Re: Python Plugin: Python Plugin Manager
Posted: Sunday 11 March 2018 9:13
Domoticz web interface log
Open source Home Automation System
https://forum.domoticz.com/
2018-03-11 09:21:34.872 Domoticz V3.9014 (c)2012-2018 GizMoCuz
2018-03-11 09:21:34.872 Build Hash: 6b5dd0b7, Date: 2018-03-10 14:16:03
2018-03-11 09:21:34.872 Startup Path: /home/pi/domoticz/
2018-03-11 09:21:35.328 Sunrise: 06:59:00 SunSet: 18:33:00
2018-03-11 09:21:35.328 Day length: 11:34:00 Sun at south: 12:05:00
2018-03-11 09:21:35.328 Civil twilight start: 06:26:00 Civil twilight end: 19:07:00
2018-03-11 09:21:35.328 Nautical twilight start: 05:47:00 Nautical twilight end: 19:46:00
2018-03-11 09:21:35.328 Astronomical twilight start: 05:06:00 Astronomical twilight end: 20:26:00
2018-03-11 09:21:35.328 EventSystem: reset all events...
2018-03-11 09:21:35.355 dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/SolarEdge.lua
2018-03-11 09:21:35.362 Philips Hue: Using default poll interval of 10 secs.
2018-03-11 09:21:35.379 Active notification Subsystems: pushover (1/14)
2018-03-11 09:21:35.422 WebServer(SSL) started on address: :: with port 443
2018-03-11 09:21:35.433 Proxymanager started.
2018-03-11 09:21:35.435 Starting shared server on: :::6144
2018-03-11 09:21:35.435 TCPServer: shared server started...
2018-03-11 09:21:35.435 RxQueue: queue worker started...
2018-03-11 09:21:36.640 Incoming connection from: 192.168.178.20
2018-03-11 09:21:37.436 SolarEdgeAPI Worker started...
2018-03-11 09:21:37.436 Philips Hue: Worker started...
2018-03-11 09:21:37.436 Netatmo: Worker started...
2018-03-11 09:21:37.936 OpenZWave: using config in: /home/pi/domoticz/Config/
2018-03-11 09:21:37.960 OpenZWave: Starting...
2018-03-11 09:21:37.960 OpenZWave: Version: 1.4-2888-g54682370-dirty
2018-03-11 09:21:38.146 OpenZWave: Driver Ready
2018-03-11 09:21:38.148 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2018-03-11 09:21:38.150 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2018-03-11 09:21:38.151 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2018-03-11 09:21:38.151 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2018-03-11 09:21:38.151 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2018-03-11 09:21:38.152 OpenZWave: Value_Added: Node: 5 (0x05), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2018-03-11 09:21:38.152 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2018-03-11 09:21:38.153 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2018-03-11 09:21:38.153 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2018-03-11 09:21:38.154 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Relative Humidity, Instance: 5
2018-03-11 09:21:38.154 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2018-03-11 09:21:38.154 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2018-03-11 09:21:38.440 RFXCOM: Using serial port: /dev/ttyUSB_RFX
2018-03-11 09:21:38.484 (Philips Hue) Lighting Limitless/Applamp (Group Woonkamer)
2018-03-11 09:21:38.494 (Philips Hue) Lighting Limitless/Applamp (Group All Lights)
2018-03-11 09:21:38.495 (Philips Hue) Lighting Limitless/Applamp (Scene Tropische schemering)
2018-03-11 09:21:38.497 (Philips Hue) Lighting Limitless/Applamp (Scene Helder)
2018-03-11 09:21:38.499 (Philips Hue) Lighting Limitless/Applamp (Scene Lezen)
2018-03-11 09:21:38.501 (Philips Hue) Lighting Limitless/Applamp (Scene Read)
2018-03-11 09:21:38.503 (Philips Hue) Lighting Limitless/Applamp (Scene Gedimd)
2018-03-11 09:21:38.505 (Philips Hue) Lighting Limitless/Applamp (Scene Nachtlampje)
