Xiaomi Mi Flora [Temp/Light/Moisture] BLE Sensor
deennoo
Re: Xiaomi Mi Flora [Temp/Light/Moisture] BLE Sensor
Post by deennoo »
Update to last stable @lepetitnicolas
http://domo-attitude.fr
pvm
Domoticz version: 4.10538
Post by pvm »
Add hardware type dummy and after that the switches
lepetitnicolas
Domoticz version: 3.5877
Post by lepetitnicolas »
I found it.... in french "Custom sensor" is translate in "texte"
I'm waiting tomorrow to see if my crontab works.
Raspberry Pi 3 - RFLink and Homewizard
deennoo
Post by deennoo »
lepetitnicolas wrote:Thanks
No lepetitnicolas, his name on french is :
lepetitnicolas
Thanks Deennoo.
Now, i see it....i don't know why it don't see it yesterday.... tiredness
but it seems working with a text sensor.
I would try this tonight to see the difference
deennoo
Post by deennoo »
advantage of a custom sensor is that you can have a graphique to show value (text doesn't do this)
jadon
Post by jadon »
LouiS22 wrote:
trixwood wrote:yes! as many as you like.
Does anybody has some info on how long the battery will last?
The users manual promises a year, but IMHO it really depends on your using habits: i.e. if you poll the data every minute, it will suck the battery really fast.
I'm using it since nov 20, so almost a month, and I'm polling the sensor every hour. The battery reports 79%. So I'm guessing it could last a year, maybe by polling it every 2 hours.
simply
Post by simply »
Impressive small devices! Ordered four of them and they arrived this friday. Got it all working yesterday after installing Jessie on my RPi B2 and then following the guide @ http://www.elinux.org/RPi_Bluetooth_LE .
Thanks for the script posted here... ;)
jkimmel
Domoticz version: 2021.1
Post by jkimmel »
Running the modified script I get
pTraceback (most recent call last):
  File "flora.py", line 1, in <module>
    import urllib.request
ImportError: No module named request
What I'm missing?
Rfxcom
Raspi 4
trixwood
Post by trixwood »
pip install requests
jkimmel
Post by jkimmel »
I don't get the script running, I'm completely new to Phyton.
Please what has to be installed to run it?
Rfxcom
Raspi 4
trixwood
Post by trixwood »
Yes so install the missing module with the command
LouiS22
Post by LouiS22 »
So I got mine today. Paired with my phone, downloaded the app, so far so good.
But...
I'm having hard time working with Domoticz. I followed the above guides, compiled bluez, my dongle is ok, lescan shows the MAC, etc. I've changed the MAC address in demo.py, but all I got in return is the following:
FW: None
File "demo.py", line 7, in <module>
    print("Name: {}".format(poller.name()))
  File "/home/pi/miflora/miflora/miflora_poller.py", line 172, in name
    timeout=self.ble_timeout)
  File "/home/pi/miflora/miflora/miflora_poller.py", line 139, in read_ble
    time.sleep(delay)
I have no Idea what's wrong. Maybe worth mentoning that the android app downloaded a firmware upgrade so the device runs a 2.7.0 firmware.
Any ideas?
deennoo
Post by deennoo »
Mine works on 2.7.0 fw and script is still working, fw isn't the key
trixwood
Post by trixwood »
It relies on gatttool... are you sure it's installed in /usr/local/bin/?
Further make sure you enable low energy:
sudo btmgmt le on
Follow this guide to compile:
https://urbanjack.wordpress.com/?s=Bluez+into+BLE
LouiS22
Post by LouiS22 »
trixwood wrote:It relies on gatttool... are you sure it's installed in /usr/local/bin/?
sudo btmgmt le on
Had a quick look on this morning, seems i screwed something, thanks for the info, will look into this later, and will do another compile, just to make sure.
LouiS22
Post by LouiS22 »
sudo btmgmt le on
Thanks, It's working now. Don't know what missed before, nevertheless I recompiled everything again and it's ok now.
trixwood
Post by trixwood »
If you get more mi floras make sure you put 1 second sleep delay between readings... it seems to help with keeping the failed and retry connections to a minimum (none in my case), which happened a lot if executed directly after each other..
See: https://github.com/Tristan79/miflora/bl ... omoticz.py
LouiS22
Post by LouiS22 »
trixwood wrote:If you get more mi floras make sure you put 1 second sleep delay between readings... it seems to help with keeping the failed and retry connections to a minimum (none in my case), which happened a lot if executed directly after each other..
Thanks I only had time to test with the demo.py :)
