Bless ya, well I appreciate your help!NickHead wrote:There is, but I aint done that yet, and wether it would work is another story.
You could always try entering other commands in to the text string to see if it changes channels/volume or whatever/
I simple read of about 10 bytes would suffice I would reckon.
i am doing too many things here at the moment , I have to rewrite my SolarPanel programs as well
not only that , I have to to work in a bit
Telnet Type Data to Domoticz Help Topic is solved
simon_rb
- Target OS: -
Re: Telnet Type Data to Domoticz Help
simon_rb
- Target OS: -
And this
http://forum.micasaverde.com/index.php?topic=22950.15
Looks like response is PWON if on and PWSTANDBY if in standby.
NickHead
This is what I got up to now:
I have done a trial run and can get it to work with my Domoticz ( Emulating Denon Send/Requests )
#!/usr/bin/env python
import os
import sys
import socket
import urllib
DStart = " "
# Denon Amp Settings
denon_host = "192.168.0.231" #IP of Denon Amp
denon_port = 8081 #Port of Denon Amp
#domoticz settings
domoticz_host = '192.168.0.148' #IP of Domoticz
domoticz_port = '8080' #Port of Domoticz
domoticz_url = 'json.htm'
avr_switch = '379' #This Number is the same as the Device ID of the Switch
def SendInit_PW():
Text = "PW?"
s.send(Text)
def ReceiveData():
global DStart
while DStart != "P":
DStart = (s.recv(1)) # Wait for a response "Pxxx"
DStart = (s.recv(3)) # Get next 3 characters
if DStart == "WON":
print " Denon Power is ON"
Switch = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command¶m=switchlight&idx=" + avr_switch + "&switchcmd=On")
urllib.urlopen(Switch)
if DStart == "WST":
print "Denon Power is OFF"
Switch = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command¶m=switchlight&idx=" + avr_switch + "&switchcmd=Off")
try:
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
print " Socket successfully created"
except socket.error as err:
print" "
s.connect((denon_host,denon_port))
print " Host =",denon_host," Port = ",denon_port
print " Connecting to Denon Amplifier"
SendInit_PW()
ReceiveData()
A lot of stuff that is doing my head in.
simon_rb
- Target OS: -
Brilliant - Thanks.
Just saved the script and filled in the details and I got this when trying to run it (assuming I have ran it correctly)
UPDATE:- I added # -*- coding: utf-8 -*- to the top of the file, then it didn't like the " " for denon_host = "192.168.1.12" so changed to ' ' and got this:-
File "/home/pi/domoticz/scripts/Denon_Airplay_Check.py", line 10
SyntaxError: Non-ASCII character '\xe2' in file /home/pi/domoticz/scripts/Denon_Airplay_Check.py on line 10, but no encoding declared; see http://www.python.org/peps/pep-0263.html for detailsCode: Select all
pi@raspberrypi ~ $ python /home/pi/domoticz/scripts/Denon_Airplay_Check.py
File "/home/pi/domoticz/scripts/Denon_Airplay_Check.py", line 11
denon_host = '192.168.1.12’ #IP of Denon Amp
SyntaxError: EOL while scanning string literal
NickHead
mmm no error on line 10 is there ?>
NickHead
Are you running it by
python Denon_Airplay_Check.py
if not , your doing it wrong
simon_rb
- Target OS: -
Got as far as this so far
File "/home/pi/domoticz/scripts/Denon_Airplay_Check.py", line 27
IndentationError: unexpected indent-
NickHead
yer, python has to be perfect on indentations
maybe the cut/paste messed it up
NickHead
def ReceiveData():
global DStart
if DStart == "WON":
If its the same when i press enter
and it isnt
NickHead
i'll attach it as a file
simon_rb
- Target OS: -
Got past that, Stuck on this now
File "/home/pi/domoticz/scripts/Denon_Airplay_Check.py", line 30
if DStart == "WON":
IndentationError: unindent does not match any outer indentation level
NickHead
wont let me do it for some reason
simon_rb
- Target OS: -
I'm half way through the code.. any ideas why the error above is there? Python is so temperamental lolNickHead wrote:wont let me do it for some reason
NickHead
if Dstart != "P":
goes directly under DSTART == "WON"
all in the same line other then DSTART = (s.recv(1))
NickHead
if there is a colon (:) then there is an indentation on the NEXT line
Python Program Rules
simon_rb
- Target OS: -
I have ran it in an online python editor and I get the same error. Can't figure it out lol
UPDATE:- It needed one more space - seems to have opened socket now..
NickHead
Sorry
if Dstart != "P":
goes directly under global DSTART
I am Soooo tired now, so off to bed, will try again tomorrow
making too many errors now, I have been at work and knackud
if Dstart != "P":
NickHead
if you can PM me, dont know wether its on, then send me an email and i'll send you the file.
should be in order then
gnite
gnite
simon_rb
- Target OS: -
Don't be sorry, I'm off to be now too - up at 6. I have it running now but it doesn't do anything after it says connecting to denon.NickHead wrote: I am Soooo tired now, so off to bed, will try again tomorrow
Host = 192.168.1.12 Port = 23
Connecting to Denon Amplifier-
simon_rb
- Target OS: -
Got the script to run but it stops after it displays Connecting to Denon... After a couple of mins I hit ctrl c and this is what it displays.. We are too close... Well you are
^CTraceback (most recent call last):
File "/home/pi/domoticz/scripts/Denon_Airplay_Check.py", line 49, in <module>
ReceiveData()
File "/home/pi/domoticz/scripts/Denon_Airplay_Check.py", line 28, in ReceiveData
KeyboardInterrupt
pi@raspberrypi ~ $
