Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
- Varazir
Re: Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
I added gcc libffi-dev pkgs to install and now it's working.
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
- Xenomes
- Domoticz version: 2026.4
Very good that it is working! Every installation is not 100% the same.Varazir wrote: Sunday 25 January 2026 13:55 I added gcc libffi-dev pkgs to install and now it's working.
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
Tinytuya
lebsana
- Domoticz version: 2025.2
Thank you so much for your work.
I followed the PDF tutorial and the instructions on GitHub, and everything worked perfectly on the first try!
Well done!
I have the MOES Smart Universal IR WiFi Infrared Remote Control. It's well integrated into Domoticz, but unfortunately, it's not yet supported by your plugin.
https://www.amazon.fr/T%C3%A9l%C3%A9com ... B07PW3R574
Do you think it's possible to integrate it?
If not, no worries, and thank you again for your work !
Well done!
- Xenomes
Hi, IR is a problem. But maybe I can check jour JSON, perhaps something changed in the output from TinyTuya. Can you create a dump.json by running debug_discovery.py from the tools directory and mail it to [email protected].lebsana wrote: Tuesday 10 February 2026 10:45 Thank you so much for your work.![]()
Well done!
Do you think it's possible to integrate it?![]()
Tinytuya
Tinytuya
pioupiou92
Thanks Xenomes for the work done.
Plugin just installed to control KSIX BXOUTL1 Model SLL04015-N. Unfortunately, only white on/off/dimmer is working.
Is it normal?
BXOUTL1 Product details https://www.amazon.fr/-/en/KSIX-Pack-Sm ... 225&sr=1-2
Is it normal?
- Xenomes
This looks like an RGB(W) spotlight. To confirm, could you please run debug_discovery.py from the tools directory to create a dump.json file and then post it as a GitHub Issue on the Domoticz-TinyTUYA-Plugin page?pioupiou92 wrote: Friday 17 April 2026 16:53 Thanks Xenomes for the work done.
Is it normal?
Tinytuya
Tinytuya
pioupiou92
Hello Xenomes,Xenomes wrote: Friday 17 April 2026 18:55This looks like an RGB(W) spotlight. To confirm, could you please run debug_discovery.py from the tools directory to create a dump.json file and then post it as a GitHub Issue on the Domoticz-TinyTUYA-Plugin page?pioupiou92 wrote: Friday 17 April 2026 16:53 Thanks Xenomes for the work done.
Is it normal?
Issue #199 opened on GitHub.
- Xenomes
Thanks very good, i will take a look!
Tinytuya
Tinytuya
When i want Extend Service Trial Periodn i get a message from tuya
All input parameters of the remote API are lost.
Do i do something wrong, i klik on the link in the pluggin
Nothing is working here at this moment because my trial period is ovber, and for a home automation 25.000 euro in a year to pay... no, thats to much
Jurgen
Jurgen
EskildP
- Domoticz version: 2026.1
Got this mail from Tuya:
"Your subscription IoT Core, Cloud Develop Base Resource Trial remaining usage is 1.00%. Once the quota limit is exceeded, the service will be suspended.
If you want to raise the limit,
you can click the link below to upgrade your plan.
https://www.tuya.com/vas/commodity/IOT_CORE_V2"
Cannot find any way to renew for free. Do I have some wrong subscription, or did Tuya change the conditions?
Any hints?
Any hints?
- Xenomes
This appears to be a default automated message. However, Tuya has a history of changing their terms. My account dates back to 2021 and is on a legacy plan with unlimited API calls that doesn't expire. Newer accounts, on the other hand, are now limited to 26,000 calls per month and have a six-month expiration period.EskildP wrote: Thursday 14 May 2026 8:45 Got this mail from Tuya:
Any hints?
See link for extension:
https://github.com/Xenomes/Domoticz-Tin ... on-expired
Tinytuya
Tinytuya
EskildP
Xenomes, thanks for answering
My account is from february this year, and was renewed after 1 month for 6 new months, so it will expire on september 17th. So the blocking must be caused by the amount of calls. But how can I have used that much? The polling interval is set to 15 minutes, and there is no automation in domoticz that I can see resulting in that amount of calls.
