Page 3 of 3
Re: Toon thermostat combined Get and Set script
Posted: Saturday 31 August 2019 19:53
by madpatrick
HansieNL wrote: Saturday 31 August 2019 12:59
Thanks @madpatrick and @waaren for your help.
I use 2 scripts. Don't know how to make it using just one script. But it works for me ok. I'm using only 3 devices: Thermostat, Scenes and Temperature. I don't use scene states, so decided to use setpoint temperature to let switch the scenes.
Nice addition to the script.
Re: (rooted) Toon thermostat combined Get and Set script
Posted: Sunday 05 July 2020 9:38
by MadMedic
imdos wrote: Saturday 20 April 2019 14:48
Yes; @jjnj, only with a rooted Toon.
I think it might be a good idea to append that not unimportant fact to (the subject of) the first posting.
Saves a bunch of us with non-rooted Toons a lot of hassle.
Just a suggestion...
Posted: Friday 30 October 2020 14:35
by Nickosz
Nice topic, i have only one question,
i can contol my toon.
only what is not working is getting the info from my toon to Domoticz.
So the Toon Temerature stay on 0 and when i try to update the device it's come with an error "No devices to Transfer too!"
who can help me?
some extra info, i'm using Domoticz from my Synology Nas.
Thanks all
Nick
Posted: Friday 30 October 2020 20:15
by madpatrick
Nick,
I've just tested the script (i'm using a different myself) and it is working.
Your domoticz will be update every minute from your Toon
Can you provide more information, like a log
It looks like a name of device is not spelled correctly or not available.
Check all the names if there are available in your UserVariables and switches.
Posted: Tuesday 03 November 2020 19:45
by madpatrick
waaren wrote: Wednesday 23 January 2019 1:45
Created for one of the Dutch forum members who experienced a problem with the two Lua scripts controlling the communication between a rooted Toon and domoticz after updating to a recent domoticz version. This script uses the same uservariables as the original Lua script. many thanks to @johan1974 for testing, patience and constructive feedback.
When switching from the Lua version to this one. Make sure you deactivate both Lua scripts and remove the actions from the selector switches.
- uservariables used in this script
- UV_ToonIP ............................................. -- Toon IP address
- UV_ToonThermostatSensorName ................... -- virtual thermostat setpoint showing current setpoint
- UV_ToonTemperatureSensorName .................. -- virtual temperature sensor showing current room temperature
- UV_ToonScenesSensorName ......................... -- virtual selector switch showing current program
- UV_ToonAutoProgramSensorName .................. -- virtual selector switch showing current auto program status
- UV_ToonProgramInformationSensorName ......... -- virtual text sensor showing displaying program information status
Main advantage of this script is the use of the async communication between domoticz and Toon. No more blocking the eventsystem if Toon is busy Domoticz event system will just work on other fun stuff and gets signaled whenever Toon decides to answer
Waaren,
Your script is working smoother then my current copied/paste script from forums.
The only thing is that i've expended the script with extra functionality like : gas and power consumption, boiler status, boiler temperatures and pressure.
Are you willing to support is adding this to your script ?
This my current script where i've add info lines per funcionality
timer = {
"every minute"
logging = {
level = domoticz.LOG_ERROR, -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level
marker = "-=# Toon #=-"
execute = function(domoticz)
local ToonThermostat = domoticz.variables('UV_ToonThermostat').value -- Sensor showing current setpoint
local ToonTemperature = domoticz.variables('UV_ToonTemperature').value -- Sensor showing current room temperature
local ToonBoilerTempIn = domoticz.variables('UV_ToonBoilerTempIn').value -- Sensor showing water temp return
local ToonBoilerTempOut = domoticz.variables('UV_ToonBoilerTempOut').value -- Sensor showing current water temp out
local ToonBoilerPressure = domoticz.variables('UV_ToonBoilerPressure').value -- Sensor showing current room temperature
local ToonBoilerModulation = domoticz.variables('UV_ToonBoilerModulation').value -- Sensor showing current Boiler Modulation
local ToonScenes = domoticz.variables('UV_ToonScenes').value -- Sensor showing current program
local ToonAutoProgram = domoticz.variables('UV_ToonAutoProgram').value -- Sensor showing current auto program status
local ToonBoilerSetpoint = domoticz.variables('UV_ToonBoilerTempSetpoint').value -- Sensor showing current boiler set point
local ToonBurnerName = domoticz.variables('UV_ToonBurnerName').value
local ToonIP = domoticz.variables('UV_ToonIP').value
local DomoticzIP = domoticz.variables('UV_DomoticzIP').value
local P1SmartMeterPower = domoticz.variables('UV_P1SmartMeterElectra').value
local P1SmartMeterGas1 = domoticz.variables('UV_P1SmartMeterGasMeterStand').value
-- local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformation').value -- Sensor showing displaying program information status
-- Handle json
-- local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
local json = assert(loadfile "/var/domoticz/scripts/lua/JSON.lua")() -- For Linux (ClearOS)
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
local ThermostatInfo = handle:read('*all')
handle:close()
local jsonThermostatInfo = json:decode(ThermostatInfo)
if jsonThermostatInfo == nil then
return
local handle2 = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP)))
local BoilerInfo = handle2:read('*all')
handle2:close()
-- JSON data from Toon contains a extra "," which should not be there.
