Page 19 of 26
Re: Python Plugin: TUYA
Posted: Tuesday 12 October 2021 15:30
by manjh
I know this has been discussed earlier, and we all agreed to just leave it as it is. But the situation keeps coming back....
Whenever Domoticz is restarted, there is a good chance that the Tuya plugin returns in a state where the devices cannot be controlled. All lamps come in with status "timed out = true".
The only way to set this right, is to go into the hardware tab, switch the Tuya plugin to "disabled", and wait a little. Then switch back to "enabled" and al is well again.
I know this is not a lot of work, but sometimes Domoticz is restarted without me realizing I have to make the correction. I'll find out the hard way when the Tuya lamps are not switched off late at night...
So I'll ask again: any chance of a fix for this?
Posted: Tuesday 12 October 2021 20:55
by Xenomes
manjh wrote: Tuesday 12 October 2021 15:30
I don't know how to simulate your problem. I have disabled a part in the script that put the light off-line.
go to the plug-in folder
git pull
git checkout manjh
sudo systemctl restart domoticz.service
please report back what is happening.
Posted: Wednesday 13 October 2021 8:35
by manjh
Xenomes wrote: Tuesday 12 October 2021 20:55
git pull
git checkout manjh
Did as you asked. It restarts, I see the following:
2021-10-13 08:30:44.170 (Tuya_devices) TUYA plugin started
2021-10-13 08:30:44.187 (Tuya_devices) Update 0:'Off' (Lamp schuifpui) TimedOut=True
2021-10-13 08:30:44.210 (Tuya_devices) Update 0:'Off' (Lamp raam 2) TimedOut=True
2021-10-13 08:30:44.225 (Tuya_devices) Update 0:'Off' (Lamp glazenkast onder) TimedOut=True
2021-10-13 08:30:44.235 (Tuya_devices) Update 0:'Off' (Lamp deur 1) TimedOut=True
2021-10-13 08:30:44.245 (Tuya_devices) Update 0:'Off' (Lamp raam 1) TimedOut=True
2021-10-13 08:30:44.266 (Tuya_devices) Update 0:'Off' (Lamp deur 2) TimedOut=True
2021-10-13 08:30:44.287 (Tuya_devices) Update 0:'Off' (Lamp glazenkast boven) TimedOut=True
2021-10-13 08:30:44.299 (Tuya_devices) Update 0:'Off' (Lamp secretaire onder) TimedOut=True
2021-10-13 08:30:44.311 (Tuya_devices) Update 0:'Off' (Lamp secretaire boven) TimedOut=True
2021-10-13 08:30:45.967 (Tuya_devices) Update 0:'Off' (Lamp schuifpui) TimedOut=False
2021-10-13 08:30:45.979 (Tuya_devices) Update 0:'Off' (Lamp raam 2) TimedOut=False
2021-10-13 08:30:45.986 (Tuya_devices) Update 0:'Off' (Lamp glazenkast onder) TimedOut=False
2021-10-13 08:30:45.992 (Tuya_devices) Update 0:'Off' (Lamp deur 1) TimedOut=False
2021-10-13 08:30:45.999 (Tuya_devices) Update 0:'Off' (Lamp raam 1) TimedOut=False
2021-10-13 08:30:46.012 (Tuya_devices) Update 0:'Off' (Lamp deur 2) TimedOut=False
2021-10-13 08:30:46.025 (Tuya_devices) Update 0:'Off' (Lamp glazenkast boven) TimedOut=False
2021-10-13 08:30:46.033 (Tuya_devices) Update 0:'Off' (Lamp secretaire onder) TimedOut=False
2021-10-13 08:30:46.040 (Tuya_devices) Update 0:'Off' (Lamp secretaire boven) TimedOut=False
But also:
2021-10-13 08:30:48.671 Error: Bluetooth beacon hardware (20) thread seems to have ended unexpectedly
2021-10-13 08:30:48.671 Error: Xiaomi flowermate hardware (21) thread seems to have ended unexpectedly
2021-10-13 08:30:48.671 Error: Tuya_devices hardware (22) thread seems to have ended unexpectedly
Tried to switch a light, and this works:
2021-10-13 08:31:36.990 (Tuya_devices) Update 1:'93' (Lamp glazenkast boven) TimedOut=0
2021-10-13 08:31:36.737 Status: User: Admin initiated a switch command (4253/Lamp glazenkast boven/Set Level)
