Dashticz - Module - Garbage collector Topic is solved
Derik
Re: Dashticz - Module - Garbage collector
Post by Derik »
mm did update my dashticz to last beta.
look there are some other setting needed...
Only i cannot use the "old" css for adjust image and place and the css for tomorrow and today font.
I used this settings:
.trash .state div.trashtoday 		{ font-size: 30px; font-weight: 3; color: blue;margin-left: 29px; font-weight: bold; font-variant: small-caps;}
.trash .state div.trashtomorrow=	{ font-size: 27px; font-weight: 2; color: white; margin-left: 29px; font-variant: small-caps;}
.trash .state div.trashrow 		{ font-size: 25px; font-weight: 1; color: red; margin-left: 29px; font-variant: small-caps;} /// alle tekst
.trashcan				{ height: 65px; width: 65px; margin-left:; margin-top: 20px;}
Only that is not function any more.
Someone have new css for the latest garbage js?
xx
aiolos
Domoticz version: stable
Post by aiolos »
Ah, those classes are accidentally removed in the whole refactor. I create a PR for it.
Also note that after 'trashtomorrow' you have an '=', that's not valid css.
Contributor to Dashticz
More on my Github profile
Derik
Post by Derik »
mm thanks for the typo..
Only the image is see very small in my setup.
And no color and i set the color on true in the config:
config['garbage_use_names'] 	= true;
config['garbage_use_colors']	= true;
config['garbage_icon_use_colors'] = true;
Just a very smal "kliko" in the left upper corner. without a color...
And i see in the img. map all the jpg that he can should use.
timyboyb
Post by timyboyb »
Since my town Groningen is also not digital available I try to get the ical from google working and make my own. He says only "loading". What to do? how to check the diffrent parts?
JacEngels
Post by JacEngels »
timyboyb wrote: Monday 01 January 2018 21:57 Hello,
Maybe for Groningen this link can be used and implemented: https://gemeente.groningen.nl/afvalwijzer/groningen
timyboyb
Post by timyboyb »
JacEngels wrote: Monday 01 January 2018 22:05
thanks for the idea but this is only a table view page, no ical orso.
I tried the google API as well but that one is also not loading...
Derik
Post by Derik »
you have to set all into the last beta
timyboyb
Post by timyboyb »
Derik wrote: Monday 01 January 2018 22:34 you have to set all into the last beta
what is the best way to install that last version? just starting up with this but know some basics here and there. Sourcetree? working in atom but also new there.
Derik
Post by Derik »
mmm I don't now.
My way.
Save the custom and custom css and perhaps your custom images.
Then remove all the dash maps
Then upload the new dash map
The replace all the custom
timyboyb
Post by timyboyb »
Derik wrote: Monday 01 January 2018 22:52 mmm I don't now.
My way.
oh, thanks man, it's working.
Derik
Post by Derik »
timyboyb wrote: Monday 01 January 2018 23:09
My way.
Change your "old" setting in to the new in the wiki..
There are some bugs..
timyboyb
Post by timyboyb »
My way.
Ah oké, what specifically? Where do I look for?
Verstuurd vanaf mijn HTC 10 met Tapatalk
Derik
Post by Derik »
Rob..
I do have the latest beta...
Only my icon is very small.
And when i use my old css there is no change of any hing..
config:
/*//////////////////////////// Afval  \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\*/
config['garbage_company'] 	= 'mijnafvalwijzer';
config['garbage_zipcode'] 	= '6656AW';
config['garbage_street'] 	= 'park33';
config['garbage_housenumber'] 	= '29';
config['garbage_maxitems'] 	= '3';
config['garbage_width'] 	= '6';
config['garbage_hideicon'] 	= 0;
config['garbage'] = {
    gft:	{kliko: 'green', 	code: '#375b23', name: 'GFT-Folie'},
    pmd: 	{kliko: 'orange', 	code: '#db5518', name: 'PMD'},
    rest: 	{kliko: 'grey', 	code: '#5e5d5c', name: 'Restafval'},
    papier: 	{kliko: 'blue', 	code: '#153477', name: 'Papier'},
    kca:	{kliko: 'red', 		code: '#b21807', name: 'Chemisch afval'},
    brown: 	{kliko: 'brown', 	code: '#7c3607', name: 'Bruin'},
    black: 	{kliko: 'black',	code: '#000000', name: 'Zwart'},};
and..
css:
.trash .state div.trashtoday 		{ font-size: 30px; font-weight: 3; margin-left: 29px; font-weight: bold; font-variant: small-caps;}
.trash .state div.trashtomorrow		{ font-size: 27px; font-weight: 2; margin-left: 29px; font-variant: small-caps;}
.trash .state div.trashrow 		{ font-size: 25px; font-weight: 1; margin-left: 29px; font-variant: small-caps;} /// alle tekst
.img.trashcan				{ height: 65px; width: 65px; margin-left:; margin-top: 20px;}
So perhaps i need a total new css??
Or?
aiolos
Post by aiolos »
Derik wrote: Tuesday 02 January 2018 14:46 Rob..
Or?
I just checked your config and css. Seems to work with the latest beta (please note that the changes to make this work were merged this morning.)
The given postalcode/housenumber doesn't give a result, but if I try another one, I see results. The layout is changed by the css then.
Derik
Post by Derik »
This is what i have..
Perhaps you can share your settings?
jdemas
Post by jdemas »
Hi Rob,
sinds 1 of january rd4 isn't working at all.
can you look into it?
regards Jeffrey
aiolos
Post by aiolos »
Derik wrote: Tuesday 02 January 2018 18:08 klein.jpg
Ah, I thought no css at all was working, but it is only the image. Use
div.col-icon { width: 100px !important;}
in your custom.css to also adapt the div around the icon. That one is by default fixed to max 50px width. (by using the 'inspect element' option in your browser and playing around with the elements you can see what happens if you disable on change css values)
Luxtux
Domoticz version: 2021.1 β
Post by Luxtux »
I've created another pull request. so the scripts can assign garbagetypes to my city's ICAL file. I'm wondering if it maybe wouldnt be a better idea to have some config option for each type of garbage; instead of keep on adding different regex words for each language.
I have one little issue that I haven't been able to solve yet. I was able to hide some entries in the previous version of the garbage module (before nov 2017) by not defining some garbage types. The ICAL file that the city provides contains all types of bins that exist in their system; but not all of them interest me. E.g. I live in an apartment, so i don't care that they come and pick up cut grass.
aiolos
Post by aiolos »
Thanks. Now that it gets some usage we can figure out what's handy to use. You are right about the adding stuff, I think we can solve it by adding a matching element in the config. That way everyone can change it to their specific situation.
For your problem with too much information a hiding option should be added, that makes sense. The earlier config had that option indeed.
And good news for the people in Groningen: implementation is on its way...
Derik
Post by Derik »
aiolos wrote: Wednesday 03 January 2018 0:40
Thanks for the tip try it tomorrow..
Only i cannot see the dash in my pc because the screen setting are different on my pc and my tablet..
Perhaps a solution for that?
