Page 19 of 24
Re: Aurora theme
Posted: Friday 08 June 2018 10:04
by devros
Im playing with theme css, and have idea about custom image (PNG with transparency) on bottom page backgrounds for each Room (different energy monitoring ,tv, irrigation, security...).
For whole theme it works pretty well (i can post screenshots and css). But looks like, i cant change it individualy because rooms are not using any css identifiers.... Any idea how to solve this?
Re: Aurora theme
Posted: Monday 11 June 2018 19:29
by rhendriks
Theme button is gone.
I have update several times but there is no button.
How can I fix this?
Re: Aurora theme
Posted: Tuesday 12 June 2018 12:12
by Xztraz
rhendriks wrote: Monday 11 June 2018 19:29 Theme button is gone.
How can I fix this?
Running beta?
Test other browser with clean cache and files
Re: Aurora theme
Posted: Tuesday 12 June 2018 12:35
by SweetPants
How can I fix this?
No problem on V3.9629
Re: Aurora theme
Posted: Tuesday 12 June 2018 16:52
by rhendriks
SweetPants wrote: Tuesday 12 June 2018 12:35
How can I fix this?
I mean this , normally stay under " Backup/Herstel" the theme button.
Re: Aurora theme
Posted: Tuesday 12 June 2018 19:17
by SweetPants
You mean like this?
Re: Aurora theme
Posted: Tuesday 12 June 2018 22:14
by rhendriks
SweetPants wrote: Tuesday 12 June 2018 19:17 You mean like this?
Yes
Re: Aurora theme
Posted: Tuesday 12 June 2018 22:18
by SweetPants
rhendriks wrote: Tuesday 12 June 2018 22:14
Yes
Well, as you can see it's still there in V3.9629 :mrgreen: :mrgreen: :mrgreen:
Re: Aurora theme
Posted: Wednesday 13 June 2018 16:30
by Xztraz
I'm on latest beta and i see the theme button.
looking at the code for that
// actually adding the settings tab.
    if (typeof(Storage) !== "undefined") { // Do we even have theme settings?
        if (!$('#tabtheme').length){
            // modifying settings menu
            $('#tabs .pull-right').before('<li id="themeTabButton"><a data-target="#tabtheme" data-toggle="tab" data-i18n="Theme">Theme</a></li>');
            // If were on a mobile phone, make the settingsmenu a dropdown.
            $('#tabs li:not(.pull-right)').click(function() {
                if ($(window).width() < 480) {
                    $(this).parent().toggleClass('menuopen');
                    if( !$(this).parent().hasClass('menuopen') ){
                        $(this).siblings('li:not(.pull-right)').slideUp("fast");
                    }else{
                        $(this).siblings('li:not(.pull-right)').slideDown("fast");
                }else{
                    $(this).siblings().show(); //safety, if user scaled/rotated the screen.
                    $(this).parent().removeClass('menuopen');
            // inserting the themesettings.html
            $('#my-tab-content').append('<div class="tab-pane" id="tabtheme"><section id="theme">Loading..</section></div>');
            $('#my-tab-content #theme').load("acttheme/themesettings.html",loadedSettingsHTML);
            // loadedSettingsHTML() was here
    } else {
        // No Web Storage support.. hmm.
one fault condition could be no web storage. so have you blocked web pages to store local files or something in your browser? did you try with another browser?
Re: Aurora theme
Posted: Thursday 14 June 2018 13:01
by Maes
When I change any settings and press save, all settings are reverted to default.
I'm using a baseURL in my domoticz, perhaps this needs special configuration with aurora?
I've tried using the parameter baseURL in custom.js but it doesn't do anything..
Re: Aurora theme
Posted: Thursday 14 June 2018 13:54
by devros
Maes wrote: Thursday 14 June 2018 13:01 When I change any settings and press save, all settings are reverted to default.
Setting in aurora is saved afaik localy, so it looks like problem with you browser (cookies disabled or private browsing enabled :) )
Re: Aurora theme
Posted: Thursday 14 June 2018 14:23
by Maes
Thanks for the help.
I checked and my chrome browser was still in pornhub mode.
I turned it off and the settings are "saved". However, the menu bar keeps going back to the top (but the setting clearly states that it should be a side bar)
Re: Aurora theme
Posted: Thursday 14 June 2018 14:28
by devros
Maes wrote: Thursday 14 June 2018 14:23 Thanks for the help.
try reset theme to default setting and reset app-cache
Re: Aurora theme
Posted: Thursday 14 June 2018 14:36
by Maes
devros wrote: Thursday 14 June 2018 14:28
I tried this just now but it doesn't work.
If I uncheck the setting "Main menu as a sidebar" and check it again then the menu goes to the side. However, once I press "APPLY SETTINGS" the menu bar goes back to the top. The setting is still saved as checked, though.
Re: Aurora theme
Posted: Thursday 14 June 2018 23:46
by jannnfe
i love the Aurora Theme but i'm not able to get the Camera Live Stream in Dashboard.
It looks like this:
The attachment Bildschirmfoto 2018-06-14 um 23.43.04.png is no longer available
and my Camera is linked to this devices:
Bildschirmfoto 2018-06-14 um 23.43.04.png (118.1 KiB) Viewed 5050 times
In the Settings the Camera Option of Aurora is enabled.
What to do?
Thanks! :)
Re: Aurora theme
Posted: Friday 15 June 2018 8:42
by devros
jannnfe wrote: Thursday 14 June 2018 23:46 Hello,
It looks like this:
What to do?
Thanks! :)
Switch Dashboard mode from compact to normal...
then it should work
Re: Aurora theme
Posted: Friday 15 June 2018 11:23
by jannnfe
devros wrote: Friday 15 June 2018 8:42
It looks like this:
What to do?
Thanks! :)
then it should work
No sorry also in Normal mode there is no preview of the camera live feed.
Cleared cache and browser history.
Re: Aurora theme
Posted: Tuesday 26 June 2018 16:55
by bueno79
Hi, did you try the theme with 4.9700 ? Does it fully work ? Sad it is not implemented by default...
Re: Aurora theme
Posted: Tuesday 26 June 2018 20:32
by Jem101
I'm running the latest beta which is slightly ahead of the release version and the Aurora theme works just fine. Which is not to say that it definitely works with 4.97 but I'd be astonished if it doesn't.
Re: Aurora theme
Posted: Tuesday 26 June 2018 21:09
by bueno79
hi,
I've test and yes it works on 4.9700. Still a bug on kodi telecommande popup windows. I love the theme, very interesting but we should be able to choose which device we want to display in 'big' and which one in small. camera or weather are interresting in Big and there is a good add ed value. for Switchs small is enought.
