Just the first 30s.
Or if you can't, all the error message you can have at startup.
Deconz is on same system than domoticz ?
You can too check the websocket connexion
netstat -tulpn | grep ":8088"Moderator: leecollings
netstat -tulpn | grep ":8088"Code: Select all
2019-02-03 19:48:24.990 (ConBee) ### Request lights
2019-02-03 19:48:24.990 (ConBee) Send Command /api/9D726911A1/lights/ with None
2019-02-03 19:48:24.990 Error: (ConBee) WebSocket Disconnected, reconnexion !
2019-02-03 19:48:24.990 Error: CConnection_connect, connect request from 'ConBee' ignored. Transport is connecting.
2019-02-03 19:48:25.041 (ConBee) onConnect called
2019-02-03 19:48:25.092 (ConBee) Classic Data : {}
2019-02-03 19:48:25.092 (ConBee) ### Request sensors
2019-02-03 19:48:25.092 (ConBee) Send Command /api/9D726911A1/sensors/ with None
2019-02-03 19:48:25.193 (ConBee) onConnect called
2019-02-03 19:48:25.246 (ConBee) Classic Data : {'2': {'uniqueid': '00:21:2e:ff:ff:03:25:d2-01', 'manufacturername': 'Philips', 'type': 'Daylight', 'config': {'sunsetoffset': -30, 'configured': False, 'on': True, 'sunriseoffset': 30}, 'name': 'Daylight', 'modelid': 'PHDL00', 'etag': None, 'state': {'daylight': None, 'lastupdated': 'none', 'status': None}, 'swversion': '1.0'}, '3': {'ep': 1, 'manufacturername': 'LUMI', 'type': 'ZHAOpenClose', 'config': {'temperature': None, 'battery': None, 'reachable': True, 'on': True}, 'name': 'Window / Door Sensor', 'modelid': 'lumi.sensor_magnet', 'etag': '21f3812ea1f500a4dc22dee672d5ee21', 'state': {'lastupdated': '2019-02-03T18:47:27', 'open': False}, 'uniqueid': '00:15:8d:00:03:11:67:91-01-0006'}, '1': {'ep': 1, 'manufacturername': 'LUMI', 'type': 'ZHAPresence', 'config': {'duration': 60, 'battery': 100, 'temperature': 0, 'reachable': True, 'on': True}, 'name': 'Motion Sensor', 'modelid': 'lumi.sensor_motion', 'etag': '0d1faa653a13b55fd73399c913fbe963', 'state': {'lastupdated': '2019-02-03T18:35:17', 'presence': False}, 'uniqueid': '00:15:8d:00:03:05:71:27-01-0406'}}
2019-02-03 19:48:25.247 (ConBee) ### Device > 2 Name:Daylight Type:Daylight Details:{'daylight': None, 'lastupdated': 'none', 'status': None}
2019-02-03 19:48:25.356 (ConBee) ### Update device (ConBee - Daylight) : {'nValue': 0, 'sValue': 'Off'}, IGNORED , no changes !
2019-02-03 19:48:25.356 (ConBee) ### Device > 3 Name:Window / Door Sensor Type:ZHAOpenClose Details:{'lastupdated': '2019-02-03T18:47:27', 'open': False}
2019-02-03 19:48:25.356 (ConBee) ### Update device (ConBee - Window / Door Sensor 1) : {'nValue': 0, 'sValue': 'Closed', 'BatteryLevel': 0}, IGNORED , no changes !
2019-02-03 19:48:25.357 (ConBee) ### Device > 1 Name:Motion Sensor Type:ZHAPresence Details:{'lastupdated': '2019-02-03T18:35:17', 'presence': False}
2019-02-03 19:48:25.357 (ConBee) ### Update device (ConBee - Motion Sensor 1) : {'nValue': 0, 'sValue': 'Off', 'BatteryLevel': 100}, IGNORED , no changes !
