Page 3 of 3
Re: OTmonitor and Domoticz parallel access to OTGW
Posted: Thursday 22 February 2018 19:25
by sincze
Haha nice one. :lol:
Is is definitely faster to setup compared to the also working 100% 'node' solution described in the beginning of this post.
Tnx for sharing.
Posted: Sunday 24 June 2018 19:35
by Hobbybob
I'm having problems with my OTGW and Domoticz (as already explained in other topics). (Very) short version: When running the OTGW with OTMonitor everyhing is fine, but when I connect Domoticz to it, it only gives me the messages that start with B or T.
sincze pointed me to this topic, and I have tried the node.js-script. When I run the script (I'm using Putty), I see only one message in the domoticz-log:
OTGW: connected to: 127.0.0.1:7689
I see the script running in Putty, but nothing happens within domoticz. Very strange. Can anybody think of a reason for this?
Posted: Wednesday 07 October 2020 15:41
by annegerben
Happy user of the script here.
I've created a (quick and dirty) docker container where otmon and the script are combined:
https://hub.docker.com/repository/docke ... rben/otmon
Posted: Thursday 04 February 2021 16:08
by Lizard
ernorv wrote: Thursday 02 February 2017 7:12 @jake
Voila
A bit of a bump after 4 years, but the OTGW firmware got an update to v5 with extra fields in the PS=1 command, can this be adapted for the nodejs app? I've looked myself but I don't understand it completely.
Posted: Saturday 06 February 2021 12:06
by jake
Voila
I read through the script and I came across a line that verifies that there are 25 responses. I think that as soon as you change that to the new 34, it is supposed to work again
Posted: Saturday 06 February 2021 13:30
by kiddigital
It is not only that the V5 firmware now has 34 instead of 25 fields, also the order of the fields has changed (still the order is the OpenTherm MsgIDs but some new MsgIDs have been added in between)
Posted: Saturday 06 February 2021 14:12
by jake
kiddigital wrote:It is not only that the V5 firmware now has 34 instead of 25 fields, also the order of the fields has changed (still the order is the OpenTherm MsgIDs but some new MsgIDs have been added in between)
This script allows users to exchange what they want to show up in the ps=1 string. For myself I have exchanged an unused parameter for my solar boiler temperature. I don't think that the new order matters here. That is taken care of in domoticz by the normal OTGW hardware
Posted: Monday 07 February 2022 23:05
by jake
I updated my Opentherm Gateway over the weekend to 5.2. I couldn't find the previous version, but I expected 5.0 or 5.1.
From that moment my solar boiler reported 0.0'C in Domoticz, but still the correct temperature in OTmonitor. It scared me, since I had replaced a faulty temperature sensor in the solar boilier just that same afternoon. To find a 0.0'C temperature in Domoticz wasn't funny.
Anyway, after comparing, splitting the PS=1 string etc. I was 'rescued' by my own input here above: I obviously didn't run a +5.0 firmware, because the otgwmod was using position 11 for solar temperature ID=29. Position 11 originally was used for DHW temperature, which my boiler doesn't supply. I used that position for the solar boiler instead, using the same type of temperature sensor in Domoticz.
After I put ID=29 on position 15 and the sample change (ID=29) from position 12 (<5.0 version) to the current (+5.0 version) position 22, Domotidz was happy again.
in OTGWmod.js I also change the code tmp.length == 25 to tmp.length == 34 to meet the current PS=1 length.
Summary:
OTGWmod works just fine in +5.0 versions of the gateway as long as:
- New position in the PS=1 string is used for the value that needs to be replaced
- tmp.length == 25 is changed to tmp.length == 34
