Nefit Easy™
SweetPants
Re: Nefit Easy™
Post by SweetPants »
access-key is with double 's'
Peacock
Domoticz version: Latest
Re: Nefit Easy™
Post by Peacock »
The mistype error didnt seem to be the problem :roll:
pepijn
Re: Nefit Easy™
Post by pepijn »
You need NodeJS 4 or up so if your node -v says 0.10 it will not work.
Peacock
Re: Nefit Easy™
Post by Peacock »
Any idea how I can install these on a ARM5 version. (have installed the v5.3.0 but doesnt seem to work), get the following: NAS> node -v
-ash: node: not found
knights
Re: Nefit Easy™
Post by knights »
@pepijn: any progress in the gass usage meter/chart ? :-)
Blaah
Domoticz version: 3.4985
Re: Nefit Easy™
Post by Blaah »
After Two nights of very little sleep i finale managed to connect my nefit easy to Domoticz using pepijn's flow in node red. Thans very much and compliments for the great work.
Main problem was the scattering of instructions all over 18 pages of this post :cry: . It definitely does not do justice to your work. When I have more time, my contribution will be a comprehensive instruction within one message. To be continued..
gizmocuz
Re: Nefit Easy™
Post by gizmocuz »
Would be nice if you could make a wiki page for it
Marcel
Re: Nefit Easy™
Post by Marcel »
HI, since I have the nefit Domoticz integration running I sometimes loose the connection to my easy thermostat both from the Nefit app and from Domoticz. This happens every 2-3 weeks (now 3 times) Restarting the easy thermostat (taking it off the wall for a couple of seconds solves the issue. It looks like either the server denies the connection or the easy thermostat looses its connection.
Anyone else have the same experience?
gizmocuz
Re: Nefit Easy™
Post by gizmocuz »
Are you using the easy server with the native domoticz implementation ?
Marcel
Re: Nefit Easy™
Post by Marcel »
Yes, running the easy-server script and native implementation.
Version: 3.4978
Build Hash: b5fe63d
Compile Date: 2016-03-17 08:33:15
m4rc3ls
Re: Nefit Easy™
Post by m4rc3ls »
I am experiencing same issue as Marcel: Running easy-server on separate RPI2. Nefit Easy thermostat seems to be hanging every 1 to 2 days, also no longer accessible through native app. Have to restart it by removing it from wall, then everything works fine again.
RPI2 433/Z-wave Plus/ZigBee
gizmocuz
Re: Nefit Easy™
Post by gizmocuz »
I dont experience these issues, maybe your internet connection went down ?
Running here for a long time
i do not use the native app of nefit
pepijn
Re: Nefit Easy™
Post by pepijn »
No issues here, I run (my) Node red solution but also the native Domoticz integration. We also use the Nefit app
m4rc3ls
Re: Nefit Easy™
Post by m4rc3ls »
Worked fine here too for a while, but since about a month the thermostat is not accepting requests (timeout) every few days. It functions by hand, but is inaccessible though Internet (native app) and local network (it's not Internet connection related). I checked but the device does keep saying it is connected to WiFi and Internet, just can not access it. Only solution is to, like I said, restart the thermostate by taking it off dock.
Because of this issue I have removed the software today unfortunately.
I am getting the feeling the thermostat blocks incoming requests at a certain point. Perhaps a new firmware version? (or old one ;)
Holland
Domoticz version: Beta Ch
Re: Nefit Easy™
Post by Holland »
@Marcel.
I had the same problem. One of the more recent version solved the time-out issue. Please make sure you have the most recent version of the Nefit http server daemon. I have version 2.1.0, which is the latest version
./easy-server -v
https://github.com/robertklep/nefit-eas ... ckage.json
Holland
Re: Nefit Easy™
Post by Holland »
@Blaah, sorry to say but you could have saved yourself a lot of time by using the native Nefit implementation of Domoticz.
You do need to install the nefit-easy-http-server daemon, which you can find overhere ; https://github.com/robertklep/nefit-easy-http-server
SweetPants
Re: Nefit Easy™
No issues here, using both Domoticz (native) integration and Nefit App without any issues. Had some problems in the beginning and contacted Nefit about loosing connection too, but this was caused by bad mounting of the thermostat on the groundplate. They also had some backend (scaling) problems, but since last two months, it works great.
dorenberg
Domoticz version: 4.10982
Re: Nefit Easy™
Post by dorenberg »
Just tried to install the nefit http server and starting to use the native support, but this completely messed up my plugwise setup. Had to reinstall a previous image and a database restoration. I will keep the node-red version for now.
Doler
Re: Nefit Easy™
Post by Doler »
For those who use the Clock Mode switch to control their Nefit and want dedicated icons for the switch I created this custom icon set:
Here is the zip-file you can use to import in Domoticz.
clockmode.zip
(4.33 KiB) Downloaded 189 times
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
Marcel
Re: Nefit Easy™
Post by Marcel »
@Holland,
Thanks for your reply. I am running 2.1.0 and latest Beta release. Somehow it looks like Nefit is blocking me occasionally because also their iOS app cannot connect to the thermostat. Internet in my house is very stable and Thermostat seems to have WIFI connection to the outside world. I also found that it occurs (more) after setting the temp from Domoticz. Maybe there is something in there that cause it to decline the connection afterwords. It is very hard to debug as it is not occurring very frequently. Because more users have the issue I am led to believe that it is something we do different....
