Page 18 of 20
Re: Buienradar Weather Lookup Plugin
Posted: Friday 05 April 2019 20:44
by DosN
Did git pull . files where updated to latest version
Now i have no logging at domoticz . only that it is started ., then system hanging
Posted: Saturday 06 April 2019 15:10
by gerbenvanasselt
Same for me, the last update gives no error in the domo-log but system (pi) is not accessible any more after a while and need a hard reboot.
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Posted: Saturday 06 April 2019 19:27
by Ewaldharmsen
gerbenvanasselt wrote: Saturday 06 April 2019 15:10
What versions are you on?
I am on Domoticz 4.10548 and python 3.5.3 and here everything works perfectly
Posted: Saturday 06 April 2019 19:31
by gerbenvanasselt
gerbenvanasselt wrote:After updating the plugin i have the following error.
Running domo beta v.10572 with python version 3.5.3 rpi 3b.
Befere the update it worked well.
First did a git pull and the following error occured. Then I deleted the plugin from hardware tab and remove the plugin from the domo plugin folder. After that i did a git clone and installed the hardware again. But the same error occured.
2019-04-05 13:37:10.872 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload:/usr/local/lib/python3.5/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.5/dist-packages'.
2019-04-05 13:37:10.872 Error: (Buienradar) Module Import failed, exception: 'ImportError'
2019-04-05 13:37:10.872 Error: (Buienradar) Error Line details not available.
See above for version.
Posted: Saturday 06 April 2019 20:02
by flyboarder
Ewaldharmsen wrote: Thursday 04 April 2019 21:09
flyboarder wrote: Thursday 04 April 2019 20:38
I installed the plug-in following the steps on the git page. But after I add Buienrader on the hardware page I see the following error in the log:
2019-04-03 23:14:03.318 Error: (Buienradar) 'onStart' failed 'TypeError':'__init__() takes from 1 to 4 positional arguments but 5 were given'.
2019-04-03 23:14:03.318 Error: (Buienradar) ----> Line 152 in /home/pi/domoticz/plugins/domoticz-buienradar/plugin.py, function onStart
2019-04-03 23:14:03.318 Error: (Buienradar) ----> Line 120 in /home/pi/domoticz/plugins/domoticz-buienradar/plugin.py, function onStart
Does anyone has a clue what is going wrong here?
can you update the plugin with git pull and try again?
Thanks, that has solved the issue.
Posted: Sunday 07 April 2019 13:36
by DosN
i run Domoticz v4.10602
Posted: Tuesday 09 April 2019 14:47
by gerbenvanasselt
After I have updated Domoticz to v4.10602. the problem with stalling seems to be solved. My pi 3b+ is running for a few days now without any problems.
Posted: Tuesday 09 April 2019 14:58
by Ewaldharmsen
Good to hear
Posted: Sunday 14 April 2019 21:13
by htca
Hi I started from scratch last weekend. I got the following error in my log:
2019-04-14 20:53:55.457 Status: (Buienradar) Started.
2019-04-14 20:53:56.362 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2019-04-14 20:53:56.362 Error: (Buienradar) Module Import failed, exception: 'ImportError'
2019-04-14 20:53:56.363 Error: (Buienradar) Module Import failed: ' Name: requests'
2019-04-14 20:53:56.363 Error: (Buienradar) Error Line details not available.
2019-04-14 20:55:00.501 Error: Buienradar hardware (5) thread seems to have ended unexpectedly
plugin.py is in the path indicated:
pi@raspberrypi:~/domoticz/plugins $ pwd
pi@raspberrypi:~/domoticz/plugins $ cd domoticz-buienradar/
pi@raspberrypi:~/domoticz/plugins/domoticz-buienradar $ ls
buienradar-logo.zip buienradar.xml ChangeLog.md LICENSE.md localtest_rf.py __pycache__ raintext.txt
buienradar.py buienradar.zip fakeDomoticz.py localtest.py plugin.py rainforecast.py ReadMe.md
Domoticz Version: 4.9700
Buienradar Version: April 4
Python Version: 3.5.3
solved:
- changed to beta
- added executable permission to plugin.py
Posted: Monday 15 April 2019 15:39
by DosN
i also installed the plugin , but it is not working at all
the PI3B will crash .
at the logging in Domticz i see:
2019-04-01 18:39:25.780 Status: (Weersverwachting (Buienradar)) Started.
2019-04-01 18:40:38.962 Error: Weersverwachting (Buienradar) hardware (24) thread seems to have ended unexpectedly
2019-04-01 18:40:52.965 Error: Weersverwachting (Buienradar) hardware (24) thread seems to have ended unexpectedly
2019-04-01 18:41:06.968 Error: Motherboard sensors hardware (23) thread seems to have ended unexpectedly
2019-04-01 18:41:06.968 Error: Weersverwachting (Buienradar) hardware (24) thread seems to have ended unexpectedly
i already updated domoticz to the lates version, and updated buienradar plugin ,, nothing helped
Posted: Wednesday 24 April 2019 21:52
by cmartens75
After updating the Buienradar plugin, the following message is being displayed in the Domoticz log:
2019-04-24 21:48:13.331 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload:/usr/local/lib/python3.5/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.5/dist-packages'.
