Python Plugin : Broadlink RM2 V4
fvdp80
Domoticz version: 4.10303
Re: Python Plugin : Broadlink RM2 V4
Post by fvdp80 »
I said before that the plugin was running like a charm, but it's not.
The "connection" between Domoticz and the Broadlink get's lost a lot. The only way to restore the connection is to restart Domoticz.
And that's not even always the solution. Then it's still not always possible to send an IR command.
What to try now for a clean install? Any ideas?
Domoticz log:
2018-12-10 11:00:59.544 Error: (IR-controller Bios) 'onHeartbeat' failed 'TypeError':'unorderable types: NoneType() > int()'.
2018-12-10 11:00:59.544 Error: (IR-controller Bios) ----> Line 473 in '/home/pi/domoticz/plugins/broadlink/plugin.py', function onHeartbeat
2018-12-10 11:00:59.544 Error: (IR-controller Bios) ----> Line 757 in '/home/pi/domoticz/plugins/broadlink/plugin.py', function checkTemp
zak45
Domoticz version: V2024.4
Post by zak45 »
@fvdp80
Are you sure that your device is able to give you the Temp ? ( function checkTemp)
fvdp80
Post by fvdp80 »
Switched the hardware device to RM2/Mini with temp device and logs are as follow:
2018-12-10 12:14:06.849 (IR-controller Bios) Device ID: '6'
2018-12-10 12:14:06.849 (IR-controller Bios) Device Name: 'IR-controller Bios - Command'
2018-12-10 12:14:06.850 (IR-controller Bios) Device nValue: 0
2018-12-10 12:14:06.850 (IR-controller Bios) Device sValue: 'Off'
2018-12-10 12:14:06.850 (IR-controller Bios) Device LastLevel: 10
2018-12-10 12:14:06.850 (IR-controller Bios) Device: 2 - ID: 47, Name: 'IR-controller Bios - Temp', nValue: 0, sValue: ''
2018-12-10 12:14:06.851 (IR-controller Bios) Device ID: '47'
2018-12-10 12:14:06.851 (IR-controller Bios) Device Name: 'IR-controller Bios - Temp'
2018-12-10 12:14:06.851 (IR-controller Bios) Device nValue: 0
2018-12-10 12:14:06.851 (IR-controller Bios) Device sValue: ''
2018-12-10 12:14:06.852 (IR-controller Bios) Device LastLevel: 0
2018-12-10 12:14:06.852 (IR-controller Bios) Device: 5 - ID: 27, Name: 'Airco Cool 21c', nValue: 0, sValue: ''
2018-12-10 12:14:06.852 (IR-controller Bios) Device ID: '27'
2018-12-10 12:14:06.852 (IR-controller Bios) Device Name: 'Airco Cool 21c'
2018-12-10 12:14:06.853 (IR-controller Bios) Device nValue: 0
2018-12-10 12:14:06.853 (IR-controller Bios) Device sValue: ''
2018-12-10 12:14:06.853 (IR-controller Bios) Device LastLevel: 0
2018-12-10 12:14:06.853 (IR-controller Bios) Device: 6 - ID: 28, Name: 'Airco Off', nValue: 0, sValue: ''
2018-12-10 12:14:06.854 (IR-controller Bios) Device ID: '28'
2018-12-10 12:14:06.854 (IR-controller Bios) Device Name: 'Airco Off'
2018-12-10 12:14:06.854 (IR-controller Bios) Device nValue: 0
2018-12-10 12:14:06.854 (IR-controller Bios) Device sValue: ''
2018-12-10 12:14:06.855 (IR-controller Bios) Device LastLevel: 0
2018-12-10 12:14:06.855 (IR-controller Bios) Device: 7 - ID: 29, Name: 'Airco Heat 21c', nValue: 1, sValue: 'On-2'
2018-12-10 12:14:06.855 (IR-controller Bios) Device ID: '29'
2018-12-10 12:14:06.855 (IR-controller Bios) Device Name: 'Airco Heat 21c'
2018-12-10 12:14:06.856 (IR-controller Bios) Device nValue: 1
2018-12-10 12:14:06.856 (IR-controller Bios) Device sValue: 'On-2'
2018-12-10 12:14:06.856 (IR-controller Bios) Device LastLevel: 0