BoilerInfo = string.gsub(BoilerInfo, ",}", "}")
jsonBoilerInfo = json:decode(BoilerInfo)
-- http://IP_TOON/hdrv_zwave?action=getDevices.json
local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP)))
local GasPowerInfo = handle4:read('*all')
handle4:close()
-- JSON data from Toon contains a extra "." which should not be there.
GasPowerInfo = string.gsub(GasPowerInfo, "dev_2.", "dev_2")
GasPowerInfo = string.gsub(GasPowerInfo, "dev_2:", "dev_2\":")
local jsonGasPower = json:decode(GasPowerInfo)
-- Update the powerconsumption
local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_24.CurrentElectricityFlow) --stroomverbruik momenteel hoogtarief
local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_26.CurrentElectricityFlow) --stroomverbruik momenteel laagtarief
local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_24.CurrentElectricityQuantity) --stroomverbruik totaal hoogtarief
local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_26.CurrentElectricityQuantity) --stroomverbruik totaal laagtarief
local CurrentElectricityDeliveredHoog = tonumber(jsonGasPower.dev_25.CurrentElectricityQuantity) --stroomgeleverd momenteel hoogtarief
local CurrentElectricityDeliveredLaag = tonumber(jsonGasPower.dev_27.CurrentElectricityQuantity) --stroomgeleverd momenteel laagtarief
local CurrentElectricityQuantity = CurrentElectricityFlowHoog + CurrentElectricityFlowLaag --stroomverbruik totaal aktueel
local totalDeliveredPower = 0
local totalDeliveredPower2 = CurrentElectricityDeliveredHoog/1000 + CurrentElectricityDeliveredLaag/1000 --stroomverbruik totaal geleverd
local CurrentGasFlow = tonumber(jsonGasPower.dev_21.CurrentGasFlow)
local CurrentGasQuantity = tonumber(jsonGasPower.dev_21.CurrentGasQuantity)
domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, CurrentElectricityQuantity, totalDeliveredPower).silent()
domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent()
--domoticz.log('*** P1 from toon: ' .. CurrentElectricityQuantityLaag/1000 .. 'kwh USAGE1 | ' ..CurrentElectricityQuantityHoog/1000 .. 'kwh USAGE2 | ' .. CurrentElectricityDeliveredLaag/1000 .. 'kwh RETURN1 | ' .. CurrentElectricityDeliveredHoog/1000 .. 'kwh RETURN2 | ' .. CurrentElectricityQuantity .. 'w consumed | '.. totalDeliveredPower2 .. 'w produced', domoticz.LOG_FORCE)
-- Update the Boiler Water In to current value
local currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp)
currentboilerInTemp = tonumber(string.format("%.0f", currentboilerInTemp)) -- afgeronde getallen is voldoende [PdB]
if domoticz.utils.round(domoticz.devices(ToonBoilerTempIn).temperature,0) ~= domoticz.utils.round(currentboilerInTemp,0) then
domoticz.log('Updating Boiler Water In to current value: ' ..currentboilerInTemp)
domoticz.devices(ToonBoilerTempIn).updateTemperature(currentboilerInTemp).silent()
-- Update the Boiler water Out to current value
local currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp)
currentboilerOutTemp = tonumber(string.format("%.0f", currentboilerOutTemp)) -- afgeronde getallen is voldoende [PdB]
if domoticz.utils.round(domoticz.devices(ToonBoilerTempOut).temperature,0) ~= domoticz.utils.round(currentboilerOutTemp,0) then
domoticz.log('Updating Boiler Water Out to current value: ' ..currentboilerOutTemp)
domoticz.devices(ToonBoilerTempOut).updateTemperature(currentboilerOutTemp).silent()
-- Update the Boiler water Pressure to current value
local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure)
-- currentBoilerPressure = tonumber(string.format("%.1f", currentBoilerPressure)) -- 1 decimaal is voldoende [PdB]
if domoticz.utils.round(domoticz.devices(ToonBoilerPressure)._nValue,0) ~= domoticz.utils.round(currentBoilerPressure,0) then
domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure, domoticz.LOG_INFO)
domoticz.devices(ToonBoilerPressure).updatePressure(currentBoilerPressure).silent()
-- Update the current temperature setpoint
local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
currentTemperature = tonumber(string.format("%.1f", currentTemperature)) -- 1 decimaal is voldoende [PdB]
-- Update the current auto program
local currentProgramState = tonumber(jsonThermostatInfo.programState)
if currentProgramState == 0 then currentProgramState = 10 -- No
elseif currentProgramState == 1 then currentProgramState = 20 -- Yes
elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary
-- Update the current scene by temperature
local currentActiveTemp = tonumber(jsonThermostatInfo.currentSetpoint) / 100
if currentActiveTemp == 20.5 then currentActiveState = 40 -- Comfort
elseif currentActiveTemp == 20 then currentActiveState = 30 -- Home
elseif currentActiveTemp == 17 then currentActiveState = 20 -- Sleep
elseif currentActiveTemp == 18.5 then currentActiveState = 10 -- Away
else currentActiveState = 50 -- Manual
-- Update the current scene by state
local currentActiveState = tonumber(jsonThermostatInfo.activeState)
if currentActiveState == -1 then currentActiveState = 50 -- Manual
elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort
elseif currentActiveState == 1 then currentActiveState = 30 -- Home
elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep
elseif currentActiveState == 3 then currentActiveState = 10 -- Away
-- Update the toon burner selector to current program state
local currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
local CurrentToonBurnerValue = domoticz.devices(ToonBurnerName).level
if currentBurnerInfo == 0 then currentBurnerInfo = 0 -- uit
elseif currentBurnerInfo == 1 then currentBurnerInfo = 10 -- cv aan
elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan
elseif currentBurnerInfo == 3 then currentBurnerInfo = 30 -- voorverwarmen volgend setpoint
-- Update toon burner selector if it has changed
if CurrentToonBurnerValue ~= currentBurnerInfo then
domoticz.log('Updating Toon burner info:' ..currentBurnerInfo,domoticz.LOG_FORCE)
domoticz.devices(ToonBurnerName).switchSelector(currentBurnerInfo)
-- Update the modulation level of the burner
local currentModulationLevel = tonumber(jsonThermostatInfo.currentModulationLevel)
if domoticz.devices(ToonBoilerModulation).percentage + 1 ~= currentModulationLevel + 1 then
domoticz.log('Updating the Modulation sensor to new value: ' ..currentModulationLevel)
domoticz.devices(ToonBoilerModulation).updatePercentage(currentModulationLevel)
-- Update the temperature Boiler setpoint to current boiler set point
local currentInternalBoilerSetpoint = jsonThermostatInfo.currentInternalBoilerSetpoint+1
if domoticz.utils.round(domoticz.devices(ToonBoilerSetpoint).temperature, 1) ~= domoticz.utils.round(currentInternalBoilerSetpoint, 1) then
domoticz.log('Updating the Boiler internal temperature setpoint to new value: ' ..currentInternalBoilerSetpoint)
domoticz.devices(ToonBoilerSetpoint).updateTemperature(currentInternalBoilerSetpoint)
-- Update the thermostat sensor to current setpoint
if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then
domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint,domoticz.LOG_FORCE)
domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent()
-- Update the temperature sensor to current room temperature
if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then
-- domoticz.log('Updating the temperature sensor to new value: ' ..temperature,domoticz.LOG_FORCE)
domoticz.devices(ToonTemperature).updateTemperature(currentTemperature)
-- Update the toon scene selector sensor to current program state
if domoticz.devices(ToonScenes).level ~= currentActiveState then -- Update toon selector if it has changed
-- domoticz.log('Updating Toon Scenes selector to: '..currentActiveState,domoticz.LOG_FORCE)
domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent()
-- Updates the toon auto program switch
if domoticz.devices(ToonAutoProgram).level ~= currentProgramState then -- Update toon auto program selector if it has changed
domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState,domoticz.LOG_FORCE)
domoticz.devices(ToonAutoProgram).switchSelector(currentProgramState).silent()
Posted: Tuesday 03 November 2020 19:58
by waaren
madpatrick wrote: Tuesday 03 November 2020 19:45
Sure; do you have a pointer to the version of the script I created and that you want to extend with the missing functionality that you now have in your script?
Posted: Tuesday 03 November 2020 20:06
by madpatrick
I'm tested your version version 0.117
The exta functionality i like to have is:
handle2:close()
handle4:close()
I hope this answer your question.
And i did not forget to give you the proper information
Posted: Monday 09 January 2023 11:25
by madpatrick
For the people who are interested, the Plugin has been adjusted a bit.
Checkout the other thread for more info
viewtopic.php?p=296916#p296916
Pleaser give us your feedback
