Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
- Varazir
Re: Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
I added gcc libffi-dev pkgs to install and now it's working.
- Xenomes
- Domoticz version: 2025.2
Very good that it is working! Every installation is not 100% the same.Varazir wrote: Sunday 25 January 2026 13:55 I added gcc libffi-dev pkgs to install and now it's working.
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
lebsana
Thank you so much for your work.
I followed the PDF tutorial and the instructions on GitHub, and everything worked perfectly on the first try!
Well done!
I have the MOES Smart Universal IR WiFi Infrared Remote Control. It's well integrated into Domoticz, but unfortunately, it's not yet supported by your plugin.
https://www.amazon.fr/T%C3%A9l%C3%A9com ... B07PW3R574
Do you think it's possible to integrate it?
If not, no worries, and thank you again for your work !
Well done!
- Xenomes
Hi, IR is a problem. But maybe I can check jour JSON, perhaps something changed in the output from TinyTuya. Can you create a dump.json by running debug_discovery.py from the tools directory and mail it to [email protected].lebsana wrote: Tuesday 10 February 2026 10:45 Thank you so much for your work.![]()
Well done!
Do you think it's possible to integrate it?![]()