I got the metioned warning on april30th, and my devices has been working until may 11th. Will it possibly be working again when a new month starts, after may 17th?
- Xenomes
The plug-in is designed for Tuya WiFi devices and uses a pull system to update the status in Domoticz.
This means that the number of API calls to Tuya depends on the number of devices and the polling interval.
With a limit of 26,000 Tuya calls per month, you can calculate the polling interval as follows:
Example for 2 devices:
26,000 calls ÷ 2 devices ÷ 31 days ÷ 24 hours ≈ 17.47 calls per hour
60 minutes ÷ 17.47 ≈ 3.43 minutes per call → set the interval to once every 4 or 5 minutes.
Adjust the "API Polling interval" according to the total number of devices in your setup.
Tinytuya
Tinytuya
EskildP
OK, I have 4 devices and 15 minutes interval, which is less than 12000 calls per month ...Xenomes wrote: Thursday 14 May 2026 11:45 The plug-in is designed for Tuya WiFi devices and uses a pull system to update the status in Domoticz.
- Xenomes
That should be good, unless the TinyTuya module uses more calls for other devices. I have only an RGBWW light, all other devices are created from setup data from other users, so I cannot verify the actual call usage. You can check your call usage on your Tuya account. I am currently developing a hybrid version of the plugin that first attempts to connect to the device locally and only switches to the cloud if needed, which will significantly reduce the number of calls used.EskildP wrote: Thursday 14 May 2026 11:59 OK, I have 4 devices and 15 minutes interval, which is less than 12000 calls per month ...
https://github.com/Xenomes/Domoticz-Tin ... ree/Hybrid
Tinytuya
Tinytuya
EskildP
Checked again today, and now it works OK.EskildP wrote: Thursday 14 May 2026 11:59OK, I have 4 devices and 15 minutes interval, which is less than 12000 calls per month ...Xenomes wrote: Thursday 14 May 2026 11:45 The plug-in is designed for Tuya WiFi devices and uses a pull system to update the status in Domoticz.
And I think I know the reason for this trouble, as there are two servers, one at home and one remote. Both servers have the same devices, 5 (not 4) at each server (4 at remote site, 1 at home)
EskildP
Installed this plugin with Domoticz Docker on Raspberry Pi OS "Trixie" 32 bit lite. Had to include
in customstart.sh, just as specified for "Bookworm".
apt install libffi-dev build-essential pkg-config libssl-dev -y-
EskildP
Struggling with version 3.2.1 on domotics 2026.4
My customstart.sh is as follows
TuyaCloud seems to start OK
But then this happens
The devices can still be turned on/off
if [ -f /opt/domoticz/FIRSTRUN ]; then
true
echo '********************* updating packages'
apt-get -qq update
echo '********************* install tinytuya Trixie'
# pip3 install tinytuya PyCryptodome==3.21.0 chardet==3.0.4 requests==2.23.0 charset-normalizer==3.0.1 --break-system-packages
pip3 install tinytuya cryptography>=3.1 pycryptodomex -U
echo 'creating FIRSTRUN file so script can check on next run'
touch /opt/domoticz/FIRSTRUN
cd /opt/domoticz || return
fi
2026-10-05 09:55:48.996 Status: RxQueue: queue worker started...
2026-10-05 09:55:50.999 Status: TuyaCloud: Started.
2026-10-05 09:55:50.999 Status: TuyaCloud: Entering work loop.
2026-10-05 09:55:51.000 Status: NotificationSystem: thread started...
2026-10-05 09:55:51.002 Status: EventSystem: reset all events...
2026-10-05 09:55:51.004 Status: Mqtt hytta : Connecting to 10.26.42.10:1883
2026-10-05 09:55:51.007 Status: Mqtt hytta : Connected to: 10.26.42.10:1883
2026-10-05 09:55:51.008 Status: EventSystem: reset all device statuses...
