Page 19 of 94
Posted: Monday 21 September 2015 22:58
by G3rard
timovd wrote: On the FIbaro Dimmer 2, I press the B-button three times to put it in learning mode, but nothing is happening. There is about 2 meter distance between the Z-stick and the Dimmer. Am I still doing something wrong?
The USB stick is now correctly recognized?
Try pressing the buttons 4 times. That works for me sometimes (1 for waking it up and then 3 for adding it).
Posted: Tuesday 22 September 2015 20:34
by timovd
Getting there... It's connected now.
How can I make the Dimmer visible at tab "Switches"?
Posted: Tuesday 22 September 2015 21:24
by G3rard
timovd wrote: How can I make the Dimmer visible at tab "Switches"?
Goto Setup - Devices and look for the dimmer. Then press the green arrow to add the device.
Posted: Tuesday 22 September 2015 21:35
by G3rard
ThinkPad wrote:Does anyone here have succesful spindown of the disks while using the packages from jumbotroll?
Haven't paid attention to it yet, but most of the time my NAS is doing only stuff that doesn't require any disk activity like VPN-server or Domoticz. So the ideal situation would be to have the disks in spindown and only let them spin up when the disks really need to be accessed.
But i'm not sure if the disks spindown, will put a Z-Wave plug between the NAS powersupply so i can monitor it.
But if it doesn't go to sleep, would there be any options to modify Domoticz to prevent it from accessing the disks every now and then? (maybe it writes the log to the disks on a set interval?).
Anyone experience with that?
My experience is that with Domoticz the NAS will not go in spindown mode because the logfile is continually been written to. The logfile is in the domoticz/var directory.
If it is possible that Domoticz writes to a log file on a USB stick then the NAS could probably go in hibernation. This is also working for other programs like Sickbeard.
@Jumbotroll, do you think it is possible to change the path of the log file? Or should there first be an option in Domoticz to change the path where the log file is stored?
Posted: Tuesday 22 September 2015 22:32
by jumbotroll
G3rard wrote: @Jumbotroll, do you think it is possible to change the path of the log file? Or should there first be an option in Domoticz the change the path where the log file is stored?
I think this must be changed in domoticz source.
Jumbotroll
Posted: Tuesday 22 September 2015 23:16
by Phuturist
I recently upgrade to version 2.3075 but this has broken the energy readings from my solar inverter through SBFspot (SMA inverter with speedwire). The sensor is there in Domoticz and it can read other realtime data like the voltage of my inverter but it reports energy unknown in the log (which is ofcourse the data I'm really after). I'd like to rollback to a previous version of the Domoticz package but I cant seem to figure out how to do this. Could someone enlighten me?
Posted: Tuesday 22 September 2015 23:26
by jumbotroll
Take a backup of database in domoticz first, then delete V2.3075.
Manually download an older "working version" from here http://jadahl.dscloud.me/sspks/index.php?fulllist=true
an manually install before you restore database from domoticz.
Jumbotroll
Posted: Wednesday 23 September 2015 11:18
by ThinkPad
Jumbotroll
It seems it is a parameter in the file that starts Domoticz:
http://domoticz.com/forum/viewtopic.php ... cation+log
Maybe it can be changed in the package? But i don't know to what... i would say /volume2/, but there are probably users that have multiple volumes, so a USB-disk would become /volume3/
Or just write it to the RAM :P I never needed to look back in the log :P
But not only the log is updated, also the domoticz.db ofcourse.... So if the HDD's would be in spindown and you turn on a light, the 'ON' entry is written to the database --> HDD's turn back on.
I think it is quite hard to get the HDD's in spindown... problem is bigger than i thought :shock:
Posted: Wednesday 23 September 2015 12:22
by jumbotroll
There is no problem to change the path where to save the logfile in the dsm-control.sh, but where do we want it? :-)
There is so many different wishes and the best thing would be to have standard setting.
I did think about a different solution, with a wizard when the user installing domoticz on synology with different settings, but time will show if my skills in programming allow this :-)
Jumbotroll
Posted: Wednesday 23 September 2015 16:40
by jumbotroll
Update
Domoticz V2.3107.
OpenZWave 1.3.487.
New
Added arch-comcerto2k for DS414j
Jumbotroll
Posted: Wednesday 23 September 2015 21:21
by Phuturist
jumbotroll wrote:Take a backup of database in domoticz first, then delete V2.3075.
