UV index readings realtime Topic is solved
FireWizard
Re: UV index readings realtime
Post by FireWizard »
@Benneton,
Hello Bernhard,
This thread is discussing the daily produced UV values, Max. UV values, Safe exposure time and the Ozone value.
In fact these are "Health" issues and indications to avoid skin burn or skin cancer.
It has nothing to do with the Solar forecast, so that you can predict what you Solar panels produce.
If you are interested in that, have a look at https://www.domoticz.com/forum/viewtopi ... r+forecast.
Here you will find also a dZVents script, that polls api.forecast.solar
I use this script for a couple of months and it works error free. However the forecast is often too optimistic.
Benneton
Post by Benneton »
Hi FireWizard,
Will look into that, and see if this bring additional value to my setup.
Solar panels monitoring still works fine :)
Bernard
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
With waaren's Open_UV script as basis looking for a new source of Ozone-information, to replace DarkSky's ozone info.
Equivalent to the devices for UV, added in Domoticz a virtual device, but as Custom Sensor to deal with ozone-level in Dobson-units, with a corresponding line in the 'data'-section of the script (see below)
openUV_ozone_Dobson_device = {initial = 65                                  },
In the script already an item which seems applicable
openUVResponse.result.ozone
Using that item, in de 'update'-section added one line equivalent to the readout & compilation of the UV-info, as shown below.
            -- Update UV devices
            dz.devices(dz.data.openUV_currentUV_device).updateUV(dz.utils.round(openUVResponse.result.uv,1))
            dz.devices(dz.data.openUV_maxUV_device).updateUV(dz.utils.round(openUVResponse.result.uv_max,1))
            -- Update Ozone device
            dz.devices(dz.data.openUV_ozone_Dobson_device).updateUV(dz.utils.round(openUVResponse.result.ozone,1))
Unfortunately no update resulting for the new device.
Any hint?
Toulon7559 wrote: Thursday 29 October 2020 16:30
You have defined a custom sensor but try to update it with a method that is only available for UV type devices.
For custom sensors you need to use the method updateCustomSensor. See this wiki chapter on this device type.
Toulon7559
@waaren
;-) Still a lot to learn for use of dzVents ........
