Page 3 of 3
Re: Domotics touchscreen remote
Posted: Sunday 11 November 2018 23:13
by ledfreak3d
I can help you with that send me an email and ill help you to get it working
Posted: Thursday 15 November 2018 9:04
by ledfreak3d
basicly you can make the gui anything you like its not to hard to customize
but realy need some extra hands to get it the way i want.
might port it to the esp32 so it can go into very low power consumption mode
with a full charge i can keep it running for 14 hours but prety sure i cna get a lot more out of it
Posted: Thursday 15 November 2018 17:12
by dozen
I have 3d Printed a case and its connected and working
I have renamed the buttons that i use and now i wanted to do some more changes in the Nextion Editor.
But i dont know to update on the Nextion.
After i made some changes like renaming a button, i click on compile and it says succesful with no errors.
Then i click upload(its com3) and there is: Connection Failed, Forced interrupt!
Dont know what im doing wrong....
Gesendet von iPhone mit Tapatalk
Posted: Thursday 15 November 2018 17:58
by dozen
Found it
I must use the tft File not the hmi
Posted: Thursday 15 November 2018 18:47
by ledfreak3d
Yep thats correct
Posted: Friday 21 June 2019 18:33
by ackcsaba
Hello!
I have a little problem .
It only works correctly when I load the firmware. As soon as I restart the D1 mini it seems as if it would not find a Wifi network (No SSID and No IP text will appear on the home screen). If I refill the firmware again, the correct SSID and IP address will appear as well as the switches react.
Please help!
Thanx
Best Regards
Csaba
Posted: Saturday 22 June 2019 14:11
by ledfreak3d
That should not be to hard to fix ive not seen that issue before yet
