Moon phase
Derik
Re: Moon phase
Post by Derik »
A solution for the api kill:
viewtopic.php?f=38&t=8979
Please ...
The icons include a how to....
xxx
Minglarn
Domoticz version: v3.8153
Re: Moon phase
Post by Minglarn »
wizjos wrote:Thanks @alexsh1!
I used your script and modified it somewhat :mrgreen:
The result looks like this: MoonPhase.PNG
As you can see with a Custom sensor that represents the actual moonphase as an icon 8-)
-- MoonPhase script
        os.execute('curl -s -i -H "Accept: application/json" "http://"'..DOMO_IP..'":"'..DOMO_PORT..'"/json.htm?type=setused&idx="'..idxmoonphaseicon..'"&name=Maanfase&description=&switchtype=0&customimage="'..moonPhaseIcon..'"&devoptions=1;%20&used=true"')
        print("Phase:\t"..moonPhase)
Hi! I'm planing to write a php script for moonphase. I've got it running and even show the right moon phase picture.
I was lurking around in the forum and saw you script and got curious when I noticed the this line in your code !
Is this a new function for domoticz?
So it is possible to change icon/picture with a JSON url ?
As I dont really understand you code, could you please explain the right URL to change the icon for me?
bertbigb
Re: Moon phase
Post by bertbigb »
Derik wrote:A solution for the api kill:
https://www.domoticz.com/forum/viewtopi ... =38&t=8979
Please ...
xxx
Can anyone help me where to find the icons? Because that is the nicest visible part in this script in my opinion.
Best regards Bert
Synology DS1517+ - DSM 6.2
bertbigb
Re: Moon phase
Post by bertbigb »
Please ...
xxx
Really no one can point me to a location where to find the pictures?
Best regards Bert
Derik
Re: Moon phase
Post by Derik »
@ bert i do also not have the icons...:-(
assenzuid
Re: Moon phase
Post by assenzuid »
Someone able to share the icon set and how to implement?
Hesmink
Re: Moon phase
Post by Hesmink »
Tiny issue: If you happen to live in a city with a space in the name, you have to escape the space to make it work, like:
local city = "Den%20Haag"
Eddiever
Domoticz version: 2022.1
Re: Moon phase
Post by Eddiever »
Scratching my head. Dunno what I missed. I used the wiki page to implement the moonphase. But I get this error:
Figured it out. Stupid mistake, Made an error in adjusting City (hard to know your own city were one lives for over 40 years :D )
bertbigb
Re: Moon phase
Post by bertbigb »
From the last error message I also could find out where to find the icons:
The icons for the moonphase can be found at https://github.com/robgeerts/dashticz_v2
They are part of the dashticz web interface
Best regards Bert
assenzuid
Re: Moon phase
Post by assenzuid »
How to configure domoticz to show the correct icon(s)
Jan Jansen
Domoticz version: Stable
Re: Moon phase
Post by Jan Jansen »
I used your script and modified it somewhat.
You have also contributed to creating a similar script used with Dashticz. Together with Dashticz, it works fine. But Dashticz does not always fit on my older devices. So it would be nice if the icon (custom text sensor Domoticz GUI) could be adjusted.
I already have a user variable "MoonPicture" (current value: moon.59.png). The relevant icons can be found at https://github.com/robgeerts/dashticz_v2 I assume that these icons can be uploaded using the "custom icon uploader" (am I right??). Is it possible to customize the code to make use of the user variable "MoonPicture"?
Thanks in advance!
Jan
natywna
Re: Moon phase
Post by natywna »
Nice work! In full moon I was always a little bit weird and slep not too good.
