Page 18 of 28
Re: Dashticz - Bug report
Posted: Monday 08 January 2018 19:25
by aiolos
geertvercamer wrote: Monday 08 January 2018 13:57
I have the same problem with the blinds switches not working (anymore).
The problem is in switches.js, function switchBlinds()
.block should be .block_
function switchBlinds(idx, action) {
switch (action.toLowerCase()) {
case 'off':
$('.block_' + idx).find('.icon').removeClass('on').addClass('off');
$('.block_' + idx).find('.icon').attr('src', $('.block_' + idx).find('.icon').attr('src').replace('open', 'closed'));
break;
case 'on':
$('.block_' + idx).find('.icon').removeClass('off').addClass('on');
$('.block_' + idx).find('.icon').attr('src', $('.block_' + idx).find('.icon').attr('src').replace('closed', 'open'));
break;
if (typeof(req) !== 'undefined') req.abort();
$.ajax({
url: settings['domoticz_ip'] + '/json.htm?type=command¶m=switchlight&idx=' + idx + '&switchcmd=' + action + '&level=0&passcode=&jsoncallback=?',
type: 'GET', async: false, contentType: 'application/json', dataType: 'jsonp',
success: function (data) {
getDevices(true);
That was indeed the function that had the bug. A fix for it was already merged today, so if you get the latest beta, it should work again.
I just saw there is another _ missing, but that it only a layout fix I think. I will create a PR for that.
Posted: Monday 08 January 2018 19:35
by barbaar
My blinds are still being displayed as on/off switches. I have 2 "blinds inverted percentage". Just did a git pull, but no change for me
Posted: Monday 08 January 2018 19:46
by aiolos
barbaar wrote: Monday 08 January 2018 19:35
You are right, that one is showing up as switch. I will see why that happens.
Edit:
The order of words was wrong, see this
PR
Posted: Monday 08 January 2018 20:42
by barbaar
aiolos wrote: Monday 08 January 2018 19:46
Edit:
PR
Works, thanks!
Posted: Monday 08 January 2018 21:45
by robgeerts
rldn wrote: Thursday 04 January 2018 12:35
robgeerts wrote: Wednesday 03 January 2018 21:42
I think graphs ont work with all types of sensors yet.
Whats the output of these devices from Domoticz?
Find it here:
http://YOURIP_AND_PORT/json.htm?type=devices
- Spoiler: show
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Humidity 64 %",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 7,
"HardwareName" : "Xiaomi Gateway",
"HardwareType" : "Xiaomi Gateway",
"HardwareTypeVal" : 95,
"HaveTimeout" : false,
"Humidity" : 64,
"HumidityStatus" : "Wet",
"ID" : "2AFE",
"LastUpdate" : "2018-01-04 12:29:42",
"Name" : "Badkamer Vochtigheid",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "LaCrosse TX3",
"Timers" : "false",
"Type" : "Humidity",
"TypeImg" : "temperature",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "51"
For example
I just changed something.
Could you test latest beta???
renerene wrote: Friday 05 January 2018 20:11
Is it because a login for Domoticz is required?
This does not work also:
In de CONFIG.js kunnen je logingegevens staan als je gebruik maakt van "http://username:[email protected]"
I think so, entering username and password in the url is not supported anymore in newer version of some browsers.
You can switch to another login-method in Domoticz-settings, although, then you have to enter login at every load of Dashticz..
case 'off':
break;
case 'on':
break;
$.ajax({
getDevices(true);
Could you try latest beta?
Posted: Tuesday 09 January 2018 18:27
by rldn
robgeerts wrote: Monday 08 January 2018 21:45
Find it here:
- Spoiler: show
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Description" : "",
"Favorite" : 1,
"HardwareID" : 7,
"Humidity" : 64,
"ID" : "2AFE",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "51"
For example
case 'off':
break;
case 'on':
break;
$.ajax({
getDevices(true);
Thanks but can you tell me how i can update the system or get the latest beta without losing config?
Posted: Wednesday 10 January 2018 16:11
by Moosjes
I do have a few 'rolluiken' with a fibaro shutter unit. These blinds have a percentage bar in domoticz but in dashticz they show with an up/down/stop button. This does not seem to work (the stop does not stop it). Is there a way to give it a percentage bar in dashticz? Like dimmer lighting?
Posted: Wednesday 10 January 2018 17:36
by htilburgs
I don't know if it's a bug, but I've the next issue:
- Create a DummySwitch - Type On/Off Switch
- I can switch it from Dashticz
- Change Switch Icon from "Light/Switch (BULB)" to "Alarm"
- It cannot be longer switched from Dashticz (like protected = true)
Posted: Wednesday 10 January 2018 18:50
by aiolos
Moosjes wrote: Wednesday 10 January 2018 16:11
Thanks for your message. Can you tell me what the relevant part of http://{domoticzIP}:8080/json.htm?type=devices for the blinds looks like? There should be a percentage bar if the blinds have that option.
I also see that the stop action does not work, but in Domoticz itself the stop button also does not work (and only shows up for 'Venetian blinds')
Posted: Wednesday 10 January 2018 18:59
by aiolos
htilburgs wrote: Wednesday 10 January 2018 17:36
I cannot reproduce this issue (the switch is only disable if I set it to protected in domoticz).
Posted: Friday 12 January 2018 20:33
by htilburgs
aiolos wrote: Wednesday 10 January 2018 18:59
Strange thing. I can select everything it still works as an on/off switch in Dashticz. Only when I select the Alarm icon, the on/off function in Dashticz is gone.
