@Benneton,
Hello Bernhard,
This thread is discussing the daily produced UV values, Max. UV values, Safe exposure time and the Ozone value.
In fact these are "Health" issues and indications to avoid skin burn or skin cancer.
It has nothing to do with the Solar forecast, so that you can predict what you Solar panels produce.
If you are interested in that, have a look at https://www.domoticz.com/forum/viewtopi ... r+forecast.
Here you will find also a dZVents script, that polls api.forecast.solar
I use this script for a couple of months and it works error free. However the forecast is often too optimistic.
UV index readings realtime Topic is solved
- FireWizard
Re: UV index readings realtime
Hi FireWizard,
Will look into that, and see if this bring additional value to my setup.
Solar panels monitoring still works fine
Bernard
Bernard
- Domoticz version: mixed
With waaren's Open_UV script as basis looking for a new source of Ozone-information, to replace DarkSky's ozone info.
Equivalent to the devices for UV, added in Domoticz a virtual device, but as Custom Sensor to deal with ozone-level in Dobson-units, with a corresponding line in the 'data'-section of the script (see below)
In the script already an item which seems applicable
Using that item, in de 'update'-section added one line equivalent to the readout & compilation of the UV-info, as shown below.
Unfortunately no update resulting for the new device.
Any hint?
openUV_ozone_Dobson_device = {initial = 65 },
openUVResponse.result.ozone
-- Update UV devices
dz.devices(dz.data.openUV_currentUV_device).updateUV(dz.utils.round(openUVResponse.result.uv,1))
dz.devices(dz.data.openUV_maxUV_device).updateUV(dz.utils.round(openUVResponse.result.uv_max,1))
-- Update Ozone device
dz.devices(dz.data.openUV_ozone_Dobson_device).updateUV(dz.utils.round(openUVResponse.result.ozone,1))
Any hint?
- waaren
For custom sensors you need to use the method updateCustomSensor. See this wiki chapter on this device type.
@waaren
Still a lot to learn for use of dzVents ........
