Page 18 of 30
Re: dtgbot - Domoticz TeleGram BOT
Posted: Saturday 27 July 2019 22:32
by beamzer
hmm, i was thinking more in the way the devices function works. Making a bash or lua script that lists them is not such a problem. But then i would like to change the values. At the moment i use 0, 1 and 2. A submenu with variables would be beter even. I was hoping someone already coded some of this.
Posted: Saturday 27 July 2019 23:27
by beamzer
this works for getting the data from all variables
#!/bin/bash
SendMsgTo=$1
mapfile -t varia < <(curl --silent 'http://domoticz.local:8080/json.htm?type=command¶m=getuservariables' | jq '.result[]|{(.Name): .Value}' | egrep -v '[{}\]' | tr -d \" )
for v in "${varia[@]}"
do
curl --data 'chat_id='$SendMsgTo --data-urlencode 'text='"$v" 'https://api.telegram.org/bot'$TelegramBotToken'/sendMessage'
done
Posted: Sunday 28 July 2019 11:48
by beamzer
Ok, this is the complete script where i can read and set domoticz variables.
If someone knows how to do this script in a telegram menu structure, i would be very interested. But at the moment this works for me.
#!/bin/bash
# Ewald 20190728
# if you would like to display with index in front, use this:
# mapfile -t varia < <(curl --silent 'http://domoticz.local:8080/json.htm?type=command¶m=getuservariables' | jq -r -c '.result[]| {Name,idx,Value}' | perl -ne '/Name\":\"(\S+?)\".*idx\":\"(\d+).*Value\":\"(\S+?)\"/ && print "\[$2\] $1: $3\n"')
# but display without the index allows for easier copy and paste to set a variable
SendMsgTo=$1
if [ -z "$2" ]; then
mapfile -t varia < <(curl --silent 'http://domoticz.local:8080/json.htm?type=command¶m=getuservariables' | jq -r -c '.result[]| {Name, Value}' | perl -ne '/Name\":\"(\S+?)\".*Value\":\"(\S+?)\"/ && print "$1 $2\n"')
do
if [[ $v != Telegram* ]]; then # leave out the dtgbot variables that start with Telegram
# another option to display only the variables ending in Alert is: [[ $v == *Alert ]]
curl --silent --data 'chat_id='$SendMsgTo --data-urlencode 'text='"$v" 'https://api.telegram.org/bot'$TelegramBotToken'/sendMessage'
fi
done
if [[ "$#" -ne 3 ]]; then
curl --silent --data 'chat_id='$SendMsgTo --data-urlencode 'text='"Sorry, i need TWO arguments, VariableName and Value" 'https://api.telegram.org/bot'$TelegramBotToken'/sendMessage'
exit 0
fi
VAR=$2; VAL=$3
if [[ $VAR == Telegram* ]]; then
curl --silent --data 'chat_id='$SendMsgTo --data-urlencode 'text='"Sorry, no changing Telegram variables" 'https://api.telegram.org/bot'$TelegramBotToken'/sendMessage'
exit 0
fi
CHECK=$(curl --silent "http://"$DomoticzIP":"$DomoticzPort"/json.htm?type=command¶m=updateuservariable&vname="$2"&vtype=0&vvalue="$3 | jq -r '.status')
if [[ $CHECK == "OK" ]]; then
curl --silent --data 'chat_id='$SendMsgTo --data-urlencode 'text='"$VAR = $VAL" 'https://api.telegram.org/bot'$TelegramBotToken'/sendMessage'
curl --silent --data 'chat_id='$SendMsgTo --data-urlencode 'text='"Oops, that didn't work" 'https://api.telegram.org/bot'$TelegramBotToken'/sendMessage'
fi
fi
Usage:
the script is named
varia.sh and put into
dtgbot/bash. So entering
varia in Telegram will give you all the variables except for the dtgbot specific variables. I left those out because they are security related, especially the
TelegramBotWhiteListedIDs. The script doesn't allow you to change those either.
Using
varia variablename value you can change the value of a specific variable.
Posted: Sunday 28 July 2019 12:15
by jvdz
beamzer wrote: Sunday 28 July 2019 11:48
-snip-
Ah ok, you mean you like support for variables in DTGMENU like we now have for devices. Well that would required quite some changes in the logic as it currently is using the Room definitions by default with the option to add "specials" via DTGMENU.CFG.
So it would require an update to the code to distinguish between Devices and UserVariables and be able to update those, but anything is possible.
