stavast wrote: ↑Friday 31 March 2017 18:40
Good luck!
I've finally got the spare time to try samsunctl. I've installed it on my Raspberry Pi using pip3 as described in the initial post from stavast. No errors during installation but running samsungctl returns an error :
~$ nmap -p 1-65535 10.0.0.71
Starting Nmap 7.01 ( https://nmap.org ) at 2017-11-17 11:43 CET
Nmap scan report for 10.0.0.71
Host is up (0.010s latency).
Not shown: 65523 closed ports
PORT STATE SERVICE
7676/tcp open imqbrokerd
7678/tcp open unknown
8000/tcp open http-alt
8001/tcp open vcom-tunnel
8002/tcp open teradataordbms
8080/tcp open http-proxy
8187/tcp open unknown
9119/tcp open unknown
9197/tcp open unknown
9999/tcp open abyss
10443/tcp open unknown
15500/tcp open unknown
Nmap done: 1 IP address (1 host up) scanned in 2.34 seconds
Then I went through all of these using --port parameter in samsungctl but still the same error.
Regards,
Per W.
Raspberry Pi 3/Raspbian GNU/Linux
Z-Wave.Me Razberry2 Z-Wave controller
3 x Aeotec ZW100 Multisensor 6
1 x Aeotec Smart Dimmer 6
2 x FIBARO System FGWPE Wall Plug
2 x FIBARO Dimmer 2 FGD-212
1 x FIBARO System FGK10x Door Sensor
1 x Popp Wall Controller
5. Depending on the setting of your TV, the TV will ask you if you want to allow the external control from the device from which you just send the mute key
6. Allow the external control with your TV Remote and voila! remote control should be working now and the volume of your TV should be muted.
How did you get this working and what is point 5?
Is it mobile device manager notification as I have this off so it shouldn't prompt but on my KS7000 I get
samsungctl -i --host 192.168.1.42 --method websocket
Error: Operation now in progress
Brings me up a menu from a quick test can send commands.
I transferred the options over to Domoticz, it sees the tv 'alive' but now have this problem
2017-12-31 19:35:17.480 (SamsungTV) isAlive status :True
2017-12-31 19:35:17.480 (SamsungTV) Devices are connected - Initialisation
2017-12-31 19:35:17.482 Error: (SamsungTV) 'onStart' failed 'ImportError'.
2017-12-31 19:35:17.482 Error: (SamsungTV) ----> Line 134 in /home/osmc/domoticz/plugins/SamsungTV/plugin.py, function onStart
2017-12-31 19:35:17.482 Error: (SamsungTV) ----> Line 287 in /home/osmc/domoticz/plugins/SamsungTV/plugin.py, function SamsungSend
2017-12-31 19:35:17.482 Error: (SamsungTV) ----> Line 10 in /usr/lib/python3.4/samsungctl/remote.py, function __init__
2017-12-31 19:35:17.482 Error: (SamsungTV) ----> Line 13 in /usr/lib/python3.4/samsungctl/remote_websocket.py, function __init__
2017-12-31 19:35:17.482 (SamsungTV) Heartbeat interval set to: 15.
It obviously creates no devices and fails, any ideas?