2018-03-11 09:21:38.508 (Philips Hue) Lighting Limitless/Applamp (Scene Concentreren)
2018-03-11 09:21:38.510 (Philips Hue) Lighting Limitless/Applamp (Scene Energize)
2018-03-11 09:21:38.512 (Philips Hue) Lighting Limitless/Applamp (Scene Arctische dageraad)
2018-03-11 09:21:38.513 (Philips Hue) Lighting Limitless/Applamp (Scene Lentebloesem)
2018-03-11 09:21:38.516 (Philips Hue) Lighting Limitless/Applamp (Scene Relax)
2018-03-11 09:21:38.522 (Philips Hue) Lighting Limitless/Applamp (Scene Savanne zonsondergang)
2018-03-11 09:21:38.524 (Philips Hue) Lighting Limitless/Applamp (Scene Last State)
2018-03-11 09:21:38.526 (Philips Hue) Lighting Limitless/Applamp (Scene Ontspannen)
2018-03-11 09:21:38.528 (Philips Hue) Lighting Limitless/Applamp (Scene Concentrate)
2018-03-11 09:21:38.530 (Philips Hue) Lighting Limitless/Applamp (Scene Energie)
2018-03-11 09:21:39.015
2018-03-11 09:21:39.091 subtype = Interface Response
Sequence nbr = 2
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 1005
Firmware type = Type2
Hardware version = 1.1
Undec off
X10 enabled
ARC enabled
AC enabled
HomeEasy EU enabled
Meiantech/Atlantic disabled
Oregon Scientific enabled
ATI/Cartelectronic disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki enabled
La Crosse disabled
FS20/Legrand disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 enabled
AE disabled
RUBiCSON enabled
FineOffset disabled
Lighting4 disabled
Conrad RSL disabled
ByronSX disabled
IMAGINTRONIX enabled
KEELOQ disabled
Home Confort disabled
2018-03-11 09:21:39.449 (P1 meter) P1 Smart Meter (Electriciteit)
2018-03-11 09:21:39.449 (P1 meter) P1 Smart Meter (Gas)
2018-03-11 09:21:43.360 (Netatmo) Temp + Humidity (Tuin)
2018-03-11 09:21:43.363 (Netatmo) Temp + Humidity + Baro (Woonkamer)
2018-03-11 09:21:43.364 (Netatmo) Air Quality (Woonkamer)
2018-03-11 09:21:43.366 (Netatmo) General/Sound Level (Woonkamer)
2018-03-11 09:21:43.367 (Netatmo) Temp + Humidity (Buiten)
2018-03-11 09:21:43.368 (Netatmo) Temp + Humidity (babykamer)
2018-03-11 09:21:43.369 (Netatmo) Air Quality (babykamer)
2018-03-11 09:21:43.371 (Netatmo) Temp + Humidity + Baro (Station)
2018-03-11 09:21:43.372 (Netatmo) Air Quality (Station)
2018-03-11 09:21:43.373 (Netatmo) General/Sound Level (Station)
2018-03-11 09:21:43.388 (SolarEdge) General/kWh (SolarEdge kWh Meter)
2018-03-11 09:21:43.389 (SolarEdge) General/Voltage (DC Inverter 1)
2018-03-11 09:21:43.390 (SolarEdge) Temp (SolarMain Inverter 1)
2018-03-11 09:21:43.390 (SolarEdge) General/Voltage (AC Inverter 1)
2018-03-11 09:21:43.391 (SolarEdge) General/Percentage (Hz Inverter 1)
2018-03-11 09:21:43.766 (Netatmo) Temp (Thermostaat)
2018-03-11 09:21:43.766 (Netatmo) Thermostat (SetPoint Thermostat)
2018-03-11 09:21:43.808 (RFXtrx) Temp + Humidity (Berging)
2018-03-11 09:21:46.050 Incoming connection from: 127.0.0.1
2018-03-11 09:21:49.461 (P1 meter) P1 Smart Meter (Electriciteit)
2018-03-11 09:21:56.082 (RFXtrx) Temp + Humidity (Voordeur)
2018-03-11 09:22:05.112 OpenZWave: Received timeout notification from HomeID: 4112738428, NodeID: 5 (0x05)
2018-03-11 09:22:08.123 (P1 meter) P1 Smart Meter (Electriciteit)
Do you have other plugins? do they run/appear on the list?florisi wrote: Sunday 11 March 2018 9:23 No error at all.
my dzVents script is also not running anymore.
2018-03-13 13:17:18.141 Domoticz V3.9043 (c)2012-2018 GizMoCuz
2018-03-13 13:17:18.144 Build Hash: c037e02a, Date: 2018-03-13 10:45:10
2018-03-13 13:17:18.145 Startup Path: /home/pi/domoticz/
2018-03-13 13:17:18.400 EventSystem: reset all events...
