Dashticz - Feature Requests
Lokonli
Re: Dashticz - Feature Requests
Post by Lokonli »
stlaha2007 wrote: Monday 08 April 2019 13:02 Hi devs...
Recently replaced my bmp280 with an bmp180. Unfortunately discovered the new device wasn't diplaying correctly (Turned Up as a Switch :lol: ).
However looked into the code of the master and beta branch and dicovered only devices are displayed correctly when they are temp / hum / baro(pressure) or temp + hum or temp + hum + baro.
So the device temp + baro is missing.
I updated my running Beta-branch here
In js/main.js:
Just below function getAutoAppendSelector(device) {
around line 1314:
         case 'Temp + Baro':
And below switch (device['Type']) {
around line 1407:
        case 'Temp + Baro':
I updated my running master-branch here
In js/main.js:
around line 1248:
         case 'Temp + Baro':
around line 1340:
        case 'Temp + Baro':
And now working as expected for me...
Can this be integrated in the near future ??
Thanks for the proposed changes. They will be merged in the next beta.
bhennink
Domoticz version: 4.10717
Post by bhennink »
I am using at this moment 10 timers which sometime both triggen devicen in different groups and I find I lose overview clicking each time on by one
I would like a timer screen where you can have all active timers listed row by row (or column)
Lokonli
Post by Lokonli »
bhennink wrote: Wednesday 12 June 2019 20:19 I am using at this moment 10 timers which sometime both triggen devicen in different groups and I find I lose overview clicking each time on by one
I don't think I understand your question.
You can create a second Dashticz screen, and add all your timers to that screen. Is that what you're looking for?
bhennink
Post by bhennink »
Yes something like that. I like the concept for a better WAF,:)
Lokonli
Post by Lokonli »
bhennink wrote: Thursday 13 June 2019 13:26 Yes something like that. I like the concept for a better WAF,:)
You can create several screens in CONFIG.js, like:
//Definition of columns
columns = {}
columns[1] = {
  blocks: [
    calendars.test,
    'garbage',
    'streamplayer',
    buttons.nunl,
    buttons.nos,
     120, 121, buttons.slide2, buttons.floorplan
  width: 4
columns[2] = {
  blocks : [buttons.moon,buttons.test, 120, 121, publictransport.ovinfo],
  width: 8
columns[3] = {
  blocks: ['sunrise','clock','traffic', 'train'],
  width: 2
columns[4] = {
  blocks: [
    'currentweather_big_owm', 'weather_owm'
  width: 10
blocks['news_sport'] = {
    feed: 'http://www.nu.nl/rss/sport'
columns[5] = {
  blocks: [
    690,
    56,
    545,
    'news_sport'],
  width: 4
//Definition of screens
screens = {}
screens[1] = {
  columns: [1, 2]
screens[2] = {
  columns: [3,4]
screens[3] = {
  columns: [5]
Of course you have to add the right devices to the columns you want to.
HansieNL
Post by HansieNL »
Is it possible to have an icon/image in front of the Streamplayer. I would love to have it a look like this... Maybe is possible to make it optional.
Blah blah blah
marmachine
Domoticz version: 3.4834
Post by marmachine »
Is it possible to use icons
icon: 'fas fa-calendar'
in blocks, type: blocktitle?
The following does not show:
blocks['block_calendar'] = {
  type: 'blocktitle',
  icon: 'fas fa-calendar',
  title: 'calendar'
Lokonli
Post by Lokonli »
marmachine wrote: Wednesday 07 August 2019 10:21 Is it possible to use icons
  type: 'blocktitle',
  title: 'calendar'
Currently it's not supported.
I'll add it to the feature enhancement list.
marmachine
In the Garbage block, today (wednesday) is Grey-day.
This means that next week is (GFT) Green-day.
On the second row of the calendar the GFT is mentioned for "wednesday".
I think it would be better to add the date when the date is >= 7 days ahead from today, i think currenty this >7 days ahead from today
However, this is just a minor detail, it's functionality works fine! Thanks!
Lokonli
Post by Lokonli »
  type: 'blocktitle',
  title: 'calendar'
Added to latest beta. Can you test?
pvklink
Domoticz version: latest b
Post by pvklink »
Can you add city_id to OWM
There are 2 Rijswijk in Holland.
The config setting only offers city name.
I think city ID is in my case a better option, because i get the wrong Rijswijk and cant adjust it...
see the city list on the website of own
https://home.openweathermap.org
Jablotron connection, Ikea
pvklink
display no on/off but only update_date
Post by pvklink »
I have a switch (regen) that turns on blue when it is (going) to rain. I use this switch for my irrigationsystem
The switch displays:
the name: regen
date: last updated
status: On/OFF
Is it possible to show the name, update_date but NOT the ON/OFF --> i can see that by the color blue that appears when it is on.
With the current block properties this combination is not possible...
when i set hide_data to true, the update_date also disappered, this date is important
HansieNL
Re: display no on/off but only update_date
Post by HansieNL »
pvklink wrote: Thursday 22 August 2019 12:09 Hi,
the name: regen
date: last updated
status: On/OFF
Can you try :
blocks[IDX] = {
    title: 'regen',
	textOff: '',
	textOn: ''
Blah blah blah
Lokonli
Post by Lokonli »
the name: regen
date: last updated
status: On/OFF
I think you can set the textOn and textOff parameters to empty strings:
blocks[123] = {
   textOn: "",
   textOff: ""
pvklink
Post by pvklink »
tried this in css and that did not work
.blocks_1423 {textOn: "", textOff: ""}
and
blocks[1423] = { textOn: "", textOff: ""}
HansieNL
Post by HansieNL »
pvklink wrote: Thursday 22 August 2019 12:54 tried this in css and that did not work
You have to use this in CONFIG.js
Blah blah blah
HansieNL
Post by HansieNL »
pvklink wrote: Wednesday 21 August 2019 18:56 Can you add city_id to OWM
Bug reported: https://github.com/Dashticz/dashticz/issues/35
Blah blah blah
pvklink
Post by pvklink »
ok, when i add that line, dashticz wont start...
Must it be added in a particular place?
blocks[1423] = {}
blocks[1423]['title'] = 'Sensor';
blocks[1423]['icon'] = 'fas fa-cloud-showers-heavy';
blocks[1423]['hide_data'] = false;
blocks[1423]['width'] = 4;
blocks[1423]['speakOn'] = 'Regensensor aan';
blocks[1423]['speakOff'] = 'Regensensor uit';
blocks[1423]['switch'] = false;
blocks[1423]['last_update'] = true;
//blocks[1423]['testOn'] = '';
//blocks[1423]['testOff'] = '';
HansieNL
Post by HansieNL »
pvklink wrote: Thursday 22 August 2019 13:03 ok, when i add that line, dashticz wont start...
blocks[1423] = {}
You forget to remove the dot in front of .blocks_1423 {textOn: "", textOff: ""}
Blah blah blah
pvklink
Post by pvklink »
domoticz hangs.. keeps loading
blocks[1423] = {}
Locked
