Easiest way to migrate Openzwave to ZWave-JS-UI
akamming
Re: Easiest way to migrate Openzwave to ZWave-JS-UI
Post by akamming »
pffffffffff i finished the zwave js ui migration for 80 devices... a lot of work, took me 2 days!
on the bright side though...: my zwave network is much more responsive now! so happy i did it!
tiga
Post by tiga »
i am trying to get my zwave up and running again using the instructions.
but somehow mqtt is not coming up on 192.168.0.115:1881
and "MQTT Auto Discovery hardware" is not showing in domoticz
what is going on?
Bospieper
Domoticz version: 2022.1
Post by Bospieper »
Port should be 1883
tiga
Post by tiga »
nothing on port 1883 allso
Bospieper
Post by Bospieper »
And your MQTT Explorer shows also nothing?
tiga
Post by tiga »
ah yes...now with port 1883 i can see stuff...
i am sorry...i am an averige computer user...this is getting pretty complicated
tiga
Post by tiga »
is "mqtt auto discovery client gateway with lan interfase" same as "MQTT Auto Discovery hardware" named in the instructions?
Bospieper
Post by Bospieper »
You need two things in the hardware section of Domoticz that is the MQTT Broker: MQTT Client Gateway with LAN interface and for the client Zwavejs: MQTT Auto discovery Client Gateway with LAN interface
tiga
Post by tiga »
ok thanks.
following problem is that ls /dev/serial/by-id is giving: ls: cannot access '/dev/serial/by-id': No such file or directory
zwave dongle is connected via usb hub becouse it is a pi-4
Bospieper
Post by Bospieper »
Did you follow the instruction to determ the port of your usb Zwave stick?
command: ls /dev/serial/by-id in your terminal?
tiga
Post by tiga »
this is coming up
i have a rfxcom connected allso but not showing
Bospieper
Post by Bospieper »
Oke, is possible that there are more usb devices connected to the Raspberry for example a Zigbee stick or P1 serial to usb? In that case you can try another usb port on the Raspberry and then renew the command ls /dev................
Domoticz version: 2024.7
@tiga When ls /dev/serial/by-id is not working you are probably on an old OS? What OS do you use?
Does ls /dev/tty* showing your USB devices eg /dev/ttyACM0 or /dev/ttyUSB0 ?
tiga
Post by tiga »
no not working....i only can chose "by-path"
is there an other option?
i know it is /dev/ttyACM0 i had that in the hardware setup for the stick in domoticz
i have this os:
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
tjabas
Post by tjabas »
I also have problems with that, I also have the Z-wave dongle connected to dev/ttyACM0, and JS UI can't connect tro it as well.
I run buster on a rpi 3b+
You can use /dev/ttyACM0, no problem. Only when using multiple USB sticks it could lead to unwanted switching of names.
You have to find out why by-id is not working as i think it should work on bullseye.
Bospieper
Post by Bospieper »
@WalterVL
In several posts you mentioned the fact that you have delete your old OZW stuff. Is deleting in the hardware section of Domomticz sufficient or do we have more deleting/uninstalling to do?
Grz Piet
Seems to be a common issue that by-id has dissapeared: https://forums.raspberrypi.com/viewtopic.php?t=351113
Bospieper wrote: Thursday 04 January 2024 19:28 @WalterVL
Grz Piet
Deleting from the setup-hardware page should be enough. Only now Domoticz has already removed the OZW hardware this seems somewhat troublesome as mentioned by other users.
tiga
Post by tiga »
my docker-compose.yml looks like this:
version: "3.7"
services:
zwave-js-ui:
container_name: zwave-js-ui
image: zwavejs/zwave-js-ui:latest
restart: unless-stopped
tty: true
stop_signal: SIGINT
environment:
- SESSION_SECRET=mySecretSession
- TZ=Europe/Amsterdam
devices:
- '/dev/ttyACM0:/dev/zwave'
volumes:
- ./store:/usr/src/app/store
ports:
- "8091:8091" # port for web interface
- "3000:3000" # port for Z-Wave JS websocket server
worked once but after reboot nothing