2018-03-13 13:17:18.731 PluginSystem: Started, Python version '3.4.2'.
2018-03-13 13:17:18.771 WebServer(HTTP) started on address: :: with port 8080
2018-03-13 13:17:18.788 WebServer(SSL) started on address: :: with port 443
2018-03-13 13:17:18.795 Proxymanager started.
2018-03-13 13:17:18.804 TCPServer: shared server started...
2018-03-13 13:17:18.805 RxQueue: queue worker started...
2018-03-13 13:17:20.805 (MiFlora) Started.
2018-03-13 13:17:20.805 (PPM) Started.
2018-03-13 13:17:20.806 (PiMonitor) Started.
2018-03-13 13:17:20.807 EventSystem: reset all events...
2018-03-13 13:17:20.808 EventSystem: reset all device statuses...
2018-03-13 13:17:20.916 PluginSystem: Entering work loop.
2018-03-13 13:17:21.852 (MiFlora) Initialized version 1.0.0, author 'blauwebuis'
2018-03-13 13:17:21.865 (MiFlora) Entering work loop.
2018-03-13 13:17:22.124 Python EventSystem: Initalizing event module.
2018-03-13 13:17:22.136 EventSystem: Queue thread started...
2018-03-13 13:17:22.136 EventSystem: Started
2018-03-13 13:17:23.610 (PPM) Initialized version 1.4.17, author 'ycahome'
2018-03-13 13:17:23.615 (PPM) Entering work loop.
2018-03-13 13:17:23.902 (PiMonitor) Initialized version 1.0.0, author 'Xorfor'
2018-03-13 13:17:23.902 (PiMonitor) Entering work loop.Code: Select all
2018-03-13 22:59:32.098 (PPM) Stop directive received.
2018-03-13 22:59:32.098 (PPM) Plugin is stopping.
2018-03-13 22:59:32.099 (PPM) Self Update Initiated
2018-03-13 22:59:32.099 (PPM) Updating Plugin:PP-MANAGER
2018-03-13 22:59:32.273 (PPM) Exiting work loop.
2018-03-13 22:59:34.306 (PPM) Succesfully pulled gitHub update: 5c09f26..7d7916 for plugin PP-MANAGER
2018-03-13 22:59:34.307 (PPM) ---Restarting Domoticz MAY BE REQUIRED to activate new plugins---
2018-03-13 22:59:34.307 (PPM) Debug logging mask set to: NONE
2018-03-13 22:59:34.602 (PPM) Stopping threads.
2018-03-13 22:59:34.602 (PPM) Stopped.
2018-03-13 22:59:34.602 (PPM) Started.
2018-03-13 22:59:36.077 (PPM) Initialized version 1.4.17, author 'ycahome'
2018-03-13 22:59:36.077 (PPM) Entering work loop.
2018-03-13 22:59:36.134 (PPM) Debug logging mask set to: NONE
2018-03-13 22:59:36.163 (PPM) Domoticz Node Name is:raspberrypi
2018-03-13 22:59:36.163 (PPM) Domoticz Platform System is:Linux
2018-03-13 22:59:36.163 (PPM) Default Python Version is:3.4.2.
2018-03-13 22:59:36.164 (PPM) Updating All Plugins!!!
2018-03-13 22:59:36.166 (PPM) Plugin:examples cannot be managed with PP-Manager!!.
2018-03-13 22:59:36.166 (PPM) Updating Plugin:Mi_Flower_mate_plugin
2018-03-13 22:59:37.608 (PPM) Plugin Mi_Flower_mate_plugin already Up-To-Date
2018-03-13 22:59:37.608 (PPM) Plugin:AwoxSMP cannot be managed with PP-Manager!!.
2018-03-13 22:59:37.608 (PPM) Updating Plugin:xfr-pimonitor
2018-03-13 22:59:39.117 (PPM) Plugin xfr-pimonitor already Up-To-Date
2018-03-13 22:59:39.117 (PPM) Plugin IdleCode: Select all
2018-03-13 23:01:53.806 Domoticz V3.9045 (c)2012-2018 GizMoCuz
2018-03-13 23:01:53.809 Build Hash: 22396569, Date: 2018-03-13 16:19:00
2018-03-13 23:01:53.810 Startup Path: /home/pi/domoticz/
2018-03-13 23:01:54.203 Sunrise: 05:55:00 SunSet: 17:36:00
2018-03-13 23:01:54.203 Day length: 11:42:00 Sun at south: 11:05:00
2018-03-13 23:01:54.203 Civil twilight start: 05:21:00 Civil twilight end: 18:10:00
2018-03-13 23:01:54.203 Nautical twilight start: 04:41:00 Nautical twilight end: 18:49:00
2018-03-13 23:01:54.203 Astronomical twilight start: 04:01:00 Astronomical twilight end: 19:30:00
2018-03-13 23:01:54.203 EventSystem: reset all events...
