69 67 :"xx","isBig
2020-05-16 15:25:12.874 (Growatt) 43 75 73 74 6f 6d 65 72 22 3a 30 2c 22 6e 6f 74 69 63 65 54 Customer":0,"noticeT
2020-05-16 15:25:12.874 (Growatt) 79 70 65 22 3a 22 22 7d 2c 22 6d 73 67 22 3a 22 22 2c 22 61 ype":""},"msg":"","a
2020-05-16 15:25:12.874 (Growatt) 70 70 5f 63 6f 64 65 22 3a 22 31 35 22 7d 7d .. .. .. .. .. pp_code":"15"}}
2020-05-16 15:25:12.874 (Growatt) Pushing 'onMessageCallback' on to queue
2020-05-16 15:25:12.874 (Growatt) Processing 'DisconnectedEvent' message
2020-05-16 15:25:12.874 (Growatt) Disconnect event received for 'server-api.growatt.com:80'.
2020-05-16 15:25:12.874 (Growatt) Pushing 'onDisconnectCallback' on to queue
2020-05-16 15:25:12.874 (Growatt) Processing 'onMessageCallback' message
2020-05-16 15:25:12.874 (Growatt) Calling message handler 'onMessage'.
2020-05-16 15:25:12.874 (Growatt) HTTP Details (3):
2020-05-16 15:25:12.874 (Growatt) >'Status':'200'
2020-05-16 15:25:12.874 (Growatt) >'Headers':
2020-05-16 15:25:12.874 (Growatt) ---->'Date':'Sat, 16 May 2020 13:25:12 GMT'
2020-05-16 15:25:12.874 (Growatt) ---->'Content-Type':'application/json;charset=UTF-8'
2020-05-16 15:25:12.874 (Growatt) ---->'Set-Cookie':
2020-05-16 15:25:12.874 (Growatt) --------['JSESSIONID=4C36AF108809EED9BA2A08A8088D13D5; Path=/; HttpOnly']
2020-05-16 15:25:12.874 (Growatt) --------['SERVERID=e86db72cfd4d7e78f9dfe069af589226|1589635512|1589635512;Path=/']
2020-05-16 15:25:12.874 (Growatt) ---->'X-Cache':'MISS from sol-prod-filter-05-dro.solcon.nl'
2020-05-16 15:25:12.874 (Growatt) ---->'Content-Length':'1040'
2020-05-16 15:25:12.874 (Growatt) ---->'Connection':'Close'
2020-05-16 15:25:12.874 (Growatt) >'Data':'b'{"back":{"isOpenDeviceList":1,"isOpenDeviceParams":0,"data":[{"plantName":"xx xx","plantId":"306431"}],"service":"1","quality":"0","isOpenSmartFamily":0,"totalData":{},"success":true,"user":{"uid":"","userLanguage":"ho","inverterGroup":[],"timeZone":1,"lng":"","dataAcqList":[],"type":0,"password":"7d394aa288984a80df3afda4c4565c6f","isValiPhone":0,"kind":0,"mailNotice":true,"id":476842,"lastLoginIp":"100.120.96.24","phoneNum":"+31624622079","approved":false,"area":"Europe","smsNotice":false,"isAgent":0,"token":"","nickName":"","parentUserId":0,"customerCode":"","counrty":"Netherlands","isPhoneNumReg":0,"createDate":"2020-05-14 20:52:26","rightlevel":1,"appType":"c","serverUrl":"","lat":"","lastLoginTime":"2020-05-16 21:25:12","roleId":0,"enabled":true,"agentCode":"ANJW2","inverterList":[],"isValiEmail":0,"accountName":"xx","email":"[email protected]","company":"","activeName":"xx van der xx","codeIndex":1,"appAlias":"xx","isBigCustomer":0,"noticeType":""},"msg":"","app_code":"15"}}''
2020-05-16 15:25:12.875 (Growatt) Retrieved following json: {"back": {"isOpenDeviceList": 1, "isOpenDeviceParams": 0, "data": [{"plantName": "xx", "plantId": "306431"}], "service": "1", "quality": "0", "isOpenSmartFamily": 0, "totalData": {}, "success": true, "user": {"uid": "", "userLanguage": "ho", "inverterGroup": [], "timeZone": 1, "lng": "", "dataAcqList": [], "type": 0, "password": "7d394aa288984a80df3afda4c4565c6f", "isValiPhone": 0, "kind": 0, "mailNotice": true, "id": 476842, "lastLoginIp": "100.120.96.24", "phoneNum": "+31624622079", "approved": false, "area": "Europe", "smsNotice": false, "isAgent": 