2018-12-10 12:14:06.856 (IR-controller Bios) Device: 8 - ID: 30, Name: 'Airco Humid 21c', nValue: 0, sValue: ''
2018-12-10 12:14:06.856 (IR-controller Bios) Device ID: '30'
2018-12-10 12:14:06.857 (IR-controller Bios) Device Name: 'Airco Humid 21c'
2018-12-10 12:14:06.857 (IR-controller Bios) Device nValue: 0
2018-12-10 12:14:06.857 (IR-controller Bios) Device sValue: ''
2018-12-10 12:14:06.857 (IR-controller Bios) Device LastLevel: 0
2018-12-10 12:14:06.858 (IR-controller Bios) Device: 9 - ID: 31, Name: 'Beamer Aan', nValue: 0, sValue: ''
2018-12-10 12:14:06.858 (IR-controller Bios) Device ID: '31'
2018-12-10 12:14:06.858 (IR-controller Bios) Device Name: 'Beamer Aan'
2018-12-10 12:14:06.858 (IR-controller Bios) Device nValue: 0
2018-12-10 12:14:06.859 (IR-controller Bios) Device sValue: ''
2018-12-10 12:14:06.859 (IR-controller Bios) Device LastLevel: 0
2018-12-10 12:14:06.859 (IR-controller Bios) Device: 10 - ID: 32, Name: 'Beamer Uit', nValue: 1, sValue: 'On-4'
2018-12-10 12:14:06.859 (IR-controller Bios) Device ID: '32'
2018-12-10 12:14:06.860 (IR-controller Bios) Device Name: 'Beamer Uit'
2018-12-10 12:14:06.860 (IR-controller Bios) Device nValue: 1
2018-12-10 12:14:06.860 (IR-controller Bios) Device sValue: 'On-4'
2018-12-10 12:14:06.860 (IR-controller Bios) Device LastLevel: 0
2018-12-10 12:14:06.861 (IR-controller Bios) Device: 11 - ID: 33, Name: 'Receiver Aan', nValue: 0, sValue: ''
2018-12-10 12:14:06.861 (IR-controller Bios) Device ID: '33'
2018-12-10 12:14:06.861 (IR-controller Bios) Device Name: 'Receiver Aan'
2018-12-10 12:14:06.861 (IR-controller Bios) Device nValue: 0
2018-12-10 12:14:06.861 (IR-controller Bios) Device sValue: ''
2018-12-10 12:14:06.862 (IR-controller Bios) Device LastLevel: 0
2018-12-10 12:14:06.862 (IR-controller Bios) Device: 13 - ID: 35, Name: 'Receiver Volume -30', nValue: 0, sValue: ''
2018-12-10 12:14:06.862 (IR-controller Bios) Device ID: '35'
2018-12-10 12:14:06.863 (IR-controller Bios) Device Name: 'Receiver Volume -30'
2018-12-10 12:14:06.863 (IR-controller Bios) Device nValue: 0
2018-12-10 12:14:06.863 (IR-controller Bios) Device sValue: ''
2018-12-10 12:14:06.863 (IR-controller Bios) Device LastLevel: 0
2018-12-10 12:14:06.863 (IR-controller Bios) Device: 14 - ID: 36, Name: 'Receiver Volume -10', nValue: 1, sValue: 'On-4'
2018-12-10 12:14:06.864 (IR-controller Bios) Device ID: '36'
2018-12-10 12:14:06.864 (IR-controller Bios) Device Name: 'Receiver Volume -10'
2018-12-10 12:14:06.864 (IR-controller Bios) Device nValue: 1
2018-12-10 12:14:06.864 (IR-controller Bios) Device sValue: 'On-4'
2018-12-10 12:14:06.865 (IR-controller Bios) Device LastLevel: 0
2018-12-10 12:14:06.865 (IR-controller Bios) Device: 15 - ID: 37, Name: 'Receiver Uit', nValue: 1, sValue: 'On-5'
2018-12-10 12:14:06.865 (IR-controller Bios) Device ID: '37'
2018-12-10 12:14:06.865 (IR-controller Bios) Device Name: 'Receiver Uit'
2018-12-10 12:14:06.865 (IR-controller Bios) Device nValue: 1
2018-12-10 12:14:06.866 (IR-controller Bios) Device sValue: 'On-5'
2018-12-10 12:14:06.866 (IR-controller Bios) Device LastLevel: 0
2018-12-10 12:14:06.866 (IR-controller Bios) Device: 254 - ID: 7, Name: 'IR-controller Bios - Discovery', nValue: 0, sValue: ''
