Page 3 of 3
Re: Samsung TV control in Domoticz
Posted: Friday 17 November 2017 11:48
by perwei
stavast wrote: Friday 31 March 2017 18:40
Good luck!
I've finally got the spare time to try samsunctl. I've installed it on my Raspberry Pi using pip3 as described in the initial post from stavast. No errors during installation but running samsungctl returns an error :
pi@raspberrypi:~ $ /usr/local/bin/samsungctl -i --host 10.0.0.71 --method websocket
Error: Operation now in progress
I was wondering which port it was using so i looped through the ports that nmap found :
~$ nmap -p 1-65535 10.0.0.71
Starting Nmap 7.01 ( https://nmap.org ) at 2017-11-17 11:43 CET
Nmap scan report for 10.0.0.71
Host is up (0.010s latency).
Not shown: 65523 closed ports
PORT STATE SERVICE
7676/tcp open imqbrokerd
7678/tcp open unknown
8000/tcp open http-alt
8001/tcp open vcom-tunnel
8002/tcp open teradataordbms
8080/tcp open http-proxy
8187/tcp open unknown
9119/tcp open unknown
9197/tcp open unknown
9999/tcp open abyss
10443/tcp open unknown
15500/tcp open unknown
Nmap done: 1 IP address (1 host up) scanned in 2.34 seconds
Then I went through all of these using --port parameter in samsungctl but still the same error.
Regards,
Per W.
Posted: Friday 17 November 2017 14:19
by EdwinK
Same error. Not smart enough to figure it out
Posted: Sunday 31 December 2017 16:04
by Calzor Suzay
4. Make sure your TV is on, run the following command from the cli (Change xxx.xxx.xxx.xxx with the IP address of your TV):
pi@domoticz:~ $ samsungctl --host xxx.xxx.xxx.xxx --method websocket KEY_MUTE
5. Depending on the setting of your TV, the TV will ask you if you want to allow the external control from the device from which you just send the mute key
6. Allow the external control with your TV Remote and voila! remote control should be working now and the volume of your TV should be muted.
How did you get this working and what is point 5?
Is it mobile device manager notification as I have this off so it shouldn't prompt but on my KS7000 I get
samsungctl -i --host 192.168.1.42 --method websocket
Any ideas?
Posted: Sunday 31 December 2017 20:40
by Calzor Suzay
Ok managed to get it further...
I have it working via the command line but specify a port, in my case 8001 and have to add a timeout option, even 1 works, so...
samsungctl -i --host 192.168.1.42 --port 8001 --method websocket --timeout 1
Brings me up a menu from a quick test can send commands.
I transferred the options over to Domoticz, it sees the tv 'alive' but now have this problem
2017-12-31 19:35:17.480 (SamsungTV) isAlive status :True
2017-12-31 19:35:17.480 (SamsungTV) Devices are connected - Initialisation
2017-12-31 19:35:17.482 Error: (SamsungTV) 'onStart' failed 'ImportError'.
2017-12-31 19:35:17.482 Error: (SamsungTV) ----> Line 134 in /home/osmc/domoticz/plugins/SamsungTV/plugin.py, function onStart
2017-12-31 19:35:17.482 Error: (SamsungTV) ----> Line 287 in /home/osmc/domoticz/plugins/SamsungTV/plugin.py, function SamsungSend
2017-12-31 19:35:17.482 Error: (SamsungTV) ----> Line 10 in /usr/lib/python3.4/samsungctl/remote.py, function __init__
2017-12-31 19:35:17.482 Error: (SamsungTV) ----> Line 13 in /usr/lib/python3.4/samsungctl/remote_websocket.py, function __init__
2017-12-31 19:35:17.482 (SamsungTV) Heartbeat interval set to: 15.
It obviously creates no devices and fails, any ideas?