0, "token": "", "nickName": "", "parentUserId": 0, "customerCode": "", "counrty": "Netherlands", "isPhoneNumReg": 0, "createDate": "2020-05-14 20:52:26", "rightlevel": 1, "appType": "c", "serverUrl": "", "lat": "", "lastLoginTime": "2020-05-16 21:25:12", "roleId": 0, "enabled": true, "agentCode": "ANJW2", "inverterList": [], "isValiEmail": 0, "accountName": "xx", "email": "[email protected]", "company": "", "activeName": "xx van der xx", "codeIndex": 1, "appAlias": "xx", "isBigCustomer": 0, "noticeType": ""}, "msg": "", "app_code": "15"}}
2020-05-16 15:25:12.875 (Growatt) Login Succesfull
2020-05-16 15:25:12.875 (Growatt) Plant ID: 306431 was found
2020-05-16 15:25:12.875 (Growatt) Analyzing Data (3):
2020-05-16 15:25:12.875 (Growatt) ---> Headers found
2020-05-16 15:25:12.875 (Growatt) ---> Process Cookie Started
2020-05-16 15:25:12.875 (Growatt) ---> SessionID found: 4C36AF108809EED9BA2A08A8088D13D5
2020-05-16 15:25:12.875 (Growatt) ---> ServerID found: e86db72cfd4d7e78f9dfe069af589226|1589635512|1589635512
2020-05-16 15:25:12.875 (Growatt) Request Data with retrieved cookie!
2020-05-16 15:25:12.875 (Growatt) Pushing 'WriteDirective' on to queue
2020-05-16 15:25:12.875 (Growatt) Processing 'onDisconnectCallback' message
2020-05-16 15:25:12.875 (Growatt) Calling message handler 'onDisconnect'.
2020-05-16 15:25:12.875 (Growatt) onDisconnect called for connection to: server-api.growatt.com:80
2020-05-16 15:25:12.875 (Growatt) Processing 'WriteDirective' message
2020-05-16 15:25:12.875 Error: (Growatt) No transport, write directive to 'HTTP Test' ignored.
2020-05-16 15:25:22.583 (Growatt) Pushing 'onHeartbeatCallback' on to queue
2020-05-16 15:25:22.591 (Growatt) Processing 'onHeartbeatCallback' message
2020-05-16 15:25:22.591 (Growatt) Calling message handler 'onHeartbeat'.
2020-05-16 15:25:22.591 (Growatt) onHeartbeat called, run again in 5 heartbeats.
2020-05-16 15:25:32.585 (Growatt) Pushing 'onHeartbeatCallback' on to queue
2020-05-16 15:25:32.607 (Growatt) Processing 'onHeartbeatCallback' message
2020-05-16 15:25:32.607 (Growatt) Calling message handler 'onHeartbeat'.
Posted: Sunday 17 May 2020 14:17
by vandermark1977
I started using your Pass2php script: https://www.domoticz.com/forum/viewtopi ... =4&t=27656 and that works fine! I hope you can see what went wrong with the plugin in my case but for now i am covered.
Posted: Wednesday 20 May 2020 17:25
by mr4hughz
can i download/install this one ? or is it not yet released ..
Posted: Thursday 21 May 2020 11:03
by sincze
Please check GitHub and dev branch :)
You will find it there
Posted: Tuesday 09 June 2020 19:27
by gerard1
Growatt icon:
The issue that you have to delete Growatt icon continuous.
The Growatt plugin stopted last night, after the restart the problem was there again.
Again the same errors in the log file.
Gr. Gerard,
Posted: Tuesday 09 June 2020 19:31
by sincze
Unfortunately I have no idea what is causing this.
Maybe somebody can explain it so we can modify it.
Posted: Tuesday 08 September 2020 11:58
by nitpicker
Is it possible to read multiple Growatt inverters with this script?
I have 2 Growatt inverters, but this script only read one of the two.