Eddiever
Re: Moon phase
Post by Eddiever »
assenzuid wrote:How to configure domoticz to show the correct icon(s)
https://www.domoticz.com/wiki/Dashticz_ ... plications
See the link above, but this is for Dashticz. I had a some troubles getting it to work but it does now and I love it!
jackslayter
Domoticz version: stable
Re: Moon phase
Post by jackslayter »
hi,
I try to make a plugin for moon phase but I have problem with python
error in dz log : "Error: (Lune) Failed to update device"
<plugin key="Lune" name="Lune" author=" " version="1.0.0" wikilink="http://www.domoticz.com/wiki/plugins/" externallink=" ">
    <params>
        <param field="Mode1" label="Key WU" width="200px" required="true" default="5ea448da70b1136f"/>
        <param field="Mode2" label="Code Country" width="100px" required="true" default="fr"/>
        <param field="Mode3" label="City" width="300px" required="true" default="paris"/>
      <param field="Mode4" label="Polling interval (minutes, 30 mini)" width="40px" required="true" default="2"/>
            <options>
                <option label="False" value="Normal"  default="True" />
            </options>
        </param>
    </params>
</plugin>
import Domoticz
# import urllib
# from urllib.request import request, urlopen
import urllib.request
import json
from datetime import datetime
from datetime import timedelta
icons = {"nouvelle": "nouvelle.zip",
         "precroi": "precroi.zip",
         "prequar": "prequar.zip",
         "gibcroi": "gibcroi.zip",
         "pleine": "pleine.zip",
         "gibdecroi": "gibdecroi.zip",
         "derquar": "derquar.zip",
         "dercroi": "dercroi.zip"}
# New/Waxing Crescent/First Quarter/Waxing Gibbous/Full/Waning Gibbous/Last Quarter/Waning Crescent
# nouvelle/precroi/prequar/gibcroi/pleine/gibdecroi/derquar/dercroi
class BasePlugin:
    def __init__(self):
        self.debug = False
        self.nextupdate = datetime.now()
        self.pollinterval = 60  # default polling interval in minutes
        self.error = False
        return
    def onStart(self):
        global icons
        Domoticz.Debug("onStart called")
        if Parameters["Mode6"] == 'Debug':
            self.debug = True
            Domoticz.Debugging(1)
            DumpConfigToLog()
        else:
            Domoticz.Debugging(0)
        # load custom battery images
        for key, value in icons.items():
            if key not in Images:
                Domoticz.Image(value).Create()
                Domoticz.Debug("Added icon: " + key + " from file " + value)
        Domoticz.Debug("Number of icons loaded = " + str(len(Images)))
        for image in Images:
            Domoticz.Debug("Icon " + str(Images[image].ID) + " " + Images[image].Name)
        # create the mandatory child device if it does not yet exist
        if 1 not in Devices:
            Domoticz.Device(Name="Lune", Unit=1, TypeName="Custom",
                            Options={"Custom": "1;"},
                            Used=1).Create()
        # check polling interval parameter
        try:
            temp = int(Parameters["Mode4"])
        except:
            Domoticz.Error("Invalid polling interval parameter")
        else:
            if temp < 1:
                temp = 1  # minimum polling interval
                Domoticz.Error("Specified polling interval too short: changed to 30 minutes")
            elif temp > 1440:
                temp = 1440  # maximum polling interval is 1 day
                Domoticz.Error("Specified polling interval too long: changed to 1440 minutes (24 hours)")
            self.pollinterval = temp
        Domoticz.Log("Using polling interval of {} minutes".format(str(self.pollinterval)))
    def onStop(self):
        Domoticz.Debug("onStop called")
    def onHeartbeat(self):
        now = datetime.now()
        if now >= self.nextupdate:
            self.nextupdate = now + timedelta(minutes=self.pollinterval)
            # data=json.loads(urllib.request.urlopen("http://api.wunderground.com/api/5ea448da70b1136f/astronomy/q/fr/paris.json").read().decode('ascii'))
            data = json.loads(urllib.request.urlopen(
                "http://api.wunderground.com/api/" + Parameters["Mode1"] + "/astronomy/q/" + Parameters["Mode2"] + "/" +
                Parameters["Mode3"] + ".json").read().decode('ascii'))
            lune = data['moon_phase']['phaseofMoon']
			# Domoticz.Log(str(lune))
