htilburgs wrote: Wednesday 28 February 2018 17:17Hi there,wmmudde wrote: Tuesday 27 February 2018 15:19Hi, great looking F1 calender! Can you send me the config for that?htilburgs wrote: Monday 26 February 2018 22:51
Try this in your custom.css
There are several modifications I use myself:Code: Select all
/* Background blocks */ .transbg.col-xs-1, .transbg.col-xs-2, .transbg.col-xs-3, .transbg.col-xs-4, .transbg.col-xs-5, .transbg.col-xs-6, .transbg.col-xs-7, .transbg.col-xs-8, .transbg.col-xs-9, .transbg.col-xs-10, .transbg.col-xs-11, .transbg.col-xs-12 { padding-top:15px; padding-bottom:15px; border: 3px solid rgba(255,255,255,0); /* border: 7px -> 3px - Smaller space between blocks */ background: rgba(0,0,0,0); /* rgba(0,0,0,0.1); -> 0,0,0,0 makes transparent */ background-clip: padding-box; border-radius: 15px; /* Round corners */ }
Transparant blocks:Smaller (or bigger) spaces between blocks:Code: Select all
background: rgba(0,0,0,0.1);Rounded corners:Code: Select all
border: 3px solid rgba(255,255,255,0);Code: Select all
If you only like your blocktitles transparant, use:
Just play around with them and see what happens...Code: Select all
div.mh.titlegroups { height: 20px !important; padding-top: 3px !important; background: rgba(0,0,0,0); }
I also like to create the color buttons for my Yeelight LED Strip, can you send me that piece also?
F1 Kalendar is an ICS file I've imported in Apple iCloud Calendar and set is as a public calendar. I've send you a PM for this.
In the config.js it's just a simple entry with the url of the public calendar:
The buttons for the Yeelight LED Strip. This is a dummy (selector) switch with code, to address the Yeelight LED Strip.Code: Select all
var calendars = {} calendars.f1 = {maxitems: 5, title:'', image:'', icalurl:'webcal://p28-calendars.icloud.com/published/2/xxxxxx'}
After that just create an entry in your config.js like normal. Make sure you look at the variables otherwise you won't see a thing
Yeelight LED.pngCode: Select all
config['selector_instead_of_buttons'] = 0; //use for selectors config['hide_off_button'] = 0; //use for selectors
Dashticz - Show your dashboard and how-to's!
joostnl
Could you please share the f1 calendar also with me? Thank you
- htilburgs
Strange thing. I see more people on the forum having problems with Calendar (or Trashapp) that keeps loading....wmmudde wrote: Thursday 01 March 2018 12:21 thanks for your feedback, i added the private/public calendar and it keeps saying Loading..
when i open my calendar link it is opening the correct ics file.
Do you know how i can fix it?
I don't have any issues with it and didn't do anything special except following the Wiki.
Hardware:
- DewGew
- Domoticz version: V4.10618
I don't have any issues either with google calender..htilburgs wrote: Thursday 01 March 2018 13:37Strange thing. I see more people on the forum having problems with Calendar (or Trashapp) that keeps loading....wmmudde wrote: Thursday 01 March 2018 12:21 thanks for your feedback, i added the private/public calendar and it keeps saying Loading..
- HansieNL
@htilburgs: I did a clean install of the latest beta and used the default config.js. I even then have problems with loading items.The strange thing is I don't have problems when running in Ubuntu Linux. Hope Rob has a solution soon.
My old version from august (was running for months) has same loading problem.
Blah blah blah
axel2906
- Domoticz version: V3.8926
You can have the F1 calendar on this website https://www.gpupdate.net/en/calendar/27 ... -calendar/ on the right you will find ical. It's freejoostnl wrote: Thursday 01 March 2018 13:06 Could you please share the f1 calendar also with me? Thank you
RPi3 - RfxComm - Milight - OWL160
brain
Hi does somebody know how to make the big screen/page buttons on the bottom ?freakshock wrote: Friday 19 May 2017 18:22 My setup so far. It's a Nexus 10 tablet in a 3D printed wall mount.