Icon type "Alarm"
- Schermafbeelding 2018-01-12 om 20.20.07.png (44.42 KiB) Viewed 8711 times
Icon type "Switch or other than Alarm"
- Schermafbeelding 2018-01-12 om 20.19.38.png (45.42 KiB) Viewed 8711 times
Posted: Saturday 13 January 2018 1:23
by plantex
Hello.
Great Job - Thanks for Dashticz.
Bug fix request:
Blinds Percentage - common problem in current Domoticz release.
Created in default dashboard Blind percentage (via My sensors USB Gateway) slide doesnt work (not possible to move it) open / close are ok
The Light (used for the same node) - slide works ok I can set e.g.25% of blind level, but unfortunately buttons are not sending the proper msg (as blinds).
So the perfect combination would be to combine both widgets
- bl.jpg (44.37 KiB) Viewed 8702 times
When both widgets are transferred to Dashticz:
- a.jpg (16.76 KiB) Viewed 8702 times
It appears to be the same like on the pervious screen but not exactly:
Blinds: Up/Down buttons work ok , Stop (wasnt on default Domoticz dashboard) here appears and works ok. Slide(cannot move it to e.g.34% but as you press the buttons open/close it jumps from 0 to 100%)
Light (as described above) - no change
I'am not a coder hence my question: Is Dashticz just a layer or there is possibility of separate communication with e.g arduino node.
Just asking because - many people is waiting for Domoticz to be fixed with blinds percentage - Maybe Dashticz is our hope ....
Plantex
Posted: Saturday 13 January 2018 17:17
by aiolos
htilburgs wrote: Friday 12 January 2018 20:33
Icon type "Alarm"
Do you have any custom javascript that can remove something? What if you have an almost empty CONFIG.js (only the bare minimum) and not custom css or js. (On my local machine I only see this behaviour if I make the switch protected)
Posted: Saturday 13 January 2018 17:23
by aiolos
plantex wrote: Saturday 13 January 2018 1:23
Hello.
Bug fix request:
Plantex
In fact Dashticz is just another layer as dashboard against domoticz backend. There are some extra things like the garbage, news and music player modules.
It is interesting to see what is exactly wrong with the blinds. Recently some small changes have been made because of some errors in displaying the blinds and I noticed that the whole stop command on domoticz is also not doing anything (the response of the API is an error), so I'm also wondering what kind of blinds you have where this works (so I can try that on my local machine too).
If there is something wrong in the domoticz backend, then dashticz cannot change that.
I will have a look at the percentage behaviour, but I don't have any blinds myself, so it is playing around with dummy switches.
Posted: Friday 26 January 2018 13:56
by htilburgs
Since the latest beta, my Neo Coolcam Door/Window Sensor don't work anymore in Dashticz. Something changed??
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Closed",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 2,
"HardwareName" : "Aeon Labs Z-Stick GEN5",
"HardwareTypeVal" : 21,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"ID" : "00002200",
"Image" : "Light",
"InternalState" : "Closed",
"IsSubDevice" : false,
"LastUpdate" : "2018-01-26 13:50:04",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 100,
"Name" : "Sensor Voordeur",
"PlanID" : "6",
"PlanIDs" : [ 6 ],
"Status" : "Closed",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "Door Contact",
"SwitchTypeVal" : 11,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "door contact",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "748",
"YOffset" : "125",
"idx" : "553"
Posted: Monday 29 January 2018 21:56
by htilburgs
htilburgs wrote: Friday 26 January 2018 13:56
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Closed",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 2,
"ID" : "00002200",
"Image" : "Light",
"Level" : 0,
"LevelInt" : 0,
"PlanID" : "6",
"PlanIDs" : [ 6 ],
"StrParam1" : "",
"StrParam2" : "",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "748",
"YOffset" : "125",
"idx" : "553"
Ok, I narrowed it down. When I use the [speakOn] options, the block is not functioning anymore. Can it be the same issue I had before, because I use IE11 on my Surface?
(I’m not able to use any other browser on that device)
Posted: Friday 02 February 2018 9:51
by gerardosamara
Hi ,
Dashticz Beta
The language options is present in custom_v2/CONFIG.DEFAULT.js but not in custom/CONFIG.DEFAULT.js
Posted: Friday 02 February 2018 12:09
by DewGew
gerardosamara wrote: Friday 02 February 2018 9:51
Hi ,
Dashticz Beta
Follow the wiki at
http://www.domoticz.com/wiki/Dashticz_V2
Posted: Friday 02 February 2018 14:44
by htilburgs
htilburgs wrote: Monday 29 January 2018 21:56
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Closed",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 2,
"ID" : "00002200",
"Image" : "Light",
"Level" : 0,
"LevelInt" : 0,
"PlanID" : "6",
"PlanIDs" : [ 6 ],
"StrParam1" : "",
"StrParam2" : "",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "748",
"YOffset" : "125",
"idx" : "553"
Nobody?
Posted: Monday 05 February 2018 12:23
by clubeddie
HarryHase wrote: Saturday 23 September 2017 18:42
webrazor wrote: Tuesday 18 July 2017 16:55
I'm using a P1 cable to monitor my smart meter but because i also have solar panels the energy usage is most of the time a minus number in domoticz dashboard it will show a negative value but in dashticz its always a positive number.
I have the same problem, is there a solution available?
Do you have solved the problem?