            self.UpdateDevice(lune)
    def UpdateDevice(self, lune):
        # Make sure that the Domoticz device still exists (they can be deleted) before updating it
        if 1 in Devices:
            if lune == "New":
                icon = "nouvelle"
                datafr = "nouvelle lune"
            elif lune == "Waxing Crescent":
                icon = "precroi"
                datafr = "premier croissant"
            elif lune == "First Quarter":
                icon = "prequar"
                datafr = "premier quartier"
            elif lune == "Waxing Gibbous":
                icon = "gibcroi"
                datafr = "gibeuse croissante"
            elif lune == "Full":
                icon = "pleine"
                datafr = "pleine lune"
            elif lune == "Waning Gibbous":
                icon = "gibdecroi"
                datafr = "gibeuse decroissante"
            elif lune == "Last Quarter":
                icon = "derquar"
                datafr = "dernier quartier"
            elif lune == "Waning Crescent":
                icon = "dercroi"
                datafr = "dernier croissant"
            try:
                Devices[1].Update(nValue=0, sValue=str(datafr), Image=Images[icon].ID)
            except:
                Domoticz.Error("Failed to update device")
        return
global _plugin
_plugin = BasePlugin()
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
def onHeartbeat():
    global _plugin
    _plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
    for x in Parameters:
        if Parameters[x] != "":
            Domoticz.Debug("'" + x + "':'" + str(Parameters[x]) + "'")
    for x in Devices:
        Domoticz.Debug("Device:           " + str(x) + " - " + str(Devices[x]))
        Domoticz.Debug("Device ID:       '" + str(Devices[x].ID) + "'")
        Domoticz.Debug("Device Name:     '" + Devices[x].Name + "'")
        Domoticz.Debug("Device nValue:    " + str(Devices[x].nValue))
        Domoticz.Debug("Device sValue:   '" + Devices[x].sValue + "'")
    return
and icons for test https://drive.google.com/file/d/0B3QY9M ... sp=sharing
thank you
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
tottka
Re: Moon phase
Post by tottka »
Fantastic thread & thank you for the work you did on this.
I'm wondering how you determined the internal icon numbers?
I think I understand most of what you did & I'm ready to give it a go.
thanks
htilburgs
Re: Moon phase
Post by htilburgs »
In some rare occassions (like today :) ) the "moonrise" hour and minute are empty
"moonrise": {
"hour":"",
"minute":""
Searching the Wunderground forum tells me "This happens when a day does not have a moon rise. In this case, the moon rose yesterday" https://apicommunity.wunderground.com/w ... g-sometime
I'm looking for a way to modify the lua script, so the script keeps running and not the error
64: attempt to concatenate global 'moonriseMinute' (a nil value)
see also: http://www.domoticz.com/forum/viewtopic ... 67&t=19404
Hardware:
elmortero
Domoticz version: 3.9639
Re: Moon phase
Post by elmortero »
something like if moonriseMinute == nil then moonriseMinute = '--' end (and same for the rest of the fetched values)
That should avoid giving an error and in your textsensor would get --:--
htilburgs
Re: Moon phase
Post by htilburgs »
elmortero wrote: Wednesday 13 September 2017 19:44 something like if moonriseMinute == nil then moonriseMinute = '--' end (and same for the rest of the fetched values)
Yes, that did the trick. Changed part:
        -- moonrise
        moonriseHour, moonriseMinute = string.match(s, [["moonrise": {"hour":"(%d+)","minute":"(%d+)"]])
        if moonriseHour == nil then moonriseHour = '--' end
        if debug then print("Moonrise:\t"..moonriseHour..":"..moonriseMinute) end
        -- moonset
        moonsetHour, moonsetMinute = string.match(s, [["moonset": {"hour":"(%d+)","minute":"(%d+)"]])
        if moonsetHour == nil then moonsetHour = "--" end
        if moonsetMinute == nil then moonsetMinute = "--" end
        if debug then print("Moonset:\t"..moonsetHour..":"..moonsetMinute) end
Hardware:
EdwinK
Re: Moon phase
Post by EdwinK »
Thanks. Seems to work again
(Why don't we have a 'thanks' button in here?) ;)
htilburgs
Re: Moon phase
Post by htilburgs »
EdwinK wrote: Wednesday 13 September 2017 20:49 Thanks. Seems to work again
I've one default on my keyboard ;-)
Hardware:
