Page 3 of 9
Re: Dashticz - Module - Spotify
Posted: Wednesday 09 August 2017 20:46
by capman
freakshock wrote: Wednesday 09 August 2017 13:22
A possible alternative is using Logitech media server with a Spotify plugin (I use Spotty).
This way you can use a standard mediaplayer block in Dashticz. That way you can use back, stop, play/pause and next buttons.
I also made a selector switch that can choose playlist within Spotty (all manual config unfortunately).
Of course you would need a server to run LMS.
Could you please explain this how to do this ? Thanks.
Posted: Wednesday 09 August 2017 23:02
by pvm
Can you open a new topic for this? (Install picoreplayer) more in New topic
Posted: Friday 11 August 2017 17:21
by vgr2
vgr2 wrote: Monday 10 July 2017 21:10
I mean, empty playlist
Something changed on last updates? I have again the empty playlist.
Posted: Tuesday 15 August 2017 18:22
by nvb1989
Hi Rob,
I'm very happy with the Spotify plugin. I was curious if you can integrated Spotify Connect within the plugin.
It would be awesome if I can choose the device to listen spotify on.
Posted: Tuesday 15 August 2017 19:21
by pvm
Is it possible to create a similar layout for LMS?
More info in
viewtopic.php?t=18835#p146316
Posted: Wednesday 16 August 2017 10:24
by robgeerts
nvb1989 wrote: Tuesday 15 August 2017 18:22
Hi Rob,
Working on it
by robgeerts
Posted: Wednesday 16 August 2017 15:46
by Trigun
Wow, would me an amazing add on rob!
Posted: Thursday 17 August 2017 20:16
by nvb1989
robgeerts wrote: Wednesday 16 August 2017 10:24
Hi Rob,
Working on it
Great job! If you need someone to test, I'm available
Posted: Thursday 17 August 2017 22:27
by pvm
Nice
Posted: Wednesday 23 August 2017 17:37
by codesnipper
Not works
I have empty page with bar (clock,title,settings icon).
In console: "Enter your Spotify ClientID in CONFIG.JS"
CONFIG.js:
var config = {}
config['domoticz_ip'] = 'http://192.168.1.24:8080';
var _CLIENTID_SPOTIFY = 'hereismyclientid';
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['spotify']
columns[1]['width'] = 5;
Redirect URIs:
http://localhost:8080/dash/
http://192.168.1.24:8080/dash/
Posted: Wednesday 23 August 2017 21:58
by robgeerts
The variable where you entered the spotify id is old, take a look at my example config.js in this topic:
http://www.domoticz.com/forum/viewtopic ... 67&t=17426
Posted: Tuesday 29 August 2017 23:25
by Trigun
Hi Guys, the spotify plug-in works like a charm, great job!! Allthough do you guys also experience that the songs only play for 30seconds? After that it asks me to open up the app. Hopefully I'm doing something wrong. Thnx!
Posted: Wednesday 30 August 2017 22:31
by Trigun
Trigun wrote: Tuesday 29 August 2017 23:25
when I run it on an Ipad it keeps asking to play the song in the spotify app.
wheni run it on a laptop, after 30 seconds i get the following message(and the music stops)
- Knipsel.PNG (11.12 KiB) Viewed 6432 times
any chance someone knows how to workaround this?
Posted: Sunday 17 September 2017 12:04
by jjnj
How is the play on other device going? I'm using a Multiroom setup in my house, that would be a great addition!!!
Posted: Wednesday 11 October 2017 21:56
by dlefol
I've tried to follow the instructions but I end up with the empty playlist box (I see the select playlist box, but no playlist to select inside it).
I have spotify installed on the tablet where I use Dashticz and spotify in the app is running fine, however I cannot make it show my playlist within Dashticz
One thing is not clear for me, do I need spotify app to run also on the server where domoticz and dashticz are hosted or is it only on the client side (the tablet in my case) that I need the spotify app (I run domoticz on a RPi so I cannot test easily the installation of spotify on it and want to know if that s the source of the problem before I dig deeper that way...)
Thanks in advance
Posted: Wednesday 11 October 2017 22:00
by woody4165
Spotify is not needed on the server.
Try to open Spotify on the same browser you use for Dashticz, login and play a song in one of your playlist.
If I don't do like this, I have your same issue.
Posted: Wednesday 11 October 2017 22:09
by dlefol
It worked
Great!
Thanks a lot for the tip. I had tried playing songs and playlists on the tablet but always through the spotify app installed on the tablet. Opening the web player on a browser tab and playing a song from there was needed.
Thanks for the quick reply
Posted: Tuesday 31 October 2017 11:25
by basxcore
Hi Rob,
Working on it
I really (want) like this feature. Do you have it available yet? Beta perhaps? Thanks!
Posted: Wednesday 08 November 2017 23:10
by robgeerts
Sorry not yet, trying to find some spare time to finish this..