2018-12-10 12:14:06.866 (IR-controller Bios) Device ID: '7'
2018-12-10 12:14:06.867 (IR-controller Bios) Device Name: 'IR-controller Bios - Discovery'
2018-12-10 12:14:06.867 (IR-controller Bios) Device nValue: 0
2018-12-10 12:14:06.867 (IR-controller Bios) Device sValue: ''
2018-12-10 12:14:06.867 (IR-controller Bios) Device LastLevel: 0
2018-12-10 12:14:06.868 (IR-controller Bios) Pushing 'PollIntervalDirective' on to queue
2018-12-10 12:14:06.868 (IR-controller Bios) Connecting to: 10.0.1.12:B4430DFC098E
2018-12-10 12:14:06.804 Status: (IR-controller Bios) Initialized version 4.1.0, author 'zak45'
2018-12-10 12:14:06.807 Status: (IR-controller Bios) Entering work loop.
2018-12-10 12:14:07.038 (IR-controller Bios) Connected to Broadlink device: 10.0.1.12
2018-12-10 12:14:07.038 (IR-controller Bios - Command) Updating device from 0:'Off' to have values 1:'10'.
2018-12-10 12:14:07.066 (IR-controller Bios) Update 1:'10' (IR-controller Bios - Command)
2018-12-10 12:14:07.085 (IR-controller Bios) No ini file :home/pi/domoticz/plugins/broadlink/ini-files/remote/plugin_remote_4.ini
2018-12-10 12:14:07.085 (IR-controller Bios) Custom Commands for Remote not managed
2018-12-10 12:14:07.085 (IR-controller Bios) Device Number begin to : 12
2018-12-10 12:14:07.086 (IR-controller Bios) Processing 'PollIntervalDirective' message
2018-12-10 12:14:07.086 (IR-controller Bios) Heartbeat interval set to: 30.
2018-12-10 12:14:16.810 (IR-controller Bios) Pushing 'onHeartbeatCallback' on to queue
2018-12-10 12:14:16.859 (IR-controller Bios) Processing 'onHeartbeatCallback' message
2018-12-10 12:14:16.861 (IR-controller Bios) Calling message handler 'onHeartbeat'.
2018-12-10 12:14:17.591 (IR-controller Bios - Temp) Updating device from 0:'' to have values 1:'12.1'.
2018-12-10 12:14:17.607 (IR-controller Bios) Update 1:'12.1' (IR-controller Bios - Temp)
2018-12-10 12:14:47.114 (IR-controller Bios) Pushing 'onHeartbeatCallback' on to queue
2018-12-10 12:14:47.128 (IR-controller Bios) Processing 'onHeartbeatCallback' message
2018-12-10 12:14:47.129 (IR-controller Bios) Calling message handler 'onHeartbeat'.
2018-12-10 12:14:55.504 (IR-controller Bios) Pushing 'onCommandCallback' on to queue
2018-12-10 12:14:55.550 (IR-controller Bios) Processing 'onCommandCallback' message
2018-12-10 12:14:55.550 (IR-controller Bios) Calling message handler 'onCommand'.
2018-12-10 12:14:55.551 (IR-controller Bios) onCommand called for Unit 254: Parameter 'On', Level: 0 , Connected : True
2018-12-10 12:14:55.551 (IR-controller Bios) Generate on Command for learned code stored on unit/ini :254
2018-12-10 12:14:55.502 Status: User: frank initiated a switch command (7/IR-controller Bios - Discovery/On)
2018-12-10 12:14:55.552 Error: (IR-controller Bios) ini file not found: home/pi/domoticz/plugins/broadlink/ini-files/BroadlinkRM2-4-254.ini
2018-12-10 12:15:17.122 (IR-controller Bios) Pushing 'onHeartbeatCallback' on to queue
2018-12-10 12:15:17.161 (IR-controller Bios) Processing 'onHeartbeatCallback' message
I'll keep monitoring if device stays online.
mattPiratt
Target OS: OS X
Post by mattPiratt »
fvdp80 wrote: Monday 10 December 2018 12:18 Switched the hardware device to RM2/Mini with temp device and logs are as follow:
Hi.