2018-03-13 23:01:54.775 PluginSystem: Started, Python version '3.4.2'.
2018-03-13 23:01:54.811 Active notification Subsystems: (0/14)
2018-03-13 23:01:54.854 WebServer(HTTP) started on address: :: with port 8080
2018-03-13 23:01:54.890 WebServer(SSL) started on address: :: with port 443
2018-03-13 23:01:54.897 Proxymanager started.
2018-03-13 23:01:54.905 Accepting shared server connections via MyDomotiz (see settings menu).
2018-03-13 23:01:54.908 Starting shared server on: :::6144
2018-03-13 23:01:54.910 TCPServer: shared server started...
2018-03-13 23:01:54.911 RxQueue: queue worker started...
2018-03-13 23:01:54.925 Incoming connection from: 192.168.1.253
2018-03-13 23:01:56.912 (MiFlora) Started.
2018-03-13 23:01:56.912 (PPM) Started.
2018-03-13 23:01:56.912 (PiMonitor) Started.
2018-03-13 23:01:56.913 EventSystem: reset all events...
2018-03-13 23:01:56.915 EventSystem: reset all device statuses...
2018-03-13 23:01:57.244 PluginSystem: Entering work loop.
2018-03-13 23:01:57.435 Python EventSystem: Initalizing event module.
2018-03-13 23:01:57.441 EventSystem: Queue thread started...
2018-03-13 23:01:57.442 EventSystem: Started
2018-03-13 23:01:58.357 (MiFlora) Initialized version 1.0.0, author 'blauwebuis'
2018-03-13 23:01:58.361 (MiFlora) Entering work loop.
2018-03-13 23:02:00.048 (PPM) Initialized version 1.4.17, author 'ycahome'
2018-03-13 23:02:00.051 (PPM) Entering work loop.
2018-03-13 23:02:00.351 (PiMonitor) Initialized version 1.0.0, author 'Xorfor'
2018-03-13 23:02:00.352 (PiMonitor) Entering work loop.
2018-03-13 23:02:00.430 (MiFlora) Automatic mode is selected
2018-03-13 23:02:00.430 (MiFlora) Scanning for Mi Flower Mate sensors
2018-03-13 23:02:00.614 (MiFlora) Already known devices:['xxxxxxxxxxxx', 'xxxxxxxxxxxxxxxx', 'xxxxxxxxxxxxxxxxx', 'xxxxxxxxxxxxx', 'xxxxxxxxxxxxxx']
2018-03-13 23:02:14.709 (MiFlora) Number of devices found via bluetooth scan = 5
2018-03-13 23:02:14.721 (PPM) Debug logging mask set to: NONE
2018-03-13 23:02:14.762 (PPM) Domoticz Node Name is:raspberrypi
2018-03-13 23:02:14.762 (PPM) Domoticz Platform System is:Linux
2018-03-13 23:02:14.763 (PPM) Default Python Version is:3.4.2.
2018-03-13 23:02:14.763 (PPM) Updating All Plugins!!!
2018-03-13 23:02:14.766 (PPM) Plugin:examples cannot be managed with PP-Manager!!.
2018-03-13 23:02:14.767 (PPM) Updating Plugin:Mi_Flower_mate_plugin
2018-03-13 23:02:16.714 (PPM) Plugin Mi_Flower_mate_plugin already Up-To-Date
2018-03-13 23:02:16.714 (PPM) Plugin:AwoxSMP cannot be managed with PP-Manager!!.
2018-03-13 23:02:16.715 (PPM) Updating Plugin:xfr-pimonitor
2018-03-13 23:02:18.265 (PPM) Plugin xfr-pimonitor already Up-To-Date
2018-03-13 23:02:18.265 (PPM) Plugin Idle
2018-03-13 23:02:18.284 (PiMonitor) Debug logging mask set to: NONECode: Select all
sudo git reset --hard HEAD
018-03-14 12:07:20.655 EventSystem: reset all events...
