Vocal command for Domoticz
Re: Vocal command for Domoticz
I have been using Jarvis for a week now on my Teclast wall tablet, that also runs Dashticz.
Because of bad voice interpretation, buggy/freezing response, I cannot have it replace my Alexa. I guess it has a 20% succes range for understanding my phrases, where Alexa is 90% correct.
Question:
What is you experience in buying a microphone upgrade?
see also https://www.domoticz.com/forum/viewtop ... 56#p160092
Question:
welby
Thanks zak but i'm still unsure of what to do with the set variable part? I've been reading the docs and API but i can't get my head around it.zak45 wrote: Friday 04 January 2019 16:48this should do the trick for Domoticz:welby wrote: Friday 04 January 2019 3:57 How do i make it just read the data from the sensor and not everything that it receives?
[url]http://192.168.1.xx:xxxx/json.htm?type=devices&rid=<YOUR IDX>[/url]
<YOUR IDX> = Domoticz device IDX
and this for jarvis
SetVariable: Data to value: system.jsonParse(system.httpGetResult().at("/result/0/Data").asText()
zak45
- Domoticz version: V2024.4
Yep, understand.. same for me, take some time.welby wrote: Friday 04 January 2019 23:36 Thanks zak but i'm still unsure of what to do with the set variable part? I've been reading the docs and API but i can't get my head around it.
This is why I decided to create a python plugin for automatic config generation, just to make this soft more accessible for begginer
for the moment, on/off, dimmer, temperature, sensors status, scene, thermostat are running...so you will be able to learn from them.
available soon ... need some more time
zak45
Do not have trouble with microphone. this run on samsung galaxy tablet.renerene wrote: Friday 04 January 2019 20:16 Question:
You can increase drastically recognition by setting right synonyms
can someone please explain the 'stop' functionality?
I have programmed a dummy device that stops the screen movement. I call this device in the stop action, using JSON.
But, how to activate this stop command? After 'Jarvis, close screens' and 'stop' nothing happens
zak45
Attached example of the configuration generated by the plugin for On/Off action on one device;renerene wrote: Sunday 06 January 2019 22:34 can someone please explain the 'stop' functionality?
This should give you overview of the possibility;
you need to unzip the file and upload the three configuration files into jarvis@home.
Go to Domoticz Net config and put your domoticz IP and port.
Go to Domoticz OnOff and replace /update / adapt the configuration for one of your device IDX number.
no so hard to understand (hope so).
kniazio
- Domoticz version: 3.7243
Is this the plugin we are waiting for?
zak45
Nope..; a small part just to show structure/possibility
Guess not.
it is french.
i have modified the variables in on/off configuration. Now what?
Three configurations x 9 tabs = 27 places to edit variables (discussion, recogition, sentence....variable) --> Which, what, why?
do I have to edit SWITCH_URL? Or this is automaticly filled?
Do you call switches by IDx number?
zak45
Nothing!renerene wrote: Tuesday 08 January 2019 20:46 i have modified the variables in on/off configuration. Now what?
Haha, correct. Waste of time.Nothing!
zak45
Right. And as AE said :
"The only thing that interferes with my learning is my education".
Last news about the plugin:
have made some test to "try" to do Geofencing (yep, last version can retreive GPS coordinate)... but not work as expected (could be me .. need to double-check)
In process to finalize devices creation...
kniazio
What's happening with jarvis @ home?
Will there be a plugin for Domoticz, who was promised?
zak45
yep, but we all have life and things not always happend as we want.. still on progress/test, and need now to write the Wiki!!kniazio wrote: Tuesday 29 January 2019 18:36 What's happening with jarvis @ home?
zak45
for people with some py knowledge.
no support from my side for the moment (not enough time).
but should not be difficult to setup (see some help on doc folder)
this manage :
Voice command
TTS
Android Notification
Geofencing (with Automate)
MyLocation(with Automate)
https://www.dropbox.com/sh/js6a1voczrm7 ... BeUWa?dl=0
this manage :
Voice command
TTS
kniazio
My errors:
configurations are different
2019-02-23 19:49:37.849 (DomVoice) Initialized version 1.0.0, author 'zak45'
2019-02-23 19:49:37.874 (DomVoice) lang file : /home/domoticz/plugins/EZJarviz/en_en.lng
2019-02-23 19:49:37.874 Error: (DomVoice) Traceback (most recent call last):
File "/home/domoticz/plugins/EZJarviz/plugin.py", line 968, in loadLang
with open(lang_file, 'r' , encoding='utf-8') as fp:
FileNotFoundError: [Errno 2] No such file or directory: '/home/domoticz/plugins/EZJarviz/en_en.lng'
2019-02-23 19:49:37.874 Error: (DomVoice) __Lang file not exist or to process data from : /home/domoticz/plugins/EZJarviz/en_en.lng__
2019-02-23 19:49:37.874 Error: (DomVoice) __Language file is missing for : en__
2019-02-23 19:49:37.875 Error: (DomVoice) 'onStart' failed 'AttributeError':''module' object has no attribute 'Connection''.
2019-02-23 19:49:37.875 Error: (DomVoice) ----> Line 205 in /home/domoticz/plugins/EZJarviz/plugin.py, function onStart - Attachments
- my config.jpg (127.13 KiB) Viewed 2474 times
- ezjsettings.JPG (127.83 KiB) Viewed 2476 times
zak45
you need to take the one on the lng folder.
kniazio
there is no en_en.lng file in the lng folder
Which means:
what is this
Which means:
2019-02-23 23:17:24.292 Error: (DomVoice) 'onStart' failed 'AttributeError':''module' object has no attribute 'Connection''.
2019-02-23 23:17:24.292 Error: (DomVoice) ----> Line 205 in /home/domoticz/plugins/EZJarviz/plugin.py, function onStart - Attachments
- my config.jpg (127.13 KiB) Viewed 2462 times
kniazio
I do not understand how it works
zak45
All is on the dropbox.
If you do not have enough python knowledge, not simple.
And without any documentation, not easy.
Maybe better for you to wait for the WiKi.
