Telnet Type Data to Domoticz Help Topic is solved
Everything about esp8266 and more.
simon_rb
Re: Telnet Type Data to Domoticz Help
Post by simon_rb »
NickHead wrote:There is, but I aint done that yet, and wether it would work is another story.
You could always try entering other commands in to the text string to see if it changes channels/volume or whatever/
I simple read of about 10 bytes would suffice I would reckon.
i am doing too many things here at the moment , I have to rewrite my SolarPanel programs as well
not only that , I have to to work in a bit :(
Bless ya, well I appreciate your help! :-)
simon_rb
Post by simon_rb »
And this
http://forum.micasaverde.com/index.php?topic=22950.15
Looks like response is PWON if on and PWSTANDBY if in standby.
NickHead
Post by NickHead »
This is what I got up to now:
I have done a trial run and can get it to work with my Domoticz ( Emulating Denon Send/Requests )
 #!/usr/bin/env python
import os
import sys
import socket
import urllib
DStart = " "
# Denon Amp Settings
denon_host = "192.168.0.231"			#IP of Denon Amp
denon_port = 8081				#Port of Denon Amp
#domoticz settings
domoticz_host = '192.168.0.148'			#IP of Domoticz
domoticz_port = '8080'				#Port of Domoticz
domoticz_url    = 'json.htm'
avr_switch        = '379'	                                                     #This Number is the same as the Device ID of the Switch
def SendInit_PW():
	Text = "PW?"
	s.send(Text)
def ReceiveData():
	global DStart
    	while DStart != "P":
  		DStart = (s.recv(1))		# Wait for a response "Pxxx"
     	DStart = (s.recv(3))			# Get next 3 characters
	if DStart == "WON":
		print " Denon Power is ON"
		Switch = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command&param=switchlight&idx=" + avr_switch + "&switchcmd=On")
		urllib.urlopen(Switch)
	if DStart == "WST":
		print "Denon Power is OFF"
		Switch = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command&param=switchlight&idx=" + avr_switch + "&switchcmd=Off")
try:
 	s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
 	print "			 Socket successfully created"
except socket.error as err:
		print" "
s.connect((denon_host,denon_port))
print "                      Host =",denon_host," Port = ",denon_port
print "			 Connecting to Denon Amplifier"
SendInit_PW()
ReceiveData()
A lot of stuff that is doing my head in.
simon_rb
Post by simon_rb »
Brilliant - Thanks.
Just saved the script and filled in the details and I got this when trying to run it (assuming I have ran it correctly)
File "/home/pi/domoticz/scripts/Denon_Airplay_Check.py", line 10
SyntaxError: Non-ASCII character '\xe2' in file /home/pi/domoticz/scripts/Denon_Airplay_Check.py on line 10, but no encoding declared; see http://www.python.org/peps/pep-0263.html for details
UPDATE:- I added # -*- coding: utf-8 -*- to the top of the file, then it didn't like the " " for denon_host = "192.168.1.12" so changed to ' ' and got this:-
pi@raspberrypi ~ $ python /home/pi/domoticz/scripts/Denon_Airplay_Check.py
  File "/home/pi/domoticz/scripts/Denon_Airplay_Check.py", line 11
    denon_host = '192.168.1.12’         #IP of Denon Amp
SyntaxError: EOL while scanning string literal
NickHead
Post by NickHead »
mmm no error on line 10 is there ?>
NickHead
Post by NickHead »
Are you running it by
python Denon_Airplay_Check.py
if not , your doing it wrong
simon_rb
Post by simon_rb »
Got as far as this so far
  File "/home/pi/domoticz/scripts/Denon_Airplay_Check.py", line 27
IndentationError: unexpected indent
NickHead
Post by NickHead »
yer, python has to be perfect on indentations
maybe the cut/paste messed it up
NickHead
Post by NickHead »
def ReceiveData():
	global DStart
	if DStart == "WON":
Should look like that
If its the same when i press enter
and it isnt
NickHead
Post by NickHead »
i'll attach it as a file
simon_rb
Post by simon_rb »
Got past that, Stuck on this now
  File "/home/pi/domoticz/scripts/Denon_Airplay_Check.py", line 30
    if DStart == "WON":
IndentationError: unindent does not match any outer indentation level
NickHead
Post by NickHead »
wont let me do it for some reason
simon_rb
Post by simon_rb »
NickHead wrote:wont let me do it for some reason
I'm half way through the code.. any ideas why the error above is there? Python is so temperamental lol
NickHead
Post by NickHead »
if Dstart != "P":
goes directly under DSTART == "WON"
all in the same line other then DSTART = (s.recv(1))
NickHead
Post by NickHead »
if there is a colon (:) then there is an indentation on the NEXT line
Python Program Rules
simon_rb
Post by simon_rb »
I have ran it in an online python editor and I get the same error. Can't figure it out lol
UPDATE:- It needed one more space - seems to have opened socket now.. :D
NickHead
Post by NickHead »
Sorry
if Dstart != "P":
goes directly under global DSTART
I am Soooo tired now, so off to bed, will try again tomorrow
making too many errors now, I have been at work and knackud
NickHead
Post by NickHead »
if you can PM me, dont know wether its on, then send me an email and i'll send you the file.
should be in order then
gnite
simon_rb
Post by simon_rb »
NickHead wrote: I am Soooo tired now, so off to bed, will try again tomorrow
Don't be sorry, I'm off to be now too - up at 6. I have it running now but it doesn't do anything after it says connecting to denon.
                      Host = 192.168.1.12  Port =  23
Speak tomorrow and thank you so so so much :D
simon_rb
Post by simon_rb »
Got the script to run but it stops after it displays Connecting to Denon... After a couple of mins I hit ctrl c and this is what it displays.. We are too close... Well you are ;)
^CTraceback (most recent call last):
  File "/home/pi/domoticz/scripts/Denon_Airplay_Check.py", line 49, in <module>
    ReceiveData()
  File "/home/pi/domoticz/scripts/Denon_Airplay_Check.py", line 28, in ReceiveData
KeyboardInterrupt
pi@raspberrypi ~ $