Jumbotroll
Thanx a bunch, a rollback fixed my issue. So it looks like I'm stuck for now.
Did notice that the full list only contains two versions per architecture at the moment while there where more when I first looked at it.
Posted: Wednesday 23 September 2015 22:05
by jumbotroll
Jumbotroll
I delete older files when I update some times to release some space on my server.
Have you tested the update domoticz v2.3107 to see if the bug was fixed in the source?
You can check the commits in the source code here: https://github.com/domoticz/domoticz/commits/master
Edit: Problem with Energy Sensor and Alert since version 3072 http://www.domoticz.com/forum/viewtopic.php?f=6&t=8175
Jumbotroll
Posted: Thursday 24 September 2015 20:42
by mvveelen
Hi, I installed v2.3113, but it crashed after a while. The version prior to this crashed every few minutes. What is going on with the latest versions? They seem to work for a while, but then......
Posted: Thursday 24 September 2015 21:58
by jumbotroll
mvveelen wrote:Hi, I installed v2.3113, but it crashed after a while. The version prior to this crashed every few minutes. What is going on with the latest versions? They seem to work for a while, but then......
v2.3113 is working stable here, but can you see what causes the crash in the log?
Is anyone else have problem with v2.3113?
I am only using rfxcom and testing with rflink, maybe it's the latest openzwave that causes this crash?
Maybe I should roll back to an older version of openzwave?
Jumbotroll
Posted: Friday 25 September 2015 8:40
by mvveelen
No, I can't see what it causes. It keeps running for an hour or longer and then it just stops. Can't see the log then.
Do you have the v2.3050 version somewhere? That one was OK. Perhaps it is the OpenZWave part.....?
If it is the DB, is there some tooling which I can use to check the DB?
Posted: Friday 25 September 2015 9:00
by ThinkPad
v2.3113 is working fine on my DS715, updated the package yesterday at ~18:00, no problems at all.
Using RFXCOM and Aeon S2 Z-Wave stick, all working fine.
So it's a bit weird that some have issues, and some don't have any problems at all.
Posted: Friday 25 September 2015 9:01
by G3rard
mvveelen wrote:No, I can't see what it causes. It keeps running for an hour or longer and then it just stops. Can't see the log then.
The logfile is in the domoticz/var folder. Maybe that gives some more information.
Posted: Friday 25 September 2015 10:39
by jumbotroll
Sorry, v2.3050 was deleted from my server.
I have build a testbuild for you with older openzwave (1.3.482)
Download from my Beta section: http://www.jadahl.com/beta.html
Jumbotroll
Posted: Friday 25 September 2015 15:55
by G3rard
@mvveelen Have you updated your Hue firmware? That is causing an issue for others.
http://www.domoticz.com/forum/viewtopic ... 191#p55921
Posted: Friday 25 September 2015 16:41
by mvveelen
Hi, I don't have any Hue lights. Thanks for the advice.
@Jumbotroll, is it possible to update to that test-version instead of installing it? I don't really want to delete the whole again and install it afterwards. I have some scripts etc. that I have to upload each time and give the files the right permissions.
v2. 3037 is running smoothly since this morning with 1 flaw:
2015-09-25 08:57:22.385 Error: SQL Query("SELECT Value, Date FROM MultiMeter_Calendar WHERE (DeviceRowID==93 AND Date>='2015-09-18' AND Date<='2015-09-25') ORDER BY Date ASC") : no such column: Value
There seems to be a DB change (??), and going back to the v2.3037 results in no more readings from my Fibaro Wall Plug.
Edit: nevermind, I uninstalled v2.3037 and installed v2.3116
This is an error message I got:
Error: SQL Query("ALTER TABLE Hardware ADD COLUMN [Extra] VARCHAR(200) DEFAULT ('')") : duplicate column name: Extra
Probably no issue ?
Edit 2:
The readings for the FWP are back :) Now, let me see if it keeps running the next few hours or more.
Thanks Jumbotroll !
Edit 3:
I see this error once in a while popping up in the log:
Error: Kodi: (Kodi) Async Read Exception: Operation canceled
Edit 4:
I decided to delete the Kodi "hardware". After adding it again, the same error pops up. So....no more Kodi status for me at this moment.