2026-10-05 09:55:51.281 Status: PluginSystem: 1 plugins started.
2026-10-05 09:55:51.594 Status: Python EventSystem: Initializing event module.
2026-10-05 09:55:51.595 Status: Python EventSystem: Initializing event module.
2026-10-05 09:55:51.597 Status: EventSystem: Started
2026-10-05 09:55:51.599 Status: EventSystem: Queue thread started...
2026-10-05 09:55:53.246 Status: TuyaCloud: Initialized version 3.2.1, author 'Xenomes'
2026-10-05 09:55:53.264 TuyaCloud: [event=startup] Domoticz version: 2026.4
2026-10-05 09:55:53.264 TuyaCloud: [event=startup] TinyTUYA 3.2.1 plugin started
2026-10-05 09:55:53.265 TuyaCloud: [event=startup] TinyTuya Version: 1.20.0
2026-10-05 09:55:53.267 TuyaCloud: [event=cloud-usage] Tuya cloud usage (restored after start) - API calls: today 0, this week 0, this month 0 | Pulsar message s: today 0, this week 0, this month 0
2026-10-05 09:55:53.268 TuyaCloud: [event=startup] Initializing Tuya plugin
2026-10-05 09:55:53.269 TuyaCloud: [event=cloud-init] Cloud mode: fetching device data from Tuya cloud
2026-10-05 09:55:55.334 TuyaCloud: [event=cloud-init] Successfully fetched 5 device(s) from Tuya cloud
2026-10-05 09:55:55.335 TuyaCloud: [event=cloud-init] - Device: SH-P01 T04 (ID: xxxxxx6463baa92eaepayf)
2026-10-05 09:55:55.335 TuyaCloud: [event=cloud-init] - Device: SH-P01 T03 (ID: xxxxxx22f7a03b39febdn0)
2026-10-05 09:55:55.336 TuyaCloud: [event=cloud-init] - Device: SH-P01 T01 (ID: xxxxxxf7fe35ab6435ypb2)
2026-10-05 09:55:55.337 TuyaCloud: [event=cloud-init] - Device: SH-P01 T05 (ID: xxxxxxcfecbea917clrdb)
2026-10-05 09:55:55.338 TuyaCloud: [event=cloud-init] - Device: SH-P01 T02 (ID: xxxxxx57ef13e8851cylqi)
2026-10-05 09:56:22.205 Error: TuyaCloud: Call to function 'onStart' failed, exception details:
2026-10-05 09:56:23.812 Error: TuyaCloud: Traceback (most recent call last):
2026-10-05 09:56:23.813 Error: TuyaCloud: File "/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 3536, in onHandleThread
2026-10-05 09:56:23.813 Error: TuyaCloud: _log_local_scan_results(localtuya, devs, 'Initial Tuya IP scan', elapsed=time.time() - scan_start)
2026-10-05 09:56:23.813 Error: TuyaCloud: ~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-10-05 09:56:23.814 Error: TuyaCloud: File "/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 3288, in _log_local_scan_results
2026-10-05 09:56:23.814 Error: TuyaCloud: Error(event="ip-scan", message=f"{label}: zero devices found on the local network at all. If this keeps happening for every scan, it usually points to a network-level problem rather than devices being offline: UDP ports 6666/6667/6668 blocked by a firewall on this host, Domoticz running in a Docker/VM network namespace that does not receive broadcast traffic, or this host being on a different subnet/VLAN than the Tuya devices.")
