Neo CoolCam Unknown: type=0200, id=1027 using NAS-WR01ZE
rron
Re: Neo CoolCam Unknown: type=0200, id=1027 using NAS-WR01ZE
Post by rron »
The file domoticz/Config/shenzen_neo/nas-wr01ze.xml present. But I have only kWh, electric voltage and CM113 and not the switch function. The indentification is now correct and the settings are availible.
I did several exclude and include but that doesn't make any differance.
Aziona
Post by Aziona »
I have two of these things that are now recognised as "Neo CoolCam Power plug 12A+" by using NAS-WR01ZE.xml. However, one is showing a normal Kwh but the other one still showing -2.14748e+07 kWh. A reset to factory defaults did not solve. Any ideas to get it to show the right number?
rron
Post by rron »
Now I have also the switch available but when I 'm giving a switch signal I got "internal node valueID not found". I have tried an other new Neo coolcam to include but the same problem. I tried all the above tips but nothing seem to help.
Any tips?
renevb
KWH problem solved
Post by renevb »
Aziona wrote: Sunday 10 March 2019 10:46 I have two of these things that are now recognised as "Neo CoolCam Power plug 12A+" by using NAS-WR01ZE.xml. However, one is showing a normal Kwh but the other one still showing -2.14748e+07 kWh. A reset to factory defaults did not solve. Any ideas to get it to show the right number?
I had the same problem but everything works fine now after resetting the value via the open zwave controle panel. Select the node there and go to the information tab. There you have the reset option. Press submit next to the reset option. This will reset the KWH to zero (check the current values).
Good luck
dens1975
Re: KWH problem solved
Post by dens1975 »
Aziona wrote: Sunday 10 March 2019 10:46 I had the same problem but everything works fine now after resetting the value via the open zwave controle panel. Select the node there and go to the information tab. There you have the reset option. Press submit next to the reset option. This will reset the KWH to zero (check the current values).
Good luck
Thanks, that does the trick for me. Solved it for me.
Aziona
Post by Aziona »
dens1975 wrote: Monday 11 March 2019 20:12 Thanks, that does the trick for me. Solved it for me.
I found the ozwcp control panel in domoticz/ozwcp/ozwcp.html but it is empty. How should I proceed? How can I get to recognize my zwave controller?
Okay, found it. I need to click on Control Panel in the controller screen.
EddyG
Post by EddyG »
Is part of Domoticz. http://<IP address>:8080/ozwcp/cp.html
coolcamneo2019
Post by coolcamneo2019 »
can someone tell me how to solve the problem?steps by steps...then we can tell others in our aliexpress stores..
this steps?
exclude the plug, delete all this plug devices in Domoticz, and then include it again.
When the device is excluded you might want to reset the device, before you include it again.
What Domoticz version are you on? Just a remark latest does not mention the version itself.
Is the file domoticz/Config/shenzen_neo/nas-wr01ze.xml present?
