Page 19 of 25
Re: Easiest way to migrate Openzwave to ZWave-JS-UI
Posted: Thursday 04 January 2024 14:57
by akamming
pffffffffff i finished the zwave js ui migration for 80 devices... a lot of work, took me 2 days!
on the bright side though...: my zwave network is much more responsive now! so happy i did it!
Posted: Thursday 04 January 2024 18:05
by tiga
i am trying to get my zwave up and running again using the instructions.
but somehow mqtt is not coming up on 192.168.0.115:1881
and "MQTT Auto Discovery hardware" is not showing in domoticz
what is going on?
Posted: Thursday 04 January 2024 18:09
by Bospieper
Port should be 1883
Posted: Thursday 04 January 2024 18:16
by tiga
nothing on port 1883 allso
Posted: Thursday 04 January 2024 18:21
by Bospieper
And your MQTT Explorer shows also nothing?
Posted: Thursday 04 January 2024 18:25
by tiga
ah yes...now with port 1883 i can see stuff...
i am sorry...i am an averige computer user...this is getting pretty complicated
Posted: Thursday 04 January 2024 18:27
by tiga
is "mqtt auto discovery client gateway with lan interfase" same as "MQTT Auto Discovery hardware" named in the instructions?
Posted: Thursday 04 January 2024 18:37
by Bospieper
You need two things in the hardware section of Domoticz that is the MQTT Broker: MQTT Client Gateway with LAN interface and for the client Zwavejs: MQTT Auto discovery Client Gateway with LAN interface
Posted: Thursday 04 January 2024 18:42
by tiga
ok thanks.
following problem is that ls /dev/serial/by-id is giving: ls: cannot access '/dev/serial/by-id': No such file or directory
zwave dongle is connected via usb hub becouse it is a pi-4
Posted: Thursday 04 January 2024 18:47
by Bospieper
Did you follow the instruction to determ the port of your usb Zwave stick?
command: ls /dev/serial/by-id in your terminal?
Posted: Thursday 04 January 2024 18:50
by tiga
this is coming up
i have a rfxcom connected allso but not showing
Posted: Thursday 04 January 2024 19:01
by Bospieper
Oke, is possible that there are more usb devices connected to the Raspberry for example a Zigbee stick or P1 serial to usb? In that case you can try another usb port on the Raspberry and then renew the command ls /dev................
Posted: Thursday 04 January 2024 19:10
by waltervl
@tiga When ls /dev/serial/by-id is not working you are probably on an old OS? What OS do you use?
Does ls /dev/tty* showing your USB devices eg /dev/ttyACM0 or /dev/ttyUSB0 ?
Posted: Thursday 04 January 2024 19:14
by tiga
no not working....i only can chose "by-path"
is there an other option?
i know it is /dev/ttyACM0 i had that in the hardware setup for the stick in domoticz
i have this os:
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
Posted: Thursday 04 January 2024 19:26
by tjabas
I also have problems with that, I also have the Z-wave dongle connected to dev/ttyACM0, and JS UI can't connect tro it as well.
I run buster on a rpi 3b+
by waltervl
You can use /dev/ttyACM0, no problem. Only when using multiple USB sticks it could lead to unwanted switching of names.
You have to find out why by-id is not working as i think it should work on bullseye.
Posted: Thursday 04 January 2024 19:28
by Bospieper
@WalterVL
In several posts you mentioned the fact that you have delete your old OZW stuff. Is deleting in the hardware section of Domomticz sufficient or do we have more deleting/uninstalling to do?
Grz Piet
Posted: Thursday 04 January 2024 19:29
by waltervl
Seems to be a common issue that by-id has dissapeared: https://forums.raspberrypi.com/viewtopic.php?t=351113
Posted: Thursday 04 January 2024 19:31
by waltervl
Bospieper wrote: Thursday 04 January 2024 19:28 @WalterVL
Grz Piet
Deleting from the setup-hardware page should be enough. Only now Domoticz has already removed the OZW hardware this seems somewhat troublesome as mentioned by other users.
Posted: Thursday 04 January 2024 19:34
by tiga
my docker-compose.yml looks like this:
version: "3.7"
services:
zwave-js-ui:
container_name: zwave-js-ui
image: zwavejs/zwave-js-ui:latest
restart: unless-stopped
tty: true
stop_signal: SIGINT
environment:
- SESSION_SECRET=mySecretSession
- TZ=Europe/Amsterdam
devices:
- '/dev/ttyACM0:/dev/zwave'
volumes:
- ./store:/usr/src/app/store
ports:
- "8091:8091" # port for web interface
- "3000:3000" # port for Z-Wave JS websocket server
worked once but after reboot nothing