2021-10-13 08:31:39.245 (Tuya_devices) Sending command for DeviceID=bfcb108044ffd382863sht
2021-10-13 08:31:39.338 (Tuya_devices) Update 1:'4' (Lamp glazenkast boven) TimedOut=0
2021-10-13 08:31:39.236 Status: User: Admin initiated a switch command (4253/Lamp glazenkast boven/Set Level)
2021-10-13 08:31:43.096 (Tuya_devices) Sending command for DeviceID=bfcb108044ffd382863sht
2021-10-13 08:31:43.204 (Tuya_devices) Update 0:'Off' (Lamp glazenkast boven) TimedOut=False
2021-10-13 08:31:43.087 Status: User: Admin initiated a switch command (4253/Lamp glazenkast boven/Set Level)
2021-10-13 08:31:46.160 (Tuya_devices) Sending command for DeviceID=6276453110521cc9adb2
2021-10-13 08:31:46.391 (Tuya_devices) Update 1:'100' (Lamp secretaire onder) TimedOut=0
2021-10-13 08:31:46.118 Status: User: Admin initiated a switch command (4254/Lamp secretaire onder/Set Level)
2021-10-13 08:31:50.800 (Tuya_devices) Sending command for DeviceID=6276453110521cc9adb2
2021-10-13 08:31:50.798 Status: setcolbrightnessvalue: ID: 109e, bri: 100, color: '{m: 2, RGB: 000000, CWWW: ff00, CT: 0}'
Looks like it works ok. Will do some more checking today.
Posted: Wednesday 13 October 2021 8:39
by manjh
git pull
git checkout manjh
I rebooted the PI, this is what's in the log:
2021-10-13 08:36:28.091 Status: (Tuya_devices) Started.
2021-10-13 08:36:29.348 Status: (Tuya_devices) Initialized version 1.0.13, author 'Wagner Oliveira contributed Xenomes'
2021-10-13 08:36:29.373 Status: (Tuya_devices) Entering work loop.
2021-10-13 08:36:32.466 (Tuya_devices) Waiting 60 seconds to connect TuyaApi login timeout
2021-10-13 08:37:37.435 Error: Tuya_devices hardware (22) thread seems to have ended unexpectedly
2021-10-13 08:37:46.554 (Tuya_devices) TUYA plugin started
2021-10-13 08:37:46.562 (Tuya_devices) Update 0:'Off' (Lamp schuifpui) TimedOut=True
2021-10-13 08:37:46.575 (Tuya_devices) Update 0:'Off' (Lamp raam 2) TimedOut=True
2021-10-13 08:37:46.582 (Tuya_devices) Update 0:'Off' (Lamp glazenkast onder) TimedOut=True
2021-10-13 08:37:46.589 (Tuya_devices) Update 0:'Off' (Lamp deur 1) TimedOut=True
2021-10-13 08:37:46.595 (Tuya_devices) Update 0:'Off' (Lamp raam 1) TimedOut=True
2021-10-13 08:37:46.608 (Tuya_devices) Update 0:'Off' (Lamp deur 2) TimedOut=True
2021-10-13 08:37:46.621 (Tuya_devices) Update 0:'Off' (Lamp glazenkast boven) TimedOut=True
2021-10-13 08:37:46.634 (Tuya_devices) Update 0:'Off' (Lamp secretaire onder) TimedOut=True
2021-10-13 08:37:46.640 (Tuya_devices) Update 0:'Off' (Lamp secretaire boven) TimedOut=True
2021-10-13 08:37:48.260 (Tuya_devices) Update 0:'Off' (Lamp schuifpui) TimedOut=False
2021-10-13 08:37:48.268 (Tuya_devices) Update 0:'Off' (Lamp raam 2) TimedOut=False
2021-10-13 08:37:48.275 (Tuya_devices) Update 0:'Off' (Lamp glazenkast onder) TimedOut=False
2021-10-13 08:37:48.282 (Tuya_devices) Update 0:'Off' (Lamp deur 1) TimedOut=False
2021-10-13 08:37:48.288 (Tuya_devices) Update 0:'Off' (Lamp raam 1) TimedOut=False
2021-10-13 08:37:48.301 (Tuya_devices) Update 0:'Off' (Lamp deur 2) TimedOut=False
2021-10-13 08:37:48.314 (Tuya_devices) Update 0:'Off' (Lamp glazenkast boven) TimedOut=False
2021-10-13 08:37:48.327 (Tuya_devices) Update 1:'On' (Lamp secretaire onder) TimedOut=False
2021-10-13 08:37:48.333 (Tuya_devices) Update 0:'Off' (Lamp secretaire boven) TimedOut=False
2021-10-13 08:37:51.438 Error: Tuya_devices hardware (22) thread seems to have ended unexpectedly
Besides the lines about threads ending unexpectedly, the lamps still work!