2019-02-03 19:48:25.357 (ConBee) ### Request Groups
2019-02-03 19:48:25.357 (ConBee) Send Command /api/9D726911A1/groups/ with None
2019-02-03 19:48:25.408 (ConBee) onConnect called
2019-02-03 19:48:25.459 (ConBee) Classic Data : {'1': {'multideviceids': [], 'hidden': False, 'id': '1', 'type': 'LightGroup', 'etag': '6c4b959f302e582c797723eef7032922', 'lightsequence': [], 'devicemembership': [], 'scenes': [], 'lights': [], 'name': 'All', 'action': {'bri': 127, 'colormode': 'hs', 'ct': 0, 'sat': 127, 'xy': [0, 0], 'effect': 'none', 'on': False, 'hue': 0}, 'class': 'Other', 'state': {'any_on': False, 'all_on': False}}}
2019-02-03 19:48:25.459 (ConBee) ### Groupe > 1 Name:All
2019-02-03 19:48:25.459 Status: (ConBee) ### deCONZ ready
2019-02-03 19:48:25.459 Status: (ConBee) ### Found 0 Operators, 3 Sensors, 1 Groups with 0 Ignored
2019-02-03 19:48:34.975 Error: (ConBee) WebSocket Disconnected, reconnexion !
2019-02-03 19:48:34.975 Error: CConnection_connect, connect request from 'ConBee' ignored. Transport is connecting.
pi@domo:~/domoticz $ sudo netstat -tulpn | grep ":8088"
python3 API_KEY.py 127.0.0.1:80 info 9D726911A1Code: Select all
netstat -tulpn pi@raspberrypi:~/domoticz/plugins/deCONZ $ sudo netstat -tulpn | grep ":8088"
tcp 0 0 0.0.0.0:8088 0.0.0.0:* LISTEN 4927/deCONZ
pi@domo:~/domoticz/plugins/Domoticz-deCONZ $ python3 API_KEY.py 127.0.0.1:80 info 9D726911A1
File "/usr/lib/python3.5/urllib/request.py", line 1254, in do_open
h.request(req.get_method(), req.selector, req.data, headers)
File "/usr/lib/python3.5/http/client.py", line 1107, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.5/http/client.py", line 1152, in _send_request
self.endheaders(body)
File "/usr/lib/python3.5/http/client.py", line 1103, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.5/http/client.py", line 934, in _send_output
self.send(msg)
File "/usr/lib/python3.5/http/client.py", line 877, in send
self.connect()
File "/usr/lib/python3.5/http/client.py", line 849, in connect
(self.host,self.port), self.timeout, self.source_address)
File "/usr/lib/python3.5/socket.py", line 712, in create_connection
raise err
File "/usr/lib/python3.5/socket.py", line 703, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File "API_KEY.py", line 64, in <module>
response = request.urlopen(req).read()
File "/usr/lib/python3.5/urllib/request.py", line 163, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.5/urllib/request.py", line 466, in open
response = self._open(req, data)
File "/usr/lib/python3.5/urllib/request.py", line 484, in _open
'_open', req)
File "/usr/lib/python3.5/urllib/request.py", line 444, in _call_chain
result = func(*args)
File "/usr/lib/python3.5/urllib/request.py", line 1282, in http_open
return self.do_open(http.client.HTTPConnection, req)
File "/usr/lib/python3.5/urllib/request.py", line 1256, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno 111] Connection refused>
pi@domo:~/domoticz/plugins/Domoticz-deCONZ $ netstat -tulpn
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.1:6010 0.0.0.0:* LISTEN -
tcp6 0 0 :::22 :::* LISTEN -
tcp6 0 0 ::1:6010 :::* LISTEN -
tcp6 0 0 :::443 :::* LISTEN -
tcp6 0 0 :::6144 :::* LISTEN -
tcp6 0 0 :::8080 :::* LISTEN -
udp 0 0 0.0.0.0:5353 0.0.0.0:* -
udp 0 0 0.0.0.0:40982 0.0.0.0:* -
udp 0 0 0.0.0.0:68 0.0.0.0:* -
udp6 0 0 :::5353 :::* -
udp6 0 0 :::43094 :::* -
2019-02-03 22:21:19.890 (ConBee) onConnect called
2019-02-03 22:21:19.891 Status: (ConBee) onDisconnect called for Name: 'deCONZ_WebSocket', Transport: 'TCP/IP', Protocol: 'None', Address: '127.0.0.1', Port: '8088', Baud: -1, Connected: False
2019-02-03 22:21:19.840 Error: (ConBee) WebSocket Disconnected, reconnexion !