2018-03-14 12:07:20.656 EventSystem: reset all device statuses...
2018-03-14 12:07:20.855 Python EventSystem: Module not found - Trying to initialize.
2018-03-14 12:07:20.855 Python EventSystem: Initalizing event module.
2018-03-14 12:07:20.856 EventSystem: Started
2018-03-14 12:07:20.924 PluginSystem: Entering work loop.
2018-03-14 12:07:21.155 OpenZWave: using config in: /home/pi/domoticz/Config/
2018-03-14 12:07:21.218 OpenZWave: Starting...
2018-03-14 12:07:21.218 OpenZWave: Version: 1.4-2501-g5af6780-dirty
2018-03-14 12:07:21.358 OpenZWave: Driver Ready
2018-03-14 12:07:21.360 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2018-03-14 12:07:21.366 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: METER, Label: Energy, Instance: 1
2018-03-14 12:07:21.366 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: METER, Label: Power, Instance: 1
2018-03-14 12:07:21.366 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2018-03-14 12:07:21.366 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2018-03-14 12:07:21.752 (PPMANAGER) Initialized version 1.5.1, author 'ycahome'
2018-03-14 12:07:21.939 (testzwave) General/kWh (kWh Meter)
2018-03-14 12:07:21.976 (testzwave) Usage (test)
2018-03-14 12:07:21.977 (testzwave) General/kWh (kWh Meter)
2018-03-14 12:07:22.214 (denon) Initialized version 1.5.1, author 'ycahome'
2018-03-14 12:07:22.268 (PPMANAGER) Debug log level set to: 'false'.
2018-03-14 12:07:22.280 (PPMANAGER) Domoticz Node Name is:raspberrypi
2018-03-14 12:07:22.280 (PPMANAGER) Domoticz Platform System is:Linux
2018-03-14 12:07:22.280 (PPMANAGER) Default Python Version is:3.5.3.
2018-03-14 12:07:22.281 (PPMANAGER) self.ExceptionList:[]
2018-03-14 12:07:22.281 (PPMANAGER) Updating All Plugins!!!
2018-03-14 12:07:22.281 (PPMANAGER) Updating Plugin:Denon4306
2018-03-14 12:07:24.942 (PPMANAGER) Plugin Denon4306 already Up-To-Date
2018-03-14 12:07:24.942 (PPMANAGER) Plugin:AwoxSMP cannot be managed with PP-Manager!!.
2018-03-14 12:07:24.942 (PPMANAGER) Plugin:examples cannot be managed with PP-Manager!!.
2018-03-14 12:07:24.942 (PPMANAGER) Plugin Idle
2018-03-14 12:07:24.945 (denon) Debug log level set to: 'false'.
2018-03-14 12:07:24.956 (denon) Domoticz Node Name is:raspberrypi
2018-03-14 12:07:24.956 (denon) Domoticz Platform System is:Linux
2018-03-14 12:07:24.956 (denon) Default Python Version is:3.5.3.
2018-03-14 12:07:24.956 (denon) self.ExceptionList:[]
2018-03-14 12:07:24.956 (denon) Updating All Plugins!!!
2018-03-14 12:07:24.957 (denon) Updating Plugin:Denon4306
2018-03-14 12:07:26.015 (denon) Plugin Denon4306 already Up-To-Date
2018-03-14 12:07:26.015 (denon) Plugin:AwoxSMP cannot be managed with PP-Manager!!.
2018-03-14 12:07:26.015 (denon) Plugin:examples cannot be managed with PP-Manager!!.
2018-03-14 12:07:31.967 OpenZWave: Received timeout notification from HomeID: 25484956, NodeID: 21 (0x15)
2018-03-14 12:07:31.969 OpenZWave: All Nodes queried
2018-03-14 12:08:58.677 (testzwave) Usage (test)
2018-03-14 12:08:58.678 (testzwave) General/kWh (kWh Meter)
Please dont!
ycahome wrote: Wednesday 14 March 2018 20:03 v.1.5.5
New: Experimental Feature that parsing all installed plugins for specific regex (text patterns)
Currently enabled only the "IP Pattern". Scan plugins for IPs on the code in order to avoid data leakage....
Edit:There is a file template (secpoluser.orig). Can be copied to "secpoluser.txt" and include all results that should be excluded.
Waiting for your feedback...
P.S: Would be nice to know if this plugin is being currently used or to stop development...
@ P.S: ...dumb question