Posted: Wednesday 13 October 2021 19:10
by Xenomes
manjh wrote: Wednesday 13 October 2021 8:39
These lines I never see, it looks like the number of devices is causing the plug-in to crash.
These line has nothing to do with the Tuya plug-in.
manjh wrote: Wednesday 13 October 2021 8:35
Timeout at start-up is disabled in the manjh test version can you pull the version and test?
Can you give me the python version, current version of Domoticz and the total number of Tuya devices? I am now running a test with 16 devices.
Posted: Friday 15 October 2021 11:09
by manjh
Xenomes wrote: Wednesday 13 October 2021 19:10
I don't know where the suddenly ending threads come from, just thought I'd mention it.
Downloaded the manjh test version, am running with that now. Everything runs OK, as far as I can see.
Python version is 3.7.3, Domoticz 2020.2. Mu,ber of Tuya devices: 9 (all are lamps).
Posted: Friday 15 October 2021 11:18
by manjh
Just restarted Domoticz, just to try.
Noticed a msg from the plugin: wait for 60 before login.
After that period, this is what I see:
2021-10-15 11:11:54.431 (Tuya_devices) Update 0:'Off' (Lamp schuifpui) TimedOut=False
2021-10-15 11:11:54.438 (Tuya_devices) Update 0:'Off' (Lamp raam 2) TimedOut=False
2021-10-15 11:11:54.445 (Tuya_devices) Update 0:'Off' (Lamp glazenkast onder) TimedOut=False
2021-10-15 11:11:54.454 (Tuya_devices) Update 0:'Off' (Lamp deur 1) TimedOut=False
2021-10-15 11:11:54.462 (Tuya_devices) Update 0:'Off' (Lamp raam 1) TimedOut=False
2021-10-15 11:11:54.470 (Tuya_devices) Update 0:'Off' (Lamp deur 2) TimedOut=False
2021-10-15 11:11:54.478 (Tuya_devices) Update 0:'Off' (Lamp glazenkast boven) TimedOut=False
2021-10-15 11:11:54.492 (Tuya_devices) Update 0:'Off' (Lamp secretaire onder) TimedOut=False
2021-10-15 11:11:54.500 (Tuya_devices) Update 0:'Off' (Lamp secretaire boven) TimedOut=False
2021-10-15 11:11:56.954 Error: Bluetooth beacon hardware (20) thread seems to have ended unexpectedly
2021-10-15 11:11:56.954 Error: Xiaomi flowermate hardware (21) thread seems to have ended unexpectedly
2021-10-15 11:11:56.954 Error: Tuya_devices hardware (22) thread seems to have ended unexpectedly
I understand it does not look ike the Bluetooth and Xiaomi errors are related to the Tuya plugin, but it is weird that this always happens when the plugin starts...