I probably do not really see how this is useful for a large community yet. You stated you want to set a uservariable to 0,1 or 2, so I probably would look at an solution with a selector switch rather than using a user variable, but again, maybe I do not really understand your requirement properly
Jos
Posted: Saturday 10 August 2019 17:27
by sejtam
Has anyone found the correct way to handle the lua5.2 issues with libssl.so.1.0.0 and lubvrypto.so.1.0.0 etc?
I just installed dtgbot as per the instructions, and it seems that the lus5.2 wants to use libssl.so.1.0.0 and libvrypto.so.1.0.0
But
# apt list --installed | egrep -i '(ssl|crypto)'
libevent-openssl-2.1-6/stable,now 2.1.8-stable-4 armhf [installed,automatic]
libk5crypto3/stable,now 1.17-3 armhf [installed,automatic]
libmbedcrypto3/stable,now 2.16.0-1 armhf [installed,automatic]
libssl-dev/stable,now 1.1.1c-1 armhf [installed]
libssl1.0.2/stable,now 1.0.2q-2 armhf [installed,automatic]
libssl1.1/stable,now 1.1.1c-1 armhf [installed]
openssl/stable,now 1.1.1c-1 armhf [installed,automatic]
python-asn1crypto/stable,now 0.24.0-1 all [installed,automatic]
python-crypto/stable,now 2.6.1-9+b1 armhf [installed,automatic]
python-cryptography/stable,now 2.6.1-3 armhf [installed,automatic]
python-openssl/stable,now 19.0.0-1 all [installed,automatic]
python3-asn1crypto/stable,now 0.24.0-1 all [installed,automatic]
python3-crypto/stable,now 2.6.1-9+b1 armhf [installed,automatic]
python3-cryptography/stable,now 2.6.1-3 armhf [installed,automatic]
python3-openssl/stable,now 19.0.0-1 all [installed,automatic]
So there are libssl1.1 ans 1.0.2 installed, not 1.0.0
Posted: Sunday 11 August 2019 11:19
by beamzer
Yes, you have to install libssl1.0.0, on my rapsberry pi it has:
sudo apt list --installed | egrep -i '(ssl|crypto)'
libgnutls-openssl27/oldoldstable,now 3.3.30-0+deb8u1 armhf [installed]
libio-socket-ssl-perl/oldoldstable,now 2.002-2+deb8u3 all [installed,automatic]
libk5crypto3/oldoldstable,now 1.12.1+dfsg-19+deb8u5 armhf [installed,automatic]
libnet-smtp-ssl-perl/oldoldstable,now 1.01-3 all [installed,automatic]
libnet-ssleay-perl/oldoldstable,now 1.65-1+deb8u1 armhf [installed,automatic]
libssl-dev/oldoldstable,now 1.0.1t-1+deb8u11 armhf [installed]
libssl-doc/oldoldstable,now 1.0.1t-1+deb8u11 all [installed,automatic]
libssl1.0.0/oldoldstable,now 1.0.1t-1+deb8u11 armhf [installed]
openssl/oldoldstable,now 1.0.1t-1+deb8u11 armhf [installed,automatic]
python-cryptography/oldoldstable,now 0.6.1-1+deb8u1 armhf [installed,automatic]
python-openssl/oldoldstable,now 0.14-1 all [installed,automatic]
python-passlib/oldoldstable,now 1.6.1-1 all [installed]
ssl-cert/oldoldstable,now 1.0.35 all [installed,automatic]
I have:
in: /etc/sources.list
deb http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
and then:
sudo apt-get update
sudo apt-get install libssl1.0.0
Posted: Sunday 11 August 2019 16:01
by sejtam
really? There is no way to make it use 1.1 or 1.0.2?
Posted: Sunday 11 August 2019 16:11
by jvdz
Have you seen my post in the previous page of this thread?
And some post above about needing to recompile them?
Jos
Posted: Thursday 13 February 2020 14:56
by Nautilus
Hi, I hadn't needed dtgbot for a while. Now I tried to use it again after a few months and didn't get any reply to my messages. I tried taking all troubleshootin steps that I found relevant, but no help. In error file there is nothing, in the log file there's just the basic info of the script starting, reading the variables etc. My first assumption was something wrong with TelegramBotOffset and incremented it with one. Then I looked at
https://www.domoticz.com/wiki/Remote_Co ... use_Errors and checked update_id as suggested and found it to be no where near to what there was in the variable in Domoticz. So I updated it to the correct update_id but that did not help either. So I have dtgbot running, nothing in error log, nothing except the startup message in normal log and no response when I send any command to the bot. I can confirm it worked a couple of months ago and there has not been any major changes in the setup meanwhile. Where should I continue troubleshooting? Can I somehow reset the chat with the bot and start again from TelegramBotOffset = 1?