I dont get it.
You reported problem with "'onHeartbeat' failed 'TypeError':'unorderable types: NoneType() ....(...)... function checkTemp" (I have the same)
zak45 asked You if You have temp sensor
Then You said "Switched the hardware device to RM2/Mini with temp device"
What was Your previous setting for "Device Type": "Remote Control RM2/RM mini3" . ?? (mine was like this and changed to "Remote Control RM2/RM mini3 with Temperature device")
I will also observe and confirm in 1 week.
fvdp80
Post by fvdp80 »
Yep, had it set to the one without temp device, because i wasn't using it as i have a separate temp/humid device.
RueDesButtes
Re: Import device
Post by RueDesButtes »
zak45 wrote: Friday 16 November 2018 18:33
RueDesButtes wrote: Tuesday 13 November 2018 20:21 Hello,
RPI3 + Raspbian Stretch + Domoticz stable V4.9700 + RM PRO+
It looks like I am close to use the Broadlink inside Domoticz,
I am stuck now with the import function, no button is active:
  • webstart
  • import
  • generate
Can you put in debug mode and post the result ?
Sorry Zakj for the delay,
Please find below the log
Domoticz
V4.9700
2018-12-17 19:31:43.119 Status: (RMPRO) Started.
2018-12-17 19:31:48.702 Status: (RMPRO) Entering work loop.
2018-12-17 19:31:48.703 Status: (RMPRO) Initialized version 4.1.0, author 'zak45'
2018-12-17 19:31:49.788 (RMPRO) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2018-12-17 19:31:49.788 (RMPRO) 'Mode1':'780F7700B2F1'
2018-12-17 19:31:49.788 (RMPRO) 'Mode6':'Debug'
2018-12-17 19:31:49.788 (RMPRO) 'Mode4':'yes'
2018-12-17 19:31:49.788 (RMPRO) 'HomeFolder':'/domoticz/plugins/BroadlinkRM2/'
2018-12-17 19:31:49.788 (RMPRO) 'DomoticzHash':'a3a45906'
2018-12-17 19:31:49.788 (RMPRO) 'Version':'4.1.0'
2018-12-17 19:31:49.788 (RMPRO) 'DomoticzBuildTime':'2018-06-23 16:24:51'
2018-12-17 19:31:49.788 (RMPRO) 'Mode3':'RM2'
2018-12-17 19:31:49.788 (RMPRO) 'HardwareID':'3'
2018-12-17 19:31:49.788 (RMPRO) 'Name':'RMPRO'
2018-12-17 19:31:49.788 (RMPRO) 'DomoticzVersion':'4.9700'
2018-12-17 19:31:49.788 (RMPRO) 'Port':'0'
2018-12-17 19:31:49.788 (RMPRO) 'Mode2':'/domoticz/plugins/BroadlinkRM2/ini'
2018-12-17 19:31:49.789 (RMPRO) 'Author':'zak45'
2018-12-17 19:31:49.789 (RMPRO) 'Key':'BroadlinkRM2'
2018-12-17 19:31:49.789 (RMPRO) 'Address':'192.168.1.26'
2018-12-17 19:31:49.789 (RMPRO) 'Mode5':'9000'
2018-12-17 19:31:49.789 (RMPRO) Device count: 6
2018-12-17 19:31:49.789 (RMPRO) Device: 1 - ID: 1, Name: 'RMPRO - Command', nValue: 0, sValue: 'Off'
2018-12-17 19:31:49.789 (RMPRO) Device ID: '1'
2018-12-17 19:31:49.789 (RMPRO) Device Name: 'RMPRO - Command'
2018-12-17 19:31:49.789 (RMPRO) Device nValue: 0
2018-12-17 19:31:49.789 (RMPRO) Device sValue: 'Off'
2018-12-17 19:31:49.789 (RMPRO) Device LastLevel: 10