ALso tried to disable the plugin in HW, and then after a little whille enabled it again. This happens:
2021-10-15 11:15:09.702 (Tuya_devices) Waiting 60 seconds to connect TuyaApi login timeout
2021-10-15 11:15:09.314 Status: (Tuya_devices) Started.
2021-10-15 11:15:09.698 Status: (Tuya_devices) Entering work loop.
2021-10-15 11:15:09.698 Status: (Tuya_devices) Initialized version 1.0.13, author 'Wagner Oliveira contributed Xenomes'
2021-10-15 11:15:15.823 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":3787,"nvalue":0,"svalue":"11.8;88;3"}
2021-10-15 11:15:24.432 (RFLink De Meern) Temp + Humidity (Utrecht temp&hum buiten)
2021-10-15 11:15:29.857 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":3786,"nvalue":0,"svalue":"15.4;70;3"}
2021-10-15 11:15:46.091 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":3713,"nvalue":0,"svalue":"1145839;1106563;0;0;121;0"}
2021-10-15 11:15:46.196 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":3712,"nvalue":0,"svalue":"679300"}
2021-10-15 11:15:50.819 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":3787,"nvalue":0,"svalue":"11.8;88;3"}
2021-10-15 11:15:53.665 (Utrecht P1) P1 Smart Meter (Utrecht Power)
2021-10-15 11:15:53.693 (Utrecht P1) P1 Smart Meter (Utrecht Gas)
2021-10-15 11:15:59.431 (RFLink De Meern) Temp + Humidity (Utrecht temp&hum buiten)
2021-10-15 11:16:03.133 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":3842,"nvalue":0,"svalue":"38.4"}
2021-10-15 11:16:04.857 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":3786,"nvalue":0,"svalue":"15.5;70;3"}
2021-10-15 11:16:09.762 (Tuya_devices) TUYA plugin started
2021-10-15 11:16:09.776 (Tuya_devices) Update 0:'Off' (Lamp schuifpui) TimedOut=True
2021-10-15 11:16:09.793 (Tuya_devices) Update 0:'Off' (Lamp raam 2) TimedOut=True
2021-10-15 11:16:09.806 (Tuya_devices) Update 0:'Off' (Lamp glazenkast onder) TimedOut=True
2021-10-15 11:16:09.819 (Tuya_devices) Update 0:'Off' (Lamp deur 1) TimedOut=True
2021-10-15 11:16:09.832 (Tuya_devices) Update 0:'Off' (Lamp raam 1) TimedOut=True
2021-10-15 11:16:09.861 (Tuya_devices) Update 0:'Off' (Lamp deur 2) TimedOut=True
2021-10-15 11:16:09.884 (Tuya_devices) Update 0:'Off' (Lamp glazenkast boven) TimedOut=True
2021-10-15 11:16:09.892 (Tuya_devices) Update 0:'Off' (Lamp secretaire onder) TimedOut=True
2021-10-15 11:16:09.899 (Tuya_devices) Update 0:'Off' (Lamp secretaire boven) TimedOut=True
2021-10-15 11:16:09.236 Error: Bluetooth beacon hardware (20) thread seems to have ended unexpectedly
2021-10-15 11:16:09.236 Error: Xiaomi flowermate hardware (21) thread seems to have ended unexpectedly
2021-10-15 11:16:12.080 (Tuya_devices) Update 0:'Off' (Lamp schuifpui) TimedOut=False
2021-10-15 11:16:12.098 (Tuya_devices) Update 0:'Off' (Lamp raam 2) TimedOut=False
2021-10-15 11:16:12.109 (Tuya_devices) Update 0:'Off' (Lamp glazenkast onder) TimedOut=False
2021-10-15 11:16:12.120 (Tuya_devices) Update 0:'Off' (Lamp deur 1) TimedOut=False
2021-10-15 11:16:12.131 (Tuya_devices) Update 0:'Off' (Lamp raam 1) TimedOut=False
2021-10-15 11:16:12.154 (Tuya_devices) Update 0:'Off' (Lamp deur 2) TimedOut=False
2021-10-15 11:16:12.168 (Tuya_devices) Update 0:'Off' (Lamp glazenkast boven) TimedOut=False
2021-10-15 11:16:12.192 (Tuya_devices) Update 0:'Off' (Lamp secretaire onder) TimedOut=False
2021-10-15 11:16:12.202 (Tuya_devices) Update 0:'Off' (Lamp secretaire boven) TimedOut=False
Ignore the unrelated lines, this is a full cut from the Domoticz log.
