Page 3 of 4
Re: Vocal command for Domoticz
Posted: Friday 04 January 2019 20:16
by renerene
I have been using Jarvis for a week now on my Teclast wall tablet, that also runs Dashticz.
Because of bad voice interpretation, buggy/freezing response, I cannot have it replace my Alexa. I guess it has a 20% succes range for understanding my phrases, where Alexa is 90% correct.
Question:
What is you experience in buying a microphone upgrade?
see also https://www.domoticz.com/forum/viewtop ... 56#p160092
Posted: Friday 04 January 2019 23:36
by welby
zak45 wrote: Friday 04 January 2019 16:48
welby wrote: Friday 04 January 2019 3:57 How do i make it just read the data from the sensor and not everything that it receives?
this should do the trick for Domoticz:
[url]http://192.168.1.xx:xxxx/json.htm?type=devices&rid=<YOUR IDX>[/url]
<YOUR IDX> = Domoticz device IDX
and this for jarvis
SetVariable: Data to value: system.jsonParse(system.httpGetResult().at("/result/0/Data").asText()
Thanks zak but i'm still unsure of what to do with the set variable part? I've been reading the docs and API but i can't get my head around it.
Posted: Saturday 05 January 2019 1:15
by zak45
welby wrote: Friday 04 January 2019 23:36 Thanks zak but i'm still unsure of what to do with the set variable part? I've been reading the docs and API but i can't get my head around it.
Yep, understand.. same for me, take some time.
This is why I decided to create a python plugin for automatic config generation, just to make this soft more accessible for begginer
for the moment, on/off, dimmer, temperature, sensors status, scene, thermostat are running...so you will be able to learn from them.
available soon ... need some more time ;-)
Posted: Saturday 05 January 2019 1:17
by zak45
renerene wrote: Friday 04 January 2019 20:16 Question:
Do not have trouble with microphone. this run on samsung galaxy tablet.
You can increase drastically recognition by setting right synonyms
Posted: Sunday 06 January 2019 22:34
by renerene
can someone please explain the 'stop' functionality?
I have programmed a dummy device that stops the screen movement. I call this device in the stop action, using JSON.
But, how to activate this stop command? After 'Jarvis, close screens' and 'stop' nothing happens
Posted: Sunday 06 January 2019 23:28
by zak45
renerene wrote: Sunday 06 January 2019 22:34 can someone please explain the 'stop' functionality?
Attached example of the configuration generated by the plugin for On/Off action on one device;
This should give you overview of the possibility;
you need to unzip the file and upload the three configuration files into jarvis@home.
Go to Domoticz Net config and put your domoticz IP and port.
Go to Domoticz OnOff and replace /update / adapt the configuration for one of your device IDX number.
no so hard to understand (hope so).
test.zip
(6.11 KiB) Downloaded 70 times
Posted: Monday 07 January 2019 19:50
by kniazio
Is this the plugin we are waiting for?
Posted: Monday 07 January 2019 20:28
by zak45
kniazio wrote: Monday 07 January 2019 19:50 Is this the plugin we are waiting for?
Nope..; a small part just to show structure/possibility
Posted: Tuesday 08 January 2019 20:46
by renerene
zak45 wrote: Sunday 06 January 2019 23:28 no so hard to understand (hope so).
test.zip
Guess not.
it is french.
i have modified the variables in on/off configuration. Now what?
Three configurations x 9 tabs = 27 places to edit variables (discussion, recogition, sentence....variable) --> Which, what, why?
do I have to edit SWITCH_URL? Or this is automaticly filled?
Do you call switches by IDx number?
Posted: Tuesday 08 January 2019 23:33
by zak45
renerene wrote: Tuesday 08 January 2019 20:46 i have modified the variables in on/off configuration. Now what?
Nothing!
Posted: Wednesday 09 January 2019 7:06
by renerene
Nothing!
Haha, correct. Waste of time.
Posted: Wednesday 09 January 2019 10:51
by zak45
renerene wrote: Wednesday 09 January 2019 7:06 Haha, correct. Waste of time.
Right. And as AE said :
"The only thing that interferes with my learning is my education".
Last news about the plugin:
have made some test to "try" to do Geofencing (yep, last version can retreive GPS coordinate)... but not work as expected (could be me .. need to double-check)
In process to finalize devices creation...
Posted: Tuesday 29 January 2019 18:36
by kniazio
What's happening with jarvis @ home?
Will there be a plugin for Domoticz, who was promised?
Posted: Tuesday 29 January 2019 23:26
by zak45
kniazio wrote: Tuesday 29 January 2019 18:36 What's happening with jarvis @ home?
yep, but we all have life and things not always happend as we want.. still on progress/test, and need now to write the Wiki!!
Posted: Saturday 23 February 2019 17:09
by zak45
for people with some py knowledge.
no support from my side for the moment (not enough time).
but should not be difficult to setup (see some help on doc folder)
this manage :
Voice command
TTS
Android Notification
Geofencing (with Automate)
MyLocation(with Automate)
https://www.dropbox.com/sh/js6a1voczrm7 ... BeUWa?dl=0
Posted: Saturday 23 February 2019 19:50
by kniazio
My errors:
 2019-02-23 19:49:37.849 (DomVoice) Initialized version 1.0.0, author 'zak45'
2019-02-23 19:49:37.874 (DomVoice) lang file : /home/domoticz/plugins/EZJarviz/en_en.lng
2019-02-23 19:49:37.874 Error: (DomVoice) Traceback (most recent call last):
File "/home/domoticz/plugins/EZJarviz/plugin.py", line 968, in loadLang
with open(lang_file, 'r' , encoding='utf-8') as fp:
FileNotFoundError: [Errno 2] No such file or directory: '/home/domoticz/plugins/EZJarviz/en_en.lng'
2019-02-23 19:49:37.874 Error: (DomVoice) __Lang file not exist or to process data from : /home/domoticz/plugins/EZJarviz/en_en.lng__
2019-02-23 19:49:37.874 Error: (DomVoice) __Language file is missing for : en__
2019-02-23 19:49:37.875 Error: (DomVoice) 'onStart' failed 'AttributeError':''module' object has no attribute 'Connection''.
2019-02-23 19:49:37.875 Error: (DomVoice) ----> Line 205 in /home/domoticz/plugins/EZJarviz/plugin.py, function onStart
configurations are different
Posted: Saturday 23 February 2019 23:06
by zak45
you need to take the one on the lng folder.
Posted: Saturday 23 February 2019 23:22
by kniazio
there is no en_en.lng file in the lng folder
Which means:
 2019-02-23 23:17:24.292 Error: (DomVoice) 'onStart' failed 'AttributeError':''module' object has no attribute 'Connection''.
2019-02-23 23:17:24.292 Error: (DomVoice) ----> Line 205 in /home/domoticz/plugins/EZJarviz/plugin.py, function onStart
what is this
Posted: Saturday 23 February 2019 23:27
by kniazio
I do not understand how it works
Posted: Saturday 23 February 2019 23:53
by zak45
kniazio wrote: Saturday 23 February 2019 23:27 I do not understand how it works
All is on the dropbox.
If you do not have enough python knowledge, not simple.
And without any documentation, not easy.
Maybe better for you to wait for the WiKi.
