Dashticz - Module - Calendar
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Module - Calendar
Post by robgeerts »
Ok, more then 1 mistakes ;)
1.) calender.hd must be calender.hobbydeed
2.) you didnt declare columns[40] with columns[40] = {}
3.) you didnt specify a width of the column
Try this:
var columns = {}
	// First Column
	columns[10] = {}
	columns[10]['blocks'] = ['clock','weather']
	columns[10]['width'] = 4;
	// Second Column
	columns[20] = {}
	columns[20]['blocks'] = ['weather']
	columns[20]['width'] = 4;
	// Fourth Column
	columns[30] = {}
	columns[30]['blocks'] = ['clock','sunrise','horizon','streamplayer',buttons.radio,buttons.nunl]
	columns[30]['width'] = 2;
	// Third Column
	columns[25] = {}
	columns[25]['blocks'] = [buttons.moon]
	columns[25]['width'] = 1;
	columns[40] = {}
	columns[40]['blocks'] = [calendars.hobbydeed]
	columns[40]['width'] = 1;
I changed the width of the column with the moon it to 1, otherwise the total width exceeds 12...
tontze
Domoticz version: Beta Ch
Post by tontze »
robgeerts wrote:Ok, more then 1 mistakes ;)
Try this:
var columns = {}
	// First Column
	columns[10] = {}
	// Second Column
	columns[20] = {}
	// Fourth Column
	columns[30] = {}
	// Third Column
	columns[25] = {}
	columns[40] = {}
I did change hobbydeed to hd before sending, thought i wouldnt want to share it, but forgot to change both :) declaring and width was indeed missing, since it wasnt in the instructions on the first page either .. :) Now i know they allways needs to be :)
Learning, learning :)
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
robgeerts
Post by robgeerts »
tontze wrote:.... since it wasnt in the instructions on the first page either ..
Added to first post ;)
robgeerts
Post by robgeerts »
In latest version, the latest calendar-module is available BUT BUT BUT
Combined doesn't work yet and probably only calendar at the time. This renewed version is FAR FROM FINISHED.
So beware ;)
lukev
Re: blacksn0w
Post by lukev »
blacksn0w wrote: To be honest, following your argumentation the switches and all other Domoticz things aren't visible. But who will stop people from looking into your CONFIG.js, find the info about your Domoticz installation and go to the Domoticz backend? Leaving this unprotected in the net is more then careless.
See my PM
mvveelen
Post by mvveelen »
robgeerts wrote:In latest version, the latest calendar-module is available BUT BUT BUT
So beware ;)
I thought you fixed it? Is it broken in the current beta? In my dashboard it keeps loading now....
EdwinK
Post by EdwinK »
Finally found out what I was doing wrong with my calendar, I used two different agenda's from different gmail-accounts. Got it working for one of them. Now I got to get rid of the old appointments.
robgeerts
Post by robgeerts »
So beware ;)
Try removing https://cors-anywhere.herokuapp.com/ in config.js
HansieNL
Post by HansieNL »
robgeerts wrote:Try removing https://cors-anywhere.herokuapp.com/ in config.js
I got the same problem, but not using cors. I make use of a local file.
Calendar still keeps loading... I'll check on regular bases if new beta solves the problem.
Blah blah blah
qwerk
Post by qwerk »
Calendar still loading. also using a local ics file
I also switch from webserver......... but ics is available via url.
blacksn0w
Post by blacksn0w »
Same here, since The New calendar module is trying to convert the ics to json via an online Service it is neccesary that the used calendar is adressed by a online url and not a local file.
qwerk
Post by qwerk »
aha,
that explains a lot.
maybe it is possible for the "intern ics" users, to also have the convertion done locally.
step by step, but for the near future .....
HansieNL
Post by HansieNL »
Mmm... uploaded the calendar.ics file to my web provider and used that url (and checked, because I can dowload the file), but still no luck.
Any suggestion?
Blah blah blah
blacksn0w
Post by blacksn0w »
HansieNL wrote:
blacksn0w wrote:
HansieNL wrote: I got the same problem, but not using cors. I make use of a local file.
Any suggestion?
Had The same Problem, try it here with your url and See if there is an error: http://ical-to-json.herokuapp.com
This is the Service used by the calendar Module.
HansieNL
Post by HansieNL »
blacksn0w wrote: Had The same Problem, try it here with your url and See if there is an error: http://ical-to-json.herokuapp.com
Got this message:
Error parsing feed: Encoding::UndefinedConversionError
"\xC3" from ASCII-8BIT to UTF-8
I'll leave it for now and hope it will be possible to use the local file some day.
Blah blah blah
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
I downloaded the latest beta and noticed that the calendar isn't sorting on date, its putting everything randomly.
I use google calendar.
HansieNL
Post by HansieNL »
SwordFish wrote:I downloaded the latest beta and noticed that the calendar isn't sorting on date, its putting everything randomly.
I don't care what you do, but for your own privacy it's maybe better that you blur your descriptions ;)
Blah blah blah
robgeerts
Post by robgeerts »
I know, sorry, I'm not ready yet with rebuilding the calendar...
SwordFish
Post by SwordFish »
Thanks, didn't thought about it :oops:
alveman
Post by alveman »
Had this conf working before I updated to the latest beta:
var _ICALENDAR_URL			= 'https://crossorigin.me/https://p02-calendarws.icloud.com/ca/subscribe/1/XXX';
var _ICALENDAR_DATEFORMAT	= 'YYYY.MM.DD HH:mm';
var _ICALENDAR_LOCALE		= 'en';
Now the calendar just saying "Loding..." any suggestions? I'm using iCloud calendar.
Martin