Screenshot:
i`m searching for days now i can`t find anything about it.
thanx
- Screenshotdash.jpg (232.67 KiB) Viewed 4790 times
- htilburgs
If you create multiple screens in your config.js, than the page bullets are created.brain wrote: Saturday 03 March 2018 9:31Hi does somebody know how to make the big screen/page buttons on the bottom ?freakshock wrote: Friday 19 May 2017 18:22 My setup so far. It's a Nexus 10 tablet in a 3D printed wall mount.
Screenshot:
thanx
See also the Dashticz Wiki (http://www.domoticz.com/wiki/Dashticz_V ... le_screens)
var screens = {}
screens[1] = {}
screens[1]['background'] = 'dv2-bg10.jpg';
screens[1]['columns'] = [1,2,3,4]
screens[2] = {}
screens[2]['background'] = 'dv2-bg9.jpg';
screens[2]['columns'] = [1,2,3,4]In custom.css you can play around with the size and position.
custom.css
.swiper-pagination-bullet {
width: 35px !important;
height: 35px !important;
.swiper-pagination {
text-align: right !important;
}Hardware:
brain
It works thank youhtilburgs wrote: Saturday 03 March 2018 11:00If you create multiple screens in your config.js, than the page bullets are created.brain wrote: Saturday 03 March 2018 9:31Hi does somebody know how to make the big screen/page buttons on the bottom ?freakshock wrote: Friday 19 May 2017 18:22 My setup so far. It's a Nexus 10 tablet in a 3D printed wall mount.
Screenshot:
thanx
See also the Dashticz Wiki (http://www.domoticz.com/wiki/Dashticz_V ... le_screens)Code: Select all
var screens = {} screens[1] = {} screens[1]['background'] = 'dv2-bg10.jpg'; screens[1]['columns'] = [1,2,3,4] screens[2] = {} screens[2]['background'] = 'dv2-bg9.jpg'; screens[2]['columns'] = [1,2,3,4]
custom.cssCode: Select all
.swiper-pagination-bullet { width: 35px !important; height: 35px !important; } .swiper-pagination { text-align: right !important; }
brain
Screenshot:
thanx
emoncuit
I have an issue with the sunrise module. It doesn't load the time. I have only the icons.
The weater works fine but not the sunrise function.
Could you help me.
Could you help me.
jake
For the longest time I have the issue that the tablet stays on forever. When I turn the screen off manually, it does. I use the camera to wake it up and that works, but when the browser / page is loaded for a couple hours, it quite often acts like that (keep the screen on).
The weird thing is that:
- after I kill / start the browser again, it works for a couple hours alright (screen turn off after preset idle time of tablet settings)
- sometimes for days/weeks it works correctly as well, without the above
- when I use different browsers than the behaviour is the same (chrome / firefox / kiosk)
- when I load another website, I don't have the problem at all
So yesterday I decided to give a freshly update Kiosk Browser a try. Page loads fine, although page swipe is very sluggish. Every couple minutes however, it shows a broadcast message 'ISL error while loading page'.
I checked the Pi-hole log to see what goes in and out and found some stuff like google analytics etc etc which is blocked by Pi-Hole
I decided to disable Pi-Hole for 5 minutes and to my surprise turned the tablet the screen of within some minutes (while it had been on for hours straight before). After enabling Pi-Hole again, the wrong behaviour was back within a short time
QUESTION:
What request is poking around constantly, keeping the tablet awake, even while the request doesn't come through repeatedly (blocked by Pi-Hole)?
Can this be removed or made more friendly?
I use:
Weather information
HVC garbage
2x Google calendar
Google maps
Public transport (9292ov)
Kodi (on local network)
QUESTION:
I use:
Weather information
HVC garbage
2x Google calendar
Google maps
joostnl
At my setup the screen goes on when status changes of example my hue dimmer. But my screen automatically turns off Didn't find an solution yet.
I solved your problem in the past to disable screen turn off in android settings. And only use the screen turn off function in kiosk browserbrowser. Developer of kiosk informed me and it worked!
jake wrote: Tuesday 13 March 2018 20:02 For the longest time I have the issue that the tablet stays on forever. When I turn the screen off manually, it does. I use the camera to wake it up and that works, but when the browser / page is loaded for a couple hours, it quite often acts like that (keep the screen on).
