Domotics touchscreen remote
- ledfreak3d
- Domoticz version: 3.8025
been tinkering around with my esp8266 and nextion display and came up with this
Latest Version
https://www.youtube.com/watch?v=c9OlHDThYEU&t
version 1
https://www.youtube.com/watch?v=8l1OMS5RgYA
version 2
https://www.youtube.com/watch?v=cjk7dPBZKyQ
version 3
https://www.youtube.com/watch?v=eGgEL6HHckQ
its still a work in progress but it turned out realy nice
also supports ota updates via a web interface
Latest Version
version 1
version 2
version 3
Unleashe the magic smoke ;)
blauwebuis
- Domoticz version: current
Re: Domotics touchscreen remote
Very nice. Is that a custom front end?
- EdwinK
- Domoticz version: BETA
I like the Star Trek one
jackslayter
- Domoticz version: stable
Need !!
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
- heggink
- Domoticz version: 12451
Those displays are pretty magnificent. Not cheap tho for the bigger ones.
P1 meter & solar panel
dannybloe
This is awesome! I do like the star trek one the best. Didn't know about that display. Cool stuff.
bilbolodz
Are you going to share your project?ledfreak3d wrote: Sunday 17 September 2017 20:21 been tinkering around with my esp8266 and nextion display and came up with this
- ledfreak3d
Yep sure are
for anybody that's wants it just contact me
new version has had a lot of updates both in the code as in the gui
- 3.JPG (34.66 KiB) Viewed 10329 times
- 2.JPG (42.83 KiB) Viewed 10329 times
- 1.JPG (34.48 KiB) Viewed 10329 times
- rbo0567
- Domoticz version: v4.9701
Is it possible to use it as an alarm keypad? Are you considering to implement that in your project?
I would really like this because I can't find a nice and good featured alarm keypad to use with domoticz.
- ledfreak3d
not sure but I can investigate
if its possible to send json commands for the keypad then it should be possible
- ledfreak3d
Latest version is here
now has a couple of new options
-ftp server onboard for uploading config files
-config can be changed via build in webserver
-battery status is reported back to domoticz.
-voice updates are possible now via the remote hw info will folow
-battery last atleast a full day with a 2600 mAh Lipo
https://github.com/ledfreak3d/Domoticz-remote-
alexsh1
- Domoticz version: v3.8975
Which Nextion display do you use please?
Could you share your 3D enclosure files as well?
Many thanks
- ledfreak3d
Hi.
I use the 3.5 inch version
there is a case i designed for it on thingiverse.
make sure you download the version with the usb port cutout
https://www.thingiverse.com/thing:1708255
- ledfreak3d
tontze
- Domoticz version: Beta Ch
Very nice !
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
dannybloe
Is this also a nice solution to create a security panel with?
- ledfreak3d
- ledfreak3d
need some help with gui optimization and code cleanup and add some features and need some people for testing
BigDog
- Domoticz version: V3.9269
WOW i really would like this one!
it it easy to adjust to personal situation?
and the "how to make it" is it good to do for a beginning electronica person , i can make some prints but not so advanced and i need a schematics
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
BigDog
question: do you guysd know where to get a printed version of this "Nextion housing for 3.5 inch"
or some place where to get a good housing for this project?