Again, the Bluetooth and Xiaomi aborts are there.
The good news, of course, is the fact that after a Domoticz restart, or a Tuya plugin restart, the lamps are fully operational and can be switched!
Posted: Friday 15 October 2021 18:59
by Xenomes
manjh wrote: Friday 15 October 2021 11:09
OK, versions are the same as my test set-up.
manjh wrote: Friday 15 October 2021 11:18
Maybe it uses a common python library, i don't have devices for the plug-ins to test.
Do you have at the plug-in the 'Data Timeout' Disabled?
Yep that is
Posted: Monday 18 October 2021 16:41
by manjh
Xenomes wrote: Friday 15 October 2021 18:59
Yes.
Posted: Monday 18 October 2021 19:12
by Xenomes
manjh wrote: Monday 18 October 2021 16:41
Yes.
OK perfect, I merge the test version with the live version. can you run that version for a wile and report back you findings .
Posted: Wednesday 20 October 2021 16:42
by manjh
Xenomes wrote: Monday 18 October 2021 19:12
Yes.
I did as you requested, looking good. WIll keep an eye on it.
Posted: Monday 25 October 2021 13:27
by jono
Hi will this plug-in control my IR blaster connected to my smart life app ?
Posted: Friday 29 October 2021 20:27
by Xenomes
jono wrote: Monday 25 October 2021 13:27
Nope, only lights and switches and some other devices on/off.
Posted: Friday 26 November 2021 8:33
by JimmyH1969
Hi There,
I have a couple of lichts added to the TUYA app on my phone and i can control them perfectly. On/Off, change brightness, Color etc..
They are also added in Domoticz, but as a type: colorswitch and a subtype: WW
So in domoticz it's only possible to switch them on/off, change brightness and warm/cold white settings, but not to change the color. Is it possible to change the subtype to RGBWW so the color can also be changed? Or is there a way to add them again with the correct subtype?
Tnx..
Posted: Friday 26 November 2021 22:34
by Xenomes
Hi JimmyH1969,
Great that everything is working! For colour detection see the Readme.md =>Key Features
Allows controlling Dimmer/RGB(WW) Colour for lights (⚠ RGBW(W) lights must be on a colour for correct detection ⚠)
I hope it will answer your question
Xenomes
Posted: Saturday 27 November 2021 17:10
by sciurius
And if not correctly detected can this be changed afterwards?
It seems that the MQTT discovery pluging also detects WW and not colour.
Posted: Saturday 27 November 2021 18:38
by Xenomes
sciurius wrote: Saturday 27 November 2021 17:10
Delete the device in Domoticz, the device will be detected again.
Posted: Saturday 27 November 2021 19:31
by sciurius
Yes, but it will be detected again as Dimmer/WW. So apparently is it not possible to modify the type after detection.
Posted: Saturday 27 November 2021 19:33
by Xenomes
U need to set a colour to the light then it will be detect as a rgbww.
Posted: Thursday 23 December 2021 23:43
by JdoTMM
[EDIT]
Found the problem: Tuya sometimes loses connections with api. needed to unplug and replug and all is working fine
Hope Tuya comes up with a fix soon.
[/EDIT]
Been using the plug-in for a couple of weeks now. The last few days I can't switch detected lights anymore.
Uninstalled then plug-in, removed the hardware and devices and deleted the folder. Reinstalled the plugin. Domoticz / Tuya plugin adds my devices without any problem:
- tuya problem domoticz.png (23.7 KiB) Viewed 2823 times
But still it will not let me control the switch. The Tuya app controls it without any problem so I know the device is working.
I did install the latest beta some day's ago 2021.1 (build 13949): could this be the source of my problems?
Regards,
John.