2026-10-05 09:56:23.814 Error: TuyaCloud: ~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-10-05 09:56:23.815 Error: TuyaCloud: TypeError: 'NoneType' object is not callable
2026-10-05 09:56:23.815 Error: TuyaCloud: During handling of the above exception, another exception occurred:
2026-10-05 09:56:23.816 Error: TuyaCloud: Traceback (most recent call last):
2026-10-05 09:56:23.816 Error: TuyaCloud: File "/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 3539, in onHandleThread
2026-10-05 09:56:23.816 Error: TuyaCloud: _log_local_scan_results(localtuya, devs, 'Initial Tuya IP scan', elapsed=time.time() - scan_start, scan_error=e)
2026-10-05 09:56:23.816 Error: TuyaCloud: ~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-10-05 09:56:23.817 Error: TuyaCloud: File "/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 3218, in _log_local_scan_results
2026-10-05 09:56:23.817 Error: TuyaCloud: Error(event="ip-scan", message=f"{label} failed{duration_str}: [{err_type}] {err_text}")
2026-10-05 09:56:23.817 Error: TuyaCloud: ~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-10-05 09:56:23.817 Error: TuyaCloud: TypeError: 'NoneType' object is not callable
2026-10-05 09:56:23.818 Error: TuyaCloud:
2026-10-05 09:56:23.818 Error: TuyaCloud: During handling of the above exception, another exception occurred:
2026-10-05 09:56:23.819 Error: TuyaCloud: Traceback (most recent call last):
2026-10-05 09:56:23.819 Error: TuyaCloud: File "/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 3159, in onStart
2026-10-05 09:56:23.820 Error: TuyaCloud: _plugin.onStart()
2026-10-05 09:56:23.820 Error: TuyaCloud: ~~~~~~~~~~~~~~~^^
2026-10-05 09:56:23.820 Error: TuyaCloud: File "/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 1976, in onStart
2026-10-05 09:56:23.820 Error: TuyaCloud: onHandleThread(True, False)
2026-10-05 09:56:23.821 Error: TuyaCloud: ~~~~~~~~~~~~~~^^^^^^^^^^^^^
2026-10-05 09:56:23.821 Error: TuyaCloud: File "/opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 6591, in onHandleThread
2026-10-05 09:56:23.821 Error: TuyaCloud: Error(event='error', message=str(e))
2026-10-05 09:56:23.822 Error: TuyaCloud: ~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-10-05 09:56:23.822 Error: TuyaCloud: TypeError: 'NoneType' object is not callable
- Xenomes
Hi EskildP,EskildP wrote:Re: Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
Post by EskildP » Today, 11:10
The TypeError: 'NoneType' object is not callable error you're seeing is a bug in version 3.2.1. It's caused by a name collision in the plugin code, where the Error() log function was accidentally overwritten by a variable with the same name. This has been fixed in the latest version of the plugin.
To resolve it, pull the latest changes from the repository:
cd /opt/domoticz/userdata/plugins/Domoticz-TinyTUYA-Plugin
git pull
As for the IP scan finding 0 devices, that's expected behaviour when Domoticz runs in Docker without host networking. UDP broadcast packets (used by the Tuya devices to announce themselves on the LAN) don't reach the container when it's on a bridge network.
The fix is documented in the Docker installation instructions. In short: run the Domoticz container with --network host (or network_mode: "host" in docker-compose). This lets the plugin see the broadcast traffic and discover your devices locally.
The relevant section is here:
https://github.com/Xenomes/Domoticz-TinyTUYA-Plugin#installation-domoticz-docker
Once the container uses host networking, the initial IP scan should find your devices and local control will start working. Until then, the plugin will keep falling back to the cloud, which is why your devices still respond to on/off commands.
Hope that helps.
Tinytuya
Tinytuya
EskildP
Thanks for 3.2.2
After upgrading I also mowed devices to the same subnet as domoticz, and got no errors on startup.
But when trying to operate a switch in domoticz nothing happens, only this error in the log
2026-10-05 23:12:46.550 Status: User: admin (IP: 10.26.42.202) initiated a switch command (37/Ovn sov3 (T04)/On)
2026-10-05 23:12:46.562 Error: TuyaCloud: [device=xxxxxx6463baa92eaepayf name="Ovn sov3 (T04)" ip=10.26.42.188 event=command] onCommand ERROR: name 'Tuyaerror' is not defined