2019-02-03 22:21:19.891 Error: (ConBee) WebSocket connexion error : Name: 'deCONZ_WebSocket', Transport: 'TCP/IP', Protocol: 'None', Address: '127.0.0.1', Port: '8088', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00
2019-02-03 22:21:19.891 Error: (ConBee) Status : 111 Description : Connection refusedCode: Select all
pi@domo:~ $ sudo netstat -tulpn
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 532/sshd
tcp 0 0 127.0.0.1:6010 0.0.0.0:* LISTEN 4897/sshd: pi@pts/0
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 339/deCONZ
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 339/deCONZ
tcp6 0 0 :::22 :::* LISTEN 532/sshd
tcp6 0 0 ::1:6010 :::* LISTEN 4897/sshd: pi@pts/0
tcp6 0 0 :::6144 :::* LISTEN 533/domoticz
tcp6 0 0 :::8080 :::* LISTEN 533/domoticz
udp 0 0 0.0.0.0:5353 0.0.0.0:* 338/avahi-daemon: r
udp 0 0 0.0.0.0:50430 0.0.0.0:* 338/avahi-daemon: r
udp 0 0 0.0.0.0:1900 0.0.0.0:* 339/deCONZ
udp 0 0 0.0.0.0:68 0.0.0.0:* 510/dhcpcd
udp6 0 0 :::5353 :::* 338/avahi-daemon: r
udp6 0 0 :::35392 :::* 338/avahi-daemon: r
pi@domo:~ $
2019-02-03 22:24:46.225 (ConBee) onHeartbeat called
2019-02-03 22:24:46.225 (ConBee) ### Request lights
2019-02-03 22:24:46.226 (ConBee) Send Command /api/AAE350A2F3/lights/ with None
2019-02-03 22:24:46.226 (ConBee) Protocol for 'deCONZ_Com' not specified, 'None' assumed.
2019-02-03 22:24:46.226 (ConBee) Transport set to: 'TCP/IP', 127.0.0.1:80.
2019-02-03 22:24:46.227 (ConBee) Connect directive received, action initiated successfully.
2019-02-03 22:24:46.227 (ConBee) Transport set to: 'TCP/IP', 127.0.0.1:8088.
2019-02-03 22:24:46.277 (ConBee) onConnect called
2019-02-03 22:24:46.278 (ConBee) Disconnect event received for '127.0.0.1:8088'.
2019-02-03 22:24:46.278 (ConBee) Sending 183 bytes of data
2019-02-03 22:24:46.328 (ConBee) Received 159 bytes of data
2019-02-03 22:24:46.329 (ConBee) onMessage called
2019-02-03 22:24:46.329 (ConBee) Classic Data : {}
2019-02-03 22:24:46.329 (ConBee) ### Request sensors
2019-02-03 22:24:46.329 (ConBee) Send Command /api/AAE350A2F3/sensors/ with None
2019-02-03 22:24:46.330 (ConBee) Disconnect directive received for '127.0.0.1:80'.
2019-02-03 22:24:46.330 (ConBee) Handling TCP disconnect, socket (127.0.0.1:80) is connected
2019-02-03 22:24:46.330 (ConBee) Queued asyncronous read aborted (127.0.0.1:80).
2019-02-03 22:24:46.380 (ConBee) Disconnect event received for '127.0.0.1:80'.
2019-02-03 22:24:46.380 (ConBee) Deallocating connection object 'deCONZ_Com' (127.0.0.1:80).
2019-02-03 22:24:46.380 (ConBee) Protocol for 'deCONZ_Com' not specified, 'None' assumed.
2019-02-03 22:24:46.380 (ConBee) Transport set to: 'TCP/IP', 127.0.0.1:80.
2019-02-03 22:24:46.381 (ConBee) Connect directive received, action initiated successfully.
