robgeerts
Domoticz version: 3.7067
Re: New Dashboard Design
Post by robgeerts »
If you open console (F12) and reload the dashboard, you can see a call made to Domoticz (network-tab), if you click on it, it will show his response, could you send me this response in a PM?
Verstuurd vanaf mijn SM-G930F met Tapatalk
Ierlandfan
Post by Ierlandfan »
I want to change the image of a custom selector switch based on the levels
I can see there is some code for that but it is hashed out.
 //if(parseFloat(data.result[r]['Level'])==0) switchHTML+='<img src="img/'+buttonimg+$
//else
 switchHTML+='<img src="img/'+buttonimg+'_on.png" class="on icon" />';
It seems I only have to define the levels and the icon I want to show for that level?
like:
 if(parseFloat(data.result[r]['Level'])==10) switchHTML+='<img src="img/some-image"
elseif
 if(parseFloat(data.result[r]['Level'])==20) switchHTML+='<img src="img/some-other-image"
switchHTML+='<img src="img/'+buttonimg+'_off.png" class="on icon" />';
Right?
Another question
 else if(typeof(data.result[r]['LevelActions'])!=='undefined' && data.result[r]['LevelActions']!=="")
How can I change that to my custom idx?
robgeerts
Post by robgeerts »
Ierlandfan wrote: It seems I only have to define the levels and the icon I want to show for that level?
Right?
Right!
Another question
How can I change that to my custom idx?[/quote]
else if(data.result[r]['idx']==123)
Ierlandfan
This test ended up in missing text and completely no block of switches
(I suck in coding html and javascript I know....I probably forgot some } somewhere?)
$('#groups').append(switchHTML);
else if(data.result[r]['idx']==104)
var actions = data.result[r]['LevelActions'].split('|');
var names = data.result[r]['LevelNames'].split('|');
var switchHTML = '<div class="col-md-4 mb no-pr switch" data-light="'+data.result[r]['idx']+'">';
switchHTML+='<div class="transbg"> ';
switchHTML+='<div class="col-md-4 no-padding">';
if(parseFloat(data.result[r]['Level'])==10) switchHTML+='<img src="img/weekend.png">;
if(parseFloat(data.result[r]['Level'])==20) switchHTML+='<img src="img/other-image'>;
if(parseFloat(data.result[r]['Level'])==30) switchHTML+='<img src="img/groen.png">;
if(parseFloat(data.result[r]['Level'])==40) switchHTML+='<img src="img/'+buttonimg+$
if(parseFloat(data.result[r]['Level'])==50) switchHTML+='<img src="img/'+buttonimg+$
if(parseFloat(data.result[r]['Level'])==60) switchHTML+='<img src="img/'+buttonimg+$
if(parseFloat(data.result[r]['Level'])==70) switchHTML+='<img src="img/'+buttonimg+$
if(parseFloat(data.result[r]['Level'])==90) switchHTML+='<img src="img/'+buttonimg+$
switchHTML+='</div>';
switchHTML+='<div class="col-md-8 no-padding">';
switchHTML+='<strong class="title">'+data.result[r]['Name']+'</strong><br />';
switchHTML+='<select onchange="switchDeviceBtn(this,this.value);">';
switchHTML+='<option value="">Selecteer</option>';
for(a in actions){
switchHTML+='<option value="'+actions[a]+'">'+names[a]+'</option>';
switchHTML+='</select>';
$('#switches').append(switchHTML);
else if(typeof(data.result[r]['LevelActions'])!=='undefined' && data.result[r]['LevelActions']!==""){
robgeerts
Post by robgeerts »
Please attach your main.js to your reply..
Ierlandfan
Here it is
main.js
(17.16 KiB) Downloaded 190 times
robgeerts
Post by robgeerts »
Well, you missed a lot of } and ' but I fixed it.
Don't know if the result is expected but at least there are no more parse errors in the script.
main.js
(14.94 KiB) Downloaded 166 times
Awst6000
Post by Awst6000 »
Is there an easy/simple way to display only the groups, switches and sliders?
I tried to edit the index.html, but I end up with only the left side of the screen filled.
robgeerts
Post by robgeerts »
You have to change:
<div class="col-md-5" style="padding-right:30px;">
to:
<div class="col-md-12" style="padding-right:30px;">
On row 34
Awst6000
Post by Awst6000 »
I'll grab a cool beer and try this immediately :-)
Txs!
Awst6000
Post by Awst6000 »
This way I get 3 very wide switchboxes on every row.
Is there a way to get about 8 of them on each row?
I wish I didn't have to ask these simple questions, but unfortunately I'm not a coder :(
robgeerts
Post by robgeerts »
You can found several times things like 'col-md-6' or 'col-md-4' in main.js, change the number to 1,2,3, etc, for example: col-md-1
Racierox
Post by Racierox »
Very nice dashboard! I got it working by copying the contents, changing the domoticz ip, wunderground api and so on.
Only problem is it doesn't automatically load my favorite switches. It doesn't load a single switch at all. What can I do about this?
robgeerts
Post by robgeerts »
I think you've set the wrong IP or PORTnumber of Domoticz.
Or do you have a username/password?
If you have username/password, enter:
http://username:pass@ip:port
e.g.: http://admin:[email protected]:8080
or if you don't have a password:
http://ip:port
e.g.: http://192.168.1.23:8080
If it still doesn't work, open your console (F12) en see if it shows any errors in console-tab.
Ierlandfan
Thanx for the main.js! Perfect! Level off and no image it won't show which is exactly what I wanted!
I noticed that the page does not respond to the change of switches. I have to manually reload (F5) the page for the change to show up.
Is there any refresh timer I can adjust?
robgeerts
Post by robgeerts »
My dashboard does response to the change of switches, although it could take some seconds... After a click on the switch it gets the new states of all switches from Domoticz and rebuild the blocks.
Ierlandfan
I started over..unzipped the original (with the then 2 hours old update) dashboard..only changed CONFIG.js (IP and Port) No refesh.
I started over...downloaded the original tar (a few minutes ago) dashboard..untarred the archive...only changed CONFIG.js (IP and Port) No refesh.
Tried Chrome, Microsoft Edge & IE..no refresh.
Tot test Domoticz I installed another frontpage...that responded.
Could it be that the update from yesterday broke the refresh?
robgeerts
Post by robgeerts »
Well, its possible, do you get any errors in console (F12)?
Ierlandfan
Did a git clone (just to make sure)...same result.
I checked out branch 8fb5c41f and that one worked immediately.
No errors in the console for as far as I can see. I can see that nzbget (which i don't use) is the only part that updates.
robgeerts
Post by robgeerts »
I'll check tonight!
Locked