2018-12-17 19:31:49.789 (RMPRO) Device: 2 - ID: 5, Name: 'RMPRO - 3-2 Tri normal descendre', nValue: 1, sValue: 'On-29'
2018-12-17 19:31:49.789 (RMPRO) Device ID: '5'
2018-12-17 19:31:49.789 (RMPRO) Device Name: 'RMPRO - 3-2 Tri normal descendre'
2018-12-17 19:31:49.789 (RMPRO) Device nValue: 1
2018-12-17 19:31:49.790 (RMPRO) Device sValue: 'On-29'
2018-12-17 19:31:49.790 (RMPRO) Device LastLevel: 0
2018-12-17 19:31:49.790 (RMPRO) Device: 3 - ID: 6, Name: 'RMPRO - 3-3 Tri normal monter', nValue: 1, sValue: 'On-32'
2018-12-17 19:31:49.790 (RMPRO) Device ID: '6'
2018-12-17 19:31:49.790 (RMPRO) Device Name: 'RMPRO - 3-3 Tri normal monter'
2018-12-17 19:31:49.790 (RMPRO) Device nValue: 1
2018-12-17 19:31:49.790 (RMPRO) Device sValue: 'On-32'
2018-12-17 19:31:49.790 (RMPRO) Device: 4 - ID: 7, Name: 'RMPRO - 3-4 Tri normal stop', nValue: 1, sValue: 'On-1'
2018-12-17 19:31:49.790 (RMPRO) Device ID: '7'
2018-12-17 19:31:49.790 (RMPRO) Device Name: 'RMPRO - 3-4 Tri normal stop'
2018-12-17 19:31:49.790 (RMPRO) Device sValue: 'On-1'
2018-12-17 19:31:49.790 (RMPRO) Device: 254 - ID: 2, Name: 'RMPRO - Remote', nValue: 0, sValue: 'Off'
2018-12-17 19:31:49.790 (RMPRO) Device ID: '2'
2018-12-17 19:31:49.790 (RMPRO) Device Name: 'RMPRO - Remote'
2018-12-17 19:31:49.790 (RMPRO) Device nValue: 0
2018-12-17 19:31:49.791 (RMPRO) Device sValue: 'Off'
2018-12-17 19:31:49.791 (RMPRO) Device LastLevel: 0
2018-12-17 19:31:49.791 (RMPRO) Device: 255 - ID: 3, Name: 'RMPRO - Import', nValue: 0, sValue: 'Off'
2018-12-17 19:31:49.791 (RMPRO) Device ID: '3'
2018-12-17 19:31:49.791 (RMPRO) Device Name: 'RMPRO - Import'
2018-12-17 19:31:49.791 (RMPRO) Device nValue: 0
2018-12-17 19:31:49.791 (RMPRO) Device LastLevel: 30
2018-12-17 19:31:49.791 (RMPRO) Pushing 'PollIntervalDirective' on to queue
2018-12-17 19:31:49.791 (RMPRO - Import) Updating device from 0:'Off' to have values 0:'Off'.
2018-12-17 19:31:49.801 (RMPRO) Update 0:'Off' (RMPRO - Import)
2018-12-17 19:31:49.801 (RMPRO) Connecting to: 192.168.1.26:XXXXXXXXXX
Latest Beta on RPI3B+
RFX, Rflink,RM Pro, Xiaomi devices, Hue bridge, Onkyo, Harmony
zak45
Post by zak45 »
do not seen error.
under /domoticz/plugins/BroadlinkRM2/ini you should have import folder, ini to import need to be there.
nono212
Domoticz version: 3.6179
Post by nono212 »
On Synology
I finally was able to make it work as it is seen in this link
https://zhougy0717.github.io/2017/07/31 ... azon_Echo/
I have a question Zak45 I did not use e-control but ihc EU I would like to know if there is a way to export the learned data
Thanks for that great job
zak45
Post by zak45 »
nono212 wrote: Wednesday 26 December 2018 0:19 On Synology
Nice you got it running.. for IHC, do not use it so no idea.