2019-04-24 21:48:13.331 Error: (Weer) Module Import failed, exception: 'ImportError'
2019-04-24 21:48:13.331 Error: (Weer) Module Import failed: ' Name: requests'
2019-04-24 21:48:13.331 Error: (Weer) Error Line details not available.
2019-04-24 21:49:18.584 Error: Weer hardware (11) thread seems to have ended unexpectedly
The buienradar plugin does not work anymore, also after a restart of the Raspberry. Does anybody know a solution for this issue?
Kind regards, Corne
Posted: Thursday 25 April 2019 8:05
by coen17st
I recently installed the rain radar plugin and so I don't know if it would have worked therefore.
I also get the following:
2019-04-25 07:52:11.288 Error: (Buienradar) failed to load 'plugin.py', Python Path used was 'C:\Program Files (x86)\Domoticz\plugins\buienradar\;C:\Program Files (x86)\Python35-32\python35.zip;C:\Program Files (x86)\Python35-32\Lib\;C:\Program Files (x86)\Python35-32\DLLs\;C:\Program Files (x86)\Domoticz'.
2019-04-25 07:52:11.288 Error: (Buienradar) Module Import failed, exception: 'ImportError'
2019-04-25 07:52:11.288 Error: (Buienradar) Module Import failed: ' Name: requests'
2019-04-25 07:52:11.289 Error: (Buienradar) Error Line details not available.
Hopefully someone has or knows a fix for this
Domoticz: V4.9700
Python: 3.5.3
OS: Windows Server 2016
Posted: Friday 03 May 2019 19:50
by Ewaldharmsen
coen17st wrote: Thursday 25 April 2019 8:05
Domoticz: V4.9700
Python: 3.5.3
you should install requests: sudo pip3 install requests
Posted: Saturday 04 May 2019 16:09
by buitje
Same issue here installed the pip requests however still the same result
2019-05-04 16:02:50.161 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2019-05-04 16:02:50.162 Error: (Buienradar) Module Import failed, exception: 'ImportError'
2019-05-04 16:02:50.162 Error: (Buienradar) Module Import failed: ' Name: requests'
2019-05-04 16:02:50.162 Error: (Buienradar) Error Line details not available.
Any other suggestions or ideas?
pip 3 list:
chardet (2.3.0)
requests (2.12.4)
SecretStorage (2.3.1)
Posted: Saturday 04 May 2019 16:46
by buitje
Got it to work again by updating the python path by adding the following lines in the beginning of the plugin.py before the import requests call is made
import sys
sys.path.append('/usr/lib/python3/dist-packages')
Posted: Saturday 04 May 2019 17:14
by Ragdag
Having the same error when installing from Github:
2019-05-04 17:11:53.173 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload:/usr/local/lib/python3.5/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.5/dist-packages'.
2019-05-04 17:11:53.173 Error: (BuienRadar) Module Import failed, exception: 'ImportError'
2019-05-04 17:11:53.174 Error: (BuienRadar) Module Import failed: ' Name: requests'
2019-05-04 17:11:53.174 Error: (BuienRadar) Error Line details not available.
Domoticz
Version: 4.10686
Build Hash: f7fc1571
Compile Date: 2019-05-04 13:17:04
dzVents Version: 2.4.18
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
Posted: Sunday 16 June 2019 13:19
by Roedii66
Ragdag wrote: Saturday 04 May 2019 17:14
Domoticz
Version: 4.10686
An additional install of:
sudo apt-get install python3-pip
helped me out of these errors.
Good luck.
Posted: Sunday 16 June 2019 22:36
by Derik
Roedii66 wrote: Sunday 16 June 2019 13:19
Domoticz
Version: 4.10686
Good luck.
mmm
This is not a apt-get install?
This give me a error:
pi@odroid:~$ sudo pip3 install requests
The directory '/home/pi/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/pi/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and own er of that directory. If executing pip with sudo, you may want sudo's -H flag.
Requirement already satisfied: requests in /usr/lib/python3/dist-packages
Posted: Tuesday 09 July 2019 13:31
by gerbenvanasselt
Hi there,
This week I tried installing the Buienradar plugin on a new sdcard with raspbian buster as OS. The domoticz runs with python v 3.7.3.
When I install the Buienradar plugin and add it in the hardware section. Domoticz stops working, even after a restart of Domo and and a reboot of my pi domoticz won't start. After deleting the plugin from the folder in domoticz it starting domoticz again. Could it be that the plugin is not suitable for python 3.7.3?
Are there other people who experience the same?
I hope there will be a solution, because I really enjoy my Buienradar plugin.
Thanks in advance!
Posted: Tuesday 09 July 2019 13:36
by darkrain
The plugin system seems to not work with buster and the python 3.7.3.
I ran into the same issue with another plugin and then decided to go back to stretch and python 3.5.3.
There is also an issue with https at the moment, please see:
https://www.domoticz.com/forum/viewtopi ... =6&t=28617 and some other topics.