QUESTION:
I use:
Weather information
HVC garbage
2x Google calendar
Google maps
Beschuitje
My final version for now of Dashticz.
Its running on a 13.3 inch Trekstar tablet. That’s pretty big but a deliberate choice because of the Autiplan agenda.
I did however, had to adjust the density of the thing because the webpage didn’t fit on the screen. Yes, I can just put a tablet on the wall running just the Autiplan app. but that’s not as fun as running it on Dashticz integrated with the smart meters (and more).
Running security with z-wave devices is next on the agenda. Already have a USB stick and sensors ready to go.
I do however liked to have rounded corners on the Autiplan iframe element.
I did find https://codepen.io/Repkit/pen/PzJqkZ which describes rounded corners of a YouTube clip in an frame but I can’t seem to make the translation to Dashticz.
I hope there is someone who can guide me in the right direction? I know the corners of the frame itself are not really round but it just looks nicer.
Second I would like to adjust the size of the popup windows when you click on a button. Because the tablet is bigger the windows can be bigger.
I understand from the forum this is not possible?
Third an last and not that important, I noticed tram 9 did not show tracking info while http://tracker.geops.ch/?z=16&s=1&x=548 ... =transport did
Through this site I found http://tracker.geops.ch/feeds/#feed-247 and http://www.ovapi.nl/ so there should be tracking or am I something missing here? Is it because the tram stop I configured is the beginning/end of the line?
Also, they could be just running right on time…..
Thanks again Rob Geerts for building this! It gave me the perfect opportunity of building Domoticz together with the Autiplan agenda.
You don’t know how much this is helping my son (and us) in his daily routine and give him easy of mind. And at the same tim, integrate it with domotica.
Made a PayPal donation to you.
- IMG_9372.jpg (141.33 KiB) Viewed 4266 times
clubeddie
So i thought it is time to show my dashboard, nothing specials, but finally everything is showed how i like it.
I now have a samsung sab 10'1, with kiosk browser with motion detection. But the browser is to heavy for the tablet so it is not behaving as well. In chrome on tablet it is also kinda slow. I lowered the refresh rate, but not responding great. Will tried to setup on a newer tablet to check how it is performing.
Also graph's are buggy, not showing all the time. But will check this later. Sadly Public Transport, Waterbus is not working
and module moonphase only one period of the month... a well, have to play with it
- EdwinK
- Domoticz version: BETA
How did you get the 'kosten gas' and 'kosten electra' ?
clubeddie
Used the python script in this thread, create a script for each future
viewtopic.php?t=22832
Only did not get it to add font awesome icon of a eurosign in it.
But just build it tonight, maybe i need to check it for a typo.
- EdwinK
Thanks. Checking it out
- EdwinK
I guess I'm doing things wrong. Only getting the euro 0.01 costs. Maybe it's because of Eneco.
Joep123
Here it's working fine with Eneco's Toon...
- EdwinK
Guess I'm doing something wrong then
Toon has idx 199 for electricity and idx200 for gas.
This how I have the script:
#!/usr/bin/env python
# -*- coding: UTF-8 -*-
energy_cost.py
Reads 'CounterToday' from Owl energy meter
Writes calculated cost to text device
This version is called from crontab
import requests
import json
# Domoticz variables - change for your installation
fixed = 0 # fixed cost in euro
unit = 0.2032 # unit cost in eurocents
OwlIdx = '199' #electra
costIdx = '367'
DomoBaseURL = 'http://192.168.0.11:8080/json.htm?type=devices&rid='
DomoWriteURL = 'http://192.168.0.11:8080/json.htm?type=command¶m=udevice&nvalue=0&idx='
# End of Domoticz variables
def domoticzread(idx, var):
url = DomoBaseURL + idx
response = requests.get(url)
jsonData = json.loads(response.text)
result = jsonData['result'][0][var]
return result;
kW = domoticzread(OwlIdx, 'CounterToday')
kWh = kW.split()[0]
cost = round((float(kWh) * unit + fixed) / 100 ,2)
cost = "Euro " + str(cost)
#print kW, cost
url = DomoWriteURL + costIdx + '&svalue=' + cost
r = requests.get(url)