2019-02-03 22:24:46.431 (ConBee) onConnect called
2019-02-03 22:24:46.431 (ConBee) Sending 184 bytes of data
2019-02-03 22:24:46.482 (ConBee) Received 1204 bytes of data
2019-02-03 22:24:46.482 (ConBee) onMessage called
2019-02-03 22:24:46.485 (ConBee) Classic Data : {'1': {'manufacturername': 'Philips', 'modelid': 'PHDL00', 'config': {'sunriseoffset': 30, 'on': True, 'configured': True, 'sunsetoffset': -30}, 'state': {'lastupdated': '2019-02-03T21:01:00', 'daylight': False, 'status': 230, 'dark': True}, 'etag': '906addf6e1a4ea0fe3fa7088fc1943df', 'type': 'Daylight', 'swversion': '1.0', 'name': 'Daylight', 'uniqueid': '00:21:2e:ff:ff:03:25:d2-01'}, '3': {'manufacturername': 'LUMI', 'modelid': 'lumi.sensor_motion', 'config': {'on': True, 'reachable': True, 'temperature': None, 'battery': 100, 'duration': 90}, 'state': {'lastupdated': '2019-02-03T21:15:24', 'presence': False}, 'etag': 'e4547dbaf12dd493e539a5de9c6e752c', 'ep': 1, 'type': 'ZHAPresence', 'name': 'Motion Sensor', 'uniqueid': '00:15:8d:00:03:05:71:27-01-0406'}, '4': {'manufacturername': 'LUMI', 'modelid': 'lumi.sensor_magnet', 'config': {'on': True, 'reachable': True, 'temperature': None, 'battery': 100}, 'state': {'lastupdated': '2019-02-03T21:16:07', 'open': False}, 'etag': 'a11c4abcb1548c84a9e27ea337c1b2a3', 'ep': 1, 'type': 'ZHAOpenClose', 'name': 'Window / Door Sensor', 'uniqueid': '00:15:8d:00:03:11:67:91-01-0006'}}
2019-02-03 22:24:46.485 (ConBee) ### Device > 1 Name:Daylight Type:Daylight Details:{'lastupdated': '2019-02-03T21:01:00', 'daylight': False, 'status': 230, 'dark': True}
2019-02-03 22:24:46.604 (ConBee) ### Update device (ConBee - Daylight) : {'nValue': 0, 'sValue': 'Off'}, IGNORED , no changes !
2019-02-03 22:24:46.604 (ConBee) ### Device > 3 Name:Motion Sensor Type:ZHAPresence Details:{'lastupdated': '2019-02-03T21:15:24', 'presence': False}
2019-02-03 22:24:46.605 (ConBee) ### Update device (ConBee - Motion Sensor) : {'BatteryLevel': 100, 'nValue': 0, 'sValue': 'Off'}, IGNORED , no changes !
2019-02-03 22:24:46.605 (ConBee) ### Device > 4 Name:Window / Door Sensor Type:ZHAOpenClose Details:{'lastupdated': '2019-02-03T21:16:07', 'open': False}
2019-02-03 22:24:46.606 (ConBee) ### Update device (ConBee - OpenClose 2) : {'BatteryLevel': 100, 'nValue': 0, 'sValue': 'Closed'}, IGNORED , no changes !
2019-02-03 22:24:46.606 (ConBee) ### Request Groups
2019-02-03 22:24:46.606 (ConBee) Send Command /api/AAE350A2F3/groups/ with None
2019-02-03 22:24:46.606 (ConBee) Disconnect directive received for '127.0.0.1:80'.
2019-02-03 22:24:46.606 (ConBee) Handling TCP disconnect, socket (127.0.0.1:80) is connected
2019-02-03 22:24:46.607 (ConBee) Queued asyncronous read aborted (127.0.0.1:80).
2019-02-03 22:24:46.607 (ConBee) Disconnect event received for '127.0.0.1:80'.
2019-02-03 22:24:46.607 (ConBee) Deallocating connection object 'deCONZ_Com' (127.0.0.1:80).
2019-02-03 22:24:46.607 (ConBee) Protocol for 'deCONZ_Com' not specified, 'None' assumed.
2019-02-03 22:24:46.607 (ConBee) Transport set to: 'TCP/IP', 127.0.0.1:80.
2019-02-03 22:24:46.608 (ConBee) Connect directive received, action initiated successfully.