Posted: Thursday 13 February 2020 15:46
by jvdz
Nautilus wrote: Thursday 13 February 2020 14:56
Could it be that you are also (like me) running on an older Raspbian OS, as I had also this kind of issue Thursday last week?
Long story short: It seems the the Telegram API site stopped support for “tlsv1” and the older version of LUASEC, which performs the webcalls is using that as default protocol. So I solved that by adding a wrapper function to DTGBOT.lua to set the protocol to “tlsv1_2” and all is working again for me.
The update was committed to
https://github.com/steps39/dtgbot/blob/ ... dtgbot.lua . This i s the only file that was modified, so just download it and give it a try.
Jos
Posted: Thursday 13 February 2020 21:10
by beamzer
jvdz wrote: Thursday 13 February 2020 15:46
Jos
Thanks! it now works again,
Posted: Friday 14 February 2020 0:16
by Nautilus
beamzer wrote: Thursday 13 February 2020 21:10
Jos
Same here, thanks a lot!
Posted: Friday 14 February 2020 11:47
by Nautilus
jvdz wrote: Friday 03 August 2018 14:53
I will have a look at this as that shouldn't be too hard to add. (His famous last words
Jos
Now after browsing through the thread I noticed this and tried it on a channel where I have the same bot. But immediately if I send a command to this channel, the bot sends a message to the 1-on-1 chat that id is not whitelisted. Is this the channel id that should be whitelisted? I guess my id is still the same. I tried adding the channel id to whitelist, but then dtgbot stopped working altogether. Maybe because the channel id is in format "-##########"? Or am I missing some configuration step?
Posted: Friday 14 February 2020 12:02
by jvdz
Nautilus wrote: Friday 14 February 2020 11:47
Jos
A channel has its own ID swhich will be the senderID for DTGBOT, so you need to add that ChannelID to the Whitelist.
Jos
Posted: Friday 14 February 2020 13:18
by Nautilus
jvdz wrote: Friday 14 February 2020 12:02
Jos
Jos
Ok, then I did the correct thing, can it be that it doesn't handle the hyphen (-) in the id correctly and therefore breaks?
Posted: Friday 14 February 2020 13:24
by jvdz
Nautilus wrote: Friday 14 February 2020 13:18
It's working fine here. Have you restarted DTGBOT as the whitelist is only read from Domoticz at startup of DTGBOT?
You can see in the DTG.log which id's it found.
Jos
by jvdz
Jos
Posted: Friday 14 February 2020 14:34
by Nautilus
jvdz wrote: Friday 14 February 2020 13:24
Jos
Yes I did restart. But I will test again this evening, just in case
Posted: Friday 14 February 2020 16:29
by jvdz
Here is an actual DTG.LOG example from last night (with the numbers changed for privacy
), where a command was send via a channel.
I use it to connect my google Home to Domoticz by using IFTTT to send a Telegram message to a channel, which is read and processed by DTGBOT to perform the Domoticz command.
2020-02-13 18:01:12 - found command <secsystem>
2020-02-13 18:01:12 - Decoded On
2020-02-13 18:01:13 - Decoded 0
2020-02-13 18:01:13 - dtgbotLogLevel set to: 0
2020-02-13 18:01:13 - WLidx 20
2020-02-13 18:01:13 - Decoded 86260000|95070000|-100000890000
2020-02-13 18:01:13 - WLString: 86260000|95070000|-100000890000
2020-02-13 18:01:13 - Getting TelegramBotOffset the previous Telegram bot message offset from Domoticz
2020-02-13 18:01:13 - Decoded 724578503
2020-02-13 18:02:03 -
2020-02-13 18:02:03 - ### In contact with Telegram servers
.................... very long line with dots, one for each longpoll cycle .................
2020-02-13 23:53:17 - WhiteList: 86260000
2020-02-13 23:53:17 - WhiteList: 95070000
2020-02-13 23:53:17 - WhiteList: -100000890000
2020-02-13 23:53:17 - Handle command function started with command-goes-here!On! February 13, 2020 at 11:53PM and -100000890000 Group:-100000890000 channelmsg:true
Jos
Posted: Friday 14 February 2020 23:14
by Nautilus
Well, I tested again - same issue. The log stayed empty, nothing in errors either after adding the new whitelisted id. But nothing happened either. Then I tried again and put a trailing | after the second id and vóila, it works
