Page 3 of 3
Re: Neo CoolCam Unknown: type=0200, id=1027 using NAS-WR01ZE
Posted: Thursday 07 March 2019 19:44
by rron
The file domoticz/Config/shenzen_neo/nas-wr01ze.xml present. But I have only kWh, electric voltage and CM113 and not the switch function. The indentification is now correct and the settings are availible.
I did several exclude and include but that doesn't make any differance.
Posted: Sunday 10 March 2019 10:46
by Aziona
I have two of these things that are now recognised as "Neo CoolCam Power plug 12A+" by using NAS-WR01ZE.xml. However, one is showing a normal Kwh but the other one still showing -2.14748e+07 kWh. A reset to factory defaults did not solve. Any ideas to get it to show the right number?
Posted: Sunday 10 March 2019 17:59
by rron
Now I have also the switch available but when I 'm giving a switch signal I got "internal node valueID not found". I have tried an other new Neo coolcam to include but the same problem. I tried all the above tips but nothing seem to help.
Any tips?
KWH problem solved
Posted: Monday 11 March 2019 17:41
by renevb
Aziona wrote: Sunday 10 March 2019 10:46
I had the same problem but everything works fine now after resetting the value via the open zwave controle panel. Select the node there and go to the information tab. There you have the reset option. Press submit next to the reset option. This will reset the KWH to zero (check the current values).
Good luck
Re: KWH problem solved
Posted: Monday 11 March 2019 20:12
by dens1975
Good luck
Thanks, that does the trick for me. Solved it for me.
Posted: Tuesday 12 March 2019 19:14
by Aziona
dens1975 wrote: Monday 11 March 2019 20:12
I found the ozwcp control panel in domoticz/ozwcp/ozwcp.html but it is empty. How should I proceed? How can I get to recognize my zwave controller?
Okay, found it. I need to click on Control Panel in the controller screen.
Posted: Tuesday 12 March 2019 19:17
by EddyG
Is part of Domoticz. http://<IP address>:8080/ozwcp/cp.html
Posted: Thursday 28 March 2019 16:04
by coolcamneo2019
can someone tell me how to solve the problem?steps by steps...then we can tell others in our aliexpress stores..
this steps?
exclude the plug, delete all this plug devices in Domoticz, and then include it again.
When the device is excluded you might want to reset the device, before you include it again.
What Domoticz version are you on? Just a remark latest does not mention the version itself.
Is the file domoticz/Config/shenzen_neo/nas-wr01ze.xml present?