2019-02-03 22:24:46.609 (ConBee) onConnect called
2019-02-03 22:24:46.609 (ConBee) Sending 183 bytes of data
2019-02-03 22:24:46.661 (ConBee) Received 450 bytes of data
2019-02-03 22:24:46.661 (ConBee) onMessage called
2019-02-03 22:24:46.662 (ConBee) Classic Data : {'1': {'devicemembership': [], 'state': {'all_on': False, 'any_on': False}, 'scenes': [], 'lights': [], 'etag': '906addf6e1a4ea0fe3fa7088fc1943df', 'action': {'bri': 127, 'effect': 'none', 'hue': 0, 'scene': None, 'xy': [0, 0], 'ct': 0, 'on': False, 'sat': 127, 'colormode': 'hs'}, 'id': '1', 'type': 'LightGroup', 'name': 'All'}}
2019-02-03 22:24:46.662 (ConBee) ### Groupe > 1 Name:All
2019-02-03 22:24:46.662 (ConBee) Disconnect directive received for '127.0.0.1:80'.
2019-02-03 22:24:46.662 (ConBee) Handling TCP disconnect, socket (127.0.0.1:80) is connected
2019-02-03 22:24:46.663 (ConBee) Queued asyncronous read aborted (127.0.0.1:80).
2019-02-03 22:24:46.663 (ConBee) Disconnect event received for '127.0.0.1:80'.
2019-02-03 22:24:46.278 Status: (ConBee) onDisconnect called for Name: 'deCONZ_WebSocket', Transport: 'TCP/IP', Protocol: 'None', Address: '127.0.0.1', Port: '8088', Baud: -1, Connected: False
2019-02-03 22:24:46.662 Status: (ConBee) ### deCONZ ready
2019-02-03 22:24:46.662 Status: (ConBee) ### Found 0 Operators, 3 Sensors, 1 Groups with 0 Ignored
2019-02-03 22:24:46.226 Error: (ConBee) WebSocket Disconnected, reconnexion !
2019-02-03 22:24:46.278 Error: (ConBee) WebSocket connexion error : Name: 'deCONZ_WebSocket', Transport: 'TCP/IP', Protocol: 'None', Address: '127.0.0.1', Port: '8088', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00
2019-02-03 22:24:46.278 Error: (ConBee) Status : 111 Description : Connection refused
2019-02-03 22:24:56.230 (ConBee) onHeartbeat called
2019-02-03 22:24:56.230 (ConBee) Transport set to: 'TCP/IP', 127.0.0.1:8088.
2019-02-03 22:24:56.231 (ConBee) Connect directive received, action initiated successfully.
2019-02-03 22:24:56.281 (ConBee) onConnect called
2019-02-03 22:24:56.281 (ConBee) Disconnect event received for '127.0.0.1:8088'.
2019-02-03 22:24:56.281 Status: (ConBee) onDisconnect called for Name: 'deCONZ_WebSocket', Transport: 'TCP/IP', Protocol: 'None', Address: '127.0.0.1', Port: '8088', Baud: -1, Connected: False
2019-02-03 22:24:56.230 Error: (ConBee) WebSocket Disconnected, reconnexion !
2019-02-03 22:24:56.281 Error: (ConBee) WebSocket connexion error : Name: 'deCONZ_WebSocket', Transport: 'TCP/IP', Protocol: 'None', Address: '127.0.0.1', Port: '8088', Baud: -1, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00
2019-02-03 22:24:56.281 Error: (ConBee) Status : 111 Description : Connection refusedCode: Select all
2019-02-03 22:56:32.478 (ConBee) ###### WebSocket Data : {'state': {'lastupdated': '2019-02-03T21:56:32', 'presence': False}, 'r': 'sensors', 't': 'event', 'id': '3', 'e': 'changed', 'uniqueid': '00:15:8d:00:03:05:71:27-01-0406'}
2019-02-03 22:56:32.479 (ConBee) ### Update device (ConBee - Motion Sensor) : {'nValue': 0, 'sValue': 'Off'}Code: Select all
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 339/deCONZCode: Select all
$ systemctl enable deconzCode: Select all
python3 API_KEY.py 127.0.0.1:80 create
Port: 8088 does not work somehow.. Don't know where to change it.Thorgal789 wrote: Monday 04 February 2019 9:17 YepIDK, why you don't have 8088.Code: Select all
BTW, if you wana rollback, the future version will have the editbox, you will can use deconz on your windows if you prefer.
But, for the moment it's not a problem, you can take 443 without problem.The Websocket server is started on an unused proxy friendly port which, depending on the system, is either 443, 8088, 8088, 20877 or any other unused random port.
