Page 3 of 11
Re: framb0ise v2 - awesome new dashboard!
Posted: Sunday 23 April 2017 17:34
by safi78
Maikie wrote:jvdz wrote:Maikie wrote:
When I now browse to my domoticz url with /framb0ise I get the domoticz offline message.
What did I do wrong?
I had the same and had to add /index.html to the end of the url.
Jos
That indeed did the trick, thanks!
did you leave out the trailing slash?
http://192.168.0.100:8080/framb0ise does not work
http://192.168.0.100:8080/framb0ise/ does work
Posted: Sunday 23 April 2017 17:36
by safi78
andi216 wrote:can you test the new version?
Nothing changed
did you emtpy your browser cache? sometimes the older version of the .js files keep being used.
Posted: Sunday 23 April 2017 17:40
by Maikie
Ah, I see, yeah with / it also works.
I only see info at the moment but that is because I don't have rooms setup I guess?
Posted: Sunday 23 April 2017 17:45
by qwerk
safi78 wrote:andi216 wrote:I have a FA20RF smoke detector.
In page icon smoke detector does not change the status (is red) even if the sensor is on or off.
I now have a green smokedetector on my screen.
Posted: Sunday 23 April 2017 17:46
by andi216
Yes.
Now it's always green. : (
Posted: Sunday 23 April 2017 17:56
by qwerk
andi216 wrote:did you emtpy your browser cache? sometimes the older version of the .js files keep being used.
Yes.
so, no fire at your place.
just kidding: same here.
always green
Posted: Sunday 23 April 2017 18:24
by safi78
Si.
Posted: Sunday 23 April 2017 18:26
by safi78
always green
Try the new update.
Posted: Sunday 23 April 2017 18:31
by qwerk
safi78 wrote:
Try the new update.
green and red smokedetectors ( at the right moments)
man, you're fast
I don't have time to find flaws with this solving rate.
Posted: Sunday 23 April 2017 18:37
by Maikie
Si.
I did have a room already but only had 1 device added to that so I now added more rooms but still nothing showing, any idea?
Posted: Sunday 23 April 2017 18:43
by qwerk
Si.
DO you need a login and password for domoticz and did you put that in the config.js?
are you using room names or device names starting with a $
Posted: Sunday 23 April 2017 18:47
by Maikie
qwerk wrote:Maikie wrote:safi78 wrote:
Si.
On the local network there is no need for a login so I didn't put that in the config file.
There is 1 default room with a $ in front called hidden devices. The ones that I created myself don't have a $ in front.
Posted: Sunday 23 April 2017 18:48
by andi216
Status smoke icon:
Domoticz SMOKE ON > framb0ise red
Domoticz SMOKE OFF (Reset) > just refresh page > framb0ise green
Posted: Sunday 23 April 2017 19:12
by qwerk
Just to be on the safe side, please try also with a username and password in the config.js.
Posted: Sunday 23 April 2017 20:01
by Maikie
In my first post I mentioned the config file was empty, it appears I was editing the config file in the domotics www folder. I just found the right config file and I changed the IP, still no luck.
Should I enter with username and pass like the format in the example? https://username:password@ip:port?
Posted: Sunday 23 April 2017 20:10
by jvdz
@safi78,
Guess this setup is becoming quite popular.
Adding the slash after the url is indeed now working, but thought I tried that in the beginning as well... not important now.
I noticed that the script is not filtering the scene in the rooms and assumes they are device idx'es. I have scene in rooms as the DTGMENU setup is using the same approach as your web front-end and using the room definitions for the telegram inline menu structure. So I have quite some SCENEs/GROUPs defined in them which are showing now obviously strange information.
How do you feel about this? Should they be filtered out or should there be support for SCENE's/Groups like in the regular frontend?
Jos
Posted: Sunday 23 April 2017 20:27
by safi78
Jos
Hi Jos,
Yeah, let's filter rooms/groups the same way.
Scenes can be a Push On
Groups can be be an On/Off
Agree?
Posted: Sunday 23 April 2017 20:30
by safi78
Nope, no idea. What does the browser console say? (usually in Developer tools in your browser). When stuff goes horribly wrong, it's usually logged in there.
Posted: Sunday 23 April 2017 20:33
by Maikie
Posted: Sunday 23 April 2017 20:35
by safi78
Wow.
You are using https:// (ssl) AND port 8080 ...
Pick 1, don't care which, it's your setup
Either use https or remove 8080 depending on your setup.