Lars65
Post by Lars65 »
The A1 sensors is checking every 30 second, is there anyway how to change this intervals?
zak45
Post by zak45 »
Lars65 wrote: Wednesday 26 December 2018 7:23 The A1 sensors is checking every 30 second, is there anyway how to change this intervals?
Not in easy way ....
nono212
Post by nono212 »
small question ...
With Broadlink I can learn RF/IR codes
but with the plugin I can learn only IR no RF is there a reason ?
corederoma82
Post by corederoma82 »
In my domoticz it's not functioning.
I select "Broadlink RM2 with Kodi Remote" and then "Device Type: discovery", and Domoticz became unusable, it's impossible to switch tab, it's impossible to do anything, the only solution has been reinstallation of Domoticz.
Why?
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
fvdp80
Post by fvdp80 »
It's a known issue. Please read the posts on the last 4-5 pages and you will have your solution.
corederoma82
fvdp80 wrote: Wednesday 02 January 2019 13:45 It's a known issue. Please read the posts on the last 4-5 pages and you will have your solution.
Thanks; there are so many post....can be this a solution?
sudo pip3 uninstall pycryptodome (but I not installed pycryptocrome),
I used this:
sudo pip3 install pyaes
Thanks again
fvdp80
Post by fvdp80 »
For me uninstalling pycryptodome didn't work. Maybe it will for you, just try it.
Otherwise try my solution mentioned a few pages back.
The plugin and Broadlink are running lika a charm again, with no connection-errors anymore.
Problem was solved by reconfiguring my router/AP/network.
corederoma82
fvdp80 wrote: Thursday 03 January 2019 7:11
Can you say me where? I don't found it.
fvdp80
Post by fvdp80 »
corederoma82 wrote: Thursday 03 January 2019 9:19
Dude, come on... it's 2 pages back. A little effort please.
Duci
Post by Duci »
-Sorry for the wall of text. Maybe it will help someone.- :D
Wrestling with getting this working for a few evenings now. Am noob, so having some issues.
The last few pages I have been reading about some people not getting it to work, and domoticz crashing when they create the hardware in domoticz. Just wanted to say that (like was being said) you need to deinstall pycryptodome. I did not even install it myself, but apparently it was still on my machine for some reason. :lol:
What I did so far:
-Make a fresh install of stretch-lite
-Install domoticz and load my databases
-Installed monit
-installed broadlink
-installed pyaes
-copied libs for Crypto and broadlink to correct dirs as described in wiki
-downloaded the plugin files, put them in the right folder and made them executable (i had to create the "BroadlinkRM2" folder myself, by the way. Is that normal?)
After doing this and adding the hardware in domoticz nothing happened or it even got stuck. The log said broadlink started and it was entering workloop, but nothing else.
-After digging in this topic, I saw that it was neccesary to uninstall pycryptodome (even though I did not install it myself, but OK)
After deinstalling at least now I am at the point where the " Broadlink RM3 - import/remote/temp/command" devices are appearing. So I guess I am going in the right direction. :)
Update- yep. Plugin seems to work! I was able to learn and save an IR signal. Unfortunately my Broadlink RM pro+ does not appear to be able to learn any RF codes with any of the apps (IHC, IHC for EU, E-control). Don't know yet how this will work in Domoticz. Is any of you having this issue as well, or am I just having a faulty device? :(
Question: Does anyone maybe have a Philips tv with RF remote working? Maybe in the e-control app, or maybe in Domoticz? And could you please send me the ini file for that so that I can upload it? I do have it working in the IHC app, but that does not allow me to export the ini.
Update 2 even though my Broadlink RM pro plus does not seem to be able to learn RF codes (probably a defect) I have found a workaround/hack. Just in case someone is encountering the same issue.
-Install the IHC app (not the "IHC for EU" one)
-This app has a library for all sorts of devices. Add your (RF) device and test it.
-To learn the codes in Domoticz, click "learn" in domoticz and then quickly tap the coresponding button in the IHC app.
-For some reason it detects this as "learning" this RF code.
-You can now save the button, and it should be working.
Would still appreciate if someone could give me the .ini for their Philips RF TV, though. :lol:
BIG thank you to zak45 for building this!
nono212
Post by nono212 »
Thanks Duci
I tryed also to learn RF I did not think usung IHC as sender ... I will try this evening
