Re: [MyDomoAtHome] Support thread
Posted: Saturday 23 January 2016 9:31
it works !
thank you very much !
Open source Home Automation System
https://forum.domoticz.com/
Thanks for the advice, unfortunately no luck yet. Set the ports as above, but trying ./start2.sh results in an error (well, row of errors, actually):epierre wrote:1) domo_path is the http address to reach your domoticz so http://192.168.1.50:8080
2) if on the same machine, 8080 port is already for domoticz, so starting MDAH will not be possible if the port is already binded to another application, leave 3001 here to test, and try ./start2.sh to validate it can start
pi@raspberrypi:~/domoticz/MyDomoAtHome$ ./start2.sh
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "UTF-8",
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
YAML Warning: Duplicate map key found. Ignoring.
Code: YAML_LOAD_WARN_DUPLICATE_KEY
Line: 17
Document: 1
at /usr/share/perl5/YAML/Mo.pm line 24
YAML::Mo::__ANON__('YAML::Loader=HASH(0x1f775a0)', 'YAML_LOAD_WARN_DUPLICATE_KEY') called at /usr/share/perl5/YAML/Loader.pm line 359
YAML::Loader::_parse_mapping('YAML::Loader=HASH(0x1f775a0)', '') called at /usr/share/perl5/YAML/Loader.pm line 168
YAML::Loader::_parse_node('YAML::Loader=HASH(0x1f775a0)') called at /usr/share/perl5/YAML/Loader.pm line 103
YAML::Loader::_parse('YAML::Loader=HASH(0x1f775a0)') called at /usr/share/perl5/YAML/Loader.pm line 25
YAML::Loader::load('YAML::Loader=HASH(0x1f775a0)', '# appdir/environments/development.yml
# configuration file fo...') called at /usr/share/perl5/YAML.pm line 34
YAML::Load('# appdir/environments/development.yml
# configuration file fo...') called at /usr/share/perl5/YAML.pm line 75
YAML::LoadFile('/home/pi/domoticz/MyDomoAtHome/environments/development.yml') called at /usr/share/perl5/Dancer/Config.pm line 201
eval {...} called at /usr/share/perl5/Dancer/Config.pm line 201
Dancer::Config::load_settings_from_yaml('/home/pi/domoticz/MyDomoAtHome/environments/development.yml') called at /usr/share/perl5/Dancer/Config.pm line 182
Dancer::Config::load('Dancer::Config') called at /usr/share/perl5/Dancer.pm line 258
Dancer::import('Dancer') called at bin/app.pl line 19
Plack::Sandbox::bin_2fapp_2epl::BEGIN() called at bin/app.pl line 19
eval {...} called at bin/app.pl line 19
require bin/app.pl called at (eval 7) line 3
eval 'package Plack::Sandbox::bin_2fapp_2epl;
my $app = do $_file;
if ( !$app && ( my $error = $@ || $! )) { die $error; }
$app;
;' called at /usr/share/perl5/Plack/Util.pm line 118
Plack::Util::_load_sandbox('bin/app.pl') called at /usr/share/perl5/Plack/Util.pm line 155
Plack::Util::load_psgi('bin/app.pl') called at /usr/share/perl5/Plack/Runner.pm line 176
Plack::Runner::__ANON__() called at /usr/share/perl5/Plack/Runner.pm line 23
Plack::Runner::__ANON__() called at /usr/share/perl5/Plack/Loader.pm line 59
Plack::Loader::preload_app('Plack::Loader=HASH(0x1847a98)', 'CODE(0x187eb28)') called at /usr/share/perl5/Plack/Runner.pm line 260
Plack::Runner::run('Plack::Runner=HASH(0x1714818)') called at /usr/bin/plackup line 10
Error while loading bin/app.pl: Can't locate Time/Moment.pm in @INC (@INC contains: /home/pi/domoticz/MyDomoAtHome/bin/../lib /home/pi/domoticz/MyDomoAtHome/lib /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm line 31.
BEGIN failed--compilation aborted at /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm line 31.
Compilation failed in require at bin/app.pl line 20.
BEGIN failed--compilation aborted at bin/app.pl line 20.
Thanks for pointing this, I have updated the installation procedure to avoid this issue.hanor wrote:it works !
{ "id"=> "Piwnica", "name"=> "Piwnica" },
#debug("DBG:".$f->{"idx"}.":".$f->{"Type"}.":".$f->{"SubType"}."\n");
debug("DBG:".$f->{"idx"}.":".$f->{"Type"}.":".$f->{"SubType"}.":PlanID:".$f->{"PlanID"}."\n");
my $PlanID = $f->{"PlanID"};
if ($PlanID == 2) {
$feeds={params =>[],"room" => "Piwnica","type" => "DevTemperature","name" => $name, "id" =>$
} else {
$feeds={params =>[],"room" => "Temp","type" => "DevTemperature","name" => $name, "id" => $f$
Hello,lowca wrote:What about room's..
I'd like to have some of temp sensors in custom room ,. add room 'piwnica' id domotocz (PlanID =2)
so my question is , is there an easiest way ..
Yes, Please ..Hello,
Is PlanID a new feature ? if so I could automatize that.
json.htm?type=plans&order=name&used=true
"result" : [
"Devices" : 3,
"Name" : "Piwnica",
"Order" : "1",
"idx" : "2" --> ( PlanID in /json.htm?type=devices )
get '/rooms' => sub {
#Room list
return {"rooms" => [
{ "id"=> "Switches", "name"=> "Switches" },
{ "id"=> "Scenes", "name"=> "Scenes" },
{ "id"=> "Temp", "name"=> "Temperature" },
{ "id"=> "Weather", "name"=> "Weather" },
{ "id"=> "Utility", "name"=> "Utility" },
it takes only the time of refresh you can set in the imperihome parameters.raym wrote:Hi guys, what would it take to show last tripped/updated time for motion sensors?
Thanks for the reply. Could you explain in more detail though please?epierre wrote:it takes only the time of refresh you can set in the imperihome parameters.raym wrote:Hi guys, what would it take to show last tripped/updated time for motion sensors?
Thanks. Understand about on/off being a Vera thing and I"m not interested in that - just the last tripped time. I'm transitioning from Vera to Domoticz and will eventually switch it offepierre wrote:Hello,
I'll have to take a look, just remember the on/off is the triggering in Vera as there is no difference of this sort in Domoticz. Maybe I'll need your domoticz.db to see if they are both the same device or not.
I don't remeber if this was you, but someone asket about using vera as a "dongle", I've started the article
http://www.domoticz.com/wiki/VERA
I sent over my DB file for you.epierre wrote:@stuiow as it is a hardware sensor, I need your database domoticz.db to be able to test it
well a kernel update broke my nvidia xorg ... not possible to test at this time...stuiow wrote:I sent over my DB file for you.epierre wrote:@stuiow as it is a hardware sensor, I need your database domoticz.db to be able to test it
Was that sufficient?
yes please, I'm really looking forward for such featureepierre wrote:lowca wrote:Is PlanID a new feature ? if so I could automatize that.